View Full Version : Manual Transmission
  1. Centerforce DF 12" shifting issues
  2. LS7/LS2 combo results
  3. instructions: how to rebuild pro 5.0
  4. Aftermarket Ls7 Flywheel?!?!?!?!?
  5. proper method for install/bleed of hydraulics
  6. centerforce clutch is it any good?
  7. Couple of problems.
  8. T56 Safety Housing
  9. updated slave part#
  10. Still Having Problems With Clutch
  11. Spec 3+ Clutch, Need Help!!
  12. Help!
  13. Another successful install “Pro 5.0”
  14. Grinding Into 6th?
  15. trannys gone bad
  16. Ordering new clutch. suggestions please.
  17. Got my clutch...Questions
  18. Strange thing happend... problem?
  19. shit! bent shift rod
  20. a ticking noise
  21. Anyone running the McLeod twin disk?
  22. T56 Stuck in 6th gear???
  23. Speedometer way off! Why?
  24. Should I get a short shifter in my position
  25. Any one use a speed inc built t-56 street trans?
  26. Textralia clutch
  27. adjustable master cylinder?
  28. t56 to 4.3
  29. LS7 clutch and alum FW installed. Any questions?
  30. Another Ram bites the dust...
  31. Spec Pp
  32. Bellhousing help.....
  33. Figured out the noise from new clutch and flywheel.
  34. Manual Transmission FAQ - Look Here First!
  35. my clutch has issues..
  36. What do think caused this?? (56k beware)
  37. Noisy Drivetrain
  38. z06 slave for fbody?
  39. Need instructions on Master Cyclinder and Slave Cylinder install?
  40. z06 clutch for sale
  41. My clutch just gave up....
  42. Is it rebuild time?
  43. TEXtralia OZ700 x or z grip? New Slave?
  44. Can't get the clutch release line off tranny!!
  45. rockauto parts?
  46. how much you think ls1 t56 weighs
  47. Do I Have To Get An Adjustable Master Cylinder?
  48. Stupid Question
  49. Earl's Solo Bleeders???
  50. Clutch Bleeding Problem!!!!
  51. New clutch, Tranny grinds when clutch is at floor help me out.
  52. what is the drill mod
  53. F1 x-lite flywheel
  54. Clutch vibration
  55. New Clutch!!! now problems...
  56. Quick Ploy Mount Question
  57. Installing ws6 short stick
  58. How hard to replace clutch?
  59. Hurst ??'s
  60. best shifter for 2/3 shift... pro 5.0???
  61. what is wrong with my cutch
  62. ARP Part # for clutch bolts...
  63. In need of a part number
  64. Clutch master O-Ring
  65. New clutch install, now car won't go into gear, PLEASE HELP!!!!
  66. Clutch install prices??
  67. will ford tremec fit lq4?
  68. which snap ring pliers for T56?
  69. just wondering?
  70. I have bench bled the master, but is it ok to put the slave in dry?
  71. removing clutch slave from tranny...?
  72. Car grinds into 5th gear and reverse when still warming up?
  73. Need a good trans mount
  74. O F&*K!! Need Help with clutch install
  75. ls7 clutch
  76. What year is this T-56?
  77. question...
  78. Slave Cylinder
  79. Spec S3 in LT1 vibrating!!!!!!!
  80. clutch sticking and noise
  81. aftermarket bellhousing?
  82. Help me diagnose my M6
  83. Centerforce dual friction w/drill mod??
  84. New GM Hydra-Matic 6 speed RWD Planetary Manual transmission
  85. new clutch, does not release fully
  86. Clutch is starting to slip bad....... :(
  87. Breaking in new clutch questions...
  88. Clutch Issue
  89. Which clutch for very high power
  90. crushed magnets??
  91. Master cylinder question
  92. Creaky clutch
  93. pro 5.0 shifter?
  94. A real problem with SPEC clutches.
  95. Can a corvette clutch/flywheel be used in a f-bod?
  96. m22 to ls1?
  97. Master Clutch Cylinder, Auto Zone?
  98. bleeder on the t56
  99. Out of Ideas, Help !!!!!
  100. Ram Clutch
  101. T-56 and Big Block
  102. whats the best clutch for t56.
  103. Anyone Using a 2-Step?
  104. LS7 clutch kit ordered...
  105. pro 5.0 springs
  106. big thanks to TDP
  107. Everybody is an idiot at least once
  108. WOT 2nd gear grind
  109. out with old in with brand new
  110. Shifter Install questions
  111. PLEASE READ!WHAT went wrong ?
  112. Loose Pressure Plate Symptoms
  113. T56 feels knotchy after driving hard (more after fluid change)
  114. t-56 question?
  115. clutch chatter?
  116. What trans is in a new z06?
  117. Tranny removal with longtubes
  118. hurst to pro 5.0?
  119. Auto Meter Quick-Lite Shift Lite???
  120. Factory "H" leather shifter knob
  121. Will LS1 work with LT1 T56??????????
  122. mcleod problems...where to start
  123. What did I break? Fluid leaking like crazy.
  124. New Clutch Fried?
  125. What can the LS7 clutch handle
  126. Clutch engages different at WOT
  127. New B&M "Precision" Short Throw Shifter opinions
  128. URGENT NEED HELP NOW. i broke the car
  129. Clutch issues.....
  130. Pilot Bearing quesitons
  131. Question about installing aluminum flywheel
  132. LS2 clutch from C6 into 01 camaro
  133. Please help me on this set up
  134. SPEC flywheel with LS7 clutch?
  135. StreetTwin, Rev-Lok II or something else?
  136. LS7 clutch came in today
  137. transmission running super hot....
