View Full Version : Manual Transmission
  1. The correct way to bleed the clutch hydraulics
  2. I need some dimensions on the ls7 slave
  3. Help clutch pedal on floor
  4. Dilemma. . . .Should I stay or should I go?
  5. clutch related or hydrallic
  6. rpms continue or rise
  7. LT1 Clutch suggestions
  8. isolating slave/master issue
  9. went for a road trip yesterday and have a few questions now.
  10. how much Horsepower/Torque can a T5 take?
  11. LS7 clutch need a break in????
  12. Clutch questions?
  13. Please Help With My Clutch Problem!!! :(
  14. Intermittantly not going into gear
  15. 8.1 BBC LS1 trans swap info
  16. Weird 3rd and 5th issue.
  17. boosted 408 t56 upgrades
  18. dumb ? on pilot bushing/bearing
  19. C6 vette...can't downshift from 6th to 5th
  20. 2000 F-body, Press Plate Broke, see pic
  21. t56 slave cylinder
  22. OK just checking only!
  23. Where to buy main cluster?
  24. Searched, found mixed answers - flywheel/PP bolt questions
  25. Transmission/Clutch Squeal! Help!
  26. Keep Blowing Slaves WTF.....Tick Master/Mcleod RST
  27. 61 tooth 5th gear?
  28. Shifting out of 1st?? Help Advice
  29. Disengagement issues with Spec Twin disc
  30. Called 2 Dealerships and nothing! Need Bolt information!
  31. McLeod Twin disc questions
  32. Hard clutch pedal
  33. Clutch Problem
  34. Just disassembled my T56. Questions?
  35. Mcleod twin disc grabs off way too high..spacers on transmission?
  36. stock t56 w/ 150hp no2
  37. will this flywheel work?
  38. borg warner clutch?
  39. shim problem?
  40. clutch issue?
  41. how much can the t56 handle?
  42. Clutch WILL NOT disengage at all!!
  43. Clutch/ tranny compatability question
  44. PROBLEM entering 1st and rev.
  45. Spec stage 2+ vs 3
  46. rattle when i let off clutch.. need some help!!
  47. LT1 T56 vs. LS1 T56 Which is better?
  48. T/A on the ramps...
  49. Spongy pedal issue
  50. Input shaft seal (LT1 tranny)
  51. Monster Stage 3 review.
  52. Just smoked my clutch on the dyno need options
  53. clutch/slave issue
  54. possibly a dumb ?
  55. Clutch Release Bearing Removal
  56. GTO Clutch
  57. How much play??
  58. what T56 goes on the L76
  59. Clutch Problem
  60. Spec 2 v. Luk Pro gold Clutch Kits
  61. Not shifting @ high rpm?? M/C problem??
  62. M29 transmission on an LSX motor?
  63. Quicktime bellhousing help!!!!
  64. LT1 Clutches, let's see them!
  65. strongest T56
  66. new tranny or rebuild
  67. Best overall shifter for my M6
  68. Tremec Magnum + Monster Stage 3
  69. Spec Stage 2 and 3 Driveability
  70. Vette T56 Disassembly
  71. why, does MC go bad?
  72. Basic clutch alignment question
  73. Clutch issue at WOT
  74. Vibration when I push in the clutch? (LT1/T-56)
  75. LT1 M6 Mcleod Clutch: Car moves with clutch pedal pressed in.
  76. ranger clutch care writeup
  77. wont go into gear
  78. short shifter
  79. T56 Wont shift into 2 4 or 6th
  80. Broken trans
  81. slave replacement
  82. Slave cylinder bolts
  83. mcleod street twin rebuild lt1
  84. T-56 mounting relative to tunnel
  85. Bought a Ram HD clutch...
  86. should iresurface my Tex flywheel??
  87. need t56 help asap!
  88. MN12 3-4 Synchro Removal
  89. monster stage 2 vs stage 3
  90. Installing new 1-2 synchron... NEED HELP!!!
  91. leaking seal?
  92. how hard can i push my t56??
  93. T56 Questions
  94. Clutch not fully realeasing, help
  95. FLT or Tick for an Fbody T56 rebuild
  96. help removing clutch line
  97. McLeod master question.
  98. Monster level 3 is here!
  99. A4 to M6 swap?
  100. Need Clutch Recommendation for under $500
  101. Monster release their twin clutch yet?
  102. which clutch/ best deal?
  103. Anyway to un-adjust a SAC LS7 pressure plate?
  104. Paging McLeod rep.....
  105. T56 rebuild help
  106. Anyone heard of this?
  107. Tranny knocking noise at idle...is this a problem?
  108. What fluid for the clutch hydraulic reservoir?
  109. Viper T56 behind LS motor
  110. Placement issues...
  111. C.r.s.???
  112. Does anyone know the part number to the T56 front cover?
  113. T-56 serious problems!!!!
  114. Wat after market flywheel n clutch wrks best ..
  115. One of these slaves is not like the other...
  116. how to build my t56
  117. LT1 trans am question
  118. Power loss with LS7 Clutch
  119. Bad speedo Gear? Video Inside
  120. Which T56 is this?
  121. Think i may have bought a Fake Hurst shifter..are t56's the same?
  122. This clutch work for an lt1?
  123. Monster Clutch or Textralia?
  124. T-56 Major Grinding
  125. getting the street twin to fully release LT1
  126. Monster clutch level 3 with lw/fw weight
  127. Best short throw shifter and place to buy
  128. gear noise
  129. AutoZone duralast clutch kit $159.00
  130. Clutch Bleeding Issue, Speedbleeder HELP
  131. T-56 Magnum
  132. mcleod street twin: loose sounding engagement?
