View Full Version : Manual Transmission
  1. Yet another sucsesfull Textrailia clutch install!
  2. is it possible
  3. Change the fluid in my M6?
  4. How to get access to reverse lockout solenoid
  5. pro 5.0 rules!!!
  6. Need advise and help please M6 rebuild, PLEASE RESPOND ASAP
  7. New clutch time
  8. Clutch's/flywheels On Sale!!!
  9. In your opinion, will a Z06 clutch hold up to what I will be doing?
  10. hurst billet plus short throw or pro 5.0?
  11. Clutch won't disengage
  12. Anyone know the power rating on the Spec Stage 4?
  13. Clutch Slipping?
  14. Double checking that I'm ordering the right parts
  15. Question about Mityvac
  16. Problems with 3rd and 5th??
  17. need expert advice, kinda long...
  18. Other shifters: Kirban, Steeda?
  19. Stuck in gear??
  20. shortest shifter
  21. I broke the Hydraulic line on the throwout bearing.....
  22. Fluids in M6?
  23. Quick question
  24. Stuck Clutch
  25. Shifter install..
  26. ram or mcleod
  27. Powershifting: The right way.
  28. Installed RAM PG...gear problem, HELP!
  29. Will master cyl adj make clutch slip?
  30. Lots of Chatter with Stock Clutch
  31. Complete M6 to A4 swap!
  32. RAM VDS questions
  33. How long did your RAM last
  34. M6 Slipping from 2000-3000 RPM, WTF???
  35. Slipping the duel friction centerforce with under 400rwhp, WTF?
  36. Noise comming from clutch??/suggestions on new brand
  37. m6 ?'s
  38. 76t/a
  39. 2nd gear
  40. Ram Pghd
  41. WTF is Chatter???
  42. clutch bleeder screw brokeoff
  43. Trans Problem- something loose
  44. vibration through clutch
  45. ARP Fly bolts - torque spec
  46. shower of sparks?
  47. some M6 questions
  48. Spec 3 + RAM adjustable m/c = no chatter?
  49. Clutch for 800+hp drag car
  50. how do I get flywheel off
  51. Clutch Vibration
  52. clutch prob
  53. Why?
  54. M6 shifter neutral safety switch idea
  55. Clutch delema
  56. Clutch Fluid Question
  57. Clutch suddenly won't fully disengage
  58. Clutch pedal sticking
  59. Pilot bearing - which way?
  60. T-56 problems shifting
  61. What else is need in my new setup???
  62. New Ram Powergrip installed
  63. Adjustable Master
  64. HELP! Bellhousing is stuck!
  65. SPEC came through
  66. HELP!! New clutch came. Its scratched, dirty and banged up. Is this ok? PIX
  67. Pro 5.0 shifter guys in here.
  68. Broke the stock flywheel into 3 pieces.
  69. SPEC stg4F engages inches off the floor???
  70. Don't Know Squat About Manny's, Help Me Find Out What's Wrong With My M6...
  71. reverse lockout?
  72. How long does the stock clutch last?
  73. difference between 2
  74. anyone using rps clutch?
  75. ls1 and tremec tko600
  76. stuck in 4th
  77. ? about reverse
  78. Clutch time. A few questions...
  79. Spec clutch
  80. What brand is the oem clutch
  81. 6, 5, 4th gear??? Tranny questions
  82. car missing after clutch install
  83. Textralia finally installed, now car won't start
  84. Clutch Return spring ... Instalation
  85. Clutch break in
  86. Flywheel, to buy or to resurface
  87. Drill mod
  88. I have an interesting problem.
  89. Some advice for textralia..
  90. Time to rid the A4!!!
  91. Pro 5.0 shifter install.....inner boot????
  92. At Home Clutch Install... Anyone who has done it come in!
  93. Clutch Install Question C5
  94. which short stick?
  95. Brass Pilot Bushing
  96. shifting funny
  97. 2000 z28 wont go into gear
  98. reverse lockout pigtail
  99. M6 Offset Lever Roll Pin
  100. cant shift when racing, shifter keeps getting loose, whats wrong?
  101. th400 back to a 6 speed...have an issue
  102. Textralia questions...need info...
  103. hydraulics question
  104. reverse?
  105. my stock clutch!!!
  106. My impressions of the Ram clutch...
  107. Clutch Install
  108. What the hell is this thing?
  109. Shift forks
  110. mcleod info?
  111. Installed Prothane Mount
  112. whats the most i should resurface my fly with...
  113. complete package?
  114. can 94to 97 t 56 fit in to 2001 ls1
  115. A4 to M6 swap complete. Clutch questions inside.
  116. Need some quick help...
  117. spec 3 took a dump tonight.....
  118. Help with my clutch install....
  119. Centerforce Duel Friction Install w/ a vibration
  120. Pro 5.0 Shifter
  121. shifter/ trans question
  122. stock shifter's threading?
  123. Z06 Clutch or Snake Oil
  124. Tip for first time clutch changers (OEM)
  125. wtf clutch?
