- lock up in 3rd
- Bellhousing
- DOT 3 or DOT 4 for clutch hydraulics?
- wich shifter
- Which brake fluid for the clutch??
- Diagnose My Clutch Failure - Pics
- did i install defective master?
- NEED HELP!! Clutch wont bleed fully, what can I do???
- Need Help Trans Hard To Shift Into All Gears
- lt1 clutch decision
- Mcleod
- Another grinding sound thread...
- whats all parts are needed for a conversion a4 to t56
- T56 troubles
- Thinkin about buying M6 car
- Torque Arm bolt into trans!! HELP !!
- Drill mod question...
- 2006z clutch woes
- clutch decision
- How does your exo skel engage on the street
- Slipping clutch
- what kind of fluid to use
- transmission question
- LS7 clutch gm part #
- T56 temperature while racing..
- Clutch chatter.
- spec 3 vs spec 4
- Clutch gets soft and wont go into gear....
- input shaft won't go into the Pilot bearing
- lost 2nd gear
- would a ws6 store shifter work on a b&m shifter?
- Help!! Reverse Grind :(
- hare to get out of gear what could it be?
- Do T need the Drill mod on a 01 TA
- New spec 3+ question grind (vette)
- hp rating for ls2 clutch
- Textralia
- Q: Fittings to convert quick disc. to an style
- VERY frustrated AGAIN
- Spec 3 slipping only 6k on it?
- linkage question
- Which master cylinder to upgrade to?
- NEWER LS1 clutch master cylinder
- problem with hurst shifter
- 2nd gear grind!!
- T56 clutch fork hitting Pressure Plate
- remote bleeder
- Replace tranny seal - driveshaft
- what kind of fluid?
- grinding without shifting?
- Need a Transmission Jack
- t56
- Clutch sticking to floor, wont go into gear..?
- Issues with shifting, please help....
- What is the purpose of slider keys?
- sharing my excitement...
- 1st to 2nd Gear Shift Grinding....?
- Need some help please guys.
- what clutch for 500-550 rwhp... ?
- Not enough tranny fluid?
- Problem with t56
- Where's the bleeder? '99 LS1 T56
- RSG Rockland Standard Gear T56 1200hp????
- Ls1 T-56 Behind BBC
- putting in spec 3+ but have to dyno next week, will I hurt my clutch
- New clutch BUT grinding in 1st Gear!
- Transmission Whine
- Rough Shifts T56
- Best way to bleed clutch
- Another Reverse Lockout issue
- Exo-skel anyone??
- tranny install trouble
- At a total loss......
- Clutch for my 95 LT1
- how does the reverse hook up on a T56?
- i need help with shifter in 96 trans am
- problems
- clutch pedal stop?
- i believe i found a good deal for a t56 setup!!!!
- drill mod
- What are the limits of the stock T56? [Tried to search, but it's not working]
- Any tips on quieting my Pro 5.0?
- My clutch just went out, flywheel question
- Car wont crank at all, seems clutch is stuck. any ideas??
- I made the switch from a4 to T56
- Missed 3rd... now this???
- stop bolts on 5.0?
- Clutch Noise
- CAGS skip shift eliminator
- Am I the only one whos tranny rattles like a little ***** in neutral?
- throw out bearing?
- Hard to get into gear.
- What is a high mileage t56 worth $$$ ?
- T56 Differences
- drill mod sucks
- Shifting Weirdness
- part numbers........ls7/ls2 pkg,slave,pilot
- Clutch and Flywheel
- Major Problem!
- what causes a clutch to not disengage??
- Just had LS7 clutch installed...and theres a smell?
- output shaft seal
- upgraded slave T56 ?
- Shifter Bolts?
- Remove braised metal covered wire???
- SPEC Twin Disk Clutch Assembly
- Removing the tranny from an LT1 t56 car
- Clutch bleeding techniques
- cheapest tranny rebuild kit?
- 4th gear not cooperating? Shift fork maybe?
- Ls7???
- pedal problem
- bUSHING OR BEARING
- Silly Clutch install Question
- anyone had problems with spec 3+?
- wont start...clutch lockout?
- What do you think this is? ( video of noise )
- Look what Byun and Fedex gave me
- pro 5.0 with ws6 short stick
- Clutch Chirp
- car wont shift into gear...
- dont know
- ws6 store short stick vs ebay
- aftermarket clutch master
- 550-600rwhp... RPS -or- Textralia -or- ?
