View Full Version : Manual Transmission
  1. ws6store short shifter
  2. Well?
  3. Shifting problems with my t56 when going harder on throttle.
  4. New Problem after rebuilding T56 (IDEAS?)
  5. TKO 600 what oil???
  6. shit, clutch help please?
  7. Clutch won't go down, HELP
  8. Stuck in gear now no reverse? WTF
  9. Putting together a clutch setup
  10. T-56's and Moroso oil pans?
  11. Vibrations - Clutch or not?
  12. clutch or tranny issue?
  13. chromoly or billet steel fywheel?
  14. Brand: Clutch master/ clutchs
  15. Clutch wont Bleed - Need Help...
  16. Clutch line and fitting HELP!!!
  17. weight of Street twin vs single disc???
  18. Slave problems
  19. New @ TICKshift: Monster Clutches ON SALE, New Offerings from SPEC, Lightweight LS7..
  20. Tick or 01-02 GM MC
  21. Vibration under engine braking...
  22. Max HP / TQ on '97 LT1 T56?
  23. How much is a stock clutch, master cylinder, slave cylinder, 17K miles worth
  24. clutch pedal not comming all the way up.
  25. Aluminum Flywheel & Clutch Q's
  26. T56 jack
  27. Trans downshifting/misc issue
  28. Ls7 clutch setup, now i have clatter
  29. Reverse lockout soloniod or sensor
  30. ls7 clutch
  31. What should the clutch pedal feel like while disconnected
  32. Monster Clutch Sale Going on?
  33. what is my setup worth?
  34. pullin tranny
  35. 2 complete cars:swapping tranny m6-a4 and a4-m6. Swap interior harness???
  36. Which mityvac model to get
  37. Packaging and shipping a T56
  38. 01+ master with drill mod vs tick master
  39. I Need T56 Parts HELP!
  40. Clutch
  41. trouble shifting under wot
  42. Pilot bushing for LS1
  43. Do I need to take the starter off to pull the bellhousing?
  44. Big confusion, have a question about SPEC
  45. What clutch setup for 900HP?
  46. ls7 clutch question
  47. Pro 5.0 install
  48. Can I make a t56 from a c5 fit into an 82 f-body?
  49. any tips on removing tailshaft seal/bushing?
  50. Locking clip for clutch pedal/piston
  51. A quick question
  52. spec2+ or spec3+
  53. Monster clutch break in
  54. Another Tick/monster setup
  55. spec1 and spec 3
  56. New clutch installed... problem with pedal stiffness
  57. Monster and tic rock!
  58. Help!
  59. any strip tips?
  60. Newb shifting questions.. dont laugh
  61. Exedy Clutch poor customer service
  62. ls7
  63. Dextron VI?!
  64. LSX Super-Single Clutch Kitch Now Available
  65. Monster & Tick Performance = Awesome
  66. Is there Any Worth To These Parts?
  67. T56 Coversion
  68. Shifter Rattling
  69. Centerforce DFX failure after 2.5K and 11 months.
  70. Reverse Inhibit Soleniod
  71. What is a T56 worth???
  72. Old SBC and T56
  73. Helpe needed ASAP shifting problems CTS-V
  74. clutch problems
  75. Rebuilt T56 or go 4L80E? good T56 rebuilders for high HP
  76. hurst billet plus centering springs
  77. Speedometer Problem after Conversion
  78. tremec tko 600
  79. Tick Performance Adj. Master???
  80. Drill mod Review: What not to do & End resluts
  81. uhh 4gear grind, and wouldent go into 2nd.
  82. Clutch Problems with 7k+rpm shifts. story inside!
  83. T-56 & v6
  84. Clutch sliping because of Oil?
  85. clutch
  86. T-56 Rebuild
  87. ram twin disc question?
  88. Clutch suggestions
  89. Trouble with clutch slave cylinder install
  90. What do I need to mate a 5.3 LH6 to a t56?
  91. Textralia After 6K Miles What Happened
  92. CTS-V supercharged LSA clutch 6 or 8-bolt?
  93. Stuck in 4th please help
  94. New Clutch Needed... Suggestions? - '97 Formula
  95. What bellhousing do I need?
  96. Any last minute advice - QM 7.25" 3-disc going in Friday
  97. Pressure Plate Bolts
  98. New master, line, and slave still wont shift at WOT
  99. Need advice. Possibly the clutch.
  100. A4 crossmember for T56?
  101. Opinions please! M6 Trans problem
  102. Is this a factory Hurst shifter?
  103. What connector did I just break on my T56?
  104. clutch issues any ideas?
  105. Used Pressure Plates?
  106. trans grind new clutch and higher rpms
  107. 0z700 Installed, Not disengaging.
  108. New to the 6 Speed world 99TA
  109. Ls7 Clutch breakin period?
  110. Car wants to roll when trying to put into gear??
  111. Had a drivetrain mishap, need some help
  112. No Reverse!
  113. Help Heard/Felt Loud Clunk after Hard Shifting
  114. T-56 clutch swap is a PITA
  115. Best deal on monster clutch
  116. Do i shim a slave for ls7 clutch?
  117. Trans question
  118. M12 shiftiing a reverse issues! PLEASE HELP
  119. Clutch and flywheel help_
  120. annoyed with my Tick adjustable
  121. Help me out!!! Clutch problems (after my dad borrowed car)
  122. torque spec?
