- ls2 slave and clutch into ls1?
- in a delema please help me out
- New Spec 2+ & pro 5.0 - No reverse
- Clutch Troubles!!!! Help Needed!!!!
- Clutch is too chattery half-engaged
- which clutch?
- Anyone want to trade trannys?
- muffler?!?!?!
- Might Vac bleed?
- Need a New Clutch - Spec 2 Short Life?
- paddle shift for t56
- pro 5.0 shifter... will it work from an 01 t/a to an ls1 corvette 6 speed?????
- Can't decide on clutch
- Diff between bleed, flush, and vacuum on clutch fluid system?
- T56 video
- trans problems
- Loctite for flywheel bolts?
- Help please
- QUICK: LS7 Clutch or Spec Stage 2???
- High mile T56?
- Best price on Fidanza?
- 6spd+Longtubes= I need help!
- 2nd gear
- Clutch is partially disengaging need advice
- Hesitation while accelerating
- Info About BOP Clutches Please
- need a measurement if ur d/s is out please..
- Is my clutch toast? SPEC 3 with lots pictures.
- to john at fuddle
- Difference between ls1/lt1
- Found this on McLeod MC
- need help w/ new clutch
- 2001 Z06 clutch....
- t56 bad bearing?
- six speed swap
- Shifter Bobbing
- skip shift..... is it all the same
- 6 spd Rebuild
- mcelod street twin grinding noises?
- T56 exhaust mount.
- shifting problem?
- Clutch return spring install tips
- What plug is this on t-56
- flywheel
- How do I check T56 tranny fluid?
- Bellhousing thread count
- Amsoil Torque-Drive Synthetic ATF
- Upper shifter plate interchangable??
- My Fourth Gear Went Out Help!
- new clutch slippage..ideas?
- Clutch suddenly won't engage
- Best Clutch for my LT1?
- I know another one but is this trans fluid ok to use in my transmission?
- clutch pedal on the floor
- Trans Grease?
- Wot Shifting Problem
- Slave cylinder shim question.
- 6 Speed Trans Fluid
- clutch problems
- 6 Speed Trans Fluid Quesion
- were can I get a new spec shim??
- sequential box for ls2 ?
- Shipping T-56 and flywheel/clutch
- T5 no reverse
- Ordering new parts for the tranny rebuild tomarrow...
- new LS7/LS2 clutch assembly engages to far out..??
- where to buy centerfoce clutch (12")
- Locked Six Speed
- how much play should yoke have?
- newb to the 6speed world
- 93 6spd to a 97
- 99 frc clutch won't hold
- Just installed WS6store short stick
- Car pops out of 2nd
- Gears going in hard!!!
- Got my Z Grip Textralia Clutch
- clutch gets so soft!!
- Who sells the stainless short stick?
- Help, Reverse wont hold!
- Hard to shift to third
- Need Help! ASAP Please Help!
- ram clutch rebuild, sorta dumb?
- Need Help Asap With M6 Swap!!!
- Mcloed RXT twin disk users help me out!!!
- Aftermarket Lighter Flywheels for LS7 Clutch?
- Trying to order lower shift boot from GMpartsdirect..
- M6 to A4 swap wireing
- Pressure Plate Bolts
- POLL:Please help me decide what clutch is best for my app!!!
- spec stage 3 replacement disc
- replace pilot bearing?
- what else should i do besides clutch and flywheel
- 1st gear grinding.. helpppp
- New clutch dosnt like to go into 1st 3rd 5th and reverse
- GM master acting like a McLoed?
- Slave Bad?
- spec 2 clutch toast after 10k miles...what now?
- Anyone ever tapped their bellhousing bolt threads?
- spec twin installed
- 5.3 or 6.0 manual tranny options
- LT1 t56 to LS1 t56 with pictures
- Just purchased a SPEC 1 clutch
- Will Not Go Into 2nd Gear At WOT..?
- please help
- Sensor HELP
- *HELP!!* New clutch, wont go into gear
- help with wat i think is the rong trane cros brase link to its a 96 m6 car
- RAM HD clutch slippage !?!?!?
- Where can i find torque specs?
- Tranny fluid coming out of bellhousing
- Salve To Master Line ??'s
- Zoom twin disc clutch(stage 2), any thoughts?
- Everyone who uses mcleod clutch come in please..
- Salve cylinder throw out bearing
- Upgrade clutch or wait..
- LS7 Clutch Where to buy?
- T56 help
- Spec Twin Disc Clutch USERS COME IN!!!
- Clutch won't release after install.
- Spec stage 3+ clutch issues under spray !
- clutch noise ?
- T56 Builders
- Might be a stupid question
- which slave cylinder??
- think i broke a tranny mount?
- anyone run this flywheel?