  126. Skip Shift Problem
  127. swap complete, PLEASE HELP ASAP
  128. Textralia
  129. Throwout bearing size question
  130. T56 swap complete!!!
  131. Sick T-56 in to see the Doctor...
  132. I think I found the problem
  133. So many M6 problems...where to start?
  134. Little hard to get into first.
  135. I have a dumb question.
  136. Anyone who has installed a clutch themself, Come in
  137. loctite flywheel bolts?
  138. Just got my new clutch done!
  139. clutch slip??
  140. new slave
  141. Impression of Pro-shifted T-56 and Spec 5
  142. Why do you need an adjustable master?
  143. last chance for the T56
  144. Here's one for you gurus...
  145. Trans Swap???
  146. Clutch Help Please
  147. Need Clutch/Master Cylinder Advise(I did search)
  148. Pilot bearing ????????
  149. Really Mad Please Help
  150. will willwood high temp brake fliud mess up my clutch hydraulics?
  151. Bore I.D. on stock clutch master
  152. B&M, Pro 5.0, SLP?????
  153. Who makes adjustable master cylinder for corvette C5 ?
  154. Slave cylinder shims
  155. Mcleod Twin disk or Ram VDS?
  156. New T56 owner
  157. Spec Clutch?
  158. Brake pedal wiring
  159. cutting a pro 5.0
  160. Hurst Ball Shifter Knob question
  161. Bent Fork... Damage???
  162. Dumb Hydraulic question...
  163. Now I need a 6 speed swap!!!
  164. How to tell when clutch is going out?
  165. Major leak from rear of tranny, bushing AND seal?
  166. Tranny rebuild... could my friend and I?
  167. Whats this?
  168. DUMB question... Reverse
  169. flywheel
  170. Clutch fork???
  171. Drill Mod?
  172. Shifter Problems..
  173. Short Shifter
  174. Bullet Proofing T56
  175. Pro 5.0 shifter
  176. Clutch Broken??...please help!
  177. Skip Shift installed.. Still not pleased..
  178. Drive shoe-less?
  179. Help guys serious slave bleeder problem.
  180. Need A New Clutch Now!!!
  181. Mcleod master questions...pedal feel ,etc.
  182. Tranny
  183. hydraulic fluid? Transmission Questions
  184. SPEC 3 broke spring?
  185. Sound lk a shifter or tranny problem to you?
  186. BIG thanks to RPM Transmissions, and Textrailia!!!
  187. which short shifter is the best for my T-56
  188. clutch quick disconnect
  189. 3/4 synchro replacement
  190. play in t56 rear bushing
  191. anyone running the VDS Ram setup?
  192. Make up MY mind...
  193. Humor me
  194. Help With Billet Flywheel
  195. Another Textrailia that doesn't work...
  196. Do I need a new flywheel also??
  197. Opinions on Pro 5.0 Shifters PLEASE!!
  198. What's wrong with my tranny?
  199. TCS going on-off with out use of switch
  200. Bleeding the Slave cylinder
  201. Do Ram Powergrips work with stock hydraulics?
  202. Please Help!!!! Trany Or Rear Problem
  203. reverse lockout help
  204. M6 Gurus... advice?
  205. soft pedal after shifting hard
  206. anyone that's cut hole in floor to get bleeder valve
  207. pro 5.0 centering fix problems
  208. Clutch Pedal Clicking Noise
  209. Clutch review- Carolina Clutch Stage 3
  210. Revers Lockout.
  211. will my t56 hold up to my slp 402 stroker and mccleoud clutch
  212. Manual Trany problems
  213. lt1 t56 flywheel
  214. slave question
  215. effects of slippage
  216. Help! Hurst Shifter Install
  217. Do the new Z06 Masters need the line mod?
  218. LS1 T56's, Borg Wanger or Tremec questions...
  219. drill mod ?
  220. drop into second, CHUNK!
  221. c6 shift knob
  222. Tranny Fluid Question
  223. SPEC 4/5 iron guys in here
  224. Opinion on Center Force dual friction clutch for LS1
  225. New Clutch Set Up Whats Best?????
  226. clutch which one???
  227. Ram adj master ??
  228. Won't go into gear passed 5000 RPM's
  229. TKO600, help!
  230. Where did the fluid go
  231. b and m ripper in a 2004 gto
  232. 4 speed behind a LS1 and still have hydraulic clutch?
  233. pro 5.0???
  234. Taking the tranny down...
  235. Tranny Dr.s: diagnosis...PLEASE (long)
  236. LS7 clutch info?
  237. switching clutches
  238. when taking out tranny, fluid just poured out of the output shaft
  239. What is the depth of the stock bellhousing?
  240. Quick Manual Trans Q
  241. trans mounts
  242. general clutch question...
  243. Anyone ever snap their Cartek/Adjustable Master?
  244. Shift Boot Clip
  245. Clutch Sliping?????????????
  246. short stick
  247. how much is this T56 swap setup worth??
  248. Need a new clutch
  249. Pro's and Cons's of Aluminum Flywheels
  250. Silly clutch bleeding question
