View Full Version : Manual Transmission
  1. New GM master install question
  2. Where do you get your syncromech ?
  3. Clutch engagement question
  4. crossmember help
  5. Tranny leaking only when driven hard
  6. Synchronizer?
  7. Difficult to get in gear
  8. Mgw??
  9. LT1 Flywheel Bolts Source
  10. Installed Tick Master and now....
  11. 1998 z/28
  12. new noise when letting out clutch....
  13. wont downshift to 2nd
  14. Any cons to running a light flywheel ?
  15. Small diameter Flywheel for LS3
  16. Recommendation for clutch with my FI setup?
  17. Find the cause of my vibration!!!!
  18. Pilot bearing or bushing, is one better than the other?
  19. Car won't go into 3rd, 5th, reverse after install?
  20. I didn't get any instruction with my TICK MC :(
  21. disconnecting master form slave
  22. Rebuilding transmission after gear grinding...
  23. need a clutch line!
  24. In car vid at the track. t56 wheelies,autos are gay
  25. Power Shifting?
  26. Cant Power shift??
  27. 6 spd guys, what gear you launch in
  28. Broken t56 value?
  29. Transmission won't line up?
  30. Measurements
  31. replacing input shaft..any easy way to do it?
  32. FINALLY OUT: Tick Performance GTO Adjustable Clutch Master Cylinder Kit & FREE Gift
  33. LABOR DAY SALE: Tick Performance Adjustable Clutch Master Cylinder Kits DISCOUNTED
  34. Cant get Tail Shaft houing back on! WTF?!!
  35. hard reverse?
  36. Weld a faceplate crack?
  37. T-56 / Bellhousing Gaskets or Silicone?
  38. M6 4x4 Tahoe
  39. Whats double clutching???
  40. Pulled my tranny for a rebuild and this sucks
  41. T56 scatter shield???
  42. Clutch noise?
  43. any one used zoom clutch
  44. How much can stock clutch handle?
  45. slave compatabilty
  46. My 6th gear is done...How much to fix?
  47. MONSTER Clutches and shims!!!!
  48. max tq t56 question
  49. stupid Yes or No question.
  50. Torque spec for pressure plate bolts on Spec AL flywheel?
  51. Proper way to bleed with Mity Vac??
  52. All about the Masters
  53. Popping out of 4th gear all the time, What could be the cause?
  54. Monster Clutch Co.
  55. catch can on t56?
  56. Energy Suspension Poly Mount
  57. Mity Vac
  58. lt1 t56 to ls1
  59. Sticking in 2nd!!!
  60. can't press pedal down
  61. Help ASAP! Clutch not disengaging, trying to fix it right now need help
  62. Need immediate help bleeding slave cylinder
  63. Shifting problems at WOT
  64. Lingenfelter clutch - 900lbs.ft Torque
  65. Shifter Boot
  66. Noise following slave install
  67. havin a issue with what i was told a new m6??
  68. Name that part....
  69. new monster and tick master.
  70. Mcleod soft lock (slipper clutch)owners step in
  71. Which Clutch - SPEC, RAM, Monster??
  72. need a cluster shaft for a t56
  73. Flywheel weights?
  74. Odd noise
  75. Monster folks....
  76. Any tricks or mods or anything I need to know when installing my new Tick master?
  77. quick question for the experts..
  78. Lightening a flywheel
  79. New clutch install now wont go in gear... need opinions
  80. countershaft extension spacer between 5/6?
  81. Carnage on a fairly new clutch
  82. Monster clutch install, have a little issue
  83. Wont downshift to second
  84. Help for a manual trans dummy?
  85. big problems with clutch or hydraulics (I think)
  86. Pro 5.0 Shifter Stops
  87. Buying a new master Tick or Mcleod?
  88. Engaging without pedal....
  89. Ebay Slave Cylinder
  90. PPG racing helical dogbox gearkit liquidation
  91. pedal ?
  92. 2 weeks with the tick master...
  93. Rebuilding T-56 couple questions
  94. How do you know if you have a bad SLAVE
  95. New clutch/master, some problems fixed, but still not right...
  96. whats a good price for a used ls7 clutch?
  97. Thanks Morris Motorsports
  98. Please come in and check out my $1,000.00 clutch and tell me what you think GURU's
  99. Trouble with my M6 for my GTO
  100. RPM Level 5 with Billet output shaft, do you have one?
  101. Tick master cylinder question
  102. Grinding in 1st gear
  103. Do I have the right flywheel for my C5?
  104. Strange question 90 degree fitting to slave?
  105. Tick Master ...Adjustments?
  106. Trans/Rearend Howling noise.
  107. clutch ? on ls1
  108. Clutch acting up...?
  109. 1000whp t56 build
  110. car wont go in gear running
  111. Im glad to get this piece out!
  112. Good Clutch for Slipping?
  113. what clutch to hold 1100+rwhp for my TT street car?
  114. flywheel weight???
  115. T-56 rebuild 5/6 gear
  116. bought all parts for t56 swap, is it too much of a hassle
  117. need some specs on a sixspeedsinc trans.
  118. Goodbye Slippage
  119. do i need a new clutch?
  120. What's wrong with my car?
  121. Clutch pedal pressure
  122. unpluged wire on the trans?
  123. bad clutch?
