- Grease for TO bearing?
- spec level 1
- Spec F Disk issues
- ARP Flywheel torque spec?
- clutch adjustment
- Help with leaky master cylinder
- Flywheels!!!!!!!!!!!!!!!
- Leaking Fluid From T56 question.....
- Clutch
- Exedy owners inside please..
- Question on my slave
- Clutch Master Cylinder
- name of transmission place
- Haven't seen this post before
- Removing and installing tranny/clutch???
- i hate to ask, but which clutch should i get?
- Will my Z06 clutch slip with heads/cam?
- Violent shaking when I start rolling from a stop
- drill mod done, and now...
- LT1 T56 prob
- clutch probs, HELP!
- ls1 tranny yoke
- drill mod necessity
- quick LT-1 clutch fork question
- Clutch Slippage?
- Clutches, which one?
- Length of the LSS?
- Lightened flywheel
- Trans mount
- Transmission noise through shifter:
- aluminum or steel??
- stupid question: would a pro 5.0 shifter from a t56 in a 03-04 cobra, fit an ls1 t56?
- Spec III i question/problem
- Help with new shifter
- Throw out Bearing
- Hard to find 3rd and so on
- Tranny starting to whine.
- how much do i adjust the master cylinder?
- shifter moves when i get on it
- LT1 pedal & crossmember in LS1 car?
- uh oh clutch petal meets stupid friend
- hurst shifter feels loose
- Tranny's not doing so good. Getting worse.
- centerforce or spec? master/slave? any clutch install tips??
- what clutch
- LS6 or Centerforce throwout bearing? (and other clutch ?'s)
- Flywheel / Clutch Balance question.
- SPEC 3 install - shift noise!
- Any one have a Spec Stage 3 Hybrid?
- Anyone have a D&D T56 trans?
- couple of post-install concerns
- a little confused...
- Shift Selector Assembly pics?
- Ram clutch review under hot laps
- T56 in a 2000 Silverado
- clutch install finished, reverse no worky
- Can a Clutch Slip at High Speed
- I need some technical opinions on a clutch problem
- "What Spec number and letter are we up to?"
- clutch feel
- T56 Oil Temp?
- will she make it? spec 3's last leg...
- Spec Clutch & Fidanza Alum Flywheel
- clutches
- Odd RPM problem when in neutral
- clutch or something else
- Tranny Rebuild And Clutch Cost?
- clutch sticking to floor
- Mushy Clutch pedal...what do I need to do?
- Help with Spec clutch install please! Shim or not? for C5 hydraulics?
- Question?
- help! pp bolts won't go in
- Gears too high/thin tires?
- Another SPEC HORRIER Story
- 19K miles T56 Problems....HELP
- Q's about ls1 TO bearing
- Pro 5.0 problems? Or just Problems
- Best deal on a Pro 5.0 and LSS?
- What kind of shifters do you guys have?
- Spec Vs Ram
- slave cylinder
- flywheel resurfacing question
- Two Step Users?????????
- How many miles do you have on your clutch?
- diagram of bolts?
- do i need a new clutch or new hydro cylinder??
- Swap an M12 Z06 T56 tranny into a 99 C5 w/ an M6 t56 tranny?
- Question about 3rd gear....
- Where to buy flywheel bolts, pressure plate bolts, and tranny bolts??
- PP and flywheel bolts
- Flywheel?
- clutch prolblem?
- PRO 5.0 Question
- Any Thoughts?
- What are the T-56 Drive Ratios?
- "T56 King"
- What should I do with the t56?
- Whats the Problem?
- Car wont go into gear. Need your opinion.
- SPEC clutch issues? (kinda long)
- What kind of shifter do I have?
- Spec 3F Installed Today
- Tranny Leak...HELP!
- Clutch break in
- T56 gear puller?
- T56 pooping out
- flywheel questions
- Just bought Ram clutch....Balance?
- Master/slave cylinders...
- Pro 5.0 is it the same as the cobra?
- Lou's Short Stick Installed
- I need a clutch
- Slave Cylinder Problems
- Z06 clutch in - pedal too low
- 1999 T-56 yoke size
- Tranny Mount
- I need your opinion guys...
- Clutch spec 3 or Ram HD
- Hays clutch any good?
- Clutch disk only???
- Clutch Problems.
- Clutch Slipping Help
- Spec SIII w/6 puck disc lasts only 6500 miles.
- are ls1 and lt1 t56 different????
