View Full Version : Manual Transmission
  1. Clutch Spring Removal - Help!
  2. Rebuilding a GM NP440 / NP 833 (A-833) 4spd to go behind and LSx
  3. HELP: T56 magnum Speedo adjustement
  4. T56 won't go from 6th to 5th, but fine 5th to 6th?!
  5. made 4 passes today in the 9's with a old spec 3i clutch
  6. SLP Skip Shift Eliminator install?
  7. Clutch Problems Help!
  8. t56 has me stumped.
  9. Re-Adjust Pro 5.0 ?
  10. T56 Rear Seal Question
  11. help to decide
  12. T56 input shaft needed
  13. Specs for gears
  14. T56 VSS signal...
  15. Reverse Problem
  16. Trans. going in saturday!
  17. Pulled trans and might have ripped wires..Help
  18. T56 for parts
  19. pro shifted t56
  20. Grinds going into 2nd.
  21. Need help solving...
  22. LS7 engagement is "delayed"
  23. Best place to get twin disc clutch rebuilt?
  24. 1st gear grinds t56
  25. input shaft bearing or throw out bearing? video inside
  26. my old spec 3I pulled a bunch of 1.4 60ft.s and a 1.38 60ft.
  27. Competition Clutch Stg2 - Troubleshooting
  28. how to tell for bad master or slave cylinders?
  29. 99 SS with factory hurst shift knob what's it mean??
  30. Opinion on fleabay clutch kits, anyone try?
  31. Transmission issues for engine swap..
  32. 3rd and 4th problems
  33. clutch or something else?
  34. Bad Clutch or pulley or belt slip?
  35. Ok. Wtf. I quit.
  36. Stumbled upon 3 T56s, help me identify them.
  37. LS9 Clutch torque rating
  38. trans/shifter noise
  39. Monster Clutch Co. End of Year Sale
  40. T56 got stuck in gear twice when I downshifted to a stop
  41. No speedo and Reverse lockout is wierd
  42. 4th gen f-body slave cyl/throwout bearing assembly ?'s
  43. Hooking up cruise control after A4>M6 tune
  44. RPM Transmissions Cyber Monday SALE!!!!!
  45. Gear for mph decisions- Roll racing
  46. Transmission front adapter plate question.
  47. Cant get front plate to slide on t56
  48. manual trans options
  49. Short throw shifter
  50. T56 Magnum Speedo Off
  51. Squeaking clutch pedal
  52. Pilot Bearing Question
  53. Attempting to rebuild a T56, can't get the counter shaft extension out
  54. HELP! What monster clutch is this????
  55. Need help deciding which T56
  56. Best Price on a Mcleod RXT?
  57. 1999 Z28 Possible Transmission Problem
  58. LQ4 flywheel?
  59. short throw shifters
  60. Clutch bleeding issues.... trying a Tick Master. $0.02 welcome
  61. Need a new clutch for my 2000 ss camaro!!!
  62. Calling Monster....
  63. Will long crank LQ4 bolt up to T10 4 speed?
  64. t56 Clutch Slave cylinder HELP, not Bolting up
  65. T56 conversion questions.
  66. Spec Clutches...
  67. ls7 clutch tick master questions
  68. T56's are junk?
  69. MGW vs Pro 5.0
  70. 01 C5Z Bent Shift Fork and 3rd Syncro issue?
  71. v6 t56 to ls1
  72. Random grinding and popping out of 2nd
  73. 60 foot/stock clutch
  74. BW T-56 won't go into gear after engine build
  75. 3-2 downshift did I hurt something
  76. Tick Performance!
  77. drivetrain folks step inside. need help.
  78. I need a t-56!! read
  79. Flywheel to Crank bolt pattern
  80. urgent help with TR6060 needed
  81. Clutch sticks question
  82. some problems
  83. clutch problems in morning
  84. 99 TA clutch peddle pushrod clip
  85. New clutch 200miles, drove hard now smells
  86. Can a T-56 be Used for Towing?
  87. a4 - m6 swap
  88. NASCAR mag bellhousings on LSx?
  89. T-56 Crossmember
  90. T6060
  91. clutch
  92. What do you guys think a t-56 is worth?
  93. t56 self rebuild possible?
  94. T56 input shaft Rockwell hardness?
  95. No 2nd gear 98 m6 ??????????
  96. Tore my T-56 apart...
  97. [DIY: TR6060 manual transmission teardown and rebuild]
  98. T56 Tail shaft knocking.
  99. LsX clutch selection help 650hp range
  100. Can someone answer this for me?
  101. Is this Textralia clutch any good. Oz700
  102. Just re-installed T56 and then....
  103. Suggestions on t56 trans
  104. TDP slave cylinder
  105. Pressure Plate Interchangability?
  106. LT1 T56 and LS6 engine
  107. Death of t56
  108. TDP tranny builds... Stg 3.
  109. Used T56 swap in during restoration
  110. Viper output shaft?
  111. Why does my clutch keep pulling air?
  112. Can you use a LS1 clutch in a LT1? Differences?
  113. Shifter issues after putting t56 back in
  114. 04 CTS-V T-56 Questions
  115. TK600 or T56 Magnum
  116. Transmission
  117. A4 to m6 swap?
  118. Anyone try the PPC Chromoly LS7 Flywheel?
  119. transmission fluid question
  120. Suddenly hard to get into reverse
  121. Sponsors.. What clutch for high RPM road racing?
  122. Faceplated T-56 opinions and questions!
  123. MPH gain 3.42 to 3.90/4.10 heavy car built motor
  124. What clutch should I go with?
  125. Swap T56 for lighter manual?
  126. 2000 V8 Clutch Pedal Question
  127. anyone heard of the Tranzilla T56 rebuilds? I got one and ????
