View Full Version : Manual Transmission
  1. What Rebuild is for my car?
  2. shifter "stiffening"
  3. Please help me diagnose T56 rattling
  4. 98-02 LS1 Style T-56 Factory Throwout Bearing Part # ?????
  5. 5th and 6th grinding
  6. New guy clutch question? Advice needed for ROOKIE!
  7. Looking for parts list for all harnesses
  8. To LS7 again or not???
  9. When putting the car in Reverse it goes forward??
  10. clutch master question
  11. clutch help please !!!!!!!!!!!
  12. Interesting issue..
  13. 4 speed LQ9
  14. How to hold Flywheel when torqueing
  15. t56 swap problems (help!!!!!!!!!)
  16. T56 behind a Supra motor
  17. Pics RE: HELP! New Slave, MC, Pilot Bearing, and Clutch Disc, STILL Problems
  18. T-56 ... 3rd gear Spits Out !!
  19. Really stupid question. Changing clutch fluid.
  20. A #1 customer service
  21. shifter cup + epoxy?
  22. T56 hp
  23. Drill mod? tried a search
  24. stuck in 4th
  25. Remove reverse lockout?
  26. tranny rebuild?
  27. Tex Racing T101 came in today
  28. Reverse lock-out?
  29. 07 corvette t56 for sale
  30. Do I have a Hurst?
  31. Transmission PROBLEM
  32. Different ohm reading from GTO to Corette CAGS?
  33. Who sells slave cylinders for c5s
  34. T56 Dowel Pins
  35. thanks Steve and Matt
  36. Play / clunk when letting out clutch
  37. white plunger
  38. 02 ta t56 for sale
  39. What size slicks are you guys running on your drag set up?
  40. Smaller, more compact T56 bellhousing?????
  41. Another hydrolic issue help
  42. T-56 Magnum Vs. TR6060
  43. Clutch needs bled, or replaced?
  44. Anyone use centerforce clutches?
  45. SPEC Stage 3 users I need some opinions.
  46. T56 Silverado question
  47. Minimum upgrades for T56 in 500-550hp 3600lb car?
  48. Spec 3+ questions...Please help
  49. Clutch (Possible master cylinder) problem, need help!
  50. T56 will not go in to 6th gear! NEED HELP!
  51. HELP! New Slave, MC, Pilot Bearing, and Clutch Disc, STILL Problems
  52. Monster clutch question
  53. 6sp Powershifting Issues, need advice?
  54. Where to buy dust shield?
  55. Tick adj. master cylinder question
  56. How to check output shaft while trans is in car.
  57. B&M synthetic trick shift fluid...
  58. T-56/Clutch Problems...?
  59. Reverse lockout operation.
  60. LS7 Clutch Kit
  61. 70K on stock clutch and hydraulic pictures
  62. tick master cylinder question
  63. How to clean a clutch?
  64. Help with Monster flywheel
  65. gto slave and master in a f-body
  66. T-56 build up gear selection advice
  67. Effects of Capping Vent Tube on T56
  68. 1996 SS clutch suggestions
  69. Can't shift at high rpms. Clutch pedal height is constant.
  70. Monster Stg 2
  71. P0704 Clutch Switch Input Circuit Malfunction
  72. help with ine from slave to mc
  73. re-assurance during clutch break in
  74. Remote Bleeder for LS7 Slave
  75. T-56 for dummies?
  76. spit shifter out of 1st on hard launch.
  77. GM Weatherpack connector name? Melted mine, need another
  78. Finished My T56 Swap
  79. stock hurst vs. pro 5.0
  80. Talk about your 2-step and/or line lock setups
  81. Rear housing removal
  82. swaping t-10 for t-56
  83. Speed Inc / PRO5.0 SALE!!!
  84. LS7 clutch/FW + new hydraulics + remote bleeder... clutch not fully disengaging
  85. which performance clutch under $600
  86. Major Drivetrain Issue!! HELP
  87. fly wheel for high rpm
  88. B&M "Stick Shift" gear lube?
  89. T-56 problems (5th gear)
  90. new clutch
  91. How much power can built FBody T56 Viper shaft hold? 1000rwhp? Any input appreciated.
  92. Anyone used a Clutchnet clutch?
  93. which company for a new built t-56
  94. Things I learned during my clutch install
  95. Which clutch for around 900hp?
  96. Ls7 clutch won't hold...which one?
  97. ZF tranny
  98. any1 want to swap there complete m6 for my a4?
  99. Idea...how bad is it?
  100. Symptoms of a failing slave?
  101. Help me choose my clutch upgrade.
  102. lt1 to ls1 t56 conversion parts costs???
  103. Mobile 1 Synthetic Tranny fluild
  104. Mcleod m800 (new transmission)
  105. 1-2 Shifting issue on hard launch
  106. Spec 3 + feels good ..
  107. shifter rattles sometimes while driving
  108. Rear bushing...T56
  109. Trying to install my Tick MC. Is my feed line upside down?
  110. monster level 3 and 9 inch equals carnage
  111. chevy t56 to sbf
  112. Were is the speed sensor located?
  113. Help with tranny removal.
  114. Tick Master Adjustment Question (Pics)
  115. new cluch help
  116. Can you hear your clutch engage?
  117. Help!!!!
  118. M6 carnage with pics, need parts.....
  119. If you re-install an old clutch,does it need another break in?
  120. Anyone using Kevlar Pilot Bearing?
  121. Master cyl fitment ?
  122. Squeaky Clutch...
  123. Shift boot RING
  124. Just got my Tick MC - I'm pissed
  125. new tranny mounts
  126. My MN12 T56 Carnage and Happy Ending
  127. Huge RPM Transmission Sale + Free Shipping!
  128. Clutch bleeding trouble. Space issue.
  129. After Clutch Install Problems
  130. 1995 t/a
  131. Bad slave???
  132. Hurst billet/plus
  133. TR6060 what one? 2 part numbers
  134. Built t-56 (viper shaft) build sheet
  135. Which Clutch would be best?
  136. Fidanza twin vs Monster M5
  137. Information on Liberty 5 speed swap?
  138. are ls7 and ls2 slave the same throw out distance?
