View Full Version : Manual Transmission
  1. pilot bearing situation!! help needed!!
  2. How do I identify if I have "viper" 2nd gear
  3. LS7 clutch problem, pics
  4. loseing pressure in pedal. help!!
  5. t56 bushing help!!!
  6. desperate help needed for car in shop, they cant bleed the slave and master!?
  7. got a bang going on in rear area for car
  8. Well my clutch is toast... Opinions?
  9. Ford TKO500
  10. monster clutch help...
  11. Tick master won't move any fluid?
  12. New T-56 Grinding 3rd
  13. T56 Mod for Speed Shifting?
  14. Camaro SS 2002 Transmission Rebuild BW Tremec T56 experiences
  15. clutch review
  16. "Drill Mod" bit size
  17. t56 torque rating
  18. Clutch soft when cold
  19. best low cost, lighweight, low power, clutch
  20. use Kubota Super UDT as clutch hydraulic fluid?
  21. Ford TKO500 behind 5.3l, couple ????
  22. replaced slave cylinder, clutch, and master cylinder and still have sticking pedal
  23. Tranny Mount
  24. vibration/engagement issues after clutch/flywheel replacement
  25. who makes the best six speed trans for the 98-02 platform
  26. Need Clutch Suggestions
  27. Master to slave cylinder line.
  28. Squeaky Clutch...
  29. Quick, probably "stupid easy" question...
  30. Play in clutch pedal
  31. HELP!!! GTO Slave cylinder to -4AN?
  32. M6 drive shaft
  33. Tick Master
  34. Hitting a wall with reverse and 1st
  35. 02 SS, Will not shift into any gear... Questions/Advice
  36. Popping out of gear after header install
  37. Clutch or Transmission?
  38. high revs = stiff clutch and raised pedal HELP
  39. Pretty sure my monster level 3 is tired
  40. T-56 swap.. Another :/
  41. GM Synchromesh-which one???
  42. Installed my Tick Master Cylinder/ Monster Stg 1 Clutch, Very Happy!
  43. T56 Tranny Problems. PLEASE HELP!!!
  44. Is this normal?
  45. Need advice on clutch and trans issue..what should i step up to?
  46. Viberation after clutch install?
  47. C5 m6: 5th & reverse gears grinding. Please help!
  48. Another stuck-in-3rd issue, not forks or keys
  49. Why can I shift into reverse while moving forward?
  50. 1st and 3rd gear problem
  51. Land rover defender - ls3 engine, manual trans & transfer case
  52. Monster 3 clutch pics
  53. A little Clutch Issue (Mcleod)
  54. flywheel indexing
  55. HELP !!!! new clutch issues ?????
  56. UMI short shifter lever
  57. FBody/GTO T56 In Foxbody question
  58. 2nd gear grunt/grind with viper stlye gear
  59. grinding and rough going into every gear
  60. anything good about the ram force 9.5 clutch
  61. What does it mean when car moves at WOT with clutch depressed?
  62. Shorten LT1 B&M Ripper shifter throw?
  63. Ls7 clutch to fit my needs?
  64. Hole in bellhousing.. Repair?
  65. T56 can't select second even engine off
  66. opinion on T56 upgrade from 27 spline output shaft
  67. Help Choosing New Clutch Kit.
  68. SSR hybrid upgrade finished...with problems
  69. convert lt1 t56 to push slave to use with ls1
  70. LS6 clutch with aluminum flywheel?
  71. How do I align a QuickTime bellhousing properly?
  72. Are the C5 Z06 and F-body slave's the same? Other than the hyd line?
  73. need help with different kinds of clutch master cylinders
  74. t56 used mainshaft wanted
  75. Best streetable Lt1 clutch for 550-600fwhp 385ci?
  76. Best streetable 600rwhp/tq clutch?
  77. need opinion of spec clutchs plz
  78. 2006 T56 from a C6 TO a 2000 C5 - direct fit?
