View Full Version : Manual Transmission
  1. Master cylinder cap??
  2. Bronze or nylon fork pads?
  3. Tranny is finally on the workbench & Partially tore down *picts*
  4. Clutches
  5. FLT or Tick?
  6. Monster Level 3 install/review
  7. Testing the Master Cylinder
  8. how to remove the clutch pedal by it self.
  9. ARP and Monster torque?
  10. Need help with Tick speed bleeder / bleeding clutch...
  11. odd noise
  12. Shift Knob Suggestions
  13. Correlation between Tick master adjustments and clutch slipping?
  14. t56 main shaft question
  15. need imput!!!
  16. tomorrow is the big day!!!
  17. stock t56 worth?
  18. Bang when coming off the clutch quick??
  19. Having the t56 rebuilt and have some questions.
  20. garage clutch swap
  21. Can 12" Clutch and PP be used on resurfaced stock 99 FW?
  22. Help with my problem
  23. How to service my 6 speed?
  24. Best Shifter?
  25. Quick question????
  26. T-56 AfterMarket Or Modded Slave Cylinder???
  27. Trans Issues
  28. T5 5th gear set interchangability?
  29. Yet another 4l60E to T56 thread!
  30. Just in: Tick/Monster. Can't get into gear at idle, but can while driving and off..
  31. M6 MSD 2step
  32. transmission vibes
  33. Flywheel differences?
  34. LS3 Flywheel Dowel?
  35. Textralia customer service sucks!
  36. New To Manual Transmissions
  37. Strange noise coming from a built T56
  38. Reverse not working
  39. Textrilla Torque Specs
  40. C5 Shifter Questions and Pic Request
  41. Heard from MGW??
  42. Anybody ever broke a stg. 2 built t56?
  43. wierd shifting problem
  44. Bleeding Clutch NOT working!
  45. Skip Shift Solenoid ?
  46. RIddle me This
  47. Short throw installation
  48. Hurst shift stick - will it fit?
  49. Clutch suggestion
  50. Where to buy a Quicktime bellhousing
  51. clutch swap parts ?'s
  52. Clutch problems. Pls help!!
  53. need bleeding help, no peddle
  54. Best place for buying LS7 clutch kit w/ flywheel
  55. What is this hole in my tranny?
  56. Clutch problems.?
  57. Which flywheel?? Help!
  58. Little shifting problem
  59. Need rebuild kit info
  60. Atlanta area machine work
  61. clutch steel braided hydralic line
  62. 97 t56 behind lq9
  63. soft monster...
  64. T-56 upgrades?
  65. Another "Clutch Won't Disengage" Thread
  66. Torque cut module for face plated and dog engagement gear sets
  67. T56 rebuild kits?
  68. mid plate torque spec
  69. Bleeding the clutch
  70. MGW Shifter, adjustable handle height?
  71. ?
  72. Need help with tranny install
  73. Please i want the bolts torque specs for McLeod Clutch ASAP necessary
  74. Lsx and Viper t56
  75. 2001 Z28 Camaro Clutch problems! This girl is clueless!
  76. Quick question
  77. Noise, vibrations and other fun issues. FIXED
  78. Clutch Master cylinder options
  79. t56, lost 2nd, 3rd/4th and 6th
  80. What clutch???
  81. new flywheel?
  82. What clutch for me?
  83. Tranny Predicament
  84. clutch not fully engaging..help
  85. Ram Hydraulic Slave or Stock Upgraded
  86. stock ac delco clutch kit
  87. Two Thumbs up for Tick Performance!
  88. Guys who have the Ram 10.5 twin disc setup installed look here
  89. clutch break in time
  90. Fluid amount
  91. New Spec 4 clutch won't work
  92. whats it worth...
  93. McLeod MC adjustment ?
  94. Changing tranny fluid
  95. Just installed clutch and Tick master......
  96. what could it b
  97. Another super newb question. Be nice!
  98. Need a Clutch 2002 Trans Am
  99. Tick speed bleeder install
  100. Looking for trans upgrade
  101. Need advice!
  102. 99 TA Cutch sinking to floor and tough time shifting.
  103. am i tripping?
  104. hard clunk into reverse?
  105. Parts on clutch install?
  106. Trans fluid change question.
  107. mixing syn. 75w140 gear lube and dex merc.?
  108. Twin turbo car--lightweight flywheel or not??
  109. Can't get into 1st or reverse??
  110. Touch of griding into 1,2 gears...advice?
  111. Quick question????
  112. no reverse
  113. Aluminum vs. Steel
  114. Clutch Bad? No reverse!
  115. Hurst Shifter
  116. MGW shifter question
  117. T56 spacer and thrust washer questions - Overhaul
  118. Tr-6060 ?
  119. Clean and lube stock Hurst shifter? Not satisfied with Pro 5.0
  120. What fluid are you running in your T-56 ?
  121. Sealant for ARP Flywheel bolts ?
  122. T56 Issue? Please watch video
  123. t56 overhaul problem
  124. 4th gear downshift
  125. RPM Transmissions are 10% for a limited time!
  126. Loose Shifter
  127. How to bleed clutch fluid?
  128. Who has M12 gearing in a F-body?
  129. Centerforce Clutch Problems Need Help
  130. Vibration, becomes worse as speed increases
  131. Out of all the gears...
  132. My 3-4 shift fork
  133. Can you buy ONLY a LS7 pressure plate?
  134. Slave cylinder location PLEASE ADVISE
  135. Need Help ASAP with master clyinder/slave cylinder
  136. Convert flange output to yoke T56?????
  137. Bleeding issue
  138. McLeod RST with spec billet flywheel
  139. T56 Experts NEED HELP F Body / Corvette Hybrid
  140. B&M ripper
  141. monster clutch!!!
