View Full Version : Manual Transmission
  1. Bleeding With Remot Bleeder??
  2. Spec Stg 3+ .. HEAVY AS HECK?!?
  3. help me diagnose my tranny problem...
  4. Anyone know where to get those "roselock" bolts?
  5. T56 Tailshaft Part Number
  6. Transmission Carnage (pics inside)
  7. Monster Clutch Co.
  8. M6 behind a '99 LQ4 will it work?
  9. Can anyone identify this Adjustable Master Cylinder?
  10. clutch acting up. how would i adjust freeplay?
  11. cllutch slip question
  12. Still can't get my clutch to work...
  13. t56 questions ..
  14. A4 to t56 swap?
  15. advice? slave and master changed
  16. Clutch bleed question
  17. LS7 clutch the latest GM clutch which mates to LS1 F-bodies?
  18. Tick Adjustable Master is the way to go. My thoughts.
  19. Are you local to Baton Rouge, LA?
  20. Scatter sheild?
  21. LS1 clutch discs. (where to get just discs)
  22. adjustable master?
  23. LS1 bell housing?
  24. New Flywheel?
  25. SES light during high RPM shifts-->
  26. Another Monster stage III install thread...
  27. What adj master cyl to buy???
  28. Texas Speed Now a Distributor for Monster Clutches!
  29. why is it?
  30. Question about 6 speed at the track
  31. Whining in 1-4 from T56,Take a look at these input/counter shaft gears
  32. HELP! anyone have this part?
  33. 99camaro t56 fit in a 98 corvette
  34. Installed my Tick Master cyl 2day
  35. clutch question
  36. cold shifting problem?
  37. Source for T56 used parts?
  38. Where does your clutch engage?
  39. How bad to solid motor mounts make a clutch swap?
  40. Clutch pedal pressure with and w/o master cyl cap???
  41. Attn: Transmission & clutch gurus
  42. Clutch & Flywheel differences??
  43. Tranny going out?
  44. happy with pro 5.0 shifter length?
  45. No mees, no fuss bleeder line, no wrench needed
  46. Clutch issue need input!!!
  47. Master cylinder reservior replacement???
  48. wont shift at hi rpm?
  49. Strange grinding noise from T56 LT1
  50. Quick ?-Clutch Fluid
  51. Luk Stg. 2 clutch
  52. Can't shift on WOT RUNS! HELP
  53. M6 conversion question
  54. Tick Speedbleeder leaking not into slave
  55. Trans Locked Up???
  56. T56 rebuild ?'s
  57. Need some input on swapping from auto to stick.
  58. Torque numbers????PLEASE!!!
  59. Stick sizes; smaller than 6"(WS6 store)
  60. reverse lockout issue after tailshaft housing removal
  61. popped out of gear. Clutch?
  62. I need synchronizers for 02 T/A
  63. Skip Shift Eliminator...
  64. Countershaft??
  65. will pro 50 shifter from a mustang t-5 work with a t-56?
  66. Can't get all air out of the clutch master...
  67. 6 spd upgrades
  68. slave and master cylinder question?
  69. WTF..plastic?!?!?
  70. Shifting into 4th/rear end rattle issues
  71. No movement after t56 conversion
  72. Another bleeder valve question
  73. GTO MN12 in my F-Body : Problems, Help
  74. anyone tried Autozone slave or master cyls?
  75. 5th/6th gear puller?
  76. MGW shifter Installed
  77. Best/cheapest Master???
  78. Poll clutch master or new slave
  79. ls1 and lt1 bellhousing the same?
  80. REVIEW: Textralia and Tick MC *PICS*
  81. Traction Control on 98's?
  82. Need your thoughts!
  83. who builds a good T56 these day?
  84. T-56 Rebuild Companies
  85. 5th gear just grinds in gear
  86. Clutch Dis-Engagement issues
  87. any reviews for tick master's
  88. Rockland Tailshaft bushing
  89. Need Some Serious Feedback Please
  90. factory shifter question
  91. MGW Shifter vibration
  92. New Clutch
  93. clutch change write ups anyone!??
  94. Short throw Shifter
  95. Need Tranny parts
  96. Gasket to quiet down the pro 5.0
  97. gto and fbody slave cylinder
  98. fidanza kevlar twin disk clutches?
  99. Tick bleed line: Where to mount
  100. anyone ever rebuild a Mcleod master cylinder
  101. Question on what is this shifter and t -56 transmission is from
  102. b&m shifter???
  103. tranny swap price?
  104. Check out my new Centerforce clutch
  105. Help...GTO swap guys step in
  106. Needing T-56 parts....
  107. Gear recommendations
  108. Level 2 tranny grinds
  109. T56 with 2 piece rear main 350
  110. GTO T56 - how many synchro friction rings?
  111. Just Installed Monster Stage 3
  112. which level monster?
  113. Braided line for the master
  114. Just broke the trani, happy birthday!
  115. Gettn better clutch... Get new flywheel?
  116. Ram Clutch Install Questions
  117. Grind After LS7 Clutch Install
  118. Help with a schizophrenic clutch please
  119. t56 swap
  120. Tick master cylinder pic request.
  121. LS7 Clutch/ ls2 flywheel what sponsor?
  122. Torque arm question
  123. large white switch under clutch pedal?
