View Full Version : Manual Transmission
  1. Spec Stage 3 Or 3 Plus
  2. Clutch disconnect
  3. Automatic to manual
  4. clutch feel
  5. Whats wrong with the slaves?????
  6. Ring in tranny
  7. reverse lock out?
  8. Clutch Cable
  9. 95 firebird M5 trans.
  10. New Slave?
  11. Clutch question.....
  12. Is there a difference?
  13. Assembling T56: Can't get extension housing on
  14. look what came out
  15. Double cone vs Triple cone design?
  16. How Much Fluid
  17. Easy as Pie
  18. Pilot bushing, is lube required?
  19. Spec 4 guys inside
  20. Questions about Spec II in LT1
  21. sometimes no reverse
  22. What's the latest and greatest daily driver/strip warrior clutch for 600+rwhp?
  23. Alignment key
  24. any tricks to putting tranny fluid in a T56?
  25. Clutch Suggestions ???
  26. Pro 5.0 installation
  27. my spec stage 3 DEFECTIVE?
  28. Where exactly is the clutch bleed valve (already tried "search")
  29. Experts In Here!!!! Help!
  30. Starting M6 w/o Trans
  31. is this the solid bronze pilot bearing (pics inside)
  32. For those of you who've gone from A4 to M6.
  33. What size nut for the bottom of tranny mount?
  34. Need Help
  35. POST MORE INFO on LS7 clutches
  36. what about an aftermarket flywheel
  37. Replacement to the LSS
  38. strange noise...need advise
  39. Please help me with some diagnosis of my tranny problem...
  40. Just installed a SPEC II problems!!!
  41. OEM clutch questions?
  42. 4 hours of bleeding - no trans engagement (yes I searched)
  43. Help me pick a rebuilt T56.
  44. It wont ENGAGE!
  45. Just installed Mcleod bellhousing
  46. SPEC 3 TOOK A CRAP @500 mi.
  47. Changing Fluid?
  48. Spec stage 4 Sweet clutch
  49. trans help quick!
  50. Upgrade Master Cylinder?? (550+ rwhp)
  51. Best Aftermarket Shifter??
  52. i cant shift
  53. Textralia OZ700 clutch destroyed in my car. Bad clutch or install?
  54. Spec Stage III clutch installation doc
  55. HELP!! Replacing clutch - pilot bearing question
  56. Clutch Problems...
  57. Oil coming out of flywheel bolt holes?
  58. ws6 shift knob?..
  59. Is there anything that can cause a shifter
  60. SPEC Clutch GP
  61. Need Help PLEASE!!
  62. trans input shaft
  63. Installed LS7/LS2 Clutch and Flywheel. My comments and questions.
  64. PILOT BEARING PROBLEM!! (SPEC II install)
  65. Need help picking between two clutches..
  66. need a new slave cylinder
  67. Need Help! Oil in bellhousing???
  68. Spec 3
  69. torque specs on clutch
  70. NEED CLUTCH ASAP....which one??
  71. driveshaft removal
  72. Mcleod pilot bearing install
  73. Trans sticks in gear upon hard accel: 1st, 2d or 3d
  74. SPEC is dead
  75. Striped The Crank Threads!
  76. Joe @ T56 Rebuilds, thumbs up!!!
  77. Difference in master cylinder..
  78. Thanks Ls1Joe
  79. T56Rebuilds.com Feb. Special. You Decide what I will offer!
  80. Clutch bleeding, 2002 Camaro T56
  81. Spec Stage 3+ Just Installed Opinions/Problem?
  82. Bought a clutch from ebay, how to verify what I got?
  83. T56 question plz help!
  84. Harlan 2-Step for Powershifting?
  85. short shift kits...
  86. fidanza flywheel
  87. Mr. Transmission screwed me
  88. Ticking Noise
  89. T56 Vent hose?
  90. Part number of upgraded slave?
  91. Tranny build up questions, t56...
  92. tranny problems?
  93. slave cylinder line
  94. wiring harness swap.
  95. Pro Shifted?
  96. Mcleod Twin Disc Problem
  97. Grind input shaft splines or hone-out throwout bearing retainer????
  98. what is up with reverse?
  99. Scattersheild
  100. what clutch???
  101. LS7 clutch installed today
  102. i smell clutch
  103. 2 problem!
  104. Finally burn't a SPEC 5 clutch
  105. removing t56
  106. Transmition output shaft?
  107. clutch confusion!
  108. Looking for new clutch!
  109. why do u use a ls2 flywheel with the ls7 clutch on ls1's?
  110. 2002 master and slave questions
  111. clutch upgrade
  112. Syncho Cost
  113. Anyone wo has ran a SPEC Clutch Come In!!!
  114. C5 clutch install
  115. Ordered a new Luk clutch and have Q's
  116. Looking for Syncromesh? Go to Autozone!
  117. Is it worth it
  118. t56 clutch replacement
  119. Possible Purchase: 98Z - HELP!
  120. 500rwhp ocasional 200 shot. what clutch
  121. would a bad slave cause this?
  122. grinding noise
  123. slipping clutch???
