PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 [60] 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130
  1. Help please
  2. QUICK: LS7 Clutch or Spec Stage 2???
  3. High mile T56?
  4. Best price on Fidanza?
  5. 6spd+Longtubes= I need help!
  6. 2nd gear
  7. Clutch is partially disengaging need advice
  8. Hesitation while accelerating
  9. Info About BOP Clutches Please
  10. need a measurement if ur d/s is out please..
  11. Is my clutch toast? SPEC 3 with lots pictures.
  12. to john at fuddle
  13. Difference between ls1/lt1
  14. Found this on McLeod MC
  15. need help w/ new clutch
  16. 2001 Z06 clutch....
  17. t56 bad bearing?
  18. six speed swap
  19. Shifter Bobbing
  20. skip shift..... is it all the same
  21. 6 spd Rebuild
  22. mcelod street twin grinding noises?
  23. T56 exhaust mount.
  24. shifting problem?
  25. Clutch return spring install tips
  26. What plug is this on t-56
  27. flywheel
  28. How do I check T56 tranny fluid?
  29. Bellhousing thread count
  30. Amsoil Torque-Drive Synthetic ATF
  31. Upper shifter plate interchangable??
  32. My Fourth Gear Went Out Help!
  33. new clutch slippage..ideas?
  34. Clutch suddenly won't engage
  35. Best Clutch for my LT1?
  36. I know another one but is this trans fluid ok to use in my transmission?
  37. clutch pedal on the floor
  38. Trans Grease?
  39. Wot Shifting Problem
  40. Slave cylinder shim question.
  41. 6 Speed Trans Fluid
  42. clutch problems
  43. 6 Speed Trans Fluid Quesion
  44. were can I get a new spec shim??
  45. sequential box for ls2 ?
  46. Shipping T-56 and flywheel/clutch
  47. T5 no reverse
  48. Ordering new parts for the tranny rebuild tomarrow...
  49. new LS7/LS2 clutch assembly engages to far out..??
  50. where to buy centerfoce clutch (12")
  51. Locked Six Speed
  52. how much play should yoke have?
  53. newb to the 6speed world
  54. 93 6spd to a 97
  55. 99 frc clutch won't hold
  56. Just installed WS6store short stick
  57. Car pops out of 2nd
  58. Gears going in hard!!!
  59. Got my Z Grip Textralia Clutch
  60. clutch gets so soft!!
  61. Who sells the stainless short stick?
  62. Help, Reverse wont hold!
  63. Hard to shift to third
  64. Need Help! ASAP Please Help!
  65. ram clutch rebuild, sorta dumb?
  66. Need Help Asap With M6 Swap!!!
  67. Mcloed RXT twin disk users help me out!!!
  68. Aftermarket Lighter Flywheels for LS7 Clutch?
  69. Trying to order lower shift boot from GMpartsdirect..
  70. M6 to A4 swap wireing
  71. Pressure Plate Bolts
  72. POLL:Please help me decide what clutch is best for my app!!!
  73. spec stage 3 replacement disc
  74. replace pilot bearing?
  75. what else should i do besides clutch and flywheel
  76. 1st gear grinding.. helpppp
  77. New clutch dosnt like to go into 1st 3rd 5th and reverse
  78. GM master acting like a McLoed?
  79. Slave Bad?
  80. spec 2 clutch toast after 10k miles...what now?
  81. Anyone ever tapped their bellhousing bolt threads?
  82. spec twin installed
  83. 5.3 or 6.0 manual tranny options
  84. LT1 t56 to LS1 t56 with pictures
  85. Just purchased a SPEC 1 clutch
  86. Will Not Go Into 2nd Gear At WOT..?
  87. please help
  88. Sensor HELP
  89. *HELP!!* New clutch, wont go into gear
  90. help with wat i think is the rong trane cros brase link to its a 96 m6 car
  91. RAM HD clutch slippage !?!?!?
  92. Where can i find torque specs?
  93. Tranny fluid coming out of bellhousing
  94. Salve To Master Line ??'s
  95. Zoom twin disc clutch(stage 2), any thoughts?
  96. Everyone who uses mcleod clutch come in please..
  97. Salve cylinder throw out bearing
  98. Upgrade clutch or wait..
  99. LS7 Clutch Where to buy?
  100. T56 help
  101. Spec Twin Disc Clutch USERS COME IN!!!
  102. Clutch won't release after install.
  103. Spec stage 3+ clutch issues under spray !
  104. clutch noise ?
  105. T56 Builders
  106. Might be a stupid question
  107. which slave cylinder??
  108. think i broke a tranny mount?
  109. anyone run this flywheel?
  110. LS1 T56 parts?
  111. Will Stock Slave Work With Ls7 Clutch?
  112. New Clutch Suggestions
  113. Clutch or something else...
  114. Silicone in Clutch Master Cylinder???
  115. LS7 clutch install advice - FWIW
  116. Need clutch help... hydraulics aren't releasing the clutch at high rpms...
  117. Grinding with letting OFF the clutch...
  118. Quicktime bellhousing
  119. t5 swap FLYWHEEL QUESTIONS
  120. T56 carnage from the dyno...what happened?
  121. Can the "updated 01-02" slave cylinde be visually identified??
  122. filling tans up
  123. pilot bearing ???
