View Full Version : Manual Transmission
  1. Noob Clutch question??
  2. SPEC Clutch install done!!! Except one thing... HELP!!!!!!!!!!!
  3. Reinstalling the hydraulic braided line on T-56..
  4. T56 yoke ?
  5. reverse light
  6. Transmission "lash"
  7. Confirm my fears here
  8. T56 Carnage
  9. Where to buy C5 9310 mainshaft?
  10. Quick Release Hydro Clutch Tool?
  11. another happy monster/tick customer!!
  12. Pro 5.0 sucks
  13. How did your spec twin disc clutches line up?
  14. Finaly got to drive my Tick Shift Faceplated T56
  15. Clutch Bleeding for 3 Hours
  16. New Slave Cylinder, posting for others...
  17. Mcleod Street twin HP loss?
  18. Leaking Clutch Fluid on Ground
  19. Clutch slipping, tick master still awesome...
  20. startup with out tranny
  21. Having horrible luck with my car - Trans just blew tonight, can case be welded?
  22. Filling T-56
  23. ls1, ls6, ls2, ls7 slave cyl differances...
  24. CAGS / Skip Shift Solenoid - what size wrench to remove?
  25. Stock adjustable master cylinder guys do you like yours?
  26. CTSV flywheel
  27. Sticky Clutch
  28. Clutch Dragging?
  29. Monster Level 3 and what else ?
  30. Does anyone else go through slave cylinders like fuel?
  31. Props to Jason at TDP
  32. Spec 2 life span
  33. Need Transmisson Advice
  34. What Synergyn fluid for t56
  35. I think I've made the decision to convert to M6
  36. 2nd LS7 clutch in a year
  37. Couple clutch questions.
  38. 390RWHP on stock clutch?
  39. i need a new t56 clutch
  40. Does anyone have the LS7 kit in stock?
  41. T56 vendors please come in. Need your help.
  42. T56 6th to 5th grinds
  43. 1996 camaro t56
  44. LT1 T-56 to gen1 SBC???
  45. Shifter Bolts Length?
  46. 2nd gear issue
  47. Monster have a clutch kit or single disk for LT1?
  48. MASTER CLY OR SLAVE CLY Which one????
  49. specs new super single clutch kit?
  50. LT1 T56 bolt/nuts specs
  51. Corvette owners- 6 speed swap c6 to c5?
  52. transmission stuck to engine
  53. Harlan Shift Light Help
  54. Brand new clutch slipping... help
  55. M6 wont shift into 3rd at Wot
  56. This is a different PG, th350, th400 vs m6 question
  57. Clutch Trouble !!!
  58. Slave cylinder part #
  59. Stuck in Reverse?
  60. Help with extension housing replacement
  61. HELP!!! After rebuild t56 FIRST LOCKED OUT
  62. low pedal engagement after break in
  63. HELP on clutch or hydraulic?
  64. LS1 flywheel minimum thickness?
  65. LS7 clutch
  66. Anyone with TICK lvl. 2 rebuild
  67. Monster + Tick . Need Reps
  68. ls7 clutch in place of ls1
  69. Just sent the old tranny out, waiting begins
  70. Need new master oring
  71. Havent seen this asked...replacement disc for Spec?
  72. Best place to buy tranny parts?
  73. Just bought T56 2nd gear grinding
  74. which tranny
  75. Hard to get in gear
  76. Synchro install quote...
  77. Is this normal?
  78. clutch is slipping at low rpm?
  79. clutch issues!!
  80. hard to shift into gear at idle?
  81. Which oil for my T56?
  82. Clutch Problem Please Help
  83. will a 98-02 t56 fit a sbc?
  84. Whats wrong with my clutch pedal????
  85. Clutch (race) recommendation for LS1
  86. T-56, TKO-600 or what?
  87. 1st Rebuilt T-56 with Tick Master and Textralia OZ700
  88. Stock LS1 Bellhousing Height Dimension?
  89. Scored a T56 this past weekend, needs conversion.
  90. T 56 upgrade parts
  91. Quick grind into 5th, only at high RPM's???
  92. 1st. time doing clutch job, how does my stocker look?
  93. Swap
  94. Whats it worth - T56 rebuilder / parts?
  95. Anyone know of any diagram showing how the brackets go back together under the trans?
  96. Leak but no fluid on the floor ??
  97. 60mph+ vibration Need help only when off of the throttle
  98. Looking for some help...
  99. Installing my clutch next week! *QUESTIONS*
  100. Can a bad clutch interlock switch cause a no start?
  101. Whats the best clutch for the C6?
  102. Stock Clutch vs Nitrous
  103. When i rev, My car vibrates
  104. Need to replace master, clutch, slave, flywheel?
  105. Clutch Pedal Stop Question for All-Custom Application
  106. Only the inside of the clutch disc is worn?
  107. clutch slipped for first time need help
  108. who has the best deal on monster clutches?
  109. monster will find your weak links
  110. Noise Diagnosis.
  111. Car wont start with clutch pedal pressed
  112. Manual transmission question...
  113. My Tick adjustible master wont adjust anymore
  114. Cant get into 1st or Reverse!
  115. New GM master install question
  116. Where do you get your syncromech ?
  117. Clutch engagement question
  118. crossmember help
  119. Tranny leaking only when driven hard
  120. Synchronizer?
  121. Difficult to get in gear
  122. Mgw??
  123. LT1 Flywheel Bolts Source
  124. Installed Tick Master and now....
  125. 1998 z/28
  126. new noise when letting out clutch....
