- engagment issues
- What is the part number for the GTO "shifter cup" or shift selector
- 5th gear
- Problem with Reverse Lockout
- LS7 w/RAM flywheel review
- problems with speed bleeder.
- looking for some help
- Tick: first impressions
- Speed Inc./ Spec Clutches $20 OFF!
- Need recommendations for a lightweight flywheel
- No-Walk bushing Walked
- SPEC LSA/8-Bolt LSX to T56 Super-Twin Billet Multidisc Clutch and Flywheel Assemblies
- t56 m6 replaced reverse lockout solenoid still LOCKED
- Pressure plate bolts
- Transmission whine?
- T56 Delema. need rebuild or exchange quicky
- instructions on replacing transmission rear seal?
- About time for clutch help me choose
- Is the Tick the only solution.
- More Spec 3+ problems
- 04 gto clutch help
- A few trans issues
- Hard getting into reverse after a tranny and clutch swap
- Reverse lockout question??
- Hydraulic Line Please help
- Trans whine on decel
- T56 speed sensor hold down
- Factory Hurst
- Shifter ID please?
- 1st gear whine from new monster clutch setup
- Any reason this won't work? (clutch hydraulics)
- cant get v6 trans out of my 99 camaro
- Clutch not engaging??
- Anyone know where i can find tail end of a t56?
- T-56 blues
- 1st gear "blocked" at stop
- Fastest time anyones installed a T56
- Driveshaft Choice Pics of broken one
- Fluid change intervals?
- What RPM to launch T56 at the track?
- slave cylinder
- Monster Clutch/SNL Review
- 5th gear kinda slipping
- Test reverse lockout Solenoid
- Ws6store short stick
- Did all SS have a hurst shifter?
- Shifter Chattering Noise
- m29 transmission rebuild suggestions
- good shops around Tallahassee, Fl.?
- MONSTER CLUTCH Blowout Sale @ Tick Performance: $125 Off Until 8/25
- Troubleshooting Spec Stage 5
- T56 grinding noise??!!
- Terrible noise from clutch/tranny
- New hurst stick.....vibration
- HELP! Pedal pressure, not engaging, new everything!
- Clutch pedal assembaly
- Need help urgent!
- Need Guidance: Car Towed...Weird Noises
- MN12, what's this lug? Can it be removed?
- Drag Racer' s
- Clutch Failure in 4000 miles... WTF? Over...
- spec stage 2 or ls7????
- Strange clutch / gearbox issue.
- Friction Disc Question
- Stripped out your transmission crossmember bolts? Easy fix.
- how much 4 a t56?
- All new Diamond Adjustable Master cylinders TEASER!
- Stage 2 T56 Build + Diamond Clutch Combo SPECIAL!
- Need a clutch PLEASE HELP!!!!!!!!!
- anyone offer an upgraded input shaft?
- clutch line release gone
- t56 gear ratio?
- Thoughts on LUKE/Brakeware Master Cylinders?
- What size nut for transmission mount?
- Shifter area, fluid filled?
- What could cause this?
- Tick M/C squeaks like a rabid mouse
- Flywheel install??
- No clutch engagement?
- LT1 Monster clutchs
- Dropping Transmission
- monster clutch ?
- Need a clutch....Recommendations?
- Fidanza flywheel help
- Tick Performance Customers - How Quick Can YOU Shift? Video Contest - Post them here!
- Finally recieved My McLeod Twin disc set up. Have a Question before Install.
- Transmission Rebuild
- Does anyone have a photo of the hurst shifter that came in the 4th gens?
- Is this normal driveshaft play?
- T-56 grinds in 5th and 6th
- LQ4/T56 flywheel bolt question
- light weight flywheel
- quicktime bellhousing and monster stage 3 - does it fit?
- Light feeling clutch?
- derlin shifter knobs?
- 2nd gear oddities
- Help, problems installing new clutch
- Losing reverse in my t56
- Stubborn Shifting
- Clutch bleeding problem....
- Clutch pedal wont release at wot? T56 LS1
- reverse light/reverse lockout/vss pigtails, Pep Boys?
- Can I mate a T-56 to a 5.3 LMG?
- t56 stuck in gear after tow
- Tick Adj. Master Cylinder, stripped rod?
- tremec 3650 to lsx 5.3
- Stuck driveshaft in T56
- hard to shift
- 2010 Chevrolet Corvette ZO6 clutch kit
- New build....small issues
- manual transmissoon that came in 1998-02 f-body
- LT1 mcleod scattershield - have to align it?
- L92 Starter on a T-56?
- New Gen III Mcleod Master Cylinder
- McLeod RST
- T5 5 Speed
- Notchy Shifting unless I rev higher (like hitting a wall for a second)
- tremec 3550
- ANyone else have a MGW SHort Shifter???
- What the hell is up with my B&M Ripper?
- Trans making whining noise, what could it be?
- Removing CAGS from my 95 Z...pleez help w.how to?
- t-56 fluid qustion
- Tick Performance Adjustable Master Cylinder Kit in GM High Tech Performance Magazine
- Sensor on left side of the trans (M6)?
