- Problem installing T-56, please help.
- My T-56 and Engine hate each other.
- Spec 3+ in 408 w/ 250 shot?
- Gears Grinding When Clutch is Down?
- t56 in ls1 GTO?
- Dropping T-56 got Question
- Anbody running Motul RBF600 and know where to get it.
- PICTURES of measuring for shim, and bench testing setups, good tech....
- parting out 2002 trans am
- New SPEC Stage 1 high rev stuck
- Noise coming from my T56...help...
- grinds going into gear
- Inspection plate is off - what do I look for?
- A bleeding issue?
- Good shop to have a T56 rebuilt near Northwest Arkansas
- checking clearances when installing a new clutch
- shift throw questions is it serious?
- Who Red powder coats their transmissions?
- Clutch engaging with clutch petal on the floor!
- T56 rebuild: shaft shimming not required?
- LS1/LT1 T56 tail housing
- AAAHHHHH! I'm yankin this tranny apart asap.. Help
- Problems getting in gear.. PLEASE HELP!
- Monster Clutch finally got our stickers!
- The LS7 clutch that never dies.
- T56 Input shaft bearing question
- not quite sure?
- 4l60e to T-56
- Monster gettin it done!
- T56 question
- Steve@MONSTER Clutch CO....
- t 56 swap
- SNL Performance and Monster Clutch Co.
- I Think Its Time For A New Clutch
- lightweight flywheel
- Shifter relocation on a F-body LS1 trans
- Monster Stage 2 in! Couple of issues...
- No Clutch Pressure???
- Trans Prob
- clutch problem
- Is a C5 clutch master compatible to Camaro LS1 slave?
- Did the rev test and need some answers.
- Tranny Rebuild Advice
- t56 build up question
- Not engaging
- T-56 transmission & the LL8 4.2 I6 compatability?
- couple questions after Ls7 clutch install
- t56 front plate ?
- Replace 5/6 sychro? pics within
- ls7 clutch issues
- T56 rattle on during right turns
- Is it in the shifter or transmission?
- Snap ring and lock ring replacement?
- One hell of a guy..
- Clutch Issues, Possible air in the system?
- Clutch pedal engages too quick and is too low
- What years t-56 will fit in a '00 Z-28?
- Flywheel shim vs slave shim
- Trans cooler on a manual?
- yes another lt-ls trans thread
- Clutch replacement opportunity.....
- centerforce DFX....opnions
- clutch choice for cam/spray/boltons
- short throw
- clutch choice ??????
- Noob Question
- Replacing master cly
- Bore Size On Stock F-Body M/C?
- Guys in need of a Level 2 Monster
- t56 faceplated
- Clutch engages right off the floor? hard to take off in 1st, need shim?
- Spec stage 3+ and stock flywheel????????
- Help, clutch dropped to the floor and hydrolic fluid leaking
- Help putting 6 spd setup into Auto body
- SPEC stage 4 pressure plate. Can it be resurfaced?
- t56 how strong?
- Clutch Bleeding Prob, T56 swap
- Spec 2+ Cluch -- Pressure plate not allowing block to mate with bellhousing
- Engine to Bellhousing Stud Kit?
- Need Hurst Billet/Plus Handle Part#
- What hydraulic fluid do you use?
- i want to chance from auto to stick
- Better off buying a built T-56 or rebuilding mine?
- GM Syncromesh in cold weather
- ran into an issue with the auto to manual swap, need input
- ?'s bout my 6sp car
- I really want a 4 speed!
- clutch for 1000rwhp?
- Dual Mass Clutch
- couple questions on transmission reinstall
- Monster stg 3 issues
- Has anyone gone faster than 8.69 with a manual??
- What is wrong with this?
- Transmission shop in NY?
- T56 wont go in or stay in reverse?
- Problem at the track w/my T-56
- 5th gear/reverse grinding on M12
- Monster level 3 chatter
- trouble installing t 56
- Need T56 input shaft end play/preload setting.
- Clutch not disengauging!
- t56 tailhousing
- t56 resource in TEXAS???
- which clutch for me?
- transmisson alignment?, shifter rubbing interror
- Clutch pedal wierdness
- New Tic performance master cyl and same issue??????????????????????/
- tremec t56 bell housing
- Anyone use Royal Purple Syncromax?
- Is It Time To Rebuild My Transmission?
- Can I use a Newer GTO shifter on my T56?
- Auto to manual trans conversion
- shifting....
- what do you wrap your hydrolic lines with?
- LS Bellhousing Thickness
- stock t56
- t56 kicking out of 1st gear
- 71 TURBO-FIRE 350CID TREMEC/Borg-Warner T-56
- where to buy a factory replacement ls2 flywheel
- Clutch/Transmission Problems.
- clutch issues
- what clutch do I have?
- Clutch not Engaging textralia
- Which Flywheel for LS7 clutch
- How do I adjust my safety switch?
- How much does a lt1 t56 weigh ?
- Leaking tranny fluid...need some help on this one.
- Monster clutch for LT1. Who here wants one?
- How to proceed with shop after wrong fluid installed...