  123. need adjustable master cyl for lt1
  124. M6 won't shift into reverse every time
  125. Throw out bearing???
  126. Another Tick Master Cylinder thread
  127. Stupid Question........
  128. Gouged Throwout Bearing
  129. 5th gear grind
  130. Changing clutch fluid
  131. 781rwhp
  132. Clutch hose question..
  133. T56 cost?
  134. HELP!!! hydraulic line disconnect tool needed!!!
  135. Cant Quick Shift........ i tried searching
  136. Textralia triple disc help - why is the slave different?
  137. ANYONE know how I can send Harlan a PM?
  138. grind going into 2nd and 4th....
  139. 9 in. driveshaft measurements
  140. ls6 clutch or ls7
  141. McLeod RXT/RST Users: Did you need the 1373 bearing?
  142. ls3 clutch flywheel fit ls1?
  143. Keep the Motor From Turning?
  144. rockland gear no walk bushing
  145. How to bypass the clutch switch??
  146. does a clutch have to break in/ and bumpy feeling why?
  147. anyone try an act ls1 clutch?
  148. drill mod Q
  149. Will this work?
  150. So...if you mishift a t56, what breaks in the tranny?
  151. dumb question on tq arm mount
  152. What is holding me back???
  153. weird noise coming from clutch..*Videos*
  154. Detailed MGW shifter pictures
  155. how do you use the mity vac on clutches? NEED HELP ASAP
  156. need a slave cylinder..
  157. LS7 Questions.
  158. need how-to for t56
  159. how to adjust McLeod street twin pedal
  160. Flushing the tranny fluid gives smoother shifting?
  161. clunking trans??
  162. Local shop rebuilding T56, which parts to upgrade?
  163. clutch master cylinder removal
  164. clutch master cylinder removal
  165. reverse synchro?'s
  166. Clutch Sticking Issues: Help Me Out
  167. 750+rwhp Cars
  168. New Drivetrain????
  169. i need a complete clutch kit by thursday
  170. anyone with an F1 cromoly and a tex come in
  171. Tranny out? Or just a hydraulic/cylinder issue?
  172. thought it was fixed, but its not, noise when turning,,, grinding, howling
  173. IS ther a difference i9n slave cylinders between 97-02?
  174. Clutch Pedal Spring
  175. Ever just change the clutch disk and not the press plate/flywheel?
  176. How Do I Test the Speed Sensor?
  177. Where can I find this shift knob?
  178. 06 vette ls1...what tranny?
  179. Slave Cyl Fluid Level Question
  180. Hurst Shifter Install...Two Issues
  181. Help please, cant shift at high rpms
  182. Will NOT go in reverse
  183. Stuck in 4th!!!
  184. Monster Level 3 break in impressions
  185. hard clutch pedal
  186. ?'s for pro 5.0 users
  187. Sticking Clutch Pedal
  188. spec 3+ to ls7 review
  189. T56 swap into a 69 Camaro.. NEEDING HELP
  190. Getting best mileage m6, cam
  191. Aftermarket Clutch Pedal Assembly
  192. Manual Transmission Fluid
  193. While I Have my Tranny Out - Pilot Bearing and Grinding Question
  194. Clutch fork or throwout problem?? (95 T56)
  195. Problems with clutch assembly
  196. Using a A4 harness on a 6 speed
  197. Houston Area: Good place to install a clutch
  198. mgw shifter!!!
  199. T-56 ?sss
  200. bellhousing questions! measurements needed!
  201. Hard to Put in Gear
  202. Monster/Tick guys.....
  203. Monster Clutch/Transmission issues?
  204. should my new clutch kick in right away
  205. How to align shift forks and rails to inset guide pin for t56
  206. Hurst shifter install tips for newbe?
  207. T5 question
  208. New GM slave already leaking!!!
  209. T56 bolt question
  210. LS7 clutch with billet flywheel: will it work?
  211. Need Torque Specs For Shifter Assembly!
  212. no idea if this is the right section, or if its been posted....
  213. B&M Ripper shifter
  214. Harlan 2 step problems
  215. slave bleeder thread
  216. broken bolt in BAD spot!!!!!!
  217. ls7 or oz700
  218. slipping with et streets?
  219. pedal assembly question
  220. Inexpensive RWD manual tranny for ls1...
  221. Need help with DLF Number
  222. Best fluid to use…
  223. Anyone else have this problem with their OEM slave?
  224. 408 going T-56
  225. time for a new clutch?
  226. What causes harder 3-4 shifts? oil??
  227. help just put a t56 in my car ami gonna have a drive shaft issue
  228. Leaky Mcleod Billet Slave
  229. Mysterious Leak
  230. Clutch setups?
  231. oil on clutch
  232. What clutch and parts should i get
  233. Clutch bleed problem
  234. stuck in fourth.....
  235. mityvac T-56 question
  236. transmission to bellhousing dowel pins
  237. master cylinder bench bleed? how?
  238. Pilot Bearing Help!
  239. Textralia EXO-SKEL Overkill for 400rwhp?
  240. Vibration in the shifter. Please help!
  241. Clutch Info Please
  242. need a 6 speed built. BY A SPONSOR
  243. wierd problem after running hard..
  244. Throwing 3 SES codes after changing clutch.
  245. Self adjusting vs. non adjustable clutch
  246. Questions about B&M ripper
  247. Question about fluid and shift pad w/ photos
  248. Flywheel and clutch dont fit. HELP!
  249. HELP! Having trouble taking the rear output shaft seal out
  250. test and tune for LTXshootout = FAIL!!!!!!!!!!!!!!
