View Full Version : Manual Transmission
  1. Frustrated with snl/monster clutch co.
  2. mcleod rst twin disk or monster stage 5
  3. T56 vent tube....what's the white thing on the end/top?
  4. DD What Clutch
  5. strange noise and i cant push the clutch in
  6. ticking noise in trans, can hear near shifter
  7. What does everyone think?
  8. Differences in transmissions????
  9. Pilot Bearing
  10. Spec twin disk owners
  11. my shifter seems to vibrate really really hard
  12. T-56 Can't shift into 3rd
  13. Spec Stage 3+ shaking the hell out of the Car
  14. pulling the tires
  15. Transmission Chattering
  16. Corvette TR6060 VS T56 internals
  17. f1 racing clutch?
  18. Clutch pedal position sensor
  19. Think my trans is hurt
  20. Replacement Clutch opinons
  21. Mcleod RXT Twin Disk.. How is yours?
  22. Clutch Master Cylinder
  23. need help with t56 !!
  24. ARP LS1 Bellhousing Stud Kit
  25. centerforce dual friction
  26. Driveable but grinds all gears??
  27. Spec 2+ opinions
  28. Third gear grind unless i double clutch????
  29. Need a disc and pressure plate for my stock flywheel on a LT1 T56
  30. Master problems?
  31. B&m shifter ??
  32. Tick master and high clutch pedal
  33. t56 price help
  34. car wont start after blowing my trans
  35. t56 mt drag radial burn out
  36. Soft Clutch Pedal with Monster Stg 4?
  37. Grind while down shifting.
  38. T-56 oil?
  39. Bolts that hold on the slave cyl size???????????
  40. SBC vs LS1 clutch compatibility
  41. Please Help
  42. How much can these trannys hold?
  43. Question...
  44. Grinding 5th
  45. clutch pedal is to easy!!! help
  46. Should I fear for my output shaft?
  47. Clutch grinding from dead stop (tech info)
  48. t56 help
  49. rebuild my t56
  50. Which flywheel?
  51. Trans rebuilt, now harder to shift
  52. Clutch/rain issue???
  53. Tick Master Leaking
  54. no reverse
  55. Need some clutch help..
  56. Quicktime bellhousing owners inside
  57. Expert opinions needed
  58. clutch pressure problems
  59. Monster Level 3 Chatter
  60. Still having problems with Reverse - New Symptoms
  61. Replaced master & slave
  62. t56 yoke length
  63. LS7 Clutch setup won't bleed
  64. Leaking at clutch quick connect
  65. What brand T-56?
  66. Monster update!!!
  67. t56 build up
  68. LT1 vs LS1 internals
  69. Royal Purple Synchromax
  70. T56 lost 2nd gear??
  71. Oil in clutch
  72. car wont go into gear at high rpms
  73. Gto slave or f-body
  74. *HELP* Grinds in all gears PICS INSIDE
  75. clutches?
  76. help with bad clutch work
  77. 94 camaro slave cyl?
  78. Need a T56 transmission..
  79. C5 Z06 clutch is good for how much power?
  80. Spec stg 3 disk 11'', stock LS6 disk 11 3/4''?
  81. What Clutch to buy?
  82. Where to get a new slave
  83. Replaced some parts still hear a noise???
  84. 01' WS6 LS7 clutch launch issue after 13k miles
  85. Clutch Engagement Point With Tick Master
  86. Quick Time Bellhousing ?
  87. Skip shift Cylinod
  88. Mcleod clutch
  89. Need Help-Is it possible to overpush the TO bearing on a T56
  90. new clutch still shifting problems
  91. Need Help with RPM Transmissions
  92. Traction control not functioning???
  93. Hard to get into reverse with MGW shifter?
  94. Tick master works great but...
  95. Weird issiue at high rpms....
  96. 3rd gear issues in t-56!!!
  97. Switching from Tex OZ700 to twin disc?
  98. Recommend me another clutch
  99. Need a Couple Ind. T56 Parts
  100. Any 11-1 1/8 -26 Disk in lt1
  101. T56 Help Needed
  102. Problems shifting at the track
  103. Cleaning clutch fluid (Ranger method)
  104. F-Body Donor For My 6 speed G-body SWAP?
  105. What clutch for 4000lbs 800hp daily driver?
  106. VSS wires ?
  107. Lightweight LS1 Flywheel: What do you think of this one?? XACT ProLite Flywheel
  108. How do you bypass the clutch engagement sensor?
  109. Torque Specs Clutch/Flywheel
  110. Need Help.
  111. pilot bearing??
  112. Monster Clutch Promotion...come on in...
  113. Clutch Slave Cylinder Shims
  114. *Revised as off 9/14*FLT Labor Day/September Special
  115. Suggest me a clutch
  116. Ubw t56
  117. T56 List
  118. clutch options
  119. Dreaded "car won't start after swap" thread
  120. Broken Bellhousing
  121. built 6spd question.
  122. Can the stock LT1 flywheel be zero balanced and can I use aftermarket pp/disc?
  123. Output shaft breakage
  124. Flywheel need replaced when doing clutch??
  125. clutch help please..
  126. Need a clutch install how to....any out there?
  127. Diamond Clutch Sale! Free remote bleeder/Free shipping, 12mo/12k warranty!
  128. how do i know if i have a HURST???