- flywheel question
- Gm Tremec 3550 To Ls1?
- How many miles for clutch break in?
- What clutch?
- Did I blow my clutch or is it something more serious?
- Car shakes under 1500rpm, but only when in gear
- locking gear other than broke key or shifter adjustment
- Help w master cyl bleeding w mighty vac
- clutch pedal depressed but car wont let me engage gear
- t56 swap help
- In the Market for New T56
- looking for a good twin disc at a good price.
- 99 TA t56 for sale
- Tips for master cylinder removal
- I need a Bellhousing 97 ss
- Installed TICK. Now i need help!!!
- Replacing clutch, anything in tranny?
- Just bought a used t-56, found this on the magnet.
- Did I get screwed?
- Reverse Gear Out?
- How often should one change transmission fluid (t56)?
- Spec 3+ starting to make grind noise on less than 10k mi.
- something wrong?
- Which gear oil ? dextron or synchromesh
- Just installed Pro 5.0 shifter
- T56- Noise in 5th & 6th gear...
- Help Looking for a LS t-56 in good working condition
- T56 help
- Trans harness, am I missing something?
- Clutch make a chatter noise
- ls7 clutch no worky!!!!
- new and doesnt work
- Put my Tick MC in today, impressions/ questions
- Do I need a new master???
- Trashed my brand new Monster slave... ARG
- Spec 3 Clutch
- Monster break in questions...
- what grinds my gears.
- Forward creep while putting car in gear...
- Slave Cylinder Spring
- how much abuse
- Fidanza clutch.. WHY? help
- Clutch Problem... Help
- Problem With my Clutch Please Help...
- Who rebuilds TEXTRALIA CLUTCHES?
- Monster half levels? - Am I missing something?
- Pick Me Out A Shift Knob...
- Drill mod gone bad!
- What is the fastest way of removing the trans on my Z?
- Tick master cylinder in action!!!! (vid)
- .......... From where can buy rebuilt T5 Trans can hold 4500rwhp ?
- Energy Suspension tranny mount? getting a rattle/vibration at 3,000 + RPM
- Anyone have a Textralia OZ 700 HD????
- T56 Rebuild and clutch replacement at the same time?
- how do I change fitting on slave?
- t56 clutch issues
- throw out bearing or new clutch?
- Question about reassembling the tailshaft housing to the rest of the transmission
- has anyone put a stock c5 clutch kit in a gto?
- cheap place to get stock replacement clutch?
- Monster Clutch Stage 3.5 and LS7 clutch
- Tick Performance clutch master question
- Drivetrain Vibration
- Need Help Deciding On a New Clutch
- need help with LS7 / C6 salve
- Pressure plate and flywheel bolts
- roasting the clutch and more...
- CTS-V M12 to fit behind a LS1, what needs to be changed?
- MONSTER LEVEL 6 AND STOCK MC, it's done!
- Car pops out of 3rd gear
- T56 winding noise
- 2nd gear scrub only when speed shifting help!!
- LS7 clutch weight
- Six Speed Inc - Can't remember what I bought
- Replacing just the disk?
- Shorter OEM concentric slave/throwout? F-body v Vette v Fords v ???
- new question: slave or tick master?
- Refninish flywheel & pressure plate?
- ls7 clutch install *need help*
- Pilot bushing for a lq4
- Tring to blead clutch: Please Help
- LS7 Clutch disc question collasped springs?
- Grinding going into second under heavy load
- Grinding Noise After Track - Can't Pin It Down?
- Problem shifting after clutch change
- Pretty sure I know the answer...slipping clutch symptom
- mgw shifter kinda hard to put in gear?
- very hard to get into reverse
- clutch fluid leak???
- Need New Trans Mount
- Air in M/C
- looking for t56 trust washer & 1-2nd synchro sleeve
- T-56 behind a Carbed 383?
- trade or sale my t-56 for your auto
- Stock motor mounts + Poly trans mount = ?
- Tick adj master cylinder ?????
- Advice on new clutch...
- Trade my t56 for your built & stalled Auto
- A COMPREHENSIVE FAQ: The Tick Performance Adjustable Clutch Master Cylinder Kit
- T56 Install Tools
- lt1 clutch... bye bye
- Master Cylinder? Slave cylinder? Need help!
- Mcleod Street Twin Sale for the LT-X
- need some opinions, advise on clutch or slave change?
- Drill mod review
- Pics of my cracked tailshaft casing - Also anyone know where I can get a new one?
- Best Price on a new CLutch Master Cylinder?
- 500hp clutch for under 500 $... what'er my options
- Monster Clutch Company.. Services...
- Can you replace clutch springs?
- slave cylinder differences
- spec clutch install gone bad..
- Has anyone overshifted with a mgw?
- LS7 clutch installed, hydraulics bled...
- Why aren't any aftermarket short shifters actually SHORT shifters?
- Anyone know the stock shifter thread size and pitch?
- Is my clutch bad?
- 9310 27 spline vs stock Z06 30 spline
- grrrrrr
- 3rd Gear
- Damaged ls6 clutch disc
