View Full Version : Manual Transmission
  1. mcleod rst twin
  2. Breaking in a Clutch
  3. how much is too much damage to an input shaft
  4. shifter problem
  5. clutch problem?
  6. LT & LS T56 gears
  7. Starting the New Year off right
  8. Occasional first gear issues...
  9. can't get clutch petal
  10. Getting a clutch, what to replace?
  11. Tranny Fluid Fill Plug on top?
  12. Who's running more than 750RWHP?
  13. Jeep Transmission Problems.
  14. My Experience With LS1 Clutches
  15. remote bleeder..how to use?
  16. LS6 Clutch?
  17. Longer 5th gear ratio
  18. Which Monster to pick
  19. will a ford 3550 or chevy tko 600
  20. Need clutch help fast
  21. what short stick
  22. T56 Rebuild manual PDF
  23. Spec or ACT
  24. Finished installing monster level 2
  25. worn out spec stage 3, what options
  26. Clutch just started to slip. What to replace with? I daily drive it.
  27. Update my 98 Hydralics to 00-02 poss slave clyinder bad??
  28. Installed short stick now shifter is louder
  29. LS7 clutch kit for a LS1? will this work?
  30. How to diagnose a bad clutch master?
  31. just order MONSTER STAGE 3 AND TICK PERFORMANCE MASTER
  32. Have a question about a t56 tranny
  33. Clutch will not release HELP
  34. Starter engages when reconnecting battery.
  35. scatter shield?
  36. Rattleing sounds in 1st
  37. Shifter install ?
  38. T-56 won't go into 5th
  39. What short shifter is this?
  40. AC Delco Clutch Master Cylinder for sale
  41. monster lvl 2 with chatter
  42. Need help with finding a retaining clip
  43. Hard Noise During 4th Gear Shifting?
  44. tick performance
  45. clutch problems
  46. Happy Holidays 2009: FREE SHIRTS from Tick Performance and TICKshift.com!
  47. Camaro SS full gearbox ID
  48. 4th gear problem.
  49. What kind of shifter is this?
  50. Forward Mounted Shifter install problem
  51. lt1 t-56 to run with 5.3
  52. I can't get my clutch to bleed!!!!
  53. Clutch sometime having a hardtime going into gear...??
  54. broken t56 skip shift solenoid
  55. Weird clutch issues.
  56. Thread pitch for the C6 Shift Knob?
  57. muncie throw out retainer
  58. Spec Twin PT Helped my HCI NA C5Z into the 10s today
  59. T56 rebuild
  60. Clutch Issues...
  61. Spec 3+
  62. ebay flywheel??
  63. What flywheel to use?
  64. LT1 t56 trans and clutch system work on a Mark IV BBC 2 piece rear main........
  65. Just ordered my MONSTER STG 3!!!!
  66. Need help quick...CLUTCH
  67. might have a problem look in and see
  68. Clutch Starting Issues
  69. Anyone running a ACT 6 puck?
  70. bushing behind the rear seal?
  71. T-56 spinning the Driveshaft in neutral?
  72. Low traction engaging
  73. Disappointed
  74. Worst Luck...More clutch issues
  75. The better one?
  76. Will this fit??
  77. clutch?
  78. Bleeding Question
  79. Anyone Using a MGW Short Throw Shifter?
  80. Who has best price for LS7 Clutch kit?
  81. Help please
  82. time estimate for a clutch swap
  83. If you have a six speed, buy a tick clutch master cylinder and avoid trouble
  84. Have to pump the clutch pedal to get the car into gear
  85. Clutch pedal doesn't disengage clutch...
  86. Flywheel & Clutch
  87. Weak Pressure Plate
  88. t56 experts please have a look inside here.
  89. MGW Shifter Vibration, HELP!!
  90. thought it was the rear end but found this after removing driveshaft...
  91. Time for a new clutch anyone running a Moster 6 yet
  92. zoom clutch
  93. How do you check clutch freeplay?
  94. MGW Shifter
  95. T56's 5th gear 1:1
  96. LT1 Centerforce DFX clutch
  97. Which clutch??? Monster or Textralia
  98. A4-m6 swap
  99. LS7 clutch questions
  100. Light Weight Clutch/PP for Fidanza Flywheel
  101. 5&6th gear noise think I broke it
  102. m6 swappers
  103. Lou's Short Stick
  104. difference between the lt1 t-56 trans and the lsx t-56 trans
  105. clutch or trans going out?
  106. Need Cash? Sell YOUR Core T56 to Tick Performance & TICKshift.com
  107. Rattling noise coming from trans at times??? 01Z28 6speed
  108. tranny questions
  109. Anyone have their throw out bearing weld to prop shaft?
  110. replace 5th gear
  111. !!!!mcleod lt1 street twin flywheel help! Mcleod chime in please!!!!
  112. broke driveshaft have some questions....
  113. bleed clutch but pedal still soft.WTD?
  114. What Best clutch for Daily Driver 600 ft lbs torque
  115. Spec 3 - Brand new , OK to dyno car with new engine?
  116. Stock Flywheel and Clutch Weight
  117. Spec 3+ Clutch Issues
  118. In need of a ls1/ls6 Flywheel
  119. master cylinder & pedal
  120. master cylinder line o-ring broke
  121. clutch pedal issue..
