- T56 swap
- ls2 to t56 transmission conversion
- Aftermarket T56 on an LSx?
- Just ordered my new tranny from Sixspeeds Inc
- ls7 clutch on a ls1
- I Need A T-56
- Time for new clutch?
- TO bearing/ Slave failure pics
- how to keep a tranny
- tell me what shifter i have
- 1993 fbodies had a different 6speed trans...
- WTF did I do wrong????
- I think I need to get a rebuild....
- 2004 z06 clutch issues
- M6 LT-1 to LS1 conversion
- fs or trade need lt1 t56
- T-56 from GTO???
- LS7 Clutch Swap
- spec 3 help
- What clutch for N20?
- t-56 with ls7 clutch problems
- C.A.T. Power Engine Parts
- ls2 flywheel
- Slave clyinder bolts
- how do you guys get into first gear?
- Wiring question for T-56 plugs????Please HELP
- Shifter cup differences GTO/F-Body
- Problems Shifting Gears
- 2 Step
- 2005 GTO Clutch ?s
- M6 Grinding?
- flywheel resurfacing Q
- Will the stock clutch hold????
- newbee t56 question
- what clutch for cam only car?
- engine to bellhousing plate?
- Knob on WS6Store short stick
- Clutch engagement issues...
- Part #'s for LS7 clutch & flywheel, best place to buy?
- What all needs to be changed when installing new clutch?
- noobie t56 question
- Prothane tranny mount mod
- Can I put this in a 96 T/A
- Silverado T56 swap, anyone out there?
- help i need a part number
- What twin dsk clutch setup?
- Why does clutch feel different at WOT?
- CAGS block off plug
- which clutch to buy? suggestions...
- reverse selonoid/ tran PICs
- clutch break in
- LG shift knob.
- new zr1 clutch compatibility???
- Tranny questions
- LSX motor and LT1 trans
- T56 Rebuild Question
- Serious clutch issues, need help
- how far have you pushed your stock T-56?
- question about torq arm
- *Guys in the Georgia area looking for a rebuild on their T-56!*
- any 408 guys with m6's running the stock 10 bolt on the street?
- 04 Z06 clutch problem..
- How much more fun would you say a M6 is over an A4
- "How to" for Drill mod??
- Vacuum bleeding the Clutch hydraulics, question
- Auto to manual trans swap?
- McLeod RST/RSX twin discs
- Slave cylinder?? Help!!
- Who Has A Centerforce Dual Friction Clutch?? (12")
- Noobie to manual transmissions
- is this a clutch problem?
- Ls7 Clutch Video
- spec stage 1 install/break in
- No revers...
- difference in hursts?
- auto or manual
- LS7 Clutch Install
- At what point is viper input shaft needed?
- clutch to handle 450rwhp + occassional N2O
- Hard reverse after head/cam.Why??
- Short and Sweet.
- Ls7 clutch, will it hold for me?
- Converting a LT1 T56 Tranny to Mate To A LS1.
- Removing transmission,..
- where can i get a stock flywheel????
- hard to put in reverse, shifter problem?
- Clutch Experts Help!!!!!
- LS7 Clutch Question
- ? about LS2 Flywheel
- Help me figure out what is wrong with my car v clutch hydrolics problem PICS!
- Problem Installing Tranny
- LS7 clutch/LS2 flywheel combo?
- gto m6 vs f body m6
- textralia question
- stiff reverse or speedo
- shifting problems at WOT!
- I am not sure if I should do it??????
- LS Block with a Tremec 600??? Where to start??
- LS7 Clutch Swap Problems
- Textralia Oz700 Z-grip Review
- Ram HDX
- compatability of new zr1 clutch in fbody?
- Leak in rear of T56...?
- which clutch?
- Question On Spec 3 + Clutch Please Help
- still having clutch problems
- need some help guys
- Need help with LT1 T56 info
- Worn Clutch or MS or SC..?? Help please!!
- Street Twin
- problems with new mcleod MC!!
- LS2 slave cylinder question
- M6 bolt-on cars. Post your times please.
- Sloppy Hurst Shifter ?
- T56 or TKO?
- how much hp can a t56 handle
- Big SPEC Sale at Tick Performance in January! FREE Shipping
- Spec dual update
- sticky trans
- Pro 5.0 LSS H Shifter Knob Angle
- Lous Short Shifter Question?
- Syncros Or Forks Or What??? Newbie Clueless
- Cost Of Used 6-speed For 98'z28 In Good Cond?
- Horrible noises!!!!!!!!!!!
- Thanks Six Speeds Inc!
- How much do I ask for a stock T-56 with 30k
- Flywheel/Clutch Compatiblity
- Tech Issues loading only page 1
- No Reverse???
- Anyone with a regular-length Pro 5.0 stick want to trade for a shortie?
- 4 -5 shift grinding
- Driving with Bad Clutch???
