PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 [89] 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130
  1. Pro 5.0 review
  2. T-56 price?? For sale?
  3. Lost rubber gasket in master cylinder reservoir do I need it?
  4. what gears for my 9inch/rim advice?
  5. ram VDS clutch questions/advice
  6. quick rpm question
  7. 01 z06 trans problems
  8. Quick Shifter Question
  9. f*&8^n transmission isn't going back in
  10. GMM Ripshift broken
  11. Out Put shaft thread size?
  12. Need Help With Ls7 Clutch!!!
  13. where to buy ls7 clutch kit
  14. do i need a...
  15. Question about transmission fluid
  16. fluid leaking please help
  17. M6 won't drop...HELP!
  18. POLL Use a mity vac to bleed or not?
  19. Hydraulic Line Removal HELP!!!
  20. Removing the Actuator cylinder line
  21. LS7 Clutch engaging RIGHT OFF THE FLOOR?
  22. HELP!! quick please
  23. New Clutch squeaking?
  24. New slave for 02 z28?
  25. Look at what came out of my car after the clutch swap !!!
  26. Ls2 flywheel difference...
  27. Just bought a Pro 5.0, how to install?
  28. Just bought a Pro 5.0.....
  29. ss Ralley Red is AWESOME Ls7 clutch install!!
  30. Recall on LS7 Clutch's ????
  31. Master cyl braided line ?
  32. LS7 Clutch on stickys at the track? Feedback on this application only please.
  33. I need a quick answer, which way does the pilot bearing go in?
  34. Clutch Removal..Spec III pics
  35. Spec Stage 3 Praise?
  36. Does the b&m ripper shifter have stoppers?
  37. question about tranny storage.
  38. Centerforce comes through again!!
  39. bad master cylinder symptoms?
  40. too hard to get in gear!!!
  41. Strange clutch issue. please help
  42. Old Clutch Fluid Problems?
  43. GMM Ripshift rattle
  44. bleeding the clutch?
  45. shifter for birthday...help me decide...please...
  46. Wish Me luck With Textralia Install
  47. New Clutch and old fluid?
  48. Housing
  49. Drill mode
  50. LS7 clutch with adjustable master
  51. Centerforce guys come in.....lookin for some advice.
  52. Is my shifter bad?
  53. Alum flywheel or billet steel with Ram HD??
  54. A4 to T56
  55. Replaced 02 Z-28 w Z06 Clutch
  56. Skip Shift Eliminator Light Still On?
  57. no speed
  58. whats this noise- how to fix it?
  59. Clutch help
  60. ls7 Clutch where to buy
  61. Have a A4 Z-28 looking to go M6
  62. Pro 5.0 and WS6store stick.. questions !?
  63. ls7 or AFter market?
  64. Broke the center section out of my Cartek Clutch...What should I get now?
  65. Couldn't get in any gear? Help please!
  66. Pressure Plate bolts?
  67. LS7 clutch need help
  68. Shipping Help
  69. Clutch/Trans Problem?
  70. What is the purpose of the springs in the clutch disc???
  71. T-56 problem after rebuild
  72. transmission part replaced with t5 part
  73. Tooth missing off flywheel?!?
  74. 3.42-> 3.70 gear, how off is my speedo?
  75. Z28 Clutch Install Guide?
  76. LS7 clutch installed!!!
  77. Slave cylinder/throw-out bearing?
  78. 2006 C6 clutch LS2
  79. Trans mount blues...Cause knock!!??
  80. Simple question: What gears are best for roll racing?
  81. inspection cover
  82. sticky gears?
  83. grinding 3rd?
  84. New RAM HD Install How long should I break it in for?
  85. Slipping Clutch?
  86. Three On The Tree
  87. Best Short Throw Handle.
  88. Anyone done a clutch/tranny on garage floor?
  89. How much fluid does a the slave, master and lines hold?
  90. Hard Shifting at WOT....
  91. Lucas Oil Treatment
  92. clutch install torque
  93. Textralia clutch and mcleod bellhousing are in - my comments inside
  94. LS& clutch users...question for you
  95. Damn stock clutch...question inside
  96. Question about Clutch Slave Cylinder and Shim
  97. what new clutch/flywheel/pressureplate to buy?
  98. What Is The Part # For The Ls7 Clutch Kit And Ls2 Flywheel Thru Gm?!
  99. pedal throw?
  100. Reverse lock out.....Question
  101. t-56 Removal Questions/Help
  102. Clutch setup for Gen 3 /TKO600 engine swap
  103. best adjustable master cylinder? any why is it the best?
  104. Wanting to beef up my t56
  105. Am i being charged too much to repair my tranny?
  106. skip shift
  107. Lt1 T56 ?
  108. C5 Corvette Clutch Hydraulics
  109. Clutch Question
  110. options for 450-500rwhp manual trans
  111. 71 muncie to t56 swap
  112. Transmission problem please help!!!
  113. Is it really worth the money?
  114. Which clutch fluid do you use?
  115. For the smoothest shifts...?
  116. Those who have installed a UMI short stick...
  117. Spec stage 5 slipping w/ 8k miles NO abuse
  118. Clutch Problem
  119. Setting the stoppers on pro 5.0
  120. Hurst Billet Shifter Issue...
  121. T56 Transmission swap
  122. Black muddy inky stuff in hydraulic resiv.
  123. M6 Shifting Problem
  124. T56 (M10) measurements
  125. Define Powershifting...
  126. T56 Synchros Out????
  127. what color plug for speed sensor on m6
  128. Oreilly master cylinder
  129. How Do The Pedal Comes Out
  130. slave clynder
  131. Clutch/Transmission
  132. can i get just a clutch?