  129. May have burned the clutch? (Result of Novice Shifting)
  130. Decided on Monster now what...?!
  131. Clutch engaging point moves down the longer i hold the clutch in
  132. ? about the MeLeod 64048B-00-07 Street twin
  133. Monster 3 engagement point?
  134. cant get imput throw both clutches HELP
  135. How can i tell if my Clutch isnt disengaging all the way ???
  136. tranny shop recommendation
  137. Spec 3 with 22k miles and still holding
  138. How much abuse can the T-56 take?
  139. T56 slave / master Questions HELP
  140. Backup/Lockout Wiring help w/ T56 Swap!
  141. LT1 t56 clutch hydraulics troubleshooting help?
  142. where can i get T-56 to bellhousing bolts?
  143. t56 question
  144. closest clutch to a cartek
  145. Clutch or trans?
  146. Clutch slipping in reverse?
  147. new tick master and gm slave still having issues
  148. "Drill Mod" gone wrong?
  149. 2000 T/A T56 mobil 1 synthetic? Please Help
  150. Flywheel question
  151. Harlan 2 Step Question on Wiring = HELP!
  152. Pictures of Tick Master Cylinder
  153. New clutch...or something?
  154. Another Won't go into gear... ehh
  155. Spec 3+ does this look like normal wear to you?
  156. Clutch for s trim lt1.
  157. ls7 clutch question
  158. Pedal assembly question
  159. Clutch pedal falling towards floor!!!
  160. SPEC Clutch @ the Holley LS Fest 2010
  161. LT1 clutch fluid change
  162. Tick Performance LOWERS Retail Pricing on our Adjustable Clutch Master Cylinder Kits!
  163. 99 vs 02 M6 hydraulic line???
  164. Installed replacement T56 and SPEC Stage 4 clutch...
  165. Need help with clutch line bad!!!
  166. Burning clutch smell for 3 days!!!!!
  167. ls2/ls7 flywheel work with gto ls2 starter?
  168. what happened to the "problems with monster clutch" thread?
  169. ls7 clutch wont line up with ls2 flywheel
  170. bleeding the clutch??
  171. t56 reassembly problems
  172. Centerforce Clutch from Speed Inc?
  173. Is this a GTO shifter???
  174. T56 sitting for 5yrs - inspect before running?
  175. clutch question
  176. signs of t56 failure ?
  177. Help needed!!!
  178. A4 to M6 Reverse Solenoid
  179. T56 reverse solenoid
  180. T56 Rebuild Questions
  181. Skip Shift Question???
  182. Need clutch advice
  183. slave cylender dimensions LS1, Z06 colorado
  184. HELP!!! car doesnt go into gear. edit FIXED!!!!!!!
  185. Not going into ANY gear smoothly, Tick MC
  186. HELP tick is bleeding off
  187. installing spec stage 3 clutch
  188. McLeod RXT Clutch 1000hp
  189. Where does your clutch engage in relation to pedal travel
  190. Atc clutch
  191. Engagment
  192. Built T56 Disaster! Help
  193. Locked Tires
  194. t56 conversion swap
  195. MGW shifter
  196. Know where to get stock slave cyl bleeder only?
  197. Tranny install help! Need help before it rains :-(
  198. Monster stage 3 clutch
  199. Resurface flywheel or not?
  200. new slave with blown seal
  201. Forgive me for the Newbieness
  202. Monster Clutch Sale (Hush)
  203. ls2 flywheel turning/cut specs v. ls1 flywheel
  204. trans grinding
  205. Clutch or Tick?
  206. have u broke ur tailshaft housing? come inside
  207. T56 ???
  208. T56 Heat? Normal?
  209. Need help with speedo gears...Trying to make T56 Mechanical
  210. How quick will my stock T56/LS7 clutch bite the dust
  211. clutch sticking please help!..
  212. ls7 clutch enguagment issues
  213. LT1 Clutch Replacement???
  214. clutche engagment issue
  215. New SFI Approved LT1 Blastcan (Bellhousing)
  216. Clutch issues
  217. slave cylinder question
  218. transmission line up hints
  219. oil sturated clutch again
  220. Need Help, Car won't start
  221. 85MikeTPI is a great guy !
  222. Just installed a Tick master...
  223. clutch switch kicking light on
  224. Clutch/Hydraulic Issue
  225. ok, shifter help please!
  226. MGW Shifter install, some pics and thoughts so far...
  227. MGW install help needed....
  228. In a pinch, new owner, need a clutch asap around North Delaware
  229. Throwout bearing
  230. Tick master
  231. spec stage 5 clutch
  232. Which twin disc
  233. Transmisson Fluid
  234. Easy question for you t56 guys
  235. INSANELY stiff clutch pedal: Tick master, slave, or Zoom ls6 clutch?
  236. How to? This a cheap aftermarket slave????
  237. Will This Work???
  238. which pilot bearing for CTS-V T56?
  239. Textralia
  240. New Delco Slave Cylinder Bad?
  241. monster clutch install write up
  242. MGW Shifter durabilty
  243. T56 stuck in gear + no change = perfect?
  244. Tick Performance master cylinder finally installed
  245. Help for the 409...T56 6 speed or 5speed
  246. Cts-v t56
  247. Which Clutch 04/05
  248. Aluminum flywheel, yey or ney...
  249. Need some help on a clutch issue
  250. Bleeding with a mighty vac??
