View Full Version : Manual Transmission
  1. Popping out of 4th gear, 2nd as well I think; really cold out.
  2. stuck in 3rd gear
  3. how can i take off the hydraulic hose from the master cylinder to the slave??
  4. drill mod & bleeding not going so well
  5. lt1 t56 vs. ls1 t56
  6. Can anyone help me with a part number for the plastic trim for shift boot?
  7. Installed my short stick. GET ONE!
  8. Billet flywheels
  9. loss of power????
  10. Pressure Plate Bolts?
  11. ran car aggressively. high rpms, hard going into gears
  12. short shifter giving faster 1/4's??
  13. resurface flywheel?
  14. T56 rebuilds is the best of the best
  15. So, did anyone call Tremec yet
  16. Ram HDX clutch. Anybody have? Opinions?
  17. Grinding in upper RPM's
  18. Won't go into 3rd, pops out of 1st
  19. throwout bearing rattle
  20. Quick Bellhousing Question
  21. Swap 04 GTO T-56 into 98 Z28 w/ T-56???
  22. m6 or a4 for turbo DD
  23. New Master Cylinder?
  24. Sticky clutch pedal
  25. ls7 VS spec3+ and other questions
  26. How much can I sell my T-56 for????
  27. 2001 z06 want to put auto in how hard?
  28. Update on T-56 issue
  29. input shaft broke
  30. Clutch goboom!
  31. Syncros Or Other Problem?
  32. Car Wont Go Into Gear!!!!
  33. Car won't Go into Gear
  34. trans/clutch stuff for 3.4 to LS1 + T56 swap
  35. Car stuck in N and will not shift after started
  36. T56 in a 70 gto
  37. shifter knob
  38. Spec Stage 4 users inside please
  39. what gear ?
  40. LS7 Clutch + Aluminum Flywheel (Who has it??)
  41. part # for 1le mount? thought i had it but...
  42. drill mod for clutch master
  43. What's the difference?
  44. Question about my friends 2000 GT
  45. Pressure plate bolts, flywheel??
  46. Clutch Sticks but not if Pumped
  47. How to test for loose Flywheel??
  48. Help me choose a clutch plz
  49. Who has blown up a clutch in their LS1 F-body?
  50. Where to buy braided line for drill mod
  51. Ordered....
  52. another t56 bites the dust
  53. *which Clutch?
  54. Recomemd Clutch / Flywheel
  55. just got the RAM Powergrip HD installed...
  56. Downshift and boom
  57. Can I replace flywheel without replacing clutch?
  58. HAY-85-105 Clutch ??
  59. Annoying sounds after clutch install.
  60. 6 speed conversion?
  61. Proshifted tranny?
  62. t56 question
  63. Gear vs Speed calculator (macro and non-macro)
  64. annoying problem with trans.
  65. Best clutch for 600ft/lbs
  66. Trans mount
  67. 3rd clutch gone - whats the deal?
  68. Which rear gear ratio with a T56 in a 408 Stroker???
  69. LS7 Experience; Good or Bad?
  70. Textralia OZ700 vs ExoSkel...Opinons?
  71. T-56 Transmission Problems
  72. Questions for guys who rebuilt their own T56
  73. T56 from LT1 into ls1 Posssible?
  74. Is there a trick to removing M6 shift knob?
  75. Exoskell clutch specs
  76. Please help! Clutch problems
  77. hurst shifters
  78. EXO-Skell / Spec Stg 3 Review
  79. ls2 flywheel resurfaced, problems finding shim!!! please help
  80. where should i get my trans redone at?
  81. Here are weights of LS7 clutch, aluminum flywheel vs stock
  82. Bronze fork pads for 5 - 6?
  83. Which Z06 Clutch for an '00 SS?
  84. wtf is wrong with my tranny
  85. Braided Line (Drill Mod)
  86. My t-56 is toast
  87. new clutch problems
  88. How Much Should Ask For My Tranny
  89. Need Help on Part numbers for LS7 Clutch
  90. m6 mated to a 5.3
  91. Spacer between 5th gear bearing and 5/6 synchro snap ring
  92. Clutch only engages when cooled off...
  93. please help!
  94. Clutch sticking to the floor.
  95. tranny noise
  96. Help and opinions please! Hydraulics???
  97. slp short throw shifter
  98. Reverse synchronizer retaining ring?
  99. What happened to my T56
  100. Textrailia review(30 miles). M6 question. This clutch is cool!
  101. hole in cap of clutch fluid lid?
  102. yet another synchro ?
  103. Can you add "Friction Material" to a Flywheel?
  104. Clutch difficulties
  105. nasty squeaking noise. help!
  106. HELP with thread size for slave and shifter
  107. clutch not disengauging?
  108. Problem with clutch
  109. do i need new pads or synchros?
  110. What fly wheel?
  111. rebuild question, what comes off next?
  112. Tranny problems..
  113. B&M short stick shift knob removal?
  114. T56 problems when WOT shifting
  115. After considering an LS7 clutch, im reconsidering going back w/ a Spec
  116. Lowest price for Mcleod LS1 bellhousing??
  117. fastest m6 list
  118. T56Rebuilds.com website temporarily down
  119. slow high rpm shifts
  120. Do i need a new clutch now or wait?
  121. getting a m6
  122. Pro 5.0 webiste?
  123. How to tell the diff. in 5-6 and reverse synchro?
  124. Slave/Master cylinder ???
  125. is the ls7 clutch good?