  124. crank from LS2 GTO work with T56?
  125. jericho 4 spd to ls2
  126. Down To Two Clutch Options
  127. t56 question
  128. Spec Clutches?
  129. Monster Clutch Level 6- why not
  130. T56 out of LT1 Camaro
  131. can't shift into reverse
  132. Need OEM tranny mount....
  133. Gto bellhousing
  134. strange sound question?
  135. Your thoughts on this flywheel?
  136. Cobra T56 in fbody
  137. my ls7 clutch in action :)
  138. Wanted LS1 style t56 Input shaft,Front cover and Bell housing
  139. T56 prob...
  140. Clutch only goes half way in
  141. A4 to M6 swap questions...
  142. trans issues
  143. Question on F-body factory shifter orientation for T-56
  144. ? on bleeding w/mity vac
  145. Bleeding the Clutch system
  146. wobbly shifter
  147. How I saved 300 bucks by making my own.
  148. Clutch problems
  149. Help!!
  150. LG solid bushing to thin?
  151. Pilot bearing ?
  152. my new monster clutch
  153. Will the MC RST clutch work with an LS2?
  154. what does this mean??
  155. VSS is not working after rebuilt T-56
  156. Clutch pedal assembly questions
  157. t56 shift linkage issue
  158. Search not working- T-56 max HP stock...
  159. Pedal sticks after drill mod.
  160. hard getting into gears after DS breakage
  161. How big of a loss in the 1/4 mile??
  162. Clutch question....
  163. lsx+t56 swap thread
  164. Noise and vibration......TOB?
  165. 2nd gear pop/grind LT1
  166. Shifting into the wrong gear?
  167. shifting issues
  168. Are any of these gears trashed?
  169. LS7, Spec 3+,RAM?????
  170. Where can J-Tools be purchased?
  171. Part # for LS2 M6 Bellhousing
  172. 2nd grinds occationally
  173. ls7 clutch
  174. A little update on the tranny rebuild
  175. Sound like the clutch or something more serious?
  176. Stripped Trans Mount Crossmember Bolt
  177. Stripped shifter bolts...what to do?
  178. ls6 or ls7 clutch??
  179. Hydraulic Fiasco Over, Slave Fixed My Sticky Clutch Pedal!
  180. ram powergrip hd questions
  181. Is there permanent damage?
  182. ok... YOU WIN YOU WIN
  183. Backwards mount GTO shifter?
  184. Help!
  185. how to bleed a 97 six speed???
  186. Exedy Twin Clutch Owners COME IN
  187. What clutch for a 02 Z06 ?
  188. Clutch Slip or Tranny Slip?
  189. Anybody pull trans without y-pipe?
  190. 6-spd. is one better than another?
  191. clutch problem
  192. Spec Stg 2 or 2+
  193. Transmission comparison.....
  194. T56 Swap... Help
  195. Clutch bleeder Valve.
  196. A4 to M6 Swap Gone Crazy Someone help
  197. Clutch for LT1 T56???
  198. quick question
  199. Manual ls1 pedals and manaul lt1 pedals
  200. LS1 Replacement vs. LS6 Part Numbers
  201. Royal Purple Syncromax in T56?
  202. How much do you know ?
  203. C5 Trans issue
  204. How hard is it to do the Drill mod
  205. 80+mph vibration
  206. T56 rebuild-want opinions-pics inside
  207. My car is "shaking" during clutch use
  208. T56 rebuilders near Dayton, Ohio
  209. weird take off{new clutch}
  210. Hydraulic/clutch issue?
  211. Slave?Clutch? Confusing
  212. Exedy (ls6) clutch - reviews & opinions?
  213. LS7 clutch with ls1 flywheel?
  214. Ram Master Cylinder vs McCloud Master vs Tick Performance
  215. now what ..help
  216. T-56 rebuild
  217. LT1 T56 in a 1989 GMC 1500?
  218. Switching transmission gears
  219. GTO Tranny problems?
  220. Who's selling the Quick Time bellhousing?
  221. Spec Super Twin review
  222. weird transmission noise
  223. Ram Powergrip HD
  224. Ordering Monster Level 3......
  225. HAHA, Stealership wants $510 just for labor to install slave!
  226. Short Throw Shifter of Choice
  227. LSx to Getrag 265?
  228. LS7 won't bite... McLeod, Ram, Tex?
  229. 5.3 to T5?
  230. HELP stumped
  231. Textralia Exo-Skel Revision
  232. Another Successful LS7 clutch install....
  233. Flywheel? steel or chromoly?
  234. 2nd gear is hard to get into.
  235. clutch question
  236. Will this clutch work from 08 Viper?
  237. Cartek Stage 8 Clutch setup? Who knows...
  238. Need bore diameter of clutch master
  239. A Sneak Preview of a Special Build We're Doing...
  240. 6 speed replacement help
  241. Drill Mod Writeup
  242. Is my clutch slipping? Symptoms inside...
  243. NEW CLUTCH PLATE - Textralia
  244. what to buy?
  245. Help Clutch change
  246. 5.3 LSx swap worries.
  247. question about fitment issues with T56 and LQ4's
  248. A4 Built to M6
  249. Tires move with clutch pushed down...
  250. Another tranny problem
