- leaking problem any ideas....
- Has anyone messed up doing the drill mod?
- tranny tech or SPEC CLUTCH tech needed in this thread
- Quick Clutch Question
- Textralia Clutch 0Z 700 Questions.
- tranny/clutch vibration?
- Inconsistent Clutch - Help please!
- What clutch fluid to buy?
- Anyone have any experience with LUK products?
- how to properly adjust master cylinder?
- what to replace with tranny out
- Tranny Bolts - What's the Secret?
- cant get my clutch bleed any sugestions
- Synthetic brake fluid in a Mcleod master?
- Quick master cylinder question
- Benefits of Chromoly vs Billet Steel Flywheel
- t56 in 69 c10
- Monster Level 5 feedback please
- GOT MY NEW TRANY TR6060 (T56 Magnum)
- Yes, Another Squeal Thread, But......
- Clutch for Drifting Abuse
- Uh Oh something broke - help
- My clutch still wont work!
- Time for a rebuild??
- Tranny Swap
- I only have 4th Gear??? HELP!
- driveshaft bushing
- 3rd gear shift fork?
- Clutch question?
- Tick Master Cylinder installed
- 2002 LS1 Master on LT1 T56?
- Quick tail housing question
- clutch questions
- Help with cylinder issues I THINK..
- Aftermarket Slave?
- Anyone Here running a SPEC Clutch in your LT1
- Monster test at pinks in memphis!!!
- First time removing LS1/M6, have questions
- Monster stage 3
- Moster 3...Did i break it in wrong??
- clutch suggestions
- How can you tell if rear bushing/bearing is bad?
- Where is this noise coming from?!?
- 400hp lt1 clutch, please help!
- Damn Clutch!
- faceplated t56, is it right for me?
- Which Mcleod to get for 850rwtq?
- Is there a trick to remove the rear transmission seal?
- Falls out of gear?
- How DO you KNow...
- number for pro 5.0?
- T56 Complete Rebuild Kit?
- ls7 install questions...
- t56 rattle at idle
- T56 problem
- car got rear ended and now cant shift into 1st or reverse
- Is T56 messed up?
- car isn't going into gear....
- tickshift master cylinder installed
- which would you pick?
- Is my slave gone now?
- Input shaft diameter?
- What is making this noise?
- What I Broke
- reverse lockout gone bad?
- 02 Camaro clutch want to stay on the floor
- Need help fixing my tail shaft housing??? HELP
- Warranty Opinions
- Missed 2nd-3rd in a C5
- Clutch Question???
- Monster stage 3 install.. my thoughts
- Reverse Lights come on Slammin 3rd
- Needed: Slave cylinder
- shifting issue with 9 inch with locker????
- 4l60e to a t56 problem
- My method of bleed Tick MC on the cheap
- Rear Main Seal Leak
- Clutch chatter?
- excess shifter rail movement
- A 6speed tranny that will hold your F/I or Nitrous power!!
- Pipe/tube from slave to braided line?
- bled my system, not the pedal feels limp
- What clutch for a slightly potent LT1?
- Is it toast?
- Did I do that???? Weak 1-2 shift...
- Reverse lockout Solenoid..
- McLeod RST - balance?
- Tune out the skip-shift in Michigan?
- 4th gear grind/scratch..just want some backup
- six speed transmission mount for 99 ss
- GMPP Flywheel...will this work?
- How does this Pressure Plate look?
- Master cyl removal...
- Question about M6s.
- T56 tail housing interchange help?!
- Transmission will not go into gear
- Fairly new clutch problem
- Best Clutch?? Whadaya think??
- Drag runs = 1st and 3rd grinding...works fine now...why?
- OK shim help
- Clutch issues. Insight please!
- Whats the best M6
- help diagnose my clutch issue
- Lt1 t56 pedel help
- Grinding into all gears
- Horsepower and stock T56
- What is the proper torque procedure for ARP Flywheel bolts?
- Shim?
- Torque spec's on flywheel and PP?
- New clutch...and flywheel?
- ls7 pressure plate machining
- ls2 clutch kit with ls1/t56 will this work??
- replacing clutch with OE parts?? Help
- McLeod 75123
- clutch hydraulics
- Two questions an I need help!!
- hurst
- My Car wont go into gear
- steel fork ??
- RAM Clutch and Flywheel help
- t56 swap help
- MGW Shifter - No Limit Stops
- How do i get ahold of Textraila ?
- any info for monster half stages?
- What Flywheel with Spec 3?
- what trans for H/C/I car?? mm6 or mn12?
- Ram Powergrip HD clutch
- Leak/1st gear issues
- Another Monster/Tick success
- HELP! Clutch hydraulics failed
- HELP throwout bearing part # needed
- Need input on Monster stg 3
- monster clutch in and it feels great and the tick master rocks
- 96 ws6-need a new clutch! need some input....