  124. Umi short shifter handle installed.
  125. reverse trouble
  126. Hurst Billit Plus shifter
  127. leaking hydraulics/clutch questions
  128. Need help with tranny install!!
  129. I need a T56 that can handle 700/700
  130. Awaiting my Textralia!!
  131. What's the difference
  132. 3 days and WHAT THE F@#k!!!!
  133. LS7 clutch swap...worth a sticky?
  134. Flywheel/PP torque???
  135. anyone know about 1999 slave cylinders?
  136. shift knob removal
  137. Adjustable Master
  138. Mcleod Clutch (LT1)
  139. howto for slave cylinder install
  140. GM Flywheel weights
  141. Anybody want an MN12 upgrade?
  142. i wanna do a t56 swap from A4
  143. Moral delima with SPEC
  144. Mity Vac clutch bleeding ?
  145. Anyone running a Meleod steel bellhousing
  146. clutch pedal?
  147. tips for removing shifter boot?
  148. balancing clutch assembly
  149. Royal purple ATF Trans fuild for t-56? good or bad
  150. Motive 4.10s installed
  151. 20,000 miles and already shifting problems?
  152. My clutch is really starting to annoy me
  153. Mcleod master cylinder line
  154. having trouble shifting?
  155. BEST CLUTCH FOR 425 HP or less
  156. Link for a clutch change: 2001 Z28??
  157. Step by Step directions on how to change my clutch?
  158. SLP LT1 Clutch
  159. Mcleod Twin vs. TEXtralia
  160. Clutch Dilemma
  161. Any experience with the spec 2+ 3+
  162. Sweet spots in an M6
  163. what RPM do you shift at?
  164. Output shaft measurement
  165. Transmission Problems
  166. cheapest hydraulics?
  167. spray & clutch choice????
  168. any ideas? invisible shift gate!!
  169. T56 Synchro keys??
  170. where to get LS7 clutch????
  171. Slipping out of third gear
  172. What effect does adjustable master have
  173. Crap or not crap??
  174. 1st, 3rd, and 4th gear problems i need LOTS OF HELP!
  175. Cheapest place to buy a clutch?
  176. Got my Stage 4 Spec today, any idea how long these last?
  177. Upgraded hydraulics for 98 T56 install questions.
  178. T-56 rebuild for cheap
  179. '97 C5...no more 3rd gear :-(
  180. Drill Mod?
  181. hardware ???
  182. Used Clutches
  183. JUST in case you get a rear trans leak!!
  184. Quick disconnect Fitting won't go back in HELP
  185. Weird tranny/clutch noise?
  186. Reverse is making a loud noise!
  187. Ups Is Here
  188. Shifting problems??
  189. taking out tranny
  190. Centerforce 12" DF Clutch installed...
  191. pilot bearing trashed, what was yours like
  192. Vibration/Rattle, Clutch????
  193. which mity vac?
  194. clutch slipping?
  195. Skip Shift
  196. How to rid my car of this vibration...
  197. Looks like LS7 clutch can hold some power
  198. Color of tranny fluid ?
  199. Anyone Shortened B&M Shifter?
  200. LT1 T56 into an LS1 car
  201. HELP! Ready to give up!
  202. Who actually makes the stock 6-speeds
  203. shifting problems with t56
  204. Tranny blanket
  205. Clutch pedal sticking 3rd/4th
  206. Bad vibration...???
  207. T-56 And 1000hp
  208. gears won't go in
  209. rattle from shifter?
  210. Who has Textralia Clutches in stock?
  211. Dead battery after shift light install?
  212. GM TSB 04-07-31-005 M/T - Clutch Pressure Plate Wear Indicator Adjustment
  213. GM TSB 01-07-31-002A M/T - Improved Hydraulic Clutch Bleeding Procedure
  214. Clutch decision..
  215. Best mpg?
  216. explane the TO bearing to me
  217. A T-56 On '68 firebird(anyone)
  218. 5th or 6th gear on highway??
  219. clutch pressures
  220. Bleeding the clutch is killing me!!!!!!!!!!!!!
  221. What parts do i need!?
  222. rusty flywheel!!!!!!
  223. T 56 or TKO 600???
  224. At what point do i need an upgraded clutch?
  225. Reduce The Noise
  226. Rear end gear for T 56?
  227. T 56 gears
  228. T 56 in stock Chevelle console???
  229. Are all T56's in GM vehicles interchangeable?
  230. How many running the Textralia clutch?
  231. Spec Stage 2 or RAM Powergrip HD
  232. clutch master cylinder ?
  233. Steal or aluminum flywheel?
  234. Factory hurst into 06 Goat
  235. changing clutch master cyl, need advice
  236. Where to buy Textralia cutch?
  237. What RPM to shift at, also to set shift light?
  238. new clutch, cant put in gear.
  239. A4 to M6 swap peeps get in here!!!
  240. Identify year of T56? Vent? Torque Arm mounts?
  241. What kind of grease in shifter housing?
  242. Looking for opinions on Ram Powergrip HD
  243. Another T56 2nd gear problem
  244. pro 5.0
  245. Rebalance clutch with alum. flywheel
  246. Clutch Pedal down for the count!?
  247. Rebalance clutch with aluminum flywheel?
  248. replacing your hydraulics
  249. luk clutch?
  250. Shift light install?