  124. T56 issue
  125. problem shifting after clutch install
  126. Just ordered my Tick MC!! Cant wait!
  127. Clutch problem, what the hell.???
  128. Cutting factory shift stick?
  129. Questions on shifters for the LS1 t-56
  130. How the hell do you get the slave cylinder off the line?? Need help ASAP
  131. T56 Swap Hole for Clutch, Other Question
  132. Transmission to Bellhousing Alignment Pins
  133. mc leod twin disk stuck to the flywheel???
  134. WOW Monster Clutch
  135. Disapointing T56 swap
  136. 5th gear gone????????
  137. Problems with Power Shifting
  138. Lost 1st and reverse. Clutch, tranny or shifter?
  139. why did my stage 3 spec fail?
  140. CAGS solenoid suddenly acting up after years of being tuned out
  141. v6 m5 to ls1 m6 swap
  142. Getting ready to do a swap need advise
  143. Mcleod master - pedal feel?
  144. Lightweight flywheel???
  145. Clutch was slipping, took it out but its perfectly fine...what to look for next? Pics
  146. 2 weeks gone clutch!!!
  147. Starts without pressing clutch
  148. Shorter short throw how to...
  149. ls6 clutch question
  150. Desperate textrelia help!!!!!!
  151. LS3 with T56 And wich Twin Disk?
  152. Kragen or Autozone flywheel?
  153. Clutch or Trans???
  154. switching from auto to man.
  155. HELP! New Master and Slave Cylinder installed
  156. Shifting to 3rd Gear
  157. 98' T56 fluid
  158. Nother clutch issue :bang:
  159. Shifter removal help needed!
  160. clutch pedal goes soft during light driving
  161. Need new clutch.
  162. installed tick master and remote bleeder
  163. t56 install help
  164. Urethane tranny and torque arm mounts. Vibration?
  165. Ram dual disk not releasing..
  166. Opinions: Should I upgrade master cylinder (budget)
  167. Just checking before I break something
  168. Textralia Install Question
  169. Do any of you guys get a SQUEAL when slowly engaging your clutch in 1st?
  170. Master Cylinder and Install
  171. mustang tr6060?
  172. WS6 store short stick with stock shifter
  173. pilot bushing, quick question!!!!
  174. TKO500 where from?
  175. Cenerforce Dual Friction on its way out... Monster?
  176. Ls7 Flywheel question
  177. torque specs? ASAP
  178. Replace flywheel too?
  179. Awesome Experience with SPEC!!! (Must Read)
  180. Clutch orders to Canada...
  181. Mcleod Twind Disc HELP!!
  182. Resurfacing Billet Steel flywheel
  183. Tremec tko + LSX
  184. I built my T56..
  185. Pilot bearings - BIG vs small
  186. m6 swap and occasionally will not start
  187. Tick Remote one man bleeder
  188. vette trans in fbody
  189. Clutch master cylinder
  190. Just installed a new LS7... Problems?
  191. When does Chatter happen
  192. Should i replace my flywheel????
  193. Monster LTx Clutch
  194. Pilot Bearing Part Number
  195. Need slave piece!!!!!
  196. LTx Adjustable Master - Are the LS1's ones the same?
  197. which clutch/flywheel
  198. Rattle coming from the shift knob.
  199. HELP! Hydraulic clutch line question
  200. Stock pressure plate question
  201. Cltuch bleeding with motor and tranny in the car.
  202. Clutch cable help please
  203. whats the best way to change the clutch
  204. monster clutch disengagement
  205. Help choosing a clutch
  206. Replaced the clutch & slave....problems...
  207. Clutch problem
  208. Drill Mod?
  209. Monster stage 3 break in question
  210. Clutch help!!!
  211. T56 Magnum
  212. shifter isnt dead on?
  213. 1-2-3-4-5 All good like butter. . . then 6 all bad! Plz Help....
  214. What years of a LQ4 will fit a t56
  215. T56 Swap into 67 Impala BBC
  216. T-56
  217. Ram clutch carnage
  218. Help:Hard to go into reverse after 9" install
  219. LS7 clutch vs. Hendrix Clutch
  220. factory T56 shifter= crap....
  221. LS7 OEM Friction Disk Thickness.....Anyone have a new one?
  222. LT1 T56 Components for conversion questions.
  223. Ordering a monster lvl 3.. Billet or Chromoly??
  224. 700whp guys what clutch
  225. Unable to shift into gear
  226. where to buy the braided line from master to tranny?
  227. Input shaft wear
  228. help grinding noise when clutch pressed
  229. reinstalling my t56 ... need a hand on a sol question...
  230. Anyone want a Auto?
  231. Cant Shift Tranny
  232. Dumb Question?
  233. Help with textrailia twin disk
  234. MF'r Im spitting 4TH! on WOT
  235. T5 World Class Upgrade Options?
  236. How much are built t-56's going for ?
  237. Installed Monster clutch and new problems arose
  238. Fidanza aluminum fly wheel on c5 z06?
  239. quick adn easy question: need a clutch reservoir
  240. What the Hell is this..??
  241. Rebuild Kit DIY
  242. T56 is dead.
  243. Wanted 6.0 clutch suggestions.
  244. Can I damage my trans if...
  245. Think we can reuse this flywheel? (pic inside)
  246. t-56 rebuild
  247. Whats the best Clutch kit and Rearend??
  248. Car shakes and shudders -- new problem help pls
  249. Short stick compatible?
  250. Shipping Weight & Dimensions - T-56?