  133. trans install problem
  134. Who makes a twin discs clutc setup for Higher HP
  135. indexing hurst shift knob
  136. Another clutch question
  137. T-56 rebuild
  138. Speed Adjustment on T56
  139. RPM transmissions in indiana?
  140. Stock Hurst Shifter Diameter TA 98-02?
  141. t56 servicing question
  142. vibrations at speed with poly trans mount
  143. t56 question
  144. Switching over from auto
  145. Shifting... the best way to shift into 2nd
  146. ES poly urethane tranny mount + stock rubber motor mounts = no no????
  147. Mighty Vac
  148. stock ls1 T56 bellhousing height????
  149. McCleod twin disc ?'s
  150. MGW is very noisy?
  151. Pedal isn't right after manual pedal install.
  152. what clutch to buy? who has the best deal?
  153. 2nd to 3rd grinds, but only when cold
  154. Is anyone rebuilding 5th gen TR6060's
  155. Clutch Break In
  156. Master and slave bleeding
  157. Problems getting into reverse?
  158. hard to get into gear
  159. LS7 clutch
  160. master line O-rings...
  161. will a t56 fit in the trunk of an F-body?
  162. 2010 Camaro Fidanza Twin Plate clutch Q's
  163. grinding in every gear
  164. Is balancing the pressure plate and flywheel necessary?
  165. prothane trans mount problem
  166. Ram PowerGrip HD driveability
  167. t56 help
  168. how to know ls7 clutch
  169. Clutch Barely Disengaging in the Morning
  170. Exedy Hyper Twin. Need some info/parts/dealers
  171. tick master and monster clutch sticky pedal
  172. Hard to get into gear when stopped
  173. Tuet2060?
  174. Reverse lockout on a4 to m6 swap
  175. Flywheel help!
  176. Spline count on TR-6060
  177. I cant get any clutch pedal pressure!!!!!
  178. Arrrgh! Second Gear AGAIN!
  179. Is the maincase trashed?
  180. built t56
  181. slave cylinder question
  182. cleaning the clutch disk
  183. Best/shortest short throw shifter?
  184. slack in hydraulic clutch
  185. Please Help!
  186. monster clutch chatter
  187. having to pump my clutch up after getting on it
  188. broke a mcleoud twin disc....
  189. LS9 clutch on a LS1?
  190. Bad slave??
  191. T56 bellhousing bolts?
  192. difference in standard and "+" spec clutches
  193. Cause for concern?
  194. easiest way to upgrade syncros?
  195. Odd grinding noise when clutch engages??
  196. ls1 driveshaft in lt1
  197. Alternate LS7 pressure plates?
  198. Pretty sure my trans is trying to escape...
  199. SPEC stage 3+ clutch
  200. Boot Retainer Broke - Any aftermarket Fix?
  201. grinding in reverse
  202. Smoothest clutch for 600-650rwhp
  203. Tick turnbuckle/rod adjustment
  204. Hurst Shifter
  205. t56 compatibility
  206. New clutch hard to get in gear
  207. Ok need help with clutch problem
  208. What am I missing?
  209. T5 Speedo Help
  210. two enguagements with the street twin??
  211. 5th gear grinding, only 30K
  212. buying a new t-56
  213. mity vac'd and pulled up black globs?
  214. Clutch replacement questions
  215. RXT vs Text
  216. Time for a Tranny Rebuild...
  217. Not Mentioned in Any Clutch Replacement Treads
  218. best mg fluid
  219. Eneos Fluids ?
  220. Short stick
  221. Clutch Problems
  222. Cheapo ebay shifters.
  223. High RPM shifting issues! HElp!
  224. How do I test my clutch?
  225. LS2 clutch into LS1 car NOT WORKING?!
  226. LS7 clutch checklist. Did I forget anything?
  227. Short Stick B&M Shifter
  228. T56, LT1, Hard to get in gear/pop out.
  229. Clutch Slipping
  230. cammed ls7 clutch
  231. Couple of questions
  232. Intorducing Diamond Clutch, our all-new adj. master cylinder! & T56 Rebuilds
  233. Need help identifying this clutch!
  234. Clutch Break in a Myth?
  235. Is a used FBody T56 tailshaft housing worth anything?
  236. LS7 clutch fylweel options.
  237. Short throw shifters for Corvettes???
  238. ~~Clutch pedal engages at different places?!?~~
  239. LS7 clutch w/ LS3?
  240. Clutch master cylinder reservoir
  241. Third gear grind
  242. 3rd gear problem
  243. Clutch break-in for non street car
  244. rebuild problems.....
  245. 1-2 T56 billet key springs
  246. What clutch and PP is this?
  247. t56 extension shaft
  248. stock t56 questions.
  249. Sticking Pedal Read sticky
  250. Will Tail Housing Break?
