View Full Version : Manual Transmission
  1. Tick Master Pedal Install Instructions??
  2. Car runs in 5th gear.
  3. Test for re-using blocker rings?
  4. Transmission install
  5. Just got an L96 and want t56; easiest way to get T56 behind it?
  6. pre-85 sbc with lt1 t56 questions
  7. Transmission Advise
  8. Looking for a clutch bang for the buck
  9. Loose shift stick?
  10. XTD Stage 3 6 Puck clutch
  11. need a 011 input
  12. Looking for a clutch kit
  13. Clutch pedal went to floor w no return
  14. All FLT customers we want YOU!!
  15. clutch master cylinder removal
  16. short shifter help
  17. 3rd gear wind sound
  18. Competition Clutch
  19. CTS-V LS6 T56 clutch question
  20. Clutch job questions
  21. Clutch help
  22. any one ever try one of these gear splitter ?
  23. Noise clutch or transmission related?
  24. Slack in clutch
  25. Highest RPM You Shift F body T56
  26. Clutch hyd fluid capacity?
  27. Buy slave cylinder or not?
  28. Clutchmasters FX300 problems
  29. Budget road race car trans options?
  30. Frankenstein T56 Question
  31. 6l80 swap for a t56 in a 2006 corvette
  32. LS6 clutch and drill mod
  33. pilot bearing flushness???
  34. tremec part numbers for MN12 T56 gears
  35. 93 LT1 input shaft needed
  36. do i need to bleed after install???
  37. Is this normal? Pics of pilot bearing.
  38. Is anyone running the Fidanza twin disc clutch?
  39. Time for a new clutch, would like some advice.
  40. Clutch bleeding
  41. 6 speed, how strong?
  42. Question About a clutch, to win a 20$ bet!
  43. Need aftermarket bellhousing
  44. Shifter Cup Bushing
  45. TB round plate???? wat is it
  46. spec stg 1 shims?
  47. Textralia triple no power to the wheels
  48. Another Tick Master thread..
  49. Viper T-56 to LS conversion
  50. just another "my trans wont shift into xx gear problem"
  51. Clutch pedal in, inconsisant grinding noise
  52. LS6 slave in CTS-V
  53. Which clutch for my setup???Decisions, Decisions...
  54. Frustrated with stock T-56!! Help
  55. MGW Shifter
  56. LT1 T56 to LS1 swap problems
  57. Balancing of flywheel???
  58. Pilot bearings disintagrated
  59. T56 Rebuild Facilities
  60. Doesn't go into any gear, then move the car 2 feet forward and it goes into gear?
  61. What brand slave comes with Monsters prem package?
  62. t-56 popularity
  63. t-56 shifting problems(reverse)
  64. T56 Mates to what?
  65. how can you tell if it is a ls7 clutch or z06 clutch
  66. a4 to m6 swap
  67. T56 Reverse lockout w/o the solenoid
  68. Info needed on Spec 3
  69. clutch suggestions. LTx car
  70. Need advice for a clutch
  71. t56 with stock long block 6.0
  72. What clutch should I buy?
  73. Cannot go into any gear?
  74. flywheel.
  75. t56 Compatibilty
  76. Tex SR1 transmission problems!!! Help!
  77. Keep 50k TOB & Slave???
  78. clutch help
  79. t56 fluid
  80. Help....Anyone in Illinois know how to assemble T56?
  81. Pilot Bearing woes
  82. Regrets? Considering A4 to M6 swap
  83. RPM’s won’t drop to idle when put into neutral and driving
  84. LS1 T-56 issues. Who to go to?
  85. does anybody recomend A+ transmision for a rebuild on my c5z t56
  86. Spec clutches
  87. Shortening a Clutch Line - Possible?
  88. new clutch
  89. T56 on a 3800?
  90. difference on input shaft lengths
  91. Fidanza on LS1/LS2
  92. new tick master or 01+ hydraulics
  93. Need bolt size asap!
  94. Tranney Alignement NIGHTMARE!!!
  95. Can I get some ideas on my reverse please?
  96. My clutch/transmission nightmare.
  97. help identify borg warner t56 no tag =/
  98. Question about pedals, a4-m6 swap
  99. M6 shiftting problems?
  100. looking for a t56 transmittion
  101. Ok, about to be in a bind with this thing, need advice....
  102. 6spd notchy in the cold?
  103. Centerforce DFX - Shudder Problem
  104. custom 5th gear in T5
  105. New clutch problem, need urgent help, emergency
  106. LS7 clutch slipping
  107. Thoughts on using Anaerobic Sealer / Gasket Maker on a t56 ?
  108. T56 oil pump
  109. CTS-V+MityVac = no vacuum
  110. Leak?
  111. Why cant you change the clutch disc without changing the PP and F/W
  112. not connecting CAGS and reverse lockout?
  113. t56 good and bad years
  114. MGW = awesome
  115. tyranny not engaging
  116. looking for a stock used six speed setup
  117. 4L60e to T56 Swap help
  118. Another clutch chatter question...
  119. Viper T56
  120. super T-10
  121. Hard clutch pedal
  122. Smooth shfting shifter?
  123. Rebuilding a dead t56
  124. High Mileage or reg dextron III T56?
  125. T56 hard to shift into 1st, 6th, and R
  126. Clutch slipping or engine???
  127. Clutch grab high. Clutch going?
  128. clutch problems help!!!!!!!!
