PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 [57] 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130
  1. GM LS1/LS6 flywheel thickness & clean-up specs?
  2. t-56 parts
  3. Remove Pilot Bearing With Grease?
  4. So far over 2000 miles on these gears and NO NOISE
  5. question on switches on pedals
  6. clutch sticking
  7. please help me
  8. Shifter Shakes in 3rd Gear
  9. What tools are needed ??????????
  10. LT1 pro 5.0 work in LS1?
  11. Losing Compression in My Clutch! Why?
  12. Short Shifter Question
  13. New rebuild Problems
  14. just installed ram powergrip clutch
  15. How can I remove the springs in my Hurst Billet?
  16. Master Cylinder Wet
  17. To all the Spec haters
  18. Clutch install
  19. all t56 guys please help if you've got one
  20. where to get clutch fork?
  21. slave issues
  22. any interest in a 5/6 and rev. lockout?
  23. T56 Rear Seal
  24. No 3rd gear but all others work!?!?!
  25. Help trans wont downshift and im out of ideas!!!
  26. Vibrations
  27. Clutch For my CAR expecting 800 Torq ( c6 )
  28. hard to put in gear (sometimes)
  29. LS-7 clutch set-up
  30. Weird trans noise shifting... ls1 t56
  31. What rpms should I cruise at?
  32. I am fed up
  33. LS7 Clutch problems (engage issue)
  34. clutch grabbing late?
  35. Is this a bad master?
  36. grinding when reved
  37. New Textralia OZ700-HD
  38. Pilot Bearing Tools Required
  39. problems with new mcleod twin disk
  40. clutch question
  41. T56 Manual in a 2.2L S10? Whats needed?
  42. Drill Mod '99 hydraulics?
  43. time for a new clutch, opinions
  44. ? about flwheel material
  45. t56 weird 5th problems bugging the hell outta me
  46. royal purple m6 fluid
  47. Can I put this Hurst Stick on my Factory Hurst Shifter?
  48. Transmission running hot?
  49. clunk from 1 to 2
  50. LS7 Clutch Disk Question...
  51. clutch install problems
  52. Textralia Disc?
  53. pros vs cons of turbo trans
  54. suggestion for those replacing master, learn from my mistake
  55. which bearing
  56. Clutch grabbing really hard and fast...
  57. Need help!!!
  58. anyone successfully put a TKO600 behind an LS?
  59. ls1 t56 into a lt1 a4 car
  60. LT1 / T56 Fork & Throwout Bearing Problems!
  61. T56 Rebuild Parts...
  62. lt1/t56 prob.
  63. Glad I replaced my stock shifter!
  64. Speedway T-56 LS1 Hydraulic Clutch Kit
  65. several weird M6 minor problems
  66. Six Speed Trans
  67. Broken 3rd Gear Blocker
  68. Preferred Trans mount ?
  69. Ram, Spec, or other?
  70. Ram Release Bearings questions????
  71. LT1 t56 swap
  72. Basic T56 Questions
  73. Installing master
  74. What is a good throwout bearing brand to get?
  75. Stock clutch life
  76. newb tranny swap question
  77. T56 Rebuild Yourself?
  78. Reverse Lockout and CAGS Solenoid
  79. Transmission noise
  80. Textralia Customer Service
  81. How much weight diff in these flywheels?
  82. Ordered the Mcleod Twin have some ?s
  83. Tranny bolts
  84. Noob Shift Questions
  85. Wont go into gear
  86. grinding noise when turning
  87. Bleeding Tool
  88. slave problems
  89. 95 LT1 and T56 in 68 camaro hydraulic questions.
  90. Which part is causing my chatter?
  91. Mcleod Street Twin w. Wilwood 1"?
  92. Where to find rubber mount?
  93. Power Tower Install
  94. LT1 Adjustable Master Cylinder
  95. 1rst gear shakes the whole car
  96. bleeding system anyone have suggestions
  97. T56 Skip Shift Solenoid Delete Plug
  98. help with tranny upgrade
  99. Mcleod master cly problem
  100. LS1Tech special! FREE SHIPPING on all T-56 parts @ D&D Performance
  101. Should I replace pilot bushing?
  102. T56 in 3rd gen, what drive shaft?????
  103. LT1 t56
  104. Clutch Problems
  105. lt1 t56 in a 99 trans am will it work?
  106. New Spec 3 installed
  107. T56 Problems
  108. t 56 questions
  109. grinding isue going into 1st?
  110. Will This Work????????
  111. "DEAD pedal syndrome?" will shim fix?
  112. Question about the t56.
  113. Reverse Lockout
  114. t56 rated to ?
  115. What clutch for street/drag strip?
  116. Clutch Question
  117. Rebuilt transmission problem: Can't downshift into third.
  118. Textralia Z Grip
  119. Rattles when I shut car off?
  120. Shift Forks and Rail Assembly
  121. 6 speed manual stuck in 4th!!
  122. Help me figure it out
  123. Anyway to tell if there is a Aftermarket clutch
  124. LT1 T56 behind an LS1
  125. what did I break?