  79. How much would a 150k+ miled LS1 T56 go for?
  80. 2002 M6 Trans mount ES or Prothane?
  81. need advice on best non adjustable master......
  82. T56 Grinding in 3rd & 4th
  83. 2000 TA T56 slides out of gear
  84. slave cylinder compressed height
  85. MANTIC CLUTCH---Free Shipping + Get 10% Off Your Next Order!!!
  86. Tick MC part request
  87. T56 Front shift shifter
  88. used T56 inspection
  89. LS7 Clutch's max ability
  90. 4L60E Vs. T56
  91. Transmission specialists PLEASE I need help
  92. Clutch bleeding question
  93. Clutch problems...Please help
  94. A4 to M6 conversion: 2000 T/A ...???
  95. Transmission rear leak
  96. possible slave leak?
  97. LS2/T56 clutch choice
  98. 2002 t56
  99. pilot bearing O.D. to small?
  100. In need of a t56 rebuild
  101. T56 feels like it wants to pop outta 2nd
  102. gto bellhousing going on fbody
  103. Hybrid T56 project
  104. tick master where does you pedal grab
  105. Monster stage 3/4 or 11 inch?
  106. best place to get a t56?
  107. aftermarket transmission yoke guys...
  108. Monster TD LVL 3 or the Borg and beck TD
  109. anyone with a quicktime, is ur clutch noisier?
  110. LS7 clutch good?
  111. Clutch Bleeding Hell
  112. Poly tranny mount, what's the consensus?
  113. T56 Removal
  114. slave cylinder fitting cut
  115. reverse solenoid connection
  116. Thanks to Tick
  117. T56 Throw out bearing sleeve broke - Help
  118. LT1 clutch making odd screeching noise
  119. shifter boot replacement or any ideas?
  120. slave cylinder quick disconnect won't go back on - please help!
  121. who has the best price on these parts
  122. For a car with less than 400 rwhp, what clutch would you recommend?
  123. Trans fluid
  124. hydraulic/clutch question??? really need help please
  125. Which Slave Cylinder????
  126. American Powertrain White Lightning Shifter
  127. T56 hard to shift into 1st! Help!!
  128. recipe for 406sbc T56 without adapters?
  129. 2006 C6 Z51 transmission..... how to convert to Fbody/GTO style?
  130. Upgraded T56 Mainshaft, Viper upgrade etc guys step in
  131. Whistling sound from t56
  132. Why can I not use my LS7 clutch on a Ls6 Flywheel?
  133. t56 Countershaft Shimming
  134. How To Install Clutch Video (Video Series Complete, Monster Level 1!)
  135. A4 to M6 conversion kit.
  136. Best streetable clutch for 450ish rwtq
  137. TR6060 (2010 Camaro) mated to a 2007 LS7
  138. normal operation? lvl 2 monster twin disc
  139. Transmission Gear Lightening
  140. did my clutch get hot enough to crack
  141. HUGE thanks to both Mark@GForce and Jeremy@RPMTransmissions!!!!!
  142. how do i dissasemble this part of my t56?
  143. Spec super twin bites the dust @900whp
  144. Hydraulics/transmission problems
  145. My clutch seems to depress after spirited driving?
  146. Texas Drivetrain Stage 2
  147. t56 to bell housing bolts
  148. T56 Mainshaft Small Bearing Stuck
  149. Monster Clutch Co. Tax Season Sale
  150. Leaking Slave out of the bleeder outlet?!
  151. Just rebuilt mn12. 1-6 shift fine..does not go into reverse(bench testing)
  152. LSX 5 speed?
  153. Cannot shift into 4th when hittin it
  154. T56 problems
  155. Clutch slipping
  156. Bell housing crack
  157. A4-m6
  158. Locked Out of Gear (again)
  159. a4 to m6 wiring help needed
  160. Slave Cylinder
  161. broken driveshaft please help!!?????? ?