  138. Those with LS7 clutch/LS2 flywheel come in.
  139. Difference in Hurst shifters???
  140. sticky idea on ls7 track use thread..
  141. Tremec vs. Borg Warner T-56's
  142. Round 3: Clutch Hydraulics
  143. wet clutch
  144. LS7, Z06, or Spec 3?
  145. Spec 5 clutch squeal....Slowhawk others help
  146. clutch ?
  147. Extra heat protection for clutch line?
  148. Troubleshooting Reverse Lockout
  149. How Much Did You Pay For Your Spec 3 Clutch?
  150. Clutch pad material for spec stage 4?
  151. Clutch is slipping but how bad?
  152. those with centerforce clutches(or not)
  153. Lt1 in a ls1
  154. Problems with a Hurst Shifter
  155. Tremec EndPlay Tool
  156. MM6/MN6 any diffrence?
  157. LS7 Clutch with Fidanza LS2 Flywheel
  158. Problem getting into gear FIXED Details inside.
  159. LS6 slave
  160. Speedometer adjustment?
  161. clutch plate
  162. So I think I blew my slave trying to adjust my master?
  163. Clutch Question?
  164. What's Going on with My Transmission? W/ Videos
  165. Air in the line?
  166. Which short stick (TNA, LSS, UMI, WS6, etc.)
  167. What tranny do i have?
  168. Help, is this an issue with my clutch ???
  169. Race shifting questions
  170. PRO 5.0 shifter rattle....uh I dont know now.
  171. T56 GM and Viper Throw Out Bearing (Slave)
  172. Found the Problem!!!
  173. Clutch ?
  174. Textralia problems?
  175. Reverse popping out!?
  176. Are these Pics Normal?
  177. Pics of broken slave cylinder and the cause...
  178. Looking for parts for my T-56
  179. Why is it when im nice to my trans, it treats me like crap?
  180. Clutch slipping at gear changes
  181. Bulletproof Tranny *sponsors come*
  182. Spec stage 3+ vs Cartek clutch setup.
  183. Stock clutch, the 1/4 mile and honey glaze...
  184. spec stage 3 clutch reliable?
  185. strange chattering noise
  186. Is this a third gear problem?
  187. When does the 1-2 shift get smoother?
  188. Wont go into gear after clutch swap? Read this.
  189. part number for the shim that goes in the slave cylinder
  190. torque amount on pressure plate to flywheel bolts
  191. How to keep the PP tight
  192. pilot bearing malfunction?
  193. Longevity of the LS7?
  194. M6 clutch question
  195. Spec stg 5 guys, what are you using for a flywheel?
  196. Spec 5
  197. clutch wont engage
  198. What are stock tranny gear ratios?
  199. Reverse Problems? Help please
  200. Adj. Master back to position
  201. Which clutch?
  202. Not to happy with my ram powergrip clutch.
  203. For you wanna be Textralia owners...
  204. did i kill my spec 3
  205. Stock Hurst?
  206. HELP! bellhouseing torque
  207. Start car with clutch 1/2 way
  208. rolling launch - downshifting
  209. McLeod adjustable lifespan?
  210. which clutch
  211. Race Tranny + DTE Brace installed but not hardened output shaft
  212. Got it in... now this!
  213. Switching to m6 questions?
  214. please vote!! which is the best clutch and flywheel setup?
  215. Master or Slave???
  216. clunking noise upshifting
  217. Best Clutch System?
  218. A4 - M6 cost
  219. i think i f*** up
  220. Manual to auto
  221. MityVac Help, quick!
  222. Releasing pressure on slave for install??
  223. 5th gear?
  224. Tranny problem
  225. Trans temp gauge in a M6?
  226. Are 93-97 T-56 crossmembers the same as LS1 crossmembers
  227. Guys...Is converting my A4 to a M6 gonna be worth it?
  228. LS7/LS2 combo impressions!
  229. Grooving tailhousing shifter mount for neoprene gasket?
  230. What's the cause of my Textralia clutch shudder?
  231. What the f*ck?!
  232. Centerforce Dual Friction Clutch
  233. Possible stupid question about installing LS7 clutch
  234. Pilot Bearing Installation. Ok to tap it in with an impact socket and small hammer?
  235. Clinking sound from the shifter area?
  236. Probably a dumb question but.. WTF is this skip shift thing?
  237. 4:10s ?
  238. killed rsp stage 3 clutch from carolina clutchs
  239. how hard can i launch my 98 z28 m6 at the revs with a z06 clutch
  240. new t56?
  241. Break in for textrailia?
  242. The difference between LS6 & LS7 clutches?
  243. I have a clunk
  244. T56Rebuilds.com NMCA Special For Bowling Green Kentucky
  245. Does an 01-02 have steel shift fork?
  246. Master back to stock... what do I need??
  247. Reinstalling T56 tailshaft problem
  248. Exactly how much fluid for a t56 tremec
  249. Centerforce guys
  250. Ring & Pinion pattern, please interpret.
