View Full Version : Manual Transmission
  1. im at the end of my rope
  2. T56 in a 944
  3. Help! How Do I Bleed
  4. ls1/ls2 pilot bearing interchangeable???
  5. 2000 camaro throwout bearing size????
  6. Transmission Vibration Please help !!!!!
  7. high rpm grind!
  8. Used spec 3???
  9. well i blew my clutch out
  10. T56Rebuilds "Real Racecars have 3 Pedals" T-Shirts.. Who all wants one
  11. McLeod Slik Stix Shifter
  12. T56 xperts - Grinding into 3rd and 4th
  13. harder to shift into 3rd?
  14. T5 trans
  15. Mating a LT1 T-56 with an LSX using ...
  16. New clutch comming in.
  17. stock clutch coast?
  18. stock flywheel
  19. Mcleoud or Textrilla?
  20. stock clutch and 125 shot?
  21. Grindin all gears
  22. Drag Racers: Type F ATF in T56?
  23. Spec Stage5
  24. McLeod Adjustable Master Questions.
  25. Which tranny fluid came in the tranny from GM?
  26. Squeaking Noises
  27. Squeaking Noises
  28. Who's got the best LS7 clutch packages?
  29. Transmission bolts
  30. clutch and flywheel?
  31. Which Master Cylinder?
  32. T56 problems
  33. How much HP/Torque can an LT1 T56 hold?
  34. optimal RPM?
  35. Got measurements, how to determine shim size?
  36. Ignorance is bliss
  37. How long should i break in my spec 3+ ??
  38. Ls7/ls2 Clutch Install,now Vibrations!
  39. i need a m6 trans!
  40. SPEC 3 5k rpm launch?
  41. Exedy rebuild questions...
  42. Will This Cure Clutch Pedal Stuck On The Floor?
  43. T56Rebuilds.com Shop Motto......
  44. clutch problems.........
  45. Tranny fluid
  46. t56 problems! help!
  47. centerforce dfx
  48. What are the differences i the LT1 and LS1 clutch
  49. whats wrong with my tranny?
  50. adapting lt1 t56 to ls1
  51. McLeod disengaugment issue. CL SL Bleeding Q,
  52. slave cylinder problems
  53. how many qrts does an M6 hold?
  54. Ls7 clutch?
  55. T56 Conversion Install - Moves with clutch in
  56. Think my Spec III is going out! You tell me.
  57. Tranny help ??? T-56
  58. what short stick do u use?
  59. Borg Warner Super T-10 4 speed manual
  60. A4 to M6 swap
  61. T56Rebuilds In Car Camera
  62. t56 input change
  63. Clunk, then clutch wont disengage, pedal is harder
  64. Wtf!!!???? Noise???
  65. Where to buy LSS?
  66. Clutch/shift problems
  67. damn tranny wont budge
  68. Gas mileage by gear
  69. poor shifting when cold
  70. pressure plate bolts!!
  71. HELP unable to shift
  72. fidanza aluminum flywheel?
  73. A4 to M6?
  74. adjusting
  75. Can I use 75w90 gear oil?
  76. New UMI Short Stick Probs
  77. lt1 t56 to ls1
  78. LS7 Clutch Problem
  79. Hard to shift from 4th to 5th. new Z06 trans
  80. pro 5.0 install question
  81. tranny fluid question
  82. Umi Ss ?
  83. Neutral + Clutch In = Stall
  84. Should I change my slave?
  85. LS6 Clutch?
  86. Bleeding the Slave
  87. Skip shift set to avoid accidental 3rd to 2nd downshift?
  88. What is the dia. on the input shaft for the
  89. Replacing slave cylinder
  90. shifter problem? please advise
  91. How many splines on the T-56 main/tail shaft?
  92. New clutch
  93. Need photos of wiring going to
  94. need new clutch, what 1?
  95. Very tired of changing clutches!!
  96. short stick vs. shifter assembly
  97. SPEC warranty
  98. T56Rebuilds.com NEW H/C Highest HP TODAY w/M6
  99. Clutch Hazed Over
  100. Clutch Problems
  101. Clutch events starting to add up...
  102. what size throwout bearing 99TA LS1
  103. Clutch hydro fluid black as hell???
  104. Shifter = ANNOYING VIBRATION!
  105. Skip shift idea/question
  106. Can you put your shifter in backwards?
  107. Squeaky Clutch (is it slipping?)
  108. what clutch for nv4500???
  109. stupid story and questions
  110. Reverse... Fuckin t56's haha
  111. Louis's short shifter problem
  112. WTB LS1 T56 Front cover
  113. 02 Slave Cylinder Spec's
  114. lt1 to ls1 t56
  115. anyone running a ram street dual?
  116. centerforce dual friction??
  117. Fall Special Stars October 12th- 31st
  118. Unkown tranny problem?????? HELP HELP
  119. What Type of Clutch to Run With
  120. Suggested Shift RPM Above Peak HP
  121. Do a Steel or Aluminum flywheel?? ls1 Fbody
  122. Lets answer this once and for all: Which clutch for 600rwhp?
  123. What Clutch do you guys recommend???? 550rwhp
  124. Any one have the SPEC 3+ in there ls1 fbody?
  125. Clutch and Hydraulics...
  126. Noob with clutch question
  127. T56 Rebuild Q's
  128. Another RAM or the Ls7
  129. Price guesstimate??
  130. Aftermarket master/slave setup
  131. clutch master issues (possibly)
  132. GM's, Viper's and Ford's T-56 ?s.
  133. help! driveshaft won't go in....
