View Full Version : Manual Transmission
  1. drill mod
  2. Anyone broke a Tex OZ700 clutch?
  3. Cheapest LS7 clutch kit?
  4. HEHE... my Spec Twin :)
  5. bad clutch or bad slave?
  6. Another bleed thread advice please.
  7. need help with drive shaft
  8. CRAZY rattle sound when I first start to move.
  9. I cut down my hurst shifter.. nice mod
  10. Your choice for clutches
  11. clutch dragging
  12. t5 clutch
  13. torque arm mount
  14. Pro 5.0 question
  15. Output shaft bushing??
  16. Pressure bleeding or vacuum bleeding clutch questions
  17. Clutch Fluid Questions
  18. need help
  19. Ls7clutch + No2 = ?
  20. t-56 oil
  21. LS7 clutch grabs low?
  22. Need Help !! Wierd Thump Noise Coming From The Tranny Area , Help.
  23. Clutch question?
  24. Couple t56 removal/installation questions
  25. Dark clutch fluid...
  26. blowproof bellhousing?
  27. Need help ASAP with hydraulic issue Please!!!!
  28. How do you tell what slave you have?
  29. Free Play on Clutch Petal
  30. what trannsmission
  31. What NOT to do with a T56
  32. Textralia Disk
  33. LT1 T56 Bbody problem
  34. Shifter Not Centering
  35. How does this clutch look
  36. Clutch options for turbo setup
  37. Shift Lights
  38. $1500 to spend
  39. Best Short Stick?
  40. Please, God, help me with this vibration
  41. m6-a4
  42. Clutch question
  43. Need C Clips for 95 Pedal assembly
  44. Will LT1 6-speed tranny fit LS1
  45. So What clutch do I get for my car?
  46. Symptoms of a bad master?
  47. all dexron/mercon III the same?
  48. Change clutch now or when it goes out?
  49. Lookin for best T56 Clutch under $500
  50. What do U Guys think of Spec 3 Clutch.
  51. Reverse lockout solenoid circuit questions
  52. t-56 starter
  53. Which clutch?
  54. fenco clutches- Any good?
  55. How many of you have....
  56. Centerforce clutches suck for my LS1
  57. do rebuilt trans. come with trans. fluid
  58. T56 fill question
  59. tranny install question
  60. 93' T56 Tag #'s ????
  61. T 56 pedals
  62. looking for a T-56 that can handle over 800 rwhp
  63. lt1 t56 bellhouisng
  64. SPEC 3 Hop after 500+
  65. Textralia OZ 700 Z SFI spec?
  66. Strange noise coming from trans under decel, any ideas?
  67. averege cost for cluth and flywheel install!
  68. Anyone know where to find a clutch hydraulic hose
  69. exoskel pp bolts
  70. who has the best deal on mcleod
  71. My Official Textralia OZ700 Z-grip Review
  72. giving it another try today..
  73. Lazy Pedal
  74. OK, to clear up some LS7 clutch and Flywheel ???'s
  75. replacing shifter top hat
  76. LS7 clutch and Fidanza FW
  77. New GM Twin Disc Clutch???
  78. Clutch Care..Yes I Read Sticky!!
  79. Have an Idea for a 3rd to 2nd gear lockout when Drag Racing
  80. Resurfacing Billet Steel Spec Flywheel
  81. how much hp can the stock 01 clutch handle?
  82. Spec Twin Disk
  83. LS7 Clutch Chattering
  84. The line from the master cylinder to the slave cylinder
  85. Who is running the Hurst shifter?
  86. ls7 clutch part number?
  87. pulling tranny with solid motor mounts
  88. LS7 Clutch installed.... need input!
  89. Stock clutch grabs high
  90. performance clutch
  91. 2nd gear grinds sometimes
  92. T 56 bolts
  93. Surface Pressure Plate
  94. T56 assembly question
  95. T56 problem with reverse and 6th
  96. Plastic Shields??
  97. Textrilia: What color is the X Grip and what color is the Z grip
  98. Is the Ls7 clutch for me?
  99. Any way to lockout 2nd gear over "X" mph?
  100. shifter springs
  101. quick clutch alignment tool question
  102. People who can shift FAST step in please.
  103. Any Insight?
  104. Just wanted to confirm LS2 Bellhousing?
  105. Help me decied what clutch disk to go with.
  106. LS7 Clutch ???
  107. LT1 Clutch Adjustment
  108. Identify my shifter please....
  109. skip shift solenoid problem?
  110. T-56 Shifting Vibration?
  111. just replaced clutch no 5th or reverse gear
  112. t-56 question
  113. Reccomendations for a cheap clutch
  114. Installing the new W2W built T56 + updated hydrualics Today any tips?
  115. Installed Ls7 Clutch Dosent Disengage
  116. Transmission clunk
  117. 1400 miles after SPEC Stage 2 clutch install.