  162. two quick questions
  163. new clutch and flywheel now hard to get in gear
  164. Best way to pull a T56
  165. Lou's short stick install q
  166. Could my t56 not be shimmed correctly??
  167. t56 problems
  168. McLeod clutch question
  169. I bought Hurst shift knob, doesn't fit, a few q's
  170. monster stage 3 break in
  171. Couple of trans related questions....
  172. Clutch Disc Replacement
  173. Another clutch question - Monster stage 2
  174. this a good clutch?????
  175. Input Shaft
  176. anyone using the McLeod 139305 13/16" MC?
  177. In need of an SFI flywheel
  178. Spec part number?
  179. Oh Crap!
  180. What type of transmission do I have?
  181. Exedy clutch anybody use one?
  182. Need some clutch help on a t-56
  183. Six Speed INC. is gone... Who does trans rebuilds?
  184. t56 problems help!!
  185. Got her done!
  186. "Viper" Spec Trans / Output shaft never cut down
  187. New T-56 Magnum noise at speed
  188. Loose Hurst shift knob problem
  189. Bleeding Hyd. Clutch System
  190. Trans help
  191. M6 rebuild costs?
  192. T56 shifter missed gate got stuck.
  193. Car lurching forward
  194. Spec stg 3+ clutch
  195. loud vibrating noise coming from t56!! vid inside!
  196. Shifting Without the Clutch?
  197. Flywheel recommendations for 500-600 rwhp
  198. T56 Magnum from Tick Performance
  199. t56 ABOUT TO PULL MY HAIR OUT!!!
  200. Best Clutch for 450~hp car or le2?
  201. LR4 5 speed options and parts list
  202. Need help finding u-joint for tick performance t56 magnum
  203. Should start sticky for the front drive LS4,F40 6speed setups, questions.
  204. Need some advice
  205. ATF gushing out of T56
  206. Mcleod RST clutch
  207. Drill mod question
  208. Need someone to tell me what's going on here
  209. Ranger clutch care method unsuccessful
  210. Stock clutch power capacity
  211. Can anybody give insight on weird clutch thing that happened?
  212. Please Help Clutch
  213. Any difference between a car pressure plate and a truck
  214. Mcleod twin vs stock assembly weight LT1
  215. Flywheel-Pressure Plate Bolts Shoulder vs All Threaded Can Someone Explain
  216. Clutch suggestions
  217. shifter pill?
  218. Master's rod material??
  219. Shift knob that doesn't rattle like hell...
  220. viper shaft too long
  221. installed my tick tonight.. a few tips that may help others
  222. What clutch for 403ci 450-500hp??
  223. 4.8 vortec/t56
  224. 2010 SS M6 wont go into gears
  225. CAGS removal & Reverse Lockout softening - May help some people?
  226. need quicktime bolts
  227. T56 & LS1 - which pilot bearing
  228. Clutch break in
  229. How Easy to Install Input Shaft Bearing?
  230. Best trans/gear sets/ clutch/ flywheel for road racing
  231. Dialing in a McLeod bellhousing?
  232. Clutch master line going to slave, my problem?
  233. Notchy shifting while engine off? Trans rebuild time?
  234. 69 firebird- ls1 t56 swap
  235. Monster Level 2 & MGW Install Review
  236. Sachs1050 flywheel and high HP clutch combo
  237. Ls1 T56 - slave cylinder inlet & outlet thread sizes
  238. can a Tick speed bleeder line be installed with out removing the transmission
  239. Chevy t56 clutch choice
  240. Different gear sets in T56 possible?
  241. bent shaft
  242. Bleeding clutch with Mytivac?
  243. Cracked bellhousing!
  244. 2011 cts-v 6 speed manual Help!
  245. Where and what to buy
  246. I think that I smoked my clutch tonight?
  247. black clutch fluid
  248. Shaft not turning after rebuild??
  249. Clutch hydraulics issues
  250. C5 stuck in Reverse, but shifter moves..HELP!