  122. WTB-Core T56
  123. ls7 clutch?
  124. Stock Flywheel Thickness? Shim measurements..
  125. master cyclinder
  126. low mileage '02 Camaro SS with clutch or transmission issue...?
  127. Throwout hydraulic line HEP!!!!
  128. Heeeelp!!!
  129. stripped out tranny crossmember bolts?
  130. T-56 with 2010 camaro LS3...will it work?
  131. What rhp #s is your LS7 clutch holding?
  132. bellhousing blanket?
  133. Good deal??
  134. What clutch??
  135. GTO hydraulics sufficient or insufficient?
  136. m6
  137. Help with shifting
  138. testing VSS
  139. clutche question ??? clutch less
  140. G Body T 56 swap help
  141. mcleod master cyl rebuild question
  142. Faceplating
  143. Help diagnose
  144. Monster level 3 and tick master installed.
  145. Need advise ASAP regarding Lq9 and Fadanza Aluminum flywheel.
  146. LS-1 Slave cylinder
  147. Spec super twin disk clutch (pt)
  148. New clutch installed, never had an aftermarket clutch
  149. clutch upgrade?
  150. Difference between LT1 T56 and LS1 t56
  151. Trans fluid on clutchfork... input shaft seal bad?
  152. T56 Problems, Trans or Clutch? Need Help.
  153. whos got the bst T56 rebuild kits?
  154. T-56 Transmission Break!
  155. whats the best t56 slave?
  156. steel fly wheel
  157. flywheel bolts
  158. clutch, slave, or air....or all of the above?
  159. SNL Performance
  160. Issues After Clutch Install
  161. Think im calling it quits
  162. What 5 speed will work on my ls1?
  163. Gear oil
  164. Anybody want to trade trannies?
  165. Interchangeable slaves?
  166. T5 rebuild??
  167. Shifting problems, hard to get in gear.
  168. Master Cylinder Question..
  169. Clutch master
  170. need a tranny
  171. Which transmission
  172. Sticky gears at high RPM shifting
  173. Fluid coming out of slave, Monster Level 3
  174. help bleeding lt1 clutch
  175. 5.0 Short Shifter Knob Q
  176. Spec 1 users lend me your ear (or eyes)
  177. Trans to bell housing bolts (NOT to block) size
  178. So why is my clutch getting worse?
  179. Shift Knob Adapters - Any Downsides?
  180. max power a Textralia Exo-Skel twin disc will hold?
  181. T-56 Dexron III
  182. Textralia 40,000 mile review with a few questions
  183. Slave cylinder condition
  184. MGW or Hurst Billet Plus?
  185. t56 upgrade ?'s
  186. Need help with clutch bleed for Z06!
  187. hydraulic line replacemenmt
  188. pedal on the floor?
  189. exedy single disc clutch kit?
  190. Transmission noise?
  191. New clutch or attempt to rebalance the old one (pics)
  192. What happpened to my fluid?
  193. cartek adjustable master cylinder
  194. What clutch for aCF flywheel
  195. T56 magnum to a zz502 questions.
  196. difference between LS2 and LS7 flywheel?
  197. Smoked new clutch on 1st pass
  198. found out what happened
  199. T-56 slave cylinder
  200. TKO 600 selctor fork problem
  201. Better than stock slave cylinder???
  202. T56 mount
  203. t5 to t56 swap
  204. resurfacing flywheel
  205. clutch hunt. What kind to i need??
  206. Slave Cylinder disassembly
  207. Stuck in 4th gear!!
  208. Trans I.D
  209. shaft
  210. Tuet6000
  211. What's wrong? just snapped my 4th clutch disc...
  212. Shifter?
  213. Auto to manual conversion
  214. Stripped out slave cylinder bolt...What to do?
  215. ALUMINUM OR STEEL FLYWHEEL? Need help choosing
  216. spec clutch noise
  217. T56 experts: Weird problem, can't DS from 6th to 5th
  218. T-56 magnum?
  219. t-56 swap HELP!!!
  220. Braided line or lines.....
  221. Park lock cable on t56 to 4l80 conversion
  222. reviews for tranny swap
  223. Need a Transmission Jack.
  224. trouble pullin t56 outta 02 ss camaro
  225. Any reason an MN12 would shift better than a Camaro T56
  226. Looking for cluch suggestion
  227. Monster Clutch & Tick Performance Hydraulic Packages for YOUR LS1 at TICKshift.com!
  228. Built tranny parts websites?
  229. Reverse pops out. Can i fix it?
  230. Tick MC - Any Regrets?
  231. wierd problem with clutch i think, need help
  232. Help with which clutch for my application
  233. Hard to shift when running through the gears
  234. Need shift fork advice.
  235. Bad synchros or worn fork pads?
  236. Spec MC?
  237. Factory Hurst or MGW Shifter
  238. where to buy MGW shifter
  239. Changin clutch master cylinder
  240. Textralia Black Friday Sale - $150 Off
  241. t56 for sale
  242. help flywheel bolts
  243. Short Stick Shifter HELP
  244. Which Slave?
  245. Tick M/C Pedal Play
  246. Help my vibrating C5 after new clutch install?
  247. ???~Hurst_Billet_Plus-OR-Pro_5.0~??
  248. Help me find a clutch
  249. What Rebuild is for my car?
  250. shifter "stiffening"