  124. Track / clutch question
  125. Corvette LS1 and F-body T56
  126. clutch or throw out bearing????
  127. Wow look at my flywheel!
  128. 3rd gear pop out + 4th gear sticking... damn it
  129. Valeo LT4 PP and Misc Disk? Flywheel?
  130. will my trans be blowing apart?
  131. Spec pressure plate + ram disc
  132. T56 6spd output shaft oil seal
  133. who else has this issue with a stage 2 clutch??
  134. Putting in new clutch
  135. reverse lockout part number
  136. Lookin for a short shifter...
  137. WTB T-56 FOR 01 z28
  138. clutch slipping??
  139. Street Legal TV's Article is out! Quickest and Fastest M6 Article
  140. Why is 3rd and 4th vibrating?
  141. pedal question
  142. best trans fluid to get
  143. ls7 clutch install problem?
  144. Clutch Not Acting Right!!!! HELP!!!
  145. what gear is 1:1 ratio
  146. I Need Help!
  147. Clutch grabbing high, pedal adjustment without master cylinder adjustment
  148. Is this an O-Ring for the Slave?
  149. Reverse problem...
  150. My T56 Swap *Pics* 56k Warning
  151. This shouldn't happen should it???
  152. Looks like i need a clutch few q's first tho
  153. trans top hat replacement
  154. Clutch hydraulics
  155. May Special "April Special's Extended"
  156. Clutch Problem, Plz Help!!!!!!!
  157. Part # For Hydrolic Hose
  158. REAL feedback needed - T-56, Twin disc clutch, peddle effort
  159. Want a new transmission mount, have some questions
  160. Dual disk clutch, flywheel and floater clean up?
  161. Now there is another problem with my M/C
  162. How Much Brake Fluid?
  163. Transmission Mount Help M6
  164. T56 help...
  165. quick drill mod question
  166. Maddog stage 3 clutch kit ?
  167. Centerforce clutch
  168. T56 problem after swap!
  169. finally starting tearing down the T56 today, pics inside! (warning 56k)
  170. Hydraulic adapters?
  171. Trans builders please come in, check out these pics
  172. Thank God for Adjustable Master Cylinders
  173. 4 Gen M6 pedal????
  174. Problem w/ Reverse T56
  175. Do I need a bellhousing?
  176. New clutch: Pedal Wont move
  177. Torque arm ideas?
  178. which clutch?
  179. time for a new clutch
  180. T5 inquiries
  181. Congrats Amber and Joe (SixSpeedsInc) on the new addition!!!
  182. torque arm came loose while driving ???
  183. Does LS7 Clutch,Flywheel,Pressure Plate come Balanced
  184. Going for 10's N/A and 9's on spray, Stay T56 or go TH400/Transbrake?
  185. do i have to cut the floor to fit the t56 on the 67?
  186. Clutch engagement problem???
  187. wiring help needed for swap
  188. clutch pedal?
  189. Still no 5th,6th or rev
  190. Hmmm Clutchs Clutchs Clutchs
  191. LS7 Clutch
  192. Drag Clutch Death Illustrated
  193. So this cant be normal.
  194. Having Problems.....
  195. Only Users Please Vds Vs Tex
  196. '69 Camaro 4-speed - wanting to go T56
  197. need help ??????
  198. ExoSkel trashed before 3k
  199. drill hole
  200. Whats the difference between early and newer T56 ?
  201. clutch and pressure plate
  202. My M6 swap saga.
  203. Throwout bearing clearence
  204. Slave Fluid change ruined my hydrolics
  205. Help Please!!!
  206. T56 vs. M4
  207. ? on B&M ripper
  208. Any of the Sponsors Rebuild Ford Trannys?
  209. slave cylinder help needed!
  210. Clutch Test: A must do!!
  211. Pulling 6th?
  212. clutch line and DRiveshaft?
  213. high whine sound from tranny??
  214. M6 Swap Underway
  215. clutch issues
  216. LUK gold clutch and flywheel junk?
  217. Losing Clutch Fluid
  218. Trying to install T56 to 99 LQ4 Motor
  219. Whining noise between gears
  220. Help, grinding noise when I push in the clutch
  221. Launching on a new LS7/LS2 combo
  222. ATTN: Spec Stage 1 users and ex-users
  223. wierd grinding noise at low speeds
  224. Anyone else wish their T56 ratios were better spread?
  225. Got my transmisson back form GEARBOX.ORG
  226. Pedals install
  227. Dust Cover Screws??
  228. Launching on a new LS7/LS2 combo
  229. Another SPEC prob. Maybe??!!
  230. Have A Look At My Clutch
  231. drill mod
  232. Anyone broke a Tex OZ700 clutch?
  233. Cheapest LS7 clutch kit?
  234. HEHE... my Spec Twin :)
  235. bad clutch or bad slave?
  236. Another bleed thread advice please.
  237. need help with drive shaft
  238. CRAZY rattle sound when I first start to move.
  239. I cut down my hurst shifter.. nice mod
  240. Your choice for clutches
  241. clutch dragging
  242. t5 clutch
  243. torque arm mount
  244. Pro 5.0 question
  245. Output shaft bushing??
  246. Pressure bleeding or vacuum bleeding clutch questions
  247. Clutch Fluid Questions
  248. need help
  249. Ls7clutch + No2 = ?
  250. t-56 oil
