View Full Version : Manual Transmission
  1. Step by step LS1 clutch replacement?
  2. t56 trans
  3. what should i buy
  4. Hydraulic line into Mcleoud master...
  5. Fidanza or Spec Flywheel?
  6. Upgrading clutch, need some help ASAP
  7. M6 Transmission Fluid Question
  8. LS6 clutch ok in Cammed C5?
  9. Need Help Started Car For First Time
  10. shifting at high rpms
  11. Which one...
  12. Bleeding the Clutch?
  13. shifters
  14. Which clutch?
  15. wheels wont spin
  16. Quick question on my purchasing choice!
  17. Will I need a new fly wheel???
  18. Gf-5r?
  19. Phucen Clutches. 422 Delema
  20. Master/Slave
  21. Burning the Clutch
  22. Remote Slave Cylinder Bleeder available for FBodies
  23. Clutch Replacement ?'s
  24. sequential?
  25. Whats trans fluid do you have in your T56?
  26. If there was a manual clutch setup available for LS1's would you buy it?
  27. How many people have gone "pro-shifted" with T-56?
  28. Weird Problem
  29. t-56 and 454 will it fit
  30. insulate clutch hydro line?
  31. Grinding while shifting gears.
  32. New clutch?
  33. T-56 or even a 5 speed that'll take 1000 rwtq?
  34. Grinding into 5th gear
  35. new clutch, slave and master
  36. Raptor Shift LIght Install Q's
  37. Is it impossible to get a very track reliable clutch that is streetable?
  38. Centerforce DF 12" Clutch??
  39. What to do with old clutch?
  40. Need minor help with LS6 clutch in LS1...
  41. What is Happening...........
  42. problem with hydraulics
  43. Possible Trans or Clutch Problems
  44. T-56 3rd gear trouble need help!!
  45. Do I need to bleed if I did this... Also Adjustable Master ?'s
  46. Ticking Noise Of Death!!!!!!!!!!!!!!!!!!!
  47. Serious Clutch Diagnosis Problem. Help!!
  48. Eveyone With A T56Rebuilds.com Tranny! We Need your Photos for our Website!
  49. When are ARP bolts needed / suggested?
  50. When are ARP bolts needed / suggested?
  51. UMI short stick vs WS6store short stick
  52. does anyone know what is causing this?
  53. i think i found out the grinding noise
  54. short stick install help
  55. Master and slave problem
  56. Fundamental question...
  57. Oh no...there the clutch goes.
  58. OEM Hurst Question
  59. Slave and Master Cynlinder
  60. about to pull the trigger.... last minute question
  61. clutches
  62. big problem
  63. fedup, pissed off, frustrated!
  64. Help with starting / clutch!
  65. bronze fork pad feedback
  66. Skip Shift light 98 Z-28 SS M6
  67. Normal rattling at 100,000 miles?
  68. clutch question
  69. "ideal" clutch pedel pressure????
  70. Long lasting, stong holding clutch.
  71. BIG POWER TURBO GUYS WITH M6's
  72. Just Got Ls7 Clutch Kit ????
  73. Just Got Ls7 Clutch Kit ????
  74. Need your help guys
  75. rebuildable hurst shifter
  76. Lost Reverse, 5th and 6th!!!! Need Help!!!!!
  77. T56 Problems inside....
  78. Dumb Question is a T56 a T56?
  79. What short stick should I get?
  80. Flameball shift knobs.
  81. Changing transmision fluid in a 6 speed?
  82. clutch problem maybe?
  83. Spec 4 Clutch who here is running it????
  84. Redline for MM6 trans?
  85. 3rd gear grinding .... help!
  86. WS6 Store Short Stick on PRO 5.0
  87. Downshifting
  88. car won't go into gear
  89. Shift light install
  90. Refacing flywheel
  91. Help Quick Clutch engaging really low
  92. Who sales Fidanza Friction Disk ?
  93. 6-speed set up...whats it worth??$$$??
  94. Does the Fidanza aluminum flywheel need balanced?
  95. Does the Fidanza aluminum flywheel need to be balanced?
  96. Looks like I’m a drill mod candidate
  97. tremmec TKO-600 ls2 69 camaro
  98. What i paid for my ls7 clutch
  99. Liberty Face Plating
  100. ctsv flywheel
  101. feedback on Hurst pistol grip??
  102. come in and give me some feedback!
  103. pics of hurst shifter
  104. Ls2 Clutch
  105. clutch problem with mcleod twin
  106. strange noises=not good!!!
  107. TEXtralia owners please chime in
  108. Spec vs. Ram
  109. Purpose of shimming a clutch
  110. where can i find a LS7 clutch kit?
  111. LS7 clutch install - shim slave? Quick answer please.
  112. clutch chatter?
  113. loose qd clutch line fitting on slave
  114. Clutch problems.. please help!
  115. SPEC 3, aftermarket flywheel...balance?
  116. Looking for Street/Strip Clutch
  117. HELP......Clutch install
  118. Know Squat about clutchs Help!!!!
  119. Will an ls7 clutch fit my needs
  120. clutch fluid hydro line?