  139. Purchasing JUST a clutch disc?
  140. How can i tell if i have a hurst?
  141. Noise when releasing the clutch pedal
  142. 2nd and 4th are gone :(. Rebuild or buy new? How much to fix?
  143. is this the right ARP bolts to get?
  144. what to look for when buying a used t56
  145. HELP, were can I find hydraulic fittings?
  146. monster pedal feel?
  147. Some changes at Monster Clutch Co.
  148. Monster Clutch Co. Holiday Sale!!!
  149. Flywheel Recommendations
  150. Firewall mount Master Cyl. What size would U use?
  151. Bellhousing supplier
  152. Stock clutch?
  153. wont go into gear after tranny install
  154. I cant connect the master to the slave... :(
  155. Clutch stuck engaged...
  156. stupid Master Cylinder question?
  157. t56 for sale with 35k miles
  158. 4th gear syncro going? Symptoms?
  159. who makes the shortest throw shifter
  160. Clutch not disengaging after missed shift Updated w/pic!
  161. decision on shifters
  162. M6 Clutch Issues, At a Complete Loss.
  163. Flywheel
  164. is this the pilot bearing ill need?
  165. Nasty grinding while engaging clutch. Loose Flywheel?
  166. M6 Build or Replace?
  167. out of town and the clutch went...
  168. F1 Dual Friction clutch?
  169. Question about reverse.
  170. need some flywheel help
  171. t56 length
  172. T56 locked out of 2, 3, 4, 5 intermittent
  173. ? for you t56 builders
  174. clutch suggestions for a truck
  175. Morris Motorsports...TICK MC and Stock MC
  176. Is the mount on a F-body T56 offset?
  177. Going about rebuilding my trans with 105k miles on it...
  178. Question about dialing in Lakewood scattershield
  179. Need wiring pics for M6 to A4---searched stickies
  180. A Tip for Bleeding - Ghettoing w/o a wobble
  181. Grinding noise in 1rst gear ? // TRANS fix NIGHTMARE story
  182. stupid clutch questions
  183. few conversion questions...no dice on search
  184. T56 Sensor identification
  185. ????? how you guys doin it 10.s on moter?????
  186. Whats the purpose of stop screws - B&m ripper shifter?
  187. What makes clutch fluid dark?
  188. New clutch and hydraulics and clutch stuck
  189. need a T-56 rebuild in ala/tenn
  190. Shifter question
  191. High Rpm Shifting Problems....
  192. what flywheel??
  193. Rear seal and bushing question
  194. clutch problems cont....
  195. Please help! Clucth disengagement issues - weeks now!
  196. Clutch Recommendations
  197. Would My CSC be the same ?
  198. kevlar pilot bushing?
  199. Problems getting into gear and reverse
  200. help please .....
  201. pilot bearing or bushing...
  202. Preferred fluid for T56?
  203. Do I really need that shifter boot???
  204. Ram HD still getting it done. 1.43 best this year/ 10.66 cam only
  205. f body / gto
  206. "Clunk" When Shifting
  207. Pilot bearing removal
  208. Help, I need a whole new transmission!
  209. Clutch problem (sorry its a little long)
  210. LS7 Clutch install
  211. T56 downshift vibration and 1ST thru 4th
  212. Just installed Tick master constant bubbles at 14kpa with mity vac
  213. McLeod Soft Lok
  214. Hurst short shifters please come in. New short chrome stick installed.
  215. what shifter comes stock on a 99 z28?
  216. Just finished the rebuild
  217. After my Spec 3+ Install, Engages low and creeps forward
  218. New clutch recommendation ?
  219. How to bleed your clutch with a TICK SPEEDBLEEDER (mod, please sticky)
  220. Help, I need a transmission shop in the Buffalo, NY area!!!
  221. Ford t-56 on a ls1 motor?
  222. Need help with my speed bleeder
  223. How To Start M6 w/out Pushing Clutch In
  224. T56 rebuild Quote
  225. Tranny fluid and shifter?
  226. Gto belhousing with camaro starter
  227. Quick Pilot Bearing Q
  228. Im constantly having clutch problems? Anyone do the hole mod?
  229. T56 Nightmare
  230. Odd clutch slipping issue?
  231. 04 GTO T56 shifter question
  232. which monster?
  233. Hydraulic problem?
  234. What does the reverse light plug on a T56 go into?
  235. centerforce clutch on a 94 t56 wont disengage!!! HELP!
  236. Help! Before i go on a shooting rampage!
  237. Difference in ls1 and ls2 shifters
  238. traill blazer ss shifter handle
  239. How to remove throwout from slave?
  240. Clutch pedal return spring
  241. This is why you eliminate weak links in tranny (pics)..
  242. cluctch or transmission problem HELP!
  243. t56 wont go into some gears!
  244. Zoom kelvar pilot bushing; which way do you install it?
  245. Complete T56 Conversion $875
  246. faceplated t56
  247. clutch pedal not returning
  248. Quick question after ls7 clutch install
  249. Clutch bleeding with Tick Speed bleeder
  250. Ever had problems with your black clutch peddle switch?