  118. Question about spec clutch
  119. brass bushing question
  120. Textrallia Clutch... Some Questions
  121. Who has an adjustable master with their Ram Powergrip HD?
  122. Dropped A Screw Help?
  123. Looking for M6 shift knob with a built in switch
  124. LS2 Flywheel/starter
  125. Trans and Clutch Or Only Clutch??
  126. Worn trans mount?
  127. Can you replace a clutch disc with a different brand, where can I get a Mcleod disc?
  128. McLeod bell minus the motor plate?
  129. fluid displacement
  130. Spec 3+
  131. T5 or T56
  132. Ram Powergrip HD engagement problem
  133. Pro 5.0
  134. High RPM grind into 3rd gear?
  135. Which Flywheel
  136. Questions regarding Mcleod single disk.
  137. Clutch/Tranny problems?
  138. Reverse Lockout????
  139. 2nd gear questions
  140. salve cylinder bolts
  141. need help
  142. Centerforce Clutch and High Rpms
  143. Pressure LIne
  144. LS6 Gearing?
  145. Clutch question
  146. Need help with T56 Part numbers
  147. lq4 mated to a t56
  148. t56 questions.
  149. Will the LS7 hold?
  150. Gear-dependent vibrations
  151. master cylinder swap issue
  152. short shifter
  153. How do I adjust my linkage
  154. Trans mount
  155. No Pressure @ Clutch Pedal
  156. Will a 12" Clutch work in 99 SS?????
  157. need some clutch advice
  158. Pedal grabs high no slip!( Race vid too)
  159. grinding noise AT 1400RPMS
  160. Six Speeds Inc. New Special (You choose 1 of 3) until April 30th!!!
  161. Introducing TICKshift.com - New T56-only site from Tick Performance!
  162. Clutch?
  163. who has installed a spec stage2 clutch in their fbody?
  164. bleeding question
  165. cross member
  166. Quick question about replacing clutch fluid
  167. Revised Slave Cylinder?
  168. Quick clutch question.
  169. Transmission Discussion/Help
  170. How many miles did you get out of your RAM clutches.
  171. Need Opinions On "New" Fidanza Flywheel
  172. What does the shift detent do?
  173. i think its clutch issue and dont know how to search it.
  174. what adjustable master cylinder should i get
  175. Clutch stays on floor/not returning
  176. Rattle noise from bellhousing on my LT1/T56....
  177. ram adj master prob
  178. www.SixSpeedsInc.com is Back :)
  179. Quick Question
  180. Help with this problem
  181. What Rebuild Kit to get for my T-56.
  182. Manual Trans fluid
  183. ram pg hd or VDS
  184. Weird problem
  185. will is work?
  186. Hoping somebody knows this... 04 G35 6 spd tranny fluid
  187. LS1 vs LS7 clutch weight *PICS*
  188. this normal for t56?
  189. Stuck in 4th gear
  190. Tranny Bolt ?
  191. In need of a new t-56, who do ya'll recommend?
  192. T56 Mainshaft & Countershaft shimming
  193. Anyone ever have a problem attaching the braided line to the slave cylinder?
  194. No more sticking clutch pedal
  195. Which Slave ?
  196. Clutch Pedal Clip?
  197. best price/quality internet site for T56
  198. How can a tranny fluid change do this...?
  199. Pedal Help!!
  200. i need a new clutch! please help
  201. T-56
  202. Clutch Hydraulics Sucking In Air On High Rev Shifts
  203. B&M shifer problem
  204. Will it work without VSS?
  205. Pro 5.0 vs. stock shifter height drop
  206. Question about T-56 Hurst Shifter Please help!!
  207. how much to rebuild a t-56?
  208. t56 vets come on in
  209. Problems Clutch Or Bad Adjustment
  210. FS... Stock Trans
  211. T56 6th gear
  212. Need a pic of a stock T56 Bellhousing.
  213. Yella Terra w/ Ram hd..SHIM????
  214. bore size
  215. quick question
  216. Difference in TKO600 for GM and Ford?
  217. Break in Period for the LS7 Clutch...
  218. is it the clutch?
  219. Converting a T56 to be used on a SBC with an SBC style clutch?
  220. tranny gurus...5th gear needs help?!?
  221. V6 Camaro Clutch Kit
  222. Typical grinding noise for all T56s?
  223. Repairing The Shifter Boot Ring?
  224. Anyone using the McLeod RXT/RST clutch?
  225. RAM Muscle cars clutch for LT1
  226. SPEC 3+.....shocking
  227. Quick Time Performance Inc SFI Bellhousing - REVIEW
  228. ??? LUK gold clutch / Alum Flywheel
  229. ??? No 2nd 4th, or 6th gear???
  230. Z07 Clutch and flywheel or Ram H/D with Ram Steel Flywheel??
  231. adj pressure plate ??
  232. Textralia OZ700 X or Z Grip?
  233. 05 T56 Power Limit?
  234. T-56 grinding when I shift
  235. Spec clutch discs
  236. i think my stock clutch is going out !!!!
  237. question
  238. Slave first or master
  239. Pedal feel for clutches...
  240. need help
  241. T56 master cylinder
  242. Six Speeds Inc.com Website
  243. What's the deal with Tex single clutches not holding up?
  244. fyi LS7 held a 5k dump
  245. might go from 4l60e to t5. need help!
  246. T56 Trans Swap
  247. How about Spec Stage 2 Clutch
  248. What's wrong with Valvoline Synpower brake fluid (3/4)
  249. T56 trade - Should i do it?
  250. Converting an LT-1 T56 to work on an LS1