- Big thanks to Steve @ Monster Clutches
- Draining Stock T-56 tomorrow, Which Fluid Should I Refill it With?
- time for a new clutch?
- Clutch Issue
- Need a new clutch, I want a STIFF SOB
- What is the bolt size for the transmission mount to T56?
- MGW shifter question
- flywheel locating pins
- Clutch????
- Which clutch??? HELP FAST!
- Presolite/Mr. Gasket Aquires Quicktime Inc.
- M6 guys, you NEED a shiftlight; check out our $55 6-LED light!
- LS6 Clutch VS LS1 Clutch
- Monster Clutch Sale ends Saturday!
- tick master cylinder = teh sh!t
- 2 Gear Grinds Bad At Almost Every RPM and i have to slam it
- RAM Master Slave Problem/
- Remote Bleeder
- Questions about stock z28 shift knob,hurst option,and aftermarket sts for 98 Camaro Z
- problem!?
- can you rebuild a shifter?
- need some help/advice. "UPDATE"
- Reverse Gone!
- replacing CTS-v slave, can I use fbody slave?
- HELP! Installed Tick MC, where is bleeder??
- t5 questions
- MGW shifter rattle fix?
- Assembly lube substitute
- I Just Rebuilt My T56
- Clutch Disc/Flywheel "Welded" Together... Maybe?
- Pilot bearing- how far into crank does it go?
- Buying a T-56..which to order help!
- Researching remote bleeders, need opinions
- Monster Break in?
- Best way to shift?+Clutch Question
- lt1 slave help.
- how to's on bleeding master
- Expensive Clutch M/C alternative
- Rpm level-v m12
- Hurst Shifter question
- I cant get my slave cylinder to properly bleed
- Which clutch should I get? Poll
- T56 reverse light conector?
- Looking at used T56 tips
- T-56 Fresh Rebuild Hard To Get In Gear
- What clutch???
- D & D Performance
- New Shift Knob ... Gauging interest
- I think theres a leak in my hydraulics?
- 03 cobra short throw into 98 z28?
- Tranny/Rear end Noise
- Turbo camaro needs a clutch!
- Save the Manuals...
- Temporary lockout of 5th and 6th and temporary lock in 3rd
- What is going on!?
- T56 Drive Shaft Will Not Go IN
- Stumped on swap wiring?
- Fresh rebuilt T56, break in ?
- What fluid do you use in your Tick MC?
- 5th gear problem
- Can 5/6 gear ratio from M6 be put in a M12?
- how to trim poly trans mount
- LS1 4L60E to T56 complete conversion kits?
- 6 speed for Gen 1 sbc
- clutch master cylinder question
- lt1 flywheel
- reduce T56 gear noise?
- shim or adjustable master?
- My clutch finally feels right
- 3 and 4th gear grinding
- What year started CF Blocker Rings?
- Tick master cylinder mounting?
- New Monster stage 3/tick mc
- Tick or RPM ?
- Clutch master issue?
- Dex 3 seem not do to well at high temperture, switch time
- 3rd gear grind question
- Help: Transmission/bellhousing stuck on block.
- Clutch noise??
- Adjusting McLeod Master LT1
- Monster Clutch Co. Twin Discs!!!!!!
- clutch help anyone
- Phoenix Friction Clutch Audition
- NAPA/Perfection Slave Cylinder, new style fitting?
- clutch engage at hight rpm even with pedal down
- TDP and Diamond Clutches
- RAM Clutch
- Centerforce clutch and spec flywheel
- Rear vent plug?
- Very soft clutch & missing 3rd
- T56 can't go in gear HELP
- Smells Bad
- need a new tranny, suggestions?
- I think I killed my clutch
- T-56 rebuild ?
- Clutch pedal sticking. Yes I read. Unique problem.
- Question about Pro 5.0 shifter install
- M6 Swap guys - cutting a hole for the shifter?
- 02 camaro ss m6 clutch noise
- best place to build t56?
- new tick master cylinder ?
- Selling our remaining Monster Clutches from the sale...come inside!
- Shift fork conversion possible?
- PITA T56 somebody help me please
- What connects the shifter to the rear transaxle on a C5 Vette?
- Clutch "squeak" when engaging in 1st gear... normal?
- Problem with 3/4 shift. New slave, tick MC
- Monster Clutch Co.'s New 11" Race Clutches!
- GMM Ripshifts @ Speed Inc
- New clutch won't engage Please Help!
- park in gear ?
- Wilwood master cylinder with 1.12" of travel
- Noob syncro question.
- not sure if i need a new clutch????
- Which clutch kit?
- Is this what "chatter" is? (new Monster Lvl 2)
- Trans is out. Lateral play on input. Busted slave. Need some advice!!
- ANother Transmission oil question
- Car bucks when shifting
- More props for the Tick Master
- stage 2 tranny rebuild
- 2004 GTO Aftermarket Shifter
- what clutch should I buy?
- Stock SUCKS!!
- Adjustable master worth the extra money?