  128. Monster level 1 clutch question. Quick help needed
  129. Thanks Tick Performance
  130. clutch choice
  131. bent alignment pin
  132. clutch upgrade
  133. t56 with 3rd gear synchro issues rebuild price??
  134. transmission grinding in 3rd n 4th gear.
  135. Take a look at this clutch for me?
  136. Strange clutch pedal issues
  137. T56 swap Tuning
  138. Not going into gear!
  139. Can I adapt a C5 remote bleeder to a C6?
  140. Oil Leak After Clutch Install
  141. New or rebuilt T56
  142. Stock Clutch? Suggestions Needed
  143. Slave Bolt question
  144. Slave Cylinder line removal!! cant get it!!!!
  145. LS7 clutch swap - need help!
  146. Aggrivating Leaks
  147. Centrifugal force clutch problem with too weak clutch fingers
  148. Who has used these wilwood pedals?
  149. Thanks Tick for recommending the McCloud RST twin
  150. Will it hold.
  151. Any M6 guys remove your parking brake?
  152. What if measurement "B" is greater than measurement"A" on clutch slave cylinder??
  153. identify clutch master cylinder.
  154. Need to lube input shaft?
  155. t56 to an4
  156. 3rd and 4th gear issues
  157. Tick performance stage 2 kit :(
  158. How many of you run a aftermarket bell housing?
  159. Need some guidance on my t56
  160. Where to get flywheel and clutch balanced?
  161. What would cause a master cylinder to not engage
  162. RPM Stage V T-56/McLeod RST twin disk clutch review
  163. Reservoir needed!!!
  164. Little Trouble with a Centerforce Dual Friction clutch
  165. Planning project
  166. T56 Grinding in 4th only when releasing clutch??
  167. high pitch whine
  168. Do i NEED a speed bleeder for new slave cylinder
  169. Which monster clutch
  170. Clutch talk
  171. Help with T56 rebuild?
  172. Odd Clunking/Popping Noise...
  173. monster stage 2 and 3 pressure plates
  174. Flywheel and clutch assembly weights-LT1?
  175. LS1 T56 Mainshaft surface
  176. Twisted splines on my slip yoke !
  177. Fun with AN fittings
  178. Whats the cost to have t56 assembled
  179. Best deal on a new T56?
  180. Is my monster clutch working right? vid inside.
  181. throwout bearing prep?
  182. bell housing dowel pins
  183. Need help choosing the right clutch for me
  184. Question on cracks found on T56 adapter plate
  185. ls1 4l60e to t56 swap I need help with cruise control
  186. which gear size for good launch 3.73 or 4.10?
  187. Installed Tick Master and now I'm getting code p0704
  188. car starts creeping with clutch depressed???!
  189. t-56 4th, 5th, 6th gear
  190. name that shifter
  191. Help with clutch...
  192. '99 lq4 swap into c5 corvette help!
  193. What shifter for GTO tranny in 70 Camaro
  194. Thanks SNL!
  195. New master and slave still no pedal, what are my options?
  196. clutch not fully disengaging
  197. T56 neutral safety wiring
  198. Clutch Slipping?
  199. Tick stage 2, Tick master, and Mcleod RST Twin installed >>>
  200. Monster Clutch Best Service TSP as well.
  201. Trans acting strange in cold weather
  202. Pedal assy from 5 speed 4th gen???????
  203. 2nd gear issues under load Please Help
  204. cant get tranny back in!!! help
  205. How to clean my clutch disc
  206. 99 Trans Am clutch master cylinder
  207. soft clutch problem
  208. Please help sovle shifting issues for good
  209. pedal stop ??
  210. How should it feel when shifting?
  211. LQ9/T56/Bellhousing/Mid Plate Questions
  212. GTO 6 speed in a 70 Camaro Possible???
  213. Buying new clutch, need help choosing
  214. T5 tranny on a ls1??
  215. Need a clutch/need advice
  216. T-56 Trans Capability
  217. Low clutch engagement after WOT RUNS!?!?!
  218. Cant get top right bolt out from t56 to bellhousing
  219. Triple Cone Synchros in F-body MM6?
  220. tick stage 2 t56...how much abuse?
  221. Just installed a MGW shifter.
  222. Do I need to shim?
  223. Monster twin disks
  224. 680hpīs at 6500 rpmīs what clutch
  225. Need some people to help me with my rebuild
  226. most affordable adapter for t400?
  227. CSC leaking
  228. Clutch engagement problems - T56/Spec Stage2
  229. Clutch hydraulics
  230. Monster Stage 5=amazing
  231. LT1/T56 clutch issues
  232. Monster stage 2 clutch chatter
  233. need help quick, engine won't turn over after transmission reinstall
  234. GM Factory External Slave?
  235. Monster Clutch Co. Halloween Sale
  236. Smellsl like food cooking?
  237. General Clutch Rebuild Questions
  238. Weird Sounds from Reinstalled Transmission
  239. 2 STEP or NOT at TRACK ?
  240. Vibration coming from shifter
  241. Alright this might be beating a dead horse but I need help
  242. t56 bolt sizes
  243. Resistance in the shifter.
  244. Which 1st gear for my car?
  245. Setup hold up?
  246. Weight of clutch discs
  247. LT1 t-56 clutch fork
  248. Lt1 t-56 to ls1 t-56
  249. t56 reverse lockout
  250. Possible bent output shaft