- correct autozone slave?
- how do you launh your 6speed, help this newbie hook
- Bent 3-4 Fork. Upgrading, need advice.
- post pro 5.0 install... some newb ?'s
- weird noise in 6th gear
- 500 mile break in, how important?
- what shifter to buy!!
- T56 Swap, price?
- Removing tail housing in car ...
- Did Spec change their PP design?
- Looking for a new worked T56 for Nitrous Vette
- Clutch chatter ???????
- Another question about my clutch swap...hydro question
- SFI #'s for Monster Clutch
- clutch pedal help???
- a4 to m6 question
- Help with taking the bell housing off
- T56 Interchangable parts? LS1/LT1 fbody, Vette, GTO
- LS1 T56 to LT1
- Camaro vs. Corvette internal slave
- Monster Flywheel question
- brakes are stiff (makes it hard to drive)
- Clutch Which one i am new to ls1 6 speed
- "Wheezing" bearing noise
- Short Stick for B&M Ripper?
- TKO600 5spd syncro crunch uprated parts?
- First time mityvac user here. Hate to start new thread.
- Do they make a Dog Box for the LS1 Fbody?
- Help: clutch slippage problems during roadracing
- t-56 issues (noob)
- anyone ever had this happen??
- Pilot bearing install question...
- noob here please help
- T56 Wiring question...
- Monster LVL 3 and chromemoly flywheel on!
- what is this?
- TR-6060 (or t-56 magnum)
- what's the purpose of this "hose"
- Clutch pedal return spring
- double cluthing
- 6 speed swap questions (5.0 shifter, and rls)
- Is my master Cylinder done?
- Do you like your shifter angled towards you?
- Master / Slave measurements
- My pet monster!
- Dot 5 BF can't be mixed with dot 3?
- Noise in t56 gto tranny in TA
- m6 problems any ideas ?
- G.t.o t-56
- In middle of LS7 clutch swap, need help
- Gmt 56
- Small leak from rear of tranny ....
- trying to find a tranny builder
- does anyone maybe know why 2nd gear not working
- clutch bleeding - bad slave ?
- Leak from rear of tranny. Need input
- Squeak when pulling out
- Had it with this Monster Clutch
- Shifter to T56 Bushing Question
- MN12 t56..what sensor is on the passenger side of the trans?
- Flywheel question?
- Difficulty level of installing slave cylinder?
- 1998 6speeds into a 1996 5 speeds
- Questions about my trans/clutch job...new problem possibly
- Ticks Master cylinder installed?
- Oreilly Slave Cylinder
- TickShift trannies?
- Shifter off tranny??
- gto t56 in f-body, LOL as expected search didnt help.........
- what flywheels work with the ls7 clutch?
- SPEC LS9/ZR-1 Super Twin Billet Multidisc Clutch and Flywheel Assemblies
- Choose my clutch....
- please help diagnose tranny noise!! (video inside)
- 6spd People come in !!!
- '09 cts-v 550hp????
- what brake fluid is best for the clutch master
- Purpose of adjustable slave?
- clutch upgrade time, Please Chime in
- Short Shift Stick
- which one is the correct pressure plate bolt
- Part #Clutch Return Bushing
- clutch and pressure plate answer A.S.A.P.
- Stock Measurement ???
- Help: Clutch pedal Light all of a sudden?
- Question about mity vac bleeding from slave bleeder
- how much hp to the wheels can a stock t-56 with a good clutch withstand?
- Twisted splines on my Viper shaft
- After market T-56 rebuilds, MUST READ...
- Classic Tube Clutch line, Drop the tranny?
- Question on minimum horizontal distance in T56 removal
- problem with t-56 gears
- What sensor is this???
- How strong is a T56? Same T56 as in a Cobra?
- noob hearing "new" noise from Pro 5.0 shifter
- New Clutch Engages at the top...WTF
- drill mod coming up. wish me luck!!!
- Clutch noise when pedal is pressed down?
- Replace syncoro's in T56
- Possible dissengagement issue? Please comment
- Torque arm bolt specs
- shift knob
- Can someone give me a measurement off a T56 please?
- Cadillac CTS-V T-56 question
- Huge Clutch Issue (FML)
- Problem going into 3rd at top of 2nd.
- reverse lights
- Clutch not fully disengaging...yes ive searched
- SBC to LS1 trans?
- Do all cars have skip shift/removing from tranny?
- Problems after Tick master install
- what is this plug harness for?
- Car keeps on slipping out of third gear, or not engaging..
- Difference in T56?
- Ls7 clutch went up in smoke.....suggestions on upgrade?
- McLeod Master Cylinder Rebuild??
- Where to buy....
