View Full Version : Manual Transmission
  1. Tuet 1260 to LS!
  2. clutch issue.....
  3. New Master now very short pedal travel
  4. easy t56 question
  5. Pilot bearing chewed up the input shaft... HELP!!
  6. A4 to Saginaw 3 speed
  7. wheres the front torque arm mount bolt
  8. shift rail parts
  9. Parts needed for my new clutch?
  10. Can i usu stock fly with new clutch?
  11. Hey guys please help..
  12. any pics on bleeding the clutch???
  13. T-56 an cold weather ?
  14. Easy question
  15. transfer case/bell housing leak.
  16. I Need a clutch!
  17. help me ASAP mcleod master cylinder
  18. Pro 5.0 shifter Issue
  19. clutch problem, bad clutch slave cylinder ?
  20. Drill Mod And Now More Problems
  21. blowing fluid through rear seal. Driveshaft issue?
  22. help? bad slave cylindar?
  23. hurst billet plus bolt size?
  24. what does shift skip means??
  25. Clutch Question???
  26. Check out these lines on my new LS7 clutch
  27. Grinding issue....
  28. Need a smooth, streetable clutch for 500+HP
  29. Difference in flywheel weights... and "seat of the pants"
  30. tranny/clutch help
  31. getting ready to rebuild my t56 myself
  32. Drill Mod = Failure Need Help
  33. help with a throw out bearing
  34. down shifting... pls respond. thx
  35. centerforce clutches?
  36. Spec Super Twin pics
  37. Clutch Flywheel combo only?
  38. So, is there any possible scenario where my T56 gets stuck in gear...
  39. Looking @ a C5 with M6.. question?
  40. Viper T56 input shaft VS. LSx input shaft
  41. Throw out bearing
  42. Help!!!!!!!!!!!
  43. transmission mount ?
  44. how much rwhp can the LS7 clutch handle
  45. help I am in over my head
  46. LS1/LS6 Slave part number?
  47. Fidanza Flywheel question
  48. LS3 + TKO500 = What clutch and flywheel??
  49. Clutch Pedal Return Spring?
  50. my clutch blew a brand new slave cilinder
  51. T-56 tools
  52. Pilot bearing Puller Help!
  53. Spec clutch, worth it?
  54. switch on the clutch pedal?
  55. possible to get pro 5.0 shifter base gto setup?
  56. lt1 BRAND NEW slave leaking to bellhousing
  57. Is my clutch done???
  58. Trani Fluid
  59. automatic to 6-speed conversion
  60. B&M Ripper shifter new style & old style differences?
  61. G-force T-56 gears
  62. Mcleod Street Twin Horrible Chatter
  63. Is LTx flywheel same as SBC?
  64. Clutch Bleeding help!!!
  65. Please help. Clutch not fully engaging
  66. Adjusting "adjustable" Master Cylinder
  67. What speed/rpm for 6th gear???
  68. M6 Problem
  69. Midplate question cable clutch
  70. Wich throw out bearing for t-56
  71. not another clutch bleeding question!!
  72. what do u think Mcleod clutches
  73. Tranny Noises
  74. t-5 ??
  75. duel disk clutch install question
  76. pedal to the floor, not going in gear
  77. Clutch line question
  78. Grinds going into 4th after rebuild - only when shifting fast.
  79. T56 Clutch problem: Randomly pedal stiffens up and clutch starts to slip. Need help
  80. t56 questions
  81. Any reason not to do the drill mod?
  82. Throw Out Bearing
  83. Who has broken their C5 MM6/M12 transmission output shaft?
  84. Shifting issue still not solved...
  85. Too much weight bad for trans???
  86. slave cyclinder done?
  87. 16oz through the hydraulics, now what?
  88. rust on flywheel question..
  89. Clutch Recommendation...
  90. stock flywheel and spec stage 3+ ?
  91. T56 shifter hole question
  92. Input shaft T56, LT1, quick question
  93. Which Short Throw?
  94. noisy shifter with high rpms
  95. rebuild: no reverse on test shifting
  96. T-56 hop up
  97. Textralia 0Z700 Z-Grip?!?
  98. Bellhousing danger?
  99. Place to buy just clutch disc
  100. Need 6spd rebuild parts! where do i get them?
  101. Need some help
  102. Does RAM still make the 910 clutch kit without the VDS PP?
  103. HELP!!! Quick need trany to bellhousing torque specs
  104. I need some T56 measurements!!!
  105. question for Spec 3 oweners ?
  106. Trans issue help Houston
  107. Surface rust on flywheel & pressure plate
  108. T-56 Shimming Specs
  109. Anyone try these shifters?
  110. Not disingaging?
  111. How much is my stock T56 and stock 10 bolt worth?
  112. How many guys are using trans blankets?
  113. competition clutch
  114. Tick performance question
  115. I can finally shift!!! My dilemma has been solved! ( yay tick!!)
  116. Slave cylinder failing?
  117. Need 2nd opinion on failed master cylinder
  118. front offset lever roll pin not budging!!!
  119. flywheel question
  120. Textrailia Twin Disc Problems!!!
  121. Vibrations above 75 MPH
  122. T-56 rebuild manuals?
  123. T56 rebuilds/ 6 Speeds INC... where did they go?
  124. G.T.O shifter
  125. 350SBC w/ T56 Clutch??