- 2008 Shop Info: What you guys want to know about Pricing, In house options and MORE!!
- HELP I had an blind man do my clutch install
- Made the A4 to M6 swap. Any way to hook up my reverse lights?
- 97 & 98 trans difference?
- REAL bad trans probelm M6 Smoking????
- A Crazy way to same $$$$$$$$$$$ that is a New Monthly Trivia Game:
- Flywheel Question!!!
- Need Tranny advice!
- Centerforce DFX
- pro 5.0 woah
- BOLTON WS6 need CLUTCH!!!!
- Ram HD Clutch Question
- Quartermaster 7.25" clutch ?s
- what clutch for an lt1
- need viper t56 to ls1 help!
- New N/A 6 Speed Record 9.11@150!!!
- shifting into first gear
- 4th to Reverse??
- clutch master resevoir
- Trouble shifting into 2nd
- I am between a Spec 3 and OZ 700
- Clutch problem?
- UMI S-stick
- What clutch for a 750-800whp c6 vette?
- The new ZR1 clutch.
- sticky clutch ??????
- LT1-T56 scatter sheild
- t56 rebuild......what level?
- a little help ls7 clutch installed
- which shifter is better hurst,pro 5.0, or b&m
- Any differences?
- Help Me Plz! Dd Acting Up!
- ?????LS7 clutch????
- Who Makes The Angled Spacer For T56 Shifters?
- Clutch Mystery
- I have a few questions!
- Question about Short Throw Shifter
- CRAZY Sale @ Tick Performance: EXTREME Viper T56 - $1400!
- master cylinder ?
- Throw Out Bearing or Transmission?
- Help!!! I think my RPS is toast!!!
- McLeoud Adj. Master vs. Ram Adj. Master
- Factory Hurst
- Question about shifter
- dumb master cylinder question
- type of trans fluid
- Why Is Bleeding A Clutch A PITA?
- Is it my car or does the stock shifter blow?
- McLeod Steet Twin Inspection
- clutch spline ?
- Big Problem??
- replacing clutch and master/slave. . .any write-ups???
- How do I know if its a hurst shifter?
- Spec Stage II+ fails
- This ever happen to anybody.
- slave vs master bleeding
- Starts in first gear (foot off of clutch pedal)???
- how to disconnect master from slave...... i have no white ring!!!
- Flywheel balancing question
- Confused with factory shifters
- M6 troubles
- Trouble hitting gears under hard acceleration
- i need shim help quick!!
- what flywheel to get?
- Simple Question.
- Help!!! Gto M6 To Ls1 .....
- Signs of Broken Motor Mounts?
- Yella Terra Ultra Light Flywheel and LS7 clutch?
- Alum Flywheel and clutch question
- good trans for 4.80 gears and 32" tires?
- Getrag trans in a fbody?
- Manual Trans Question, Regarding a T56
- Harlan Engineering
- I just bleed my clutch Now a funny vibration is happening??
- drill mod question
- sfi bellhousing
- FS Hurst Billet Plus Shifter!!!
- 02 6 sped driveshaf fit a 95 ta 6 speed
- what short throw should i get?
- Clutch Install Video Thread
- Does this look Normal???
- Texatralia EXO-SKEL users come in!!!
- Six Speeds Inc. New Years Hours
- Those with LS7 clutch whats you best 60'?
- Clutch system bleeding
- Why Does My Master Cylinder Reservoir Cap Keep Cracking???
- Just put in an OEM hurst... what a difference!
- Flywheel/ new clutch question
- Size of LS1 vs LS2 or 7 clutch
- Clutch Pedal Wont Move
- T56?
- C5 shift knob...thread pattern
- Hurst Hot Shift ATF in T56????
- Help: Poll What Clutch Would Be Best For My Application!?!?!?!?
- HELP!Why does my girlfriends car drive in NEUTRAL! Wont go in any gear...
- spec 5 clutch
- easy way to bleed
- Clutch issue (I read the FAQ, I swear!)
- F1 Racing Chromoly Flywheel
- Spec Stage 3+ Problems
- lt1 t56 on a 400 sbc
- shifter knowledge
- LT1/LS1 t-56 guestion
- Major Hydrolic Issue With 02 Z28
- P1810?? Help
- clutch issues, can you help me?
- New Clutch Question
- Mobil 1 trans fluid: Regular ATF or Synthetic?
- T56 Problems
- Clutch wont bleed, do I need adjustable master? (Centerforce Dual Friction)
- Anybody have GM part numbers for LS7 clutch/LS2 flywheel?
- my car 427 RWHP what cluth i need?
- Can't keep traction when launching
- wont bleed after LS7/LS2 swap (damn mccloed master)
- Amsoil MTF...
- Clutch Issues???
- Delrin Shift knob?
- 04 gto flacid clutch