  134. T56 no 5th/6th or downshift after "rebuild"
  135. 402 and a M6
  136. RPM transmissions has anyone tried these?
  137. is the cartek clutch strong enough for 450-550 to the ground
  138. shifter squeek!
  139. Ls7 Clutch
  140. clutch help wont disengage
  141. Need Info
  142. Spec Warranty?
  143. Cant go into Second Need Help
  144. New Clutch Question
  145. Clutch Problem
  146. CLUELESS ... please help ... clutch problems...
  147. clutch slipping
  148. may sound like a stupid questions but....
  149. Friend wants to use a T56 with a 500+ci BBC... I have ?s
  150. T-56 questons
  151. if a car is tough to get in 1st from a stop...
  152. What's the difference between an Adjustable Master and a Clutch Pedal Stop?
  153. spec5 install ???'s
  154. How do spec clutches feel?
  155. Fall Special- Need Input from everyone!
  156. New Centerforce DFX Clutch???
  157. question about shifters
  158. 6 speed trans problem help!
  159. Clutch is sticking!
  160. spec stage 3+
  161. replacing master
  162. How long will my stock ls6 clutch last with a 150 wet shot?
  163. Clutch Pedal is bleeding off pressure... WTF?
  164. clutch squeaking!!!!
  165. stock tranny with spec 4 question
  166. Tranny fluid
  167. paper/carbon fiber syncros?
  168. Having Clutch Problems
  169. Clutch? Tranny? or a combo of both?
  170. LS7 Clutch Install Questions
  171. Clutch/Trans Problems 98-00
  172. Fresh rebuild Car jumps out of 6th gear
  173. Changing tranny fluid
  174. Transmission/Clutch Know-it-Alls. HELP! lol
  175. how much hp/tq can the stock ls6 clutch handle?
  176. lightweight flywheels and heavy duty clutches
  177. Spec Stage 3 Install few questions
  178. Which clutch to get?
  179. Output shaft seal question!!!!!!!!!!
  180. T56 Gurus get in here !
  181. possible GP on LS2 aluminum flywheels
  182. shifter clunk-clunk?
  183. Exedy twin slips on a 150 shot - rebuild time?
  184. Sloppy clutch pedal...
  185. Need some advice... Is it my driving? Or the clutch setup???? LS7 time?
  186. M6 question?
  187. Another clutch engagement
  188. Textralia Clutches
  189. whats the drill mod??
  190. Line Up Tool Help!!!
  191. Grinding going into 3rd after clutch install
  192. Throw out Bearing
  193. clutch wont bleed!!
  194. Trans??
  195. shifting problem
  196. Manuel Swap
  197. Centerforce Q's
  198. master cylinder or shim?
  199. Rebuilding tranny and have a question.
  200. T56 to '84 SBC??
  201. Rebuilding the T-56
  202. LS7 vs LS1 Clutches
  203. stock tranny question?
  204. mn12 tranny
  205. just installed rebuilt tranny have ????
  206. I just have the clutch disk!
  207. ls7 from byunspeed
  208. clutch is slipping time for a new
  209. WRU Byunspeed Website???
  210. WOT grinding issue
  211. Whats the best clutch for me?
  212. Tranny Problem
  213. Master cylinder
  214. B&M Short Throw
  215. Cores Needed
  216. 3rd Gear Vibration -- Worn Clutch or Transmission Problem?
  217. stuck in 4th!!
  218. New slave, break in???
  219. Shifter for 01 SS
  220. Spec Stage 3+ questions
  221. Help! Clutch won't disengage!I think!
  222. Camaro SS shift knob
  223. napa clutches
  224. ls7 STILLL isnt here yet!
  225. Driving Schools?
  226. 2 Wks Left on Special
  227. Pressure (Power) Bleeding PSI
  228. Clutch recommendation for mods listed
  229. Looking for a good forum to discuss the T-56....
  230. Which Poly Trans Mount?
  231. T5 on an ls2? what does it take?
  232. Need HELP fast!! pulling tranny STUCK!!
  233. To use textralia or not?
  234. Stock Flywheel Bolts or Crank stronger??
  235. [b]slave Shim And Drill Mod[/b]
  236. Bad Slave
  237. clutch issues
  238. Very hard to get into reverse.........any ideas???
  239. Anyone Running a SPEC 1?
  240. My toasted Spec III clutch, PICS inside.
  241. what clutch do I need
  242. Is there a special flywheel to put a T56 on a 6.0? Stock one won't work...
  243. Whats a better short throw Pro 5.0 or B&M Ripper??
  244. the best t56 rebuild parts
  245. T56 Problems.
  246. kinda puzzled
  247. stright cut gears?
  248. Calculating Gear Ratios
  249. Tough shifting M6..I learned something
  250. transmission problems
