- can't downshift from 6th to 5th
- Spec 3 F1 flywheel Gap
- Good bang for the buck clutch?????
- Bench bleed?
- Trans Shop
- LT1 T56 Removal Question
- Dowel pins - where to buy???
- Clutch Issue...
- Pro 5.0 shifter rattling
- tranny issues or clutch?
- 3rd gear feels farther away
- Got transmission in....something not right yet though.
- Is it possible to adjust clutch pedal?
- Slave reservoir
- Crack Bleeder During Slave Install?
- Clutch Chatter
- Pilot bearing questions
- A little fun video..... Joe on the BUMPER in the Racecar
- 3rd gear problem
- Throw out bearing noise
- Clutch problems
- What do I need to do?
- About 1" vertical shifter movement normal?
- Strange discovery about my clutch and hydraulics...
- t56 with 4-10s
- Chevy Dealer Wont Tune For Swap
- Changing clutch. Can I just remove trans. and leave bellhousing bolted to block?
- t56 clutch&flywheel
- Shim needed w/ Centerforce 12" Dual Friction???
- About to get stage 4 spec, do I really need a new flywheel?
- grease the slave cylinder/throwout bearing assembly?
- LS3 mated to 1998 WS6 T56?
- Have you? Trans install
- Light weight clutch options for LS1/M3
- Has anyone replaced JUST the 3-4 Fork?
- Clutch Problems....
- McLeod twin disk with Ram adj master
- Please Identify Parts In Pic
- Shifter is lifting up
- M6 fluid change
- t-56/ls6 flywheel loose
- ls6 clutch
- Speedo gear...
- Car Won't Move
- 04 T-56 with 40k on it?
- *Transmission Experts I have a dilemma and need your help*
- Mc leod adjustable master position?
- Best place to order
- the drill mod didnt fix it
- Barely any pedal??
- ram adjustable master questions
- Got a problem
- Byunspeed Order- How long to wait?
- Ls2 / Ls7 swaped, now need more
- slave and master cylinder
- Pro 5.0 Problem
- MGW vs. B&M Ripper (F-body T-56 Shifters)
- Thanks Miti Vac
- bell housing to engine block
- problem with 6th
- what clutch too go with?
- Will 02 Z06 clutch work in 01 WS6?
- help, clutch slips after motor and tranny install
- Spec 3/Billet steel flyweel vs. ls7 clutch/ls2 flywheel
- Is this the proper T-56 lever setup?
- 01 LS1 looking for upgrade
- Re-use stock flywheel
- anyone use the slp line lock????
- Is Alum. flywheels good for track?
- New Clutch Problems
- RAM Muscle Car Clutch
- Part # for LS7 clutch ??
- trans/clutch issue?
- Ls7 clutch intall ?
- maybe syros?
- T-56 whining
- Horror Story...watch what pilot bearing you put in
- locked out of 3rd gear
- Couple of 6 speed swap questions
- grinding?
- Clutch problem
- Rebuild of McLeoud Street-Twin??
- Tranny hits the floor board on shifts
- m6 missing 5th gear
- Anyone elses clutch pedal breaking the floor?
- Neutral Safety Switch Hook Up/'72 Ss
- car wont start, dunno where to turn
- Slave Question
- FS: Faceplated T56 with Viper Input/Output Conversions
- Hydrulic clutch line disconnect tool... where to get it ?
- Gear play....
- Lou's short stick for pro 5.0
- New Special! Just Added. Check it out Clutch/Rebuild/Hydraulic Special
- Rubber o-ring on top of mainshaft...
- Ram hydraulic release bearing?
- Spec stage 1 for replacement ? Experience anyone ?
- clutch cylinder problem?
- Ls7 Clutch failure ???
- Shifting problem persists...
- Built T56 value
- Switching A4 to M6???
- Which Texralia
- D&D Viper T56, 6 gear grinding when letting out clutch? Wont stay in 6th!!
- stupid clutch stop fighting
- t56 running hot
- broken tailhousing where the torque arm mounts to the tranny!
- Textralia help...
- G.T.O T-56 trans
- LS1 t56 shifting problems
- DriveTrain Modification Question
- LT1 M6 release / TO bearing..
- Need Advice
- Another LS7 clutch issue...
- drill mod question
- centerforce clutch?
- Bellhousing To Engine Bolts
- Unexpected problem during clutch swap, cracked flywheel.
- anyone swapping to t56 conversion!
- GTO Bell Housing vs. Camaro Bell Housing
- Any experience with Cartek clutches?
- What kind of fluid????
- tranny problem? PIX*
- Textralia OZ700 X or Z grip
- What clutch
- cultch pedal problem need help
- WONT shift..need help
- Transmission making noise after clutch install 04 GTO M6
- How do you measure end play?
