- transmission help??? skip shift
- Diamond Clutch; New Years Special!
- $680 Stg 2 T56 builds coming to an end (price-wise)!
- Has anyone tried AMERICAN PROWERTRAINS SF clutches?
- LS7 Clutch... Near impossible to get in gear
- T-56 issue- Occuring when doing a hard pull
- shifter knob won't twist off. help?
- clutch hyd. issues
- 6 speed trans problem
- HELP! CLUTCH NEEDED! Very little time!
- Clutch slipping & soft pedal (tech info)
- So what the best clutch set for LT1's????
- The LT1 that won't shift
- shifter boot rings
- gm slave vs mcleod slave
- Tremec TR6060
- squealing trans/clutch
- T56 reverse issue
- Getting T56 rebuilt- what else to do?
- Just drove the first LS9-clutch F-body
- Daily Driving cammed 355
- whats it worth? T56 trans
- question about synthetic manual transmission fluid from GM
- Clutch grinding?
- Splines
- What clutch to buy
- Will LS3 Clutch Work In F-Body like the LS7 Will?
- trans swap
- End of the Year Inventory Reduction sale
- shifting at WOT
- spec clutch install
- t-56 first gear pop out
- 3rd gear grind
- Better Dyno after Clutch Install?
- T56-shifter issue! Help!
- upgrades?
- t56 questions
- Pilot Bushing not installed
- Won't shift to reverse
- need help with master cylinder line
- First thing to break running mid 9's
- how do i know if my clutch is bad
- t56 gears grinding
- Joey and ALL at TICK...
- Clutch?
- damn clutch pedal sticking, help!!
- problem's shifting in sub freezing temperatures
- tranny difference?
- LS7 clutch question
- Reverse idler washers.
- MGW/Hurst Billet shifters--Pros/Cons
- What size bolts needed?
- Manual trans options?
- gto ls2 and t56 into my 99 ta. whats compatable
- 30, 31 & 32 Spline Mainshaft Conversions
- For all you guys with the vibration at 1800 rpm and then again at 4000 rpm, come in
- i searched.... 4th gear issue!!!
- How to Remove Throwout Bearing?
- Tick M/C Throwout Bearing Travel Question
- Aston Martin Vanquish T56 help
- Need advise removing clutch pedal/master
- T56 shifter recommendation?
- Are 5 speed pedals the same as 6 six speed pedals?
- Bruteing
- How long will it last outside??
- Short shifter options
- Spec 3
- Can anyone help figure this out please
- HELP Sprung a Leak???
- what to do
- Gear selection rebuilding T56
- Upgrading a good clutch?
- quick spec question help
- 17t to 10t relutor conversion?
- C6 Slave Cylinder Adapter to F-body?
- Just installed tick master cylinder
- T56 And 408 Install Help
- Magically Disappearing 9310 Mainshaft Thread - Where'd it go?
- t56 rebuild kit
- CTS-V twin clutch... McLeod 6912-07?
- upgrade T56 transmission?
- clutch/hydraulic issue
- Gear ratios in the TR6060 vs T-56
- T56 rebuild vendors
- Anyone ever bought one of these?
- want to buy a T56
- Monster Stage 2/3 Vs Centerforce 12in DF
- Who runs a Diamond Clutch?
- MayDay! Tranny/Clutch?
- Anyone know this shift knob?
- need a part # : gasket/seal for clutch fluid reservoir cap
- GMM RipShifter
- Have a problem with 6spd!
- pro 5.0 lous stick issues
- Valeo has discontinued the LT1 clutch kit
- Centerforce 12inch DF Clutch
- 7 sec 6 speed?
- NEED HELP ASAP!! LS7 Clutch now it wont shift!!
- Did ALL SS/WS6 come with a hurst shifter stock?
- Textralia OZ700 Series Z- Grip Clutch......NEED some advice
- monster stage 6 clutch
- LS1/T56 - Help w/ clutch recommendations for Christmas present for brother
- short shifter opinions
- GM pilot bearing help?
- Clutch rubbing sound.... I think... Help appreciated
- high rpm lockout
- CTS-V T56 question
- clutch install
- cant get into gear
- Project "fix that damn 5th/6th gear high speed vibration".
- monster clutch
- LT1 6 speed ?
- Pro 5.0 Power Tower Shifter in 98 ws6 question ?? help please
- Pro 5.0 Power Tower Shifter ?? help please
- oops oil pouring out of tail housing
- how big of a hole for the clutch master cylinder? a4 to m6
- Clutch pedal play
- question about master cylinders and hydraulics
- Bleeding Clutch after ls7 clutch ...
- how to shift with no clutch??
- too much transmission ?
- Have a broken T56 sitting around? Turn it into more cash for mods!!
- Cannot get out of gear at WOT.
- Bolt in T56 Magnum for LS1 F-body and GTO!