  121. clicking noise coming from tranny/clutch
  122. trans making wierd noise
  123. McLeod?
  124. Mcleod twin disc owners inside please.....important
  125. Stock T56 hp limits?
  126. Cheapest place for LS7 clutch package?
  127. slave cylinder question
  128. 1st - 2nd....problem...
  129. reverse problem
  130. problem with my 3rd
  131. how long did it take you to rebuild your first t-56
  132. removing the clutch master cylinder
  133. clutch install problem
  134. T56 eletical connections
  135. Just did the LS7 Clutch install
  136. Should I do my own clutch install?
  137. Starting problem
  138. Rear main seal leaking oil? Have I ruined my clutch?
  139. Big Problem In 4th!
  140. Gettin an Ls6 Clutch, Which flywheel do i get??!?!?
  141. Need Bellhousing Torque Specs!!!
  142. T-56 leaking after synthetic Mobil 1??
  143. Cartek Clutch? Who has one?
  144. Is aluminum worth the extra cost
  145. For those with SS and WS6...
  146. help t56 problem
  147. Mcleod Master Cyl. Line Question
  148. what the most you are willing to spend on a new clutch
  149. LS6 Clutch (Off road only)??
  150. Clutch setup? Any Opinions
  151. Help with Tranny problems please
  152. Is it Worth buying a short stick for my stock hurst shifter?
  153. SPEC 3 spacer?
  154. My Spec Stage 3 Ceramic Clutch is dead!Have questions??
  155. Help....Clutch install
  156. clutch cleaning question
  157. How do you bleed the clutch Using MityVac
  158. shifter?
  159. Spec clutches
  160. 2nd gear locks me out
  161. Clutch Pedal Slop....Need help!
  162. 500rwhp clutch choice?
  163. which clutch to buy...
  164. 02 SS stock clutch??
  165. So how long do you guys think my stock clutch will hold?
  166. stock 99 z shifter vs Stock hurst?
  167. Problems, noises, and grinds, oh my!
  168. Need a quality clutch-SLP?
  169. drill mod qustions???
  170. Harlan Two Step
  171. New Website is up and my new toll free number
  172. Spec 3 vs. LS7
  173. Short stick on stock shifter?
  174. HOLy crap Bellhousing! help
  175. bad news
  176. Any tips for installing new clutch/pp/flywheel?
  177. Slave quick disconnect..
  178. grinding noise ?M6
  179. T56 value
  180. New to transmissions, gotta few questions..
  181. resurfacing flywheel necessary???
  182. i need a clutch.....help me choose
  183. need help on Reviars for my T56
  184. Clutch help... Pretty easy question...
  185. trade shift kitted A4 for m6
  186. oh no, my clutch is gone
  187. m6 conversion people ecu flash
  188. Shifter ?
  189. part number for slave cylinder
  190. what size is the clutch master?
  191. LT1 and LS1 T56 differences
  192. T56 rebuilds.com Did a great job!
  193. 4spd. tranny
  194. Big thumbs up to Pete at Textralia for his customer service.
  195. how steetable is a spec 4 clutch
  196. t56 question
  197. need help with mityvac and clutch bleeding
  198. Clutch break in
  199. Solved clutch stuck to floor...mabye
  200. HELP where to get t56 parts HELP
  201. Mcleod twin disk clutch question...
  202. Light or heavy flywheel?
  203. McLeod bellhousing problems
  204. Complications after a4 to m6 swap?
  205. Centerforce guys inside
  206. Viper bellhousing
  207. Ram Adjustable Master Cylinder
  208. Pilot bearing removal/install
  209. HELP!Good pedal pressure but can't shift into any gear from a stop.
  210. Which flywheels will work with an ls7 clutch?
  211. Stock T56 bellhousing
  212. help with lt1 clutch install
  213. T56 vs Viper 6 speed
  214. Test drove m6 somthing weird?
  215. M6 got stuck in 4th, need help ASAP
  216. can anyone get EXEDY replacement discs?
  217. LSS question
  218. 2nd pilot bearing TRASHED on C5! whats happening?!?
  219. car wont go in gear after line lock install..
  220. Flywheel Question
  221. new clutch help!!!
  222. 6 Speed Refill Question
  223. Is my clutch sliping?
  224. clutch help
  225. ratcheting (sp?) type noise....
  226. clutch problems?
  227. P0704...guys that have done the A4->M6 swap
  228. LSS Thread Size
  229. Troubles Pullin out a t56
  230. Issue with drill mod.
  231. Will this Tranny Fit?
  232. Do I need a flywheel?
  233. Difference in steel flywheels?
  234. clutch install
  235. rattle when i push the clutch in??
  236. where do i get the.....
  237. Z06 clutch in a regular Vette?
  238. Air in Line?
  239. SPEC 5 out/new clutch in
  240. Weak petal
  241. What are the signs of a bad trans mount for a m6
  242. Weight of a T56
  243. SES light after skip shift eliminator install
  244. Tranny work
  245. Factory Clutch Life
  246. Clutch makes a ticking sound
  247. Spec Stage 3 Or 3 Plus
  248. Clutch disconnect
  249. Automatic to manual
  250. clutch feel