  133. Ok more recent textralia feedback please
  134. trany wont go back in?...help!!!
  135. Used Parts - Where to Buy?
  136. No lube = T56 MELTDOWN! Pics...
  137. 01-02 slave part number?
  138. car in neutral=rising rpms?
  139. quick shifter question
  140. McLeod Single Disk Problems Help!!
  141. Return Spring *PIC*
  142. Cobra T56 in LS1???
  143. 6" or a 6.5"?
  144. does a vert use a different crossmember than hardtop/t-tops?
  145. T56 Questions Plz Help!
  146. Clutch death question ....
  147. grinding noise when coasting to stop
  148. SPEC sucks!
  149. How far can tail be lowered when removing trans?
  150. RAM clutches?
  151. What is McLeod contact info?
  152. hard clutch pedal stickin low!!!
  153. About to upgrade clutch, what else should I change while I'm in there?
  154. Ls7 clutch beatdown !
  155. What do you use??
  156. 01 Dodge Ram 3/4ton NV3500 Clutch issue, I need some input!!
  157. Clutch riding debate
  158. Any Members Looking To Do M6-A4 Swap?
  159. LS6 Master Cylinder? *PIC*
  160. WARNING SPEC parts and customer service...
  161. My Mcleod SFI bellhousing does not line up
  162. RAM Street Dual disc
  163. do i need the mcleod adj master with there clutch?
  164. T56 Turbo truck clutch poll
  165. NEW T-56 rebuild and new CM clutch... wont go into gear.
  166. Thunk/pop on hard decel & when reversing up an incline - Drivshaft/tranny
  167. What clutch do i have?
  168. shudder problems?
  169. Clutch Problems
  170. LS7 Clutch guys, come in!
  171. SPEC 3 in a '99, No Flywheel and Upgraded Hydraulics
  172. Slipping/Shuddering Clutch
  173. Stuck in 5th T56 Tranny Please Help
  174. Flywheel????
  175. Will the C6 shift knob fit a Lou's Short Stick?
  176. HELP!!!!!!!! Drivetrain angle confusion:trans to rear parallel angles necessary?
  177. Reverse Lights...
  178. Resurfacing flywheel
  179. Harlan shift light question
  180. Good (firm) pedal but clutch won't completely disengage
  181. Slave cylinder loose?
  182. Just how good is the factory Hurst shifter?
  183. LT1 hydraulics vs LS1 hydraulics
  184. Hurst shifter?
  185. I think I killed my clutch
  186. And I forgot to order some stuff...
  187. Some nasty noises!
  188. Where to get new disks for my street twin?
  189. Ram HD gets its 1st test!!!
  190. slave cylinder issues
  191. 402+N20 Clutch
  192. Spec stage 3 is gone...... need some pointers on picking out a new clutch
  193. Guys with pressure plate bolt loosening, may have a partial explanation
  194. changing the clutch fluid?
  195. Synchronizer
  196. Clutch Problem... Need Help
  197. My slave that came with Textralia clutch - is it correct one??
  198. TEXtralia OZ700 options questons
  199. whos got the ls7 clutch?
  200. Do Not Buy Ram Clutches
  201. Quick disconnect + Air in Clutch line ??
  202. I think I need a new tranny!!
  203. Shifter shaking violently... Loud knocking...
  204. trans repair cheap
  205. Clutch/Slave/Master Cylinder question
  206. feels like clutch is slipping
  207. Spec Stage 2...With this combo?
  208. Clutch in but ?
  209. transmission problems (m6)
  210. needa quick answer
  211. Could wrong fluid cause a grinding when power shifting?
  212. Some stupid questions for an idea I have...
  213. GM 1LE Tranny Mounts
  214. your thoughts on spec stage 1 clutch
  215. !cags
  216. T-56 just rebuilt..... stiff as a board? Break-in time?
  217. I downshifted to 3rd on the interstate....
  218. Which clutch???
  219. Transmission Gear Grind
  220. Flywheel Question HELP!!
  221. What the hell happend
  222. mcleod and shim?
  223. Please explain/describe clutch "chatter"
  224. Center Force DF question???
  225. Hurst Billet Plus Shifter./ FASTENAL
  226. Tranny Swap!!
  227. Finished New Clutch INstall Need Help
  228. Hydrolics ???
  229. Clutch install question.
  230. winding when in gear
  231. What happened????
  232. What is a (never used) NOS 93 T56 Worth?
  233. Need Help to solve clutch problem....
  234. M6 and M5 tranny issues that are similar
  235. Clutch for T56 and 800+ WHP?
  236. I just cant figure out my problem
  237. forged t56 internals?
  238. Polyeurathane tranny mount question
  239. What manual transmissions will bolt to 4.8?
  240. looked threw the sponsors BUT reco on Trany?
  241. Is 93-97 T56 the same as the 98-02 T56
  242. Clutch question?
  243. slave cylinder problem
  244. My 93 04 LS1 mustang, mating MN12 ?s.
  245. How many of you are using the ls6 clutch
  246. My Nearly New Pro 5.0 Not Returning to Center
  247. New clutch cost...
  248. what throwout bearing??
  249. Tranny install question
  250. McLeod twin disk arrived