  129. synchoes?
  130. LS1 bellhousing
  131. Clutch or trans?
  132. Average install time?
  133. t 56 bellhousing oem or aftermarket
  134. Mgw shifter!!!
  135. QM button clutch 3 disc. ?'s
  136. What all do I need?
  137. T56 Transmission Mount - Couple of questions...
  138. car will not power shift......HELP!!!!!
  139. Is this clutch/PP combo still good?(pics)
  140. Shifting Problems Still after New Master
  141. clutch for turbo build
  142. wont go into 5th gear i need advice
  143. T-56 Problems
  144. Is The MGW stiff
  145. question about buying a clutch
  146. Still cant quickshift
  147. T56 Magnum Electrical Connections
  148. Tranny fluid smell leaking through Pro 5.0 shifter
  149. Monster Install Help!
  150. Can't shift into 6th
  151. Need help picking a clutch...
  152. for those who replaced pcm along with tranny swap..
  153. Need part number for switches, 2002 trans Am
  154. LS7 clutch with slicks?
  155. need help packing up my clutch...
  156. What is the simple fix if any on this issue with cluch
  157. Tick Master Cylinder, LS7 clutch issues
  158. MGW shifter
  159. Now offering reman'ed T56's outright !
  160. Bolt Size
  161. LS2 Flywheel
  162. What am I doing wrong on bleeding the clutch fluid?? FRUSTRATED!
  163. Cracked my tranny neck housing by shifter what to do
  164. Cracked my tranny neck house by shifter what to do
  165. Bellhousing Dowel Removal
  166. LS T-56 throwout bearing question
  167. tourque arm moun
  168. T56 can't shift into 1,3,5,6, or Reverse
  169. clutch master cylinder
  170. tick master or mcleod?
  171. Transmission Gear Ratios?
  172. Faceplated Trans
  173. Transmission "Re-Fin"? = Rebuild for $320?
  174. What bolts with quicktime bellhousing?
  175. LT1 to Muncie M22 questions
  176. monster clutch weight info!
  177. Clutch pedal not returning sometimes..
  178. Best T56 clutch?
  179. Gears swaps on ctsv-Fbody t5-6
  180. Good clutch Lt1?
  181. Cash for Trashed T56s! Top dollar paid!
  182. 3rd gear
  183. T-56 Tailshaft housing trouble
  184. 11 inch clutch?
  185. drill mod ?
  186. what gear is it best to finish in 4th or 5th
  187. New LS9R clutch for F-body/GTO
  188. New LS9X clutch for F-body/GTO
  189. T56 Troubles
  190. Need Tranny Advise
  191. How to tell if you need synchros when rebuilding a tranny??
  192. Tick Performance Customers: We Want YOUR Car on OUR Website!
  193. mgw shifter noob question
  194. Will a 5/8 bore Clutch Master work??
  195. Blow Proff bellhousing help
  196. LS7 Clutch enough?
  197. New Throwout Leaks at threads - fix?
  198. bbc-tr6060
  199. what 6 speed to use
  200. cts-v vs camaro t56 rebuild kits
  201. Ok guys I need some advice on what to do.
  202. [VIDEO] Driveline Video How-To Thread
  203. Straight cut gearset and faceplating discussion and info thread
  204. T-56 rebuild heeeeeeelp
  205. T56 LT1 to LS1 debate.
  206. Grinds in 1st gear, only from a roll
  207. ACT or DFX
  208. Bad Clutch/Flywheel?
  209. Ls7 clutch kit question
  210. clutch help
  211. What shifter nob do you use?
  212. noob clutch
  213. Story of my first clutch install
  214. What could be wrong with my T56?
  215. Is this a GM slave? pics inside
  216. GTO vs Fbody bellhousings
  217. Tick Performance
  218. Yay...transmission rebuild time
  219. Problem with clutch/flywheel..take a look
  220. MN12 vent tube, part number?
  221. final ratio on my 97 T56??
  222. Bolt on C6Z06+Monster Stage 3 clutch=10.34@134.60mph
  223. shift knob removal?
  224. Let's see those bent shift forks!!!!!
  225. Good deal for a Spec flywheel
  226. T56 clutch pedel hard as rock
  227. Clutch question
  228. What will a stock t56 hold?
  229. i need some help with my centerforce disc :(
  230. Clutch is slipping, need advice
  231. unusually smelly clutch...
  232. Zoom/Perfection clutch disk failures
  233. look at this
  234. Soft Pedal
  235. T56 Shop/Mechanic near Laredo, TX
  236. T56 kicks out of 3rd when down shifted
  237. Damaged shift forks, 98 Z28 6-spd
  238. Practical Transmission Question.....
  239. Knock/banging noise I can feel in shifter
  240. SPEC 2 fails to operate
  241. Slave or master?
  242. New clutch and cannot get in to reverse! Please help!
  243. t 56 wont shift
  244. Tick master adjustment
  245. throw out bearing and master cylinder questions
  246. clutch "FEEL"
  247. McCloud RXT/RST for drag racing
  248. Tickshift master cylinder question
  249. Does this disk look worn to you? (Monster 3)
  250. Input shaft split.