- Clutch Installation help
- Compilation of specific tools needed for T56 rebuild
- clutch decisions
- My Rebuilt Trans is acting weird..HELP PLEASE
- cheapest place for rebuilt T56
- What's the word on the Harlen Drag Cags??
- Just ordered a Ram 3 powergrip clutch kit
- Spec dealers, rebuild question inside, cost?
- How much does the zo6 clutch assembly weigh?
- Clutch going and my Low Trac is acting up
- Car would'nt shift into gear
- Ughh
- Broke the T/A!!!!!!!!
- Is this normal? Pics inside.
- Help my clutch pedal is riding high
- HELP! slave quick connect wont come off
- Spec 3, 02 Slave, drill mod, and Viper Spec installed!
- 2nd gear
- new clutch..
- throwout barring???
- Z06 clutch ?
- 6-speed transmission corvette C5 - Camaro LS1 the same?
- Need Help
- SFI T56 Bellhousing
- centerforce are strong
- T56 Swap into NBS truck?
- slp or pro 5.0
- Is my 5-6 speed gear messed up?
- how can i build my own bullitproof T56?
- help
- so confused...
- Slave & TO Bearing numbers?
- 4.10 ET gains
- tips on driving manual??
- bang... and now wont shift.. what the hell?
- M6:Grinding noise when i accelerate?? Help!
- New Procedure to bleed the hydraulic system
- Where to buy Trans mounts?
- transmission yoke
- Killin Me!!!!
- ?Tremec Transmissions? How accurate is this?
- Is the T56 out of cobra same as camaro?
- mityvac - Ton's of bubbles-can't blead
- Anyone ever order a New GM slave from Spec?
- Good trans shop in Eastern NC?
- With MeLoed clutch, pedal all over the place.WTF?
- hurst billet plus Q
- Whats wrong with my clutch??
- tranny grinding when coming to a stop
- 1st gear bog down???? HELP???
- Are there 2 different McLeod Master cyl.?
- Problems with shifting at high RPMs
- and my clutch install saga begins...
- Is an M6 stronger than an A4?
- rear bushing in T-56
- 2nd Gear Slip
- Line Lock Users Come Inside
- lookin for rebuild?
- First Drive Since Pro 5.0 Install
- wheres a good trany shop in CT?
- Stock feel clutch?
- Part Number For Gm Mt Synchromesh??
- About to order textralia clutch, any reason not to?
- Manual guys - what RPM you usually shift at in normal driving
- help with problems after tranny swap
- spring broke on clutch pedal
- Bad Slave Cylinder
- New Transmission Fluid
- part # for clutch alignment tool.
- Help, mushy clutch, how do I re-route line to solve the problem?
- can't downshift from 6th to 5th
- fidanza shifter?
- good clutch for oldschool?
- problems with t-56 after a day at the track
- Identifying Transmission...
- Short throw
- LS1 4L60 to T56 SWAP Guide
- Well I took the Tranny out and...
- Burn out?
- Vibration At high speeds.
- A4 to M6 pedal question
- clutch went down south...... help please!!
- second gear help!!
- really hard to get into gear
- new z06 flywheel with spec ok?
- How much power can you throw at a T56?
- Shifter Shaking like...
- Clunking noise after I shift
- Shuddering.....
- New owner questions
- stock flywheel and spec 2
- Trying to handle 600rwhp?
- z06 gear box question
- Did I just get owned by a Trans Shop???
- Where to get my SPEC3 and LS6 slave/MC
- phase 2
- Brand new SPEC III slipping.....help!
- Anyone else afraid of their Pro 5.0 shifter?
- Shifter whine
- Won't go in gear
- Identify This Tube In The T56 Tranny
- T56 or ZF 6-Speed?
- Master Cylinder Hole
- Spec Stage 4 and Flywheel
- are these the correct GM part numbers for master and slave?
- Mcleod twin slipping? or hydrolic problem?
- Pulling the Trans
- the plastic white cup under the shifter
- changing clutch master cylinder
- centerforce
- pilot bearing help please
- Dropping a T56 in an Auto
- Pro 5.0 upgrade
- How do you tell if....
- Spec 3 friction disk
- Any1 made a T56 Drill Mod Write-Up?
- clutch upgrade 2001 ta
- slave line
- anyone wanna trade t56 for my 4l60e? NY,will drive 2 trade
- Nos
- RAM HD Installed
- slipping
- the truth about spec?
- zo6 clutch
- PPLS choice on clutch kits
- Stock ADJ master cyl?