- LS1 T56 parts?
- Will Stock Slave Work With Ls7 Clutch?
- New Clutch Suggestions
- Clutch or something else...
- Silicone in Clutch Master Cylinder???
- LS7 clutch install advice - FWIW
- Need clutch help... hydraulics aren't releasing the clutch at high rpms...
- Grinding with letting OFF the clutch...
- Quicktime bellhousing
- t5 swap FLYWHEEL QUESTIONS
- T56 carnage from the dyno...what happened?
- Can the "updated 01-02" slave cylinde be visually identified??
- filling tans up
- pilot bearing ???
- Track / clutch question
- Corvette LS1 and F-body T56
- clutch or throw out bearing????
- Wow look at my flywheel!
- 3rd gear pop out + 4th gear sticking... damn it
- Valeo LT4 PP and Misc Disk? Flywheel?
- will my trans be blowing apart?
- Spec pressure plate + ram disc
- T56 6spd output shaft oil seal
- who else has this issue with a stage 2 clutch??
- Putting in new clutch
- reverse lockout part number
- Lookin for a short shifter...
- WTB T-56 FOR 01 z28
- clutch slipping??
- Street Legal TV's Article is out! Quickest and Fastest M6 Article
- Why is 3rd and 4th vibrating?
- pedal question
- best trans fluid to get
- ls7 clutch install problem?
- Clutch Not Acting Right!!!! HELP!!!
- what gear is 1:1 ratio
- I Need Help!
- Clutch grabbing high, pedal adjustment without master cylinder adjustment
- Is this an O-Ring for the Slave?
- Reverse problem...
- My T56 Swap *Pics* 56k Warning
- This shouldn't happen should it???
- Looks like i need a clutch few q's first tho
- trans top hat replacement
- Clutch hydraulics
- May Special "April Special's Extended"
- Clutch Problem, Plz Help!!!!!!!
- Part # For Hydrolic Hose
- REAL feedback needed - T-56, Twin disc clutch, peddle effort
- Want a new transmission mount, have some questions
- Dual disk clutch, flywheel and floater clean up?
- Now there is another problem with my M/C
- How Much Brake Fluid?
- Transmission Mount Help M6
- T56 help...
- quick drill mod question
- Maddog stage 3 clutch kit ?
- Centerforce clutch
- T56 problem after swap!
- finally starting tearing down the T56 today, pics inside! (warning 56k)
- Hydraulic adapters?
- Trans builders please come in, check out these pics
- Thank God for Adjustable Master Cylinders
- 4 Gen M6 pedal????
- Problem w/ Reverse T56
- Do I need a bellhousing?
- New clutch: Pedal Wont move
- Torque arm ideas?
- which clutch?
- time for a new clutch
- T5 inquiries
- Congrats Amber and Joe (SixSpeedsInc) on the new addition!!!
- torque arm came loose while driving ???
- Does LS7 Clutch,Flywheel,Pressure Plate come Balanced
- Going for 10's N/A and 9's on spray, Stay T56 or go TH400/Transbrake?
- do i have to cut the floor to fit the t56 on the 67?
- Clutch engagement problem???
- wiring help needed for swap
- clutch pedal?
- Still no 5th,6th or rev
- Hmmm Clutchs Clutchs Clutchs
- LS7 Clutch
- Drag Clutch Death Illustrated
- So this cant be normal.
- Having Problems.....
- Only Users Please Vds Vs Tex
- '69 Camaro 4-speed - wanting to go T56
- need help ??????
- ExoSkel trashed before 3k
- drill hole
- Whats the difference between early and newer T56 ?
- clutch and pressure plate
- My M6 swap saga.
- Throwout bearing clearence
- Slave Fluid change ruined my hydrolics
- Help Please!!!
- T56 vs. M4
- ? on B&M ripper
- Any of the Sponsors Rebuild Ford Trannys?
- slave cylinder help needed!
- Clutch Test: A must do!!
- Pulling 6th?
- clutch line and DRiveshaft?
- high whine sound from tranny??
- M6 Swap Underway
- clutch issues
- LUK gold clutch and flywheel junk?
- Losing Clutch Fluid
- Trying to install T56 to 99 LQ4 Motor
- Whining noise between gears
- Help, grinding noise when I push in the clutch
- Launching on a new LS7/LS2 combo
- ATTN: Spec Stage 1 users and ex-users
- wierd grinding noise at low speeds
- Anyone else wish their T56 ratios were better spread?
- Got my transmisson back form GEARBOX.ORG
- Pedals install
- Dust Cover Screws??
- Another SPEC prob. Maybe??!!
- Have A Look At My Clutch
- drill mod
- Anyone broke a Tex OZ700 clutch?
- Cheapest LS7 clutch kit?