  142. car wont go in gear
  143. T56 Whine
  144. Money and parts thrown away. Need help please!!!
  145. GM 5 Speed manual
  146. Pulling 5th synchro in car
  147. LT1 T56, Clutch fork hits pressure plate
  148. Slipping in first?
  149. MGW email?
  150. short throw shifter
  151. water in t56-how much damage
  152. Built t56 slight vibration in 3rd gear
  153. Tick clutch master cylinder problems
  154. Looking for new clutch
  155. fresh trans rebuild, downshift grinding 2nd intermittently.
  156. how much power ls7 clutch?
  157. squeaking while shifting
  158. Need some help won't go into any gear t56 00z28
  159. LS2 to son of tranzilla clutch question
  160. trans conversion
  161. Diamond Stage 1 & dowel pin question
  162. 4l60e to t56 magnum
  163. Rebuilt clutch kits by Exedy
  164. Who has Textralia clutches in stock??
  165. vibration at a certain rpm
  166. grind second
  167. Junk Clutch & flywheel
  168. quicktime bellhousing and clutch shimming ?s
  169. clutch? for forced induction
  170. Twin disk clutch failure...whats your opinion? PICS!!! :)
  171. gear lash sound. Is it normal?
  172. changing fluid in the 6 speed...
  173. T56 snatchy notchy crap when driving gently.
  174. Is this a '04 GTO clutch, and will it work in 4th gen Z28?
  175. 3/4 shift fork
  176. Mcleod RST twin disc question
  177. Clutch and Flywheel
  178. Clutch gets soft/soggy
  179. Header swap help change clutch cyl?
  180. What will break first in my T56?
  181. Need help!
  182. Clutch Travel
  183. Pulled tranny, chipped case and oily bellhousing
  184. Trans tunnel acess pannel pic
  185. T56 gear whine in 5th and 6th
  186. Slipping up top
  187. looking for a t56 transmission
  188. manual t56 guys what rpms you shifting?
  189. LS7 Clutch/Adjustable Master Needed?
  190. Input shaft chewed up...
  191. Clutch issue
  192. Problem after Pro 5.0 install
  193. Fixing to need to disk?
  194. very hard to shift
  195. T56 problems
  196. tranny hitting floor?
  197. About to pull the trigger on a Monster stg2 and Tick master
  198. t56 issues
  199. weird issue with fresh rebuild
  200. Clutch and/or Trans problems? Grinding and stiff shifts...
  201. t-56/ clutch combo for LSX 440
  202. Shifter cup replacement?
  203. MN6 02 ws6 fluid change
  204. t-56
  205. Competition Clutches?
  206. CTS-V Hydraulic Line retaining clip
  207. where to find a spec clutch disk
  208. 6 speed trans problems
  209. HELP!! Need help getting a shifter!
  210. McLeod RXT vs. 0Z700 Textralia
  211. thinking about getting spec 3
  212. Grinded 2nd, no lift shifting!
  213. normal wear on 0z700?
  214. Lost 2nd but no grind
  215. Clutch question
  216. GTO T-56 Model #?
  217. lt1 clutch slipping help
  218. monster level 3
  219. T-56 grinds need some advice
  220. clutch pedal engagement question & BEWARE Monster clutches
  221. SPEC 3 slipping
  222. Are These Paper or Carbon Blockers??? (PICS)
  223. Throwout bearing. 02 Firebird fit 06 GTO?
  224. New Shifter on t-56
  225. manual transmission fluid..help
  226. Question about my t56
  227. o ring size help
  228. T56 measurement please
  229. Slipping or chatter - New to LS1 F-Bodys
  230. MGW shifter
  231. 4th Gear not there
  232. how do you do a burnout with a manual tranny.
  233. Will 2002 corvette transmission and rear end fit in a 2006 corvette
  234. where to get t56 speedo gear?
  235. Clutch Bleeding
  236. Q regarding shim / throw out bearing measuring
  237. Trans fluid...?
  238. pedel sticking. wont go into gear.
  239. F-body slave with GTO Transmission
  240. Monster Stage 3 good for 1.45 60fts in my BOLT on C6Z w/video
  241. Slave / master cylinder question
  242. T5 Tranny Problems. Need Help!!!
  243. short shifter
  244. Dumb Question
  245. best clutch for 408 and nitrous
  246. RPS Carbon Carbon BC2 Twin Disk clutch ???
  247. Diamond Clutch Special: now til 2/28
  248. Wanted: Junk T56s. Will Paypal you immediately!
  249. Transmission grinding noise. HELP
  250. MT stuck in gears! Clutch stuck on floor
