- LS2 and Z06 Clutch
- Is my clutch going?
- 4th gear stuck!!! HELP
- Weird grind in 1,2,3
- What Shift light?
- Bell housing bolts
- T56 rebuild, is my parts list complete?
- knocking when clutch is disengaged
- clutch bolts! HELP ASAP!
- 5th gear issue
- Cartek Clutch Level 7? Ebay master and slave cylinder?
- Hey Guys !
- First 6-Speed....Help!
- Spec stg 4 or stg 5.... Help me decide!
- Which clutch?
- Anyone heard of Scarab clutch?
- need help ASAP
- Urgent - rebuilding mcleod master question
- Clutch Shutter Gone When Car Shuts Off After New Engine, Problem?
- Problems getting tranny back in (t56)
- Which T56?
- please help with clutch problem
- Think the clutch is going out
- trouble bleeding clutch
- centerforce duel friction clutch
- T56 1st gear change???
- Who makes a good Transmission Bushing poly etc t56?
- clutch is acting funny
- Smoothing out shifts/ Synthetic fluid
- step by step t56 build book?
- After the drill mod,do I still need to bleed the Master Cyclinder?
- Wierd knocking sound
- ?Adjustable master cylinder?
- After 15 months and 15000 miles, look what happened to my Textralia
- strange car trouble
- Clutch line reinstall
- Where to buy t56 parts?
- Not so short stick?
- Can Someone Post LS7 Clutch Pics??
- Which fluid for Trans?
- clutch/transmission rattling sound
- Quick Question about shifters...
- found 3 more gears and 90 more wrhp
- Ram Aluminium Flywheel Pics LT1
- T56 Disassembly Questions
- Is it ok to use Royal purple full synth. on M6
- Help!!! We Keep Breaking Slave Cylinders
- Where to get a clutch hydraulic line
- Need Info
- Need a new clutch? or down on power?
- hey guys i need help performing the drill mod on T56
- New Cartek Clutch
- Spec 4 is in!
- clutch sticks
- Mcleod Twin disk is done. Which clutch now?
- WS6store.com short stick
- Write up: Fix or replace your reverse lock out solenoid
- Hey Guys What Do You Think???
- Power steering fluid in M6
- Help Parts Ordering Please
- Master and Slave Questions
- Who sells a set up for bleeding clutch
- Textralia ?'s
- LS7 clutch peddal height??
- What clutch for a 402?
- Changed fluid on my friends car, now grinds?
- Amber@Six Speeds Inc. out of town next week
- Bent shift fork/3-4 slider?!?!
- why do we have to take out the master cylinder for the drill mod???
- >>>clutch pedal goes down at WOT and 1st to 2nd grind
- T-56 rebuild for dummies?
- spinning slave bolt
- m6 needs to be rebuilt
- Centerforce install...
- If your clutch is slipping, will you smell it burning?
- Need some Quick help identifying these fasteners
- Viper t-56
- clutch swith input circuit???
- Clutch Shopping
- Clutch Disc direction
- bench bleeding master
- Who sells Textralia cluch kits?
- Poly tranny mount
- m6 ratios
- Broke 2nd slave, please help.
- please some one help me
- Is this the clutch I need?
- What do you think?
- Slave Cylinder, how does it work?
- a couple Textralia questions...
- Clutch line Part #
- M6 crossmember
- pro 5.0 shifter
- Hmm now wonder if should have got the ram street twin disc.
- LS7 clutch installed, tough to get into gear
- Slave shim pattern
- Any other manual transmissions....
- STUCK in the middle of T56 removal
- STUCK in middle of T56 removal
- Need QUICK input..T56 Tremec BRONZE fork pads, Yes or No
- Additional Question on Drill Mod?
- Should I Rebuild My T56 Myself?
- Help me finish my T56 rebuild. Stuck. :(
- Best Shifter?
- LT1 clutches
- Good (strong) Aftermarket T-56 6-speed
- I want this shift knob...BUT....
- Flywheel and ram slave cylinder
- need something that hold my 650-750rwhp
- Part number for clutch line heat shield or proper name for it from gm?
- Ok ready to order rear end strange or dts dana 60?
- More tex twin observations and stuff
- 6th To 5th
- how to wrap master line?
- ls7 clutch
- Clutch master install problem
- Shifter question
- Carbon Blocker Ring Help (Installation Information)
- Whose had good luck with a rebuilt T56?
- Difference between gold and green hydrolic lines
- Replacing 5/6 synchro without tranny removal
- Shift Light Advice?
- Just Lost 2nd Guys! Need Help Diagnosing.