  126. Weak slave??
  127. LT-1 t56 with LS1 Slave??
  128. LS7 Clutch Pressure Plate Adjustment?
  129. going on my 3rd pilot bearing...why????
  130. Problems with Spec 3+
  131. Help with Raptor install
  132. Clutch help.
  133. removing the transmission
  134. shifters?
  135. Z06 clutch good enough?
  136. Pressure Plate "fingers" bent in
  137. Pro 5.0 shifter stick vs WS6 store short stick
  138. Clutch LS7 NOT Working
  139. downshifting problem
  140. Tools for T56 rebuild. Please check.
  141. Textrailia
  142. B&M Ripper vs Pro 5.0
  143. 103,xxx miles and shot upshift solenoids...time for a rebuild?
  144. 02 Ta wont go into gear
  145. opinions on my tranny, pics inside
  146. signs of dying hydraulics?
  147. Let me see your shifter knobs!!!
  148. pistol grip handle
  149. Exoskell users, give me feedback.
  150. Clutch or Tranny Help....?????
  151. Blocking Ring Function
  152. drill nod questions
  153. What clutch will I need for these mods?
  154. trans swap question!!
  155. please help with m6 conversion
  156. Cant Remove pilot bearing
  157. M6 brands
  158. can I reuse my tranny fluid
  159. Please Confirm Cartek Fluid DOT 5 or DOT 5.1
  160. paddle shifters
  161. Slider still worth using?
  162. Parasitic HP loss from a dual disk clutch or T56rebuilds tranny???
  163. Slave Cylinder
  164. So what's the going consensus on ClutchMasters?
  165. is my clutch dead???
  166. Any one ever warp an Aluminum Flywheel?
  167. RPS Carbon Kevkar Or Spec Stage 3+
  168. need help finding what clutch i need/flywheel..how to know?
  169. shifting/clutch problems
  170. Wont go in gear, hard to shift. HELP!
  171. will a Lt1 T56 bolt right up to a SBC
  172. Newb Question
  173. Okay so you guys hate spec and the LS7 is still a question
  174. Pilot Bearing Tool: Kent-Moore J-43276
  175. Will Textralia hold 850 rwhp/750 rwtq ??
  176. Broken transmission?
  177. clutch sticking when its cold
  178. lou's short stick vs. ws6store
  179. pro 5.0 or hurst billet
  180. Rebuilding a T-56
  181. a4-t56 swap..few pre questions
  182. LS7 clutch install ?
  183. Searched............is there a write up somewhere on replaceing the tailshaft seal???
  184. Any good instructions for 1-2 and 3-4 assy?
  185. Transmission Work (Clutch Sticking) -Orlando
  186. noob clutch ??
  187. Where to Buy?
  188. T handle hurst knob w/short stick
  189. Noob here...slider?
  190. t5 trans rebuild- please help me
  191. im trying to identify this piece
  192. Rattle
  193. SPEC 3 and 4, how many pucks?
  194. viper internals in GM t56?
  195. Master cylinder braided line
  196. Which Flywheel???
  197. Broken tranny mount
  198. 05 GTO A4 to M6 Swap?
  199. Speedometer not working after clutch install
  200. Slight grinding going into gear, what is it?
  201. ls7 clutch with lightened fly
  202. stock clutch with 400 rwhp and a 12 bolt?? how long till it pops
  203. Mikronite Face Plated T-56
  204. Master braided line.
  205. Help me choose a clutch for my RWHP.
  206. Need T-56 main shaft
  207. Hard To Get Into 5th Gear
  208. Shims and bleeding
  209. Anyone toasted a LS7 clutch?
  210. Need DD clutch for 500whp on N2O
  211. Switched from A4 -> M6
  212. Drill Mod Help????
  213. Poll: Stock Master or Adjustable
  214. Master cylinders with Textralia...whats the difference?
  215. cant find noise location
  216. Clutch Kill Switch... Will a stock T56 take it??
  217. Problem with shifting. either clutch or slave cylinder.
  218. t 56 problems
  219. short stick on non hurst shifter
  220. Change Shifter or Stick?
  221. Sticking clutch pedal
  222. Cutting Pro 5.0 stick?
  223. I NEED HELP PLEASE...clutch problems
  224. How much damage can i do?
  225. t56 for ls1!!!
  226. 96 trans am 6 speed
  227. ticking noise...
  228. rear gears and T56
  229. can i put a LT1 t56 onto a LS1 engine?
  230. Textralia OZ700 install problem
  231. How long would you expect a Spec 3+ to last in a DD?
  232. Pro 5.0 on Viper Trans.
  233. pro 5.0 for ls1 fit lt1?
  234. switching to GM synchromesh
  235. Clutch decision
  236. Bolt pattern questions
  237. Vibration/rattle under load on accel, any ideas?
  238. Exo-Skel break in.
  239. where to get ls7
  240. clutch question
  241. Teaching the girlfriend to drive a stick...
  242. need a new clucth
  243. Lighten the stock fly wheel?
  244. LS7 with 400rwhp + 150 shot, think it will hold for long?
  245. ls7 flywheel?
  246. Anyone use the LS7 clutch, flywheel, pp?
  247. POLL. ls6, Centerforce DF, or RAM HDX
  248. ls6, Centerforce DF, or RAM HDX
  249. OEM GM or Aftermarket
  250. McLeod Adustable Master Cylinder