  126. Difference between these two Ram clutchs?
  127. T56 gear grind when cold. Normal?
  128. clutch or tranny?
  129. Help!!!
  130. spec 3 or mcleod single
  131. Any news on pricing of twin disc clutch/flywheel in new CTS-V and ZR1's from GM?
  132. Adjustability of clutch engagement?
  133. Southbend Clutches, anyone else running them?
  134. Do I have a worn tailshaft bushing?
  135. Clutch suddenly will not disengage, changed master and slave, didnt work.
  136. couple questions
  137. Got my Tick master cylinder installed....
  138. How bad is the stock t56?
  139. Installed driveshaft, now tranny leak
  140. Changing a M6 to a A4?
  141. Pro 5.0 Install, problems with 2nd gear..
  142. Installing ls7... Question on slave/master cylinder
  143. Figure this out?!?!
  144. New Twin From ATC...I think this may be a winner !
  145. 06 6 Speed
  146. t-56 desperate help needed. Soo close.
  147. will an ls7 clutch work here? suggestions?
  148. LTx clutch recommendations
  149. Pilot Bearing removal issues
  150. How hard can I launch my 94 without breaking? obviously its opinions
  151. Buy a used clutch?
  152. Whats the min thickness for an LT1 flywheel?
  153. Clutch Recommendations
  154. What fits?T-56 yoke
  155. Spec Twin vs Tex Exo-Skel-If you have had both, please comment
  156. t56 noises
  157. Help:Where is the Clutch Bleeder?
  158. Spec 3 clutch stupid question
  159. Where do I get an LT4 PP?
  160. Short stick questions
  161. Clutch acting up
  162. Spec will not fully disengage
  163. compare between two GM and RAM
  164. few questions
  165. Drill mod question: not the usual
  166. G.T.O t-56 swap
  167. Question, need your help..
  168. HEEEELP!!!!! no 5th or 6th gear
  169. HELP-installing tranny today!
  170. lt1 to ls1 conversion
  171. LS6 Vs. LS7 Clutch
  172. reverse wont go in..
  173. 5th gear grind/vibration?
  174. need a part number or name for driveshaft balancer
  175. Trans noise...any ideas?
  176. Need help asap on shift knob removal
  177. How to make T56 hold up in high HP cars.
  178. t-56 swap questions
  179. New T5 clutch, makin more noise?
  180. Centerforce Dual Friction or LS7?
  181. Best remote bleeder and where to buy?
  182. Rebuilt Jasper Transmission???
  183. Replacing clutch - Should I replace t/o bearing too??
  184. Trans. fluid rec. by 6 spd trans. builders?
  185. 2 Cars, M6 and MN12-Which to use?
  186. Noise in transmission.....help please.
  187. Bronze Pilot Bushing
  188. LS7 clutch smell !! why ?
  189. T56 Not shifting properly after rebuild
  190. Recommend me a clutch!
  191. Actual power/performance loss with LS7 clutch?
  192. LS2 clutch ?'s
  193. Southbend Stage 2 clutch
  194. t56 Transmission to bellhousing bolts
  195. MGW + Pro 5.0 Review
  196. Shifter question
  197. Cheapest place to buy new billet flywheel.
  198. need some help
  199. looking for great shop
  200. clutch????? come on help me out pls
  201. clutch???
  202. Need some help, kinda bad.....
  203. Great Customer Service!
  204. Found my clutch problem
  205. New clutch!
  206. Textralia OZ 700
  207. Where to buy parts or rebuild kits?
  208. T56 bellhousing
  209. What clutch for 600+hp and 600+tq
  210. t56 swap using m6 tranny/engine harness (wiring questions)
  211. G.T.O.trans question
  212. Can this be done?? Tailhousing swap T56
  213. Clutch problems? Time for a new one?
  214. Help me pick a clutch for my setup (LT1 T56)
  215. Shimming questions
  216. regular 6 speed with big power
  217. Ram Powergrip HD
  218. Tick Master Cylinder Review/ Install Tips
  219. Hurst Billet vs. MGW
  220. Where can i buy a ls7 clutch cant find anyhwere
  221. which is the best for my application ?
  222. What do I do with used up clutches and pressure plates.
  223. Master cylinder problem?
  224. My tranny is NOT happy
  225. Possible to order a new throwout bearing?
  226. Six Speeds Inc?
  227. New T56
  228. Who makes GM clutches?
  229. Anyone know the physical dimensions of the T56?
  230. Missing gears, trans cold?
  231. Should i rebuild?
  232. wtf??? another clutch problem
  233. Help with connectors not connected to anything on tranny..
  234. people that have changed they`re clutch please look
  235. 5th gear grind
  236. HELP! Won't go into reverse!
  237. Converting a4 to m6... Whats the $$$?
  238. LS7 clutch or Centerforce Dual Friction?
  239. trans leak
  240. Time for a rebuild??
  241. Baddest of the bad T56 replacement!
  242. Tailshaft seal and loctite?
  243. Go pick up a copy of Camaro Performers mag
  244. depth of muncie 4 speed manual bellhousing ?
  245. I need a shifter bushing, where to purchase?
  246. Textraila Exo-Skell Slipping Help!
  247. Z grip texatraila!
  248. Some quick clutch questions 4 a newB
  249. Clutch/Flywheel combo LS7/LS2???
  250. Any Monster clutch updates or feedback?