  127. wont downshift to 2nd
  128. Any cons to running a light flywheel ?
  129. Small diameter Flywheel for LS3
  130. Recommendation for clutch with my FI setup?
  131. Find the cause of my vibration!!!!
  132. Pilot bearing or bushing, is one better than the other?
  133. Car won't go into 3rd, 5th, reverse after install?
  134. I didn't get any instruction with my TICK MC :(
  135. disconnecting master form slave
  136. Rebuilding transmission after gear grinding...
  137. need a clutch line!
  138. In car vid at the track. t56 wheelies,autos are gay
  139. Power Shifting?
  140. Cant Power shift??
  141. 6 spd guys, what gear you launch in
  142. Broken t56 value?
  143. Transmission won't line up?
  144. Measurements
  145. replacing input shaft..any easy way to do it?
  146. FINALLY OUT: Tick Performance GTO Adjustable Clutch Master Cylinder Kit & FREE Gift
  147. LABOR DAY SALE: Tick Performance Adjustable Clutch Master Cylinder Kits DISCOUNTED
  148. Cant get Tail Shaft houing back on! WTF?!!
  149. hard reverse?
  150. Weld a faceplate crack?
  151. T-56 / Bellhousing Gaskets or Silicone?
  152. M6 4x4 Tahoe
  153. Whats double clutching???
  154. Pulled my tranny for a rebuild and this sucks
  155. T56 scatter shield???
  156. Clutch noise?
  157. any one used zoom clutch
  158. How much can stock clutch handle?
  159. slave compatabilty
  160. My 6th gear is done...How much to fix?
  161. MONSTER Clutches and shims!!!!
  162. max tq t56 question
  163. stupid Yes or No question.
  164. Torque spec for pressure plate bolts on Spec AL flywheel?
  165. Proper way to bleed with Mity Vac??
  166. All about the Masters
  167. Popping out of 4th gear all the time, What could be the cause?
  168. Monster Clutch Co.
  169. catch can on t56?
  170. Energy Suspension Poly Mount
  171. Mity Vac
  172. lt1 t56 to ls1
  173. Sticking in 2nd!!!
  174. can't press pedal down
  175. Help ASAP! Clutch not disengaging, trying to fix it right now need help
  176. Need immediate help bleeding slave cylinder
  177. Shifting problems at WOT
  178. Lingenfelter clutch - 900lbs.ft Torque
  179. Shifter Boot
  180. Noise following slave install
  181. havin a issue with what i was told a new m6??
  182. Name that part....
  183. new monster and tick master.
  184. Mcleod soft lock (slipper clutch)owners step in
  185. Which Clutch - SPEC, RAM, Monster??
  186. need a cluster shaft for a t56
  187. Flywheel weights?
  188. Odd noise
  189. Monster folks....
  190. Any tricks or mods or anything I need to know when installing my new Tick master?
  191. quick question for the experts..
  192. Lightening a flywheel
  193. New clutch install now wont go in gear... need opinions
  194. countershaft extension spacer between 5/6?
  195. Carnage on a fairly new clutch
  196. Monster clutch install, have a little issue
  197. Wont downshift to second
  198. Help for a manual trans dummy?
  199. big problems with clutch or hydraulics (I think)
  200. Pro 5.0 Shifter Stops
  201. Buying a new master Tick or Mcleod?
  202. Engaging without pedal....
  203. Ebay Slave Cylinder
  204. PPG racing helical dogbox gearkit liquidation
  205. pedal ?
  206. 2 weeks with the tick master...
  207. Rebuilding T-56 couple questions
  208. How do you know if you have a bad SLAVE
  209. New clutch/master, some problems fixed, but still not right...
  210. whats a good price for a used ls7 clutch?
  211. Thanks Morris Motorsports
  212. Please come in and check out my $1,000.00 clutch and tell me what you think GURU's
  213. Trouble with my M6 for my GTO
  214. RPM Level 5 with Billet output shaft, do you have one?
  215. Tick master cylinder question
  216. Grinding in 1st gear
  217. Do I have the right flywheel for my C5?
  218. Strange question 90 degree fitting to slave?
  219. Tick Master ...Adjustments?
  220. Trans/Rearend Howling noise.
  221. clutch ? on ls1
  222. Clutch acting up...?
  223. 1000whp t56 build
  224. car wont go in gear running
  225. Im glad to get this piece out!
  226. Good Clutch for Slipping?
  227. what clutch to hold 1100+rwhp for my TT street car?
  228. flywheel weight???
  229. T-56 rebuild 5/6 gear
  230. bought all parts for t56 swap, is it too much of a hassle
  231. need some specs on a sixspeedsinc trans.
  232. Goodbye Slippage
  233. do i need a new clutch?
  234. What's wrong with my car?
  235. Clutch pedal pressure
  236. unpluged wire on the trans?
  237. bad clutch?
  238. T56 issue
  239. problem shifting after clutch install
  240. Just ordered my Tick MC!! Cant wait!
  241. Clutch problem, what the hell.???
  242. Cutting factory shift stick?
  243. Questions on shifters for the LS1 t-56
  244. How the hell do you get the slave cylinder off the line?? Need help ASAP
  245. T56 Swap Hole for Clutch, Other Question
  246. Transmission to Bellhousing Alignment Pins
  247. mc leod twin disk stuck to the flywheel???
  248. WOW Monster Clutch
  249. Disapointing T56 swap
  250. 5th gear gone????????