- What press tool can I use to remove the 2/3 gears
- Breaking throwout bearings...
- C5/CTS-V T56 rebuilder parts
- Transmission Coolers on Manuals???
- clutch help
- Tips for lining up the clutch
- LS6 pilot bushing different/longer than LS1 ?
- August Short Term Transmission Rebuild Special
- We are now a Ram Clutch Dealer. 5% off Clutches thru the end of August
- Time to get clutch WHAT ONE?
- short throw shifter
- Wantin a Manual???
- clutch fluid and other questions
- T56 Conversion Wiring..
- Clutch pumping up?
- My Clutch Is Sticking To The Floor When Im Trying To Race
- Cant wait to do the drill mod!
- Dead pedal issues....
- 3rd & 4th gear
- TEASER THREAD: Tick Performance's Revolutionary NEW Adjustable Master Cylinder
- Vibrations
- is it the tranny or gears
- need help with t56 reverse problem
- Another slave-master cylinder quick connect problem
- Don't need gear puller for 5th or 6th gear....
- Zoom Clutch Sliping!!! Help!!!
- 1st hard launch = problem!
- question on quick disconnect (getting frustrated)
- DFX chatter with 650 miles on break in?
- Spec 3+ or Spec 4 or Spec 5-Help me decide what's best for my app!
- pilot bushing question
- "Tighten" the clutch?
- Cannot bleed the clutch PLEASE ANSWER THIS
- Replace stock clutch with ls7
- wierd clutch noise
- Master hydraulic line wont plug into slave
- 1969 camaro t56 swap sbc
- Spec 3+ VS Spec 4
- Can Burnt Hydro Fluid Make Clutch Slip???
- T56 won't go into reverse
- Need a Spec Shim
- cant get my shift linkage right wtf!! help
- I may need a new clutch?
- !!!!help, pilot bushing!!!!!
- How the F do you get quicktime bellhousings to fit?
- Hp limit for stock t56?
- Is This Normal???
- Which Clutch 550rwhp
- trade auto harness for a manual harness
- socket stuck on slave bleeder
- Master to slave hose - where to find
- So many clutches! Please vote!
- Some wierd problems
- Textralia flywheel and spec clutch??
- GM LS1/LS6 flywheel thickness & clean-up specs?
- t-56 parts
- Remove Pilot Bearing With Grease?
- So far over 2000 miles on these gears and NO NOISE
- question on switches on pedals
- clutch sticking
- please help me
- Shifter Shakes in 3rd Gear
- What tools are needed ??????????
- LT1 pro 5.0 work in LS1?
- Losing Compression in My Clutch! Why?
- Short Shifter Question
- New rebuild Problems
- just installed ram powergrip clutch
- How can I remove the springs in my Hurst Billet?
- Master Cylinder Wet
- To all the Spec haters
- Clutch install
- all t56 guys please help if you've got one
- where to get clutch fork?
- slave issues
- any interest in a 5/6 and rev. lockout?
- T56 Rear Seal
- No 3rd gear but all others work!?!?!
- Help trans wont downshift and im out of ideas!!!
- Vibrations
- Clutch For my CAR expecting 800 Torq ( c6 )
- hard to put in gear (sometimes)
- LS-7 clutch set-up
- Weird trans noise shifting... ls1 t56
- What rpms should I cruise at?
- I am fed up
- LS7 Clutch problems (engage issue)
- clutch grabbing late?
- Is this a bad master?
- grinding when reved
- New Textralia OZ700-HD
- Pilot Bearing Tools Required
- problems with new mcleod twin disk
- clutch question
- T56 Manual in a 2.2L S10? Whats needed?
- Drill Mod '99 hydraulics?
- time for a new clutch, opinions
- ? about flwheel material
- t56 weird 5th problems bugging the hell outta me
- royal purple m6 fluid
- Can I put this Hurst Stick on my Factory Hurst Shifter?
- Transmission running hot?
- clunk from 1 to 2
- LS7 Clutch Disk Question...
- clutch install problems
- Textralia Disc?
- pros vs cons of turbo trans
- suggestion for those replacing master, learn from my mistake
- which bearing
- Clutch grabbing really hard and fast...
- Need help!!!
- anyone successfully put a TKO600 behind an LS?
- ls1 t56 into a lt1 a4 car
- LT1 / T56 Fork & Throwout Bearing Problems!
- T56 Rebuild Parts...
- lt1/t56 prob.
- Glad I replaced my stock shifter!
- Speedway T-56 LS1 Hydraulic Clutch Kit
- several weird M6 minor problems
- Six Speed Trans