  126. clutch issue
  127. Six Speeds Inc. is no longer selling online parts
  128. any rebuilders, 3 ls1 t56 cores for sale
  129. How to tell difference between slave cylinders
  130. rebuilt transmission probem, no first or second
  131. RPM Stage IV, problem
  132. Looking for T56 input shaft a bad one
  133. Master Cylinder - Causes of Failure?
  134. Transmission Damage from running something over?
  135. Tranny installation problem!
  136. Symptoms of a bad master cylinder
  137. Rev match 2nd gear
  138. output shaft spline problems
  139. Trouble finding master cylinder line for 99 Trans AM
  140. Clutch help!
  141. Mcleod RST vs RXT clutch
  142. Transmission fluid.....can it be a cause of this problem?
  143. Clutch or Trans
  144. Spec 3 Question
  145. t56 parts in stock? and diagram for t56
  146. T56 question
  147. t56 issues please help
  148. Flushing hypro system, any cleansers i can use.
  149. Strange Clutch Problems!!!
  150. Cheap LT1 clutch
  151. Worn Clutch - Would it cause this?
  152. T56 Grinds in 4th
  153. What are these items? Look at Pics!!!
  154. Spec Flywheel Issue
  155. crash box t56?
  156. McLeod Master Help!
  157. Who makes an adj. slave cylinder for 97 lt1?
  158. Tell Me About Your Ram Twin Disk Problems
  159. Need Some Help With Hydraulic Line
  160. does anyone need t56 cores i have three of them..
  161. Help with sticky clutch.
  162. LT1 A4 to LS1 T56
  163. Thoughts on clutches?
  164. New McLeod master cylinders... a review
  165. Spec stage one.
  166. T56 Transmission Leak...help needed!
  167. Looking for good T56 Rebuild Shop on East Coast
  168. lighter LS2/7 flywheel, any interest?
  169. exo-skel install nighmare any help...
  170. ls1 t56 slave cylinder?
  171. Finished the drill mod today. Afterthoughts inside
  172. Weird shift at dragstrip
  173. Welp broke my transmission!
  174. McLeod twin disk issues.
  175. Input shaft splines hitting the Pilot bearing...wrong bellhousing?
  176. hydraulic leak question??????
  177. Vibrations in shifter
  178. Need opinions, clutch or tranny problems?!?!
  179. dropped 7/16" socket into bell housing, how to remove?
  180. What flywheel for ls7 clutch
  181. slipping clutch
  182. Viper T56 in LT1 car?
  183. Clutch slipping
  184. pressure plate resurfacing????
  185. HELP, Lost "roll pin" while performing drill mod
  186. Vss..
  187. Need a new clutch, suggestions?
  188. Anyone "tight" with Mcleod Industries?
  189. T56 Issue... Reverse Block Plate??
  190. T56 won't bolt to bellhousing 3/8" gap.
  191. bleeding new slave resolution
  192. Textralia OZ700 Z grip on slicks with high dumps!?!?
  193. OK... help with a spec 3
  194. Grinding Noise in all gears under heavy throttle
  195. Lenco
  196. t 56 output shaft question
  197. Best brand of clutch fluid for performance
  198. Flywheel Shield?
  199. Clutch/Transmission Issues - Help Amber!
  200. Pilot Bearing Install???
  201. Rebuilding Trans
  202. Disengagement question: Ram powergrip HD needing slim on c5?
  203. 6.0 Install with T56, What is different from LS1?
  204. Torque Spec question
  205. How long to "break" it in for?
  206. 70k and having clutch replaced... master cyl required?
  207. McLeod Street Twin Spec Discs?
  208. Lost 5th 6th and reverse No noise, no anything... Ideas???
  209. Clutch Help!!!!
  210. how do you remove/install a new Slave cylinder?
  211. ls1 six speed into a lt1 auto car
  212. Some clutch master cylinder and "quick" disconnect Qs
  213. LS7 slave/throwout bearing
  214. Just completed L S7 Clutch install
  215. Clutch problem after break in?
  216. Clutch Failure -- Master Cylinder Valve?
  217. T56 Rebuild
  218. Where to buy a new FACTORY HURST shifter?
  219. Pressure Plate to Flywheel torque spec on a Textralia?
  220. Manual trans question
  221. will a master cylinder from a 00 camaro work for a 02 vette?
  222. Shifter Movement & banging noise in 1st and 2nd - already replaced trans and TQ mount
  223. need help. reverse lockout solenoid
  224. clutch woes
  225. HELP!! cant get clutch to bleed
  226. reverse lights dont come on
  227. Will this slave work?
  228. Need help asap! Problems with tranny/clutch...
  229. 3rd Gear issues....
  230. Another T 56 installation tip
  231. Bellhousing cracked??
  232. Who sells bell housings?
  233. Rockland std gear extension housing bushing
  234. 1000flywheel hp-T56?
  235. Ram Twin Clutch Questions
  236. Bleeder Valve - You wont believe this....
  237. Best Place to Buy Pro 5.0
  238. Cant go into 5th.
  239. 1st - 2nd Grinding :(
  240. New clutch and rebuilt trans
  241. Clutch fork problem?
  242. Bleeding question
  243. LS7 Flywheel Question
  244. Worth?
  245. non hydraulic tranny options?
  246. Shifting woes
  247. oz700 flywheel ?
  248. Would an adjustable master more slave travel?
  249. !$^@$%& McLeod Back order HELL #$%^%
  250. My Clutch, Stock?