- Monster clutch shim??
- help removing clutch hose.
- monster stage 3 clutch chatter
- Cruise Control not Working after getting Clutch Installed
- clutch issue with cold weather
- Tick Performance Adjustable Clutch Master Cylinder Reviews: I had to share these two!
- Flywheel, LS vs Gen II Question
- Need opinions quick lt1 t56!
- TDP built 6 SPD info
- 6th only vibration
- Transmission grinding 1-2 and 3-4
- help with reverse thrust washer
- clutch return spring?
- Cyber Monday Monster Clutch Sale from Lashway!
- Clutch recommendation
- cts v t 56
- Stuck in gears on all new setup
- Shifting problem
- To upgrade T56 or not? 700rwhp...
- Textralia triple disc help please
- Built 6 spd by rpm tick performance or who.
- HELP: Car won't go into any gear.
- Clutch Squeal / Chirp
- Is my ls7 clutch on its way out?
- HELP: How to fit 2002 Viper T56 to 1996 Impala LT1
- short sticks causing sychro wear?
- Transmission problem..
- New Clutch Kit, New Master, New Slave, Clutch Still Sticking!!!
- T56 on my LS1 takes forever to upshift when racing...
- Short stick
- sticky suggestion
- Need help on Transmission installation!
- T-56 differenses ?
- LS7 Flywheel weight concerns.
- Super t10 question.
- How would you compare these 2 clutches, and which would you recommend for my GTO?
- Rebuild 5 Speed
- ls1 t56 think i broke it
- RPM Transmissions - Cyber Monday Sale
- UMI short stick
- replacing a clutch
- Luk alumnium flywheel - need new friction surface
- Clutch visual inspection possible? Slipping etc.
- Clutch question
- shifting issue
- Anyone interested in an M29 LS1 T56??
- Monster Clutch Co. Holiday Sale!
- Flywheel delays are over!
- T56 Rebuild Same Day Turnaround! Stage 2 $680 Starting price!
- starting car with no transmission
- LT1 Clutch Measurement Request
- What manual trans&clutch setup will handle 1000whp?
- how to identify factory hurst shifter?
- So i just bought a shift light from frost and need help!!!
- street twin (clunking and engagement issues)
- Air entering the clutch system?
- T56 Input shaft swap question
- T56 5th gear problem
- Excesive humming/whining noise in 2nd gear
- getting the transmission flush with belhousing.
- How much tranny fluid do i put in?
- Who has a crack in the firewall by the clutch master cylinder?
- will the textrilla oz700 billet flywheel work with a spec 3 clutch?
- aftermarket slave?
- Tailshaft housing still wont go on.
- What tire size? M6 4.11 Gear Questions
- Budget turbo transmission
- CF Synchro Ring on Reverse
- Smoked a RPS BC2 in 2000 miles! pics
- Tick M/C
- LS7 Clutch Kit
- Really need help figuring out my transmission problem
- Tick Performance remote bleeder is great!!!
- Weird sound when in gear.
- FBody "Temec" T56 6 Speed Man. Trans.
- Stick really stiff after first shift
- How to install Hurst C.A.G.S. Skip Shift Eliminator Kit
- help with synchro intall?
- New Clutch Install!!
- Pilot bushing removal
- Buy LT1 T56 and Convert to LS1?
- Throwout bearing! Help needed ASAP!
- 5 speed in c4 vette/RICHMOND TRANS
- should I replace pressure plate?
- flywheel resurfacing
- Clanking noise when clutch is pressed in..
- manual-auto-manual swap
- Clutch Disengage problem
- Need help finding a part
- LT1 Clutch Kits
- FREE!!! 30 Spline upgrade on your F-body Level 5 T56!!!
- My M6 slave wont accept line from master??
- clutch going out?
- Can't shift into gear
- Difference in rebuilds?
- Which clutch for my dd bolt on car? Spec or C6Z06?
- Monster Clutch Job
- close thread
- Swap complete! 1 more question
- Transmission vibration & "chatter" noise - Not clutch chatter
- slave cylinder bleeder size?
- need transmission advice
- TEX T101 bellhousing/clutch info?
- The shifting in my car feels weird.
- speed bleeders?
- My Tick Master Cylinder fun...
- Swap guys! need help asap
- clutch bleeding issues need some suggestions
- Tick Master Over-pressurizing?!?
- Best shifter!
- I'm gonna stump the pros
- Few more questions on swap?
- My tick master came in! Install instructions?
- Monster 11" race clutch review
- LS7 clutch/flywheel questions
- best way to remove tranny?
- Clutch install help ASAP
- How many bolts?
- t56 gurus needed
- LS7 Pressure plate not adjusted correctly?
- Cluth pedal vibration
- Reverse lockout soleniod question
- Slave question
- clutch dead pedal question.
- Questions before i start swap