- RAM powergrip, steel billet fly wheel + more came in (pics)
- Parts store FLYWHEEL
- Powershifting, speed shifting, etc
- New m6 driver..need help
- Clutch sticks to floor
- installed spec 3+
- Labor Hours Needed for a clutch install
- Poly Tranny mount ?
- why do pedal stick to the floor at high rpm's
- Help me buy parts for my tranny
- Totally stock transmission problems
- Plastic slave?
- Transmission Hard to shift into reverse?
- SPEC stage 2+ Q's
- converting 2000z28 from A4 to M6
- transmission oil?
- corvette slave fit f body T56 ?
- slave or master cylinder, ways to trouble shoot which one!!
- help picking short throw shifter
- Pedal just lays on floor, whats going on???
- Does your master cyl. leak air and cause a bad pedal???
- New master with clutch install?
- brand new spec 3+....
- Need input on slave cylinder part number
- T56 Differences?
- Need some tranny help?
- Got my Ram Powergrip HD Installed!
- 3.8 -> LS1 can I keep the M5?
- RAM HD and 5000rpm dumps?
- Energy Suspension Trans Mount..
- WTF now i cant connect my hydraulic line!!!
- bleeding with the mighty vac
- Pops out of reverse
- new clutch how to install throwout bearing???
- New clutch install, then racing
- M6 to TH350, do I have everything?
- Wow i messed up T56 guys inside!
- Pro 5.0 Shifter & boot install
- Corvette vs. F-Body T56.
- will a ls7 clutch/flywheel be a direct bolt in
- Mcleod or Ram Adjustable master?????
- Could you tell me what is wrong with my car?
- What needs replaced with the clutch
- HELP!! should I go witht the spec2+ or LS7
- stripped out tranny cross member bolts
- clutch hydraulics!! im about to go CRAZY!!!
- Z06 clutch kit?
- 5 speed to 6 spd conversion, peddals?
- flywheel
- do you loose any power going to a ls7 clutch and ls2 flywheel?
- HELP!!! trans or throwout bearing???
- If you havent done the drill mod.....DO IT!!!
- C5-m6 grinds and a thud into gears after motor swap
- Clutch package shopping
- Interesting shifting fix
- Hurst Billet Plus Questions
- stock clutch master cyl.
- How streetable is faceplating?
- cracks in bellhousing
- Soft/sticking pedal after WOT thru 4th...clutch not hydraulics, right?
- pedal sticking with new master and slave
- Fragged Blocker Ring?
- Slave is spewing fluid...
- Clutch Problem
- Transmission Blanket
- grinding 6th, no speedo, no reverse solinoid, fresh build
- 6-Speed 350 in 3rd gen questions....
- so i got the 6" stick, and..
- grinds going into 5th when cold! HELP!
- Flywheels
- no fluid in hydrolic resivore?
- Making stock Master adjustable?
- Clutch pedal gets soft...
- Where do you get the "ring"
- t 56 rebuild
- how many different manual trans are there?
- hard to shift
- i know everyone asks but wich clutch please help
- Clutch Question
- installing 1 - 2 slider
- slave cyl.pic
- getting a clutch what else
- Surface finish for SPEC flywheel
- Sticky On Wot Issues
- T56 tailhousing swap?
- Clutch master cylinder *CONFIRMATION*
- Spec Stage 2 In 6.0 Slipping
- B&M Ripper shifter??
- clutch master clutch kit
- Master Cylinder Question
- best place to get an ls7 clutch
- going from auto to stick...
- Tranny squeal
- Voodoo shift forks?
- Clutch "POPS" up after 3/4 disengagement
- Tranny whine?
- Where do i get all bolts for my t-56 install!!!
- Exoskel after 1200 DD miles
- Where can I get the braided line for tha master cyl at??
- Manual vs Powerglide
- what bolts for the bellhousing
- Shifterboot retention ring?
- Need Help Quick!!! Drill Mod
- Spec questions
- Question about parking brake cables
- Six Speeds Inc. Monthly Special **Free Shipping is Back**
- Whats this noise??
- tailshaft seal
- Where to find McLeod Street Twin
- Textralia Clutch Problem
- spec3 +
- Wow. Just got off the phone with T56Rebuilds/SixSpeedsInc
- 05 GTO T56 + Stock clutch on 98 LS1
- Bad blocker rings? Or clutch problem?
- H/C Combo with approx. 400-420 RWHP Do I replace the stock LS6 Clutch?
- Clutch install writeup
- Powershifting..Or not
- T56 corvette question
- again with the noises!!!
- LS7 clutch installed!!!
- Pilot bearing?
- what clutch to go with for 700 rwhp
- when drivin hard i cant get into 3rd?!
- Ram VDS