- clutch master cylinder install question
- master cylinder
- part number and price for 01-02 slave cyl?
- I Love It When A Plan Comes Together
- Speed bleeders on clutch.. do they always leak?
- slave/throw out to clutch measurement?
- bad thump noise when I shift!!!
- what clutch....
- Problems 600 miles after tranny rebuild/clutch swap
- Rebuild my 99 t56 trannny
- shifter bolts help!!!!???
- stuck in gear
- LS7 clutch question
- Whos running stock clutch with high HP
- RAM powergrip HD break in period?
- Clutch probs i think...HELP!!!
- Clutch going out?
- Ok got remote speed bleeder. Best way to bleed clutch with it..on person still ok?
- 1st impressions of my '99 T56 swap..and questions?
- Drill Mod
- clutch line inside car
- T-56 Hp?
- Please Help!!!!!!!
- Ram Adustable master Problem....
- Help on a problem
- need help no pressure
- Help quick, hole in transmission?
- 2004 zo6 clutch
- making the GTO shift knob work with Fbody?
- Will A LS1 T56 work with a LT1 ?
- clutch replace Q???
- More gear options....
- Clutch problems please help
- Grinding shifting into second, why?
- Not able to powershift to 3rd and 4th...
- problem with 5th gear
- Broken Slave Cylinder Line, need input
- question about ls1 t56 to a older engine
- difference between a LT1 t56 and LS1 t56?
- Clutch fluid change over
- What clutches use stock hydraulics and no spacer?
- ordering Ls7 Clutch ..Whitch one?
- LS7 Clutch 26 spline?
- main shaft rear seal
- Clutch Question
- Noting But Air....help
- what if you put pilot in backwards?
- To do the PRO 5.0 or not
- Why replace slave cylinder?
- Shifter Knob issues
- Does factory hurst shifter need rtv?
- Some stupid, basic, M6 behavior questions....
- Drill mod trouble
- Should this be happening AFTER the trans rebuild?
- Speedo off after A4-M6 swap
- need pics
- clutch master mod
- Is it possible to use mighty vac to replace clutch fluid
- textalia twin owners install questions.
- Tore into the tranny today.
- Need help on clutch desicion
- GTO trans in F-body
- Clutch?
- cags Solenoid threads
- Clutch pedal assembly
- Clutch masters
- spacer shim for slave cyl- to use or not to use?
- fourth gear problem
- New clutch, master and slave install....now it wont go into gear
- LPP Remote Bleeder...?
- Tranny install from hell!
- somethin is wrong but I don't know what.
- Mcleod street twin guys
- Short throw shifter
- Having trouble getting into gear
- Correct LS6 Clutch Package part #
- Anyone broken there tail shaft during a hard launch?
- Won't go into 3rd at high RPM?
- What is causing this vibration?
- Clutch not disengaging
- will not do into 3rd at high rpm
- Slave ????? Asap!!!
- Read if you have a clutch squeal problem!
- What causes this to happen?
- Noise coming from rear of my C5
- pilot bearing????
- who else is using the Spec Super twin?
- Clutch Pedal Pressure?
- First Impressions of the Textraila OZ700
- ZOOM Clutches...? Who's using them.
- stock ls1 bellhousing #
- Help ASAP
- Is this bad? *pic*
- Stick with LS6 until it pops....or upgrade to spec 3+
- Slave replacement??
- slave cylinder parts
- Change B&M back to Hurst with LSS ??
- Tranny rebuild
- Missing Third!!!!
- LS7 Clutch Review
- question about pro 5.0
- No 2nd gear, Please Help
- T56 Rebuild Cost
- adjustable rod?
- centerforce df 395010?
- Converting my t56 from lt1 to ls1
- Reccomend me a clutch!
- Bench Bleed new Slave?
- My slave cylinder came with little o ring???
- T56 Rebuild
- Can I Use an LS7 Clutch and Spec ALUM Flywheel???
- Reaaaally bad vibration when clutched in and revved.
- the Zoom D2 Series Twin Disc Clutch Kits
- flywheel bolts
- Six Speeds Inc. New Shipping Policy
- Textralia Exo-Skel Triple Pics...
- cruise control not working!
- Pressure Plate -- Is This Normal?? (PIC)
- Clutch opinions
- Fidanza Flywheel Wear Issues?
- clutch?, drivetrain problem?
- Where the heck can i get a VSS??
- BIG problem
- New Slave Cylinder...can it be bleed first?
- torque specs on flywheel?
- LS7 Clutch
- Sponsers: LS7 clutch & flywheel
