View Full Version : Gears & Axles
- Guys with PY3400 or PY3600 come in
- Where to buy shims, outside of a rear rebuild kit
- Tranny Problems helpppppppp
- a new gear question
- Torque Arm for 1.4 60ft?
- Has anyone's BMR Torque arm done this.....pics
- Part # for Gm 4.10 gears that will fit stock 7.5 bolt, anyone have?
- What controls lock up?
- Will 288 Slave be ok?
- Stuck in 4th
- Rev-Lok II, how do you like it?
- stock u joint??
- Rearend Life Span?
- WTF are my pinion & tranny seals leaking so soon after replacement???
- How to tell when slave/master is going?
- Definition of Master and Slave Cylinder?
- Gear Problem
- 1st post for me, need help/advise please.
- Paging Fireball (Brian)
- What TC when going to A3?
- Bad slave/TO bearing experience?
- SY 3500 works great!!!
- Drill bit size for "drill out mod"?
- Anyone know anything about Empire driveline driveshafts?
- Whats the deal with this?
- posi vs spool? help
- Moser 9" and ABS "only"???
- Anyone having problems with Moser 12 bolt and torque arm bolts?
- A simple way to a quieter diff. ........
- Locker for Moser 12 bolt?
- Gear swap and HP loss on dyno??
- No lockup in 3rd gear or higher! HELP :(
- Size of bolts for backing plates
- Rear-End question?
- Yukon Gears from Randys Ring and Pinion any good?
- Torque Arm questions...Help!
- My F@#*in tranny is broke AGAIN
- 4L70-Lock up in first gear
- Will a center section from a 78 malibu work?
- 30 or 33 spline axles?
- A3 swap-What is needed?
- Car is surging in OD
- What carrier size in Moser 12bolt?
- TP 4600 okay with 100 shot?
- SHIFTING POINTS???
- Trans braked 400 questions--->
- Has anyone ever changed the pinion gear seal in their diff?
- Do any of you actually feel that D is faster around town than OD?
- Noisy driveline?...
- How much will power change my TP4400 shift ext?
- Posi additive
- 7th REBUILD on TRANNY!! Need HELP PLEASE
- Any experience with National Drivetrain's Eliminator gears?
- Can driveline components cause misfires?
- Diff Fluid leak
- Weird problem last night....Help!
- Will 3.73s help??
- Scattered the Rearend again...
- Help!!
- Homemade Mastercylinder
- Torque Arm ?'s
- Why not 9" for a little more $$??
- Ah crap, did I blow up my transmission or what?
- Vibrations and clunks, need help.
- Thunder Racing Line loc button
- EATON posi or spool?
- Update on rear tranny seal:
- Drag CAGS question...
- What is needed to go from 2.73 to 3.42
- How much TQ and HP will the 12 bolt and 9" hold?
- ?? for ones in the know
- 4.10 and topend pull
- Best TC from a roll
- Pros and Cons of RAM sintered iron disk vs. 6130?
- Going Stage 4 Spec...any special break in procedures?
- Stock torque arm with moser 12 bolt?
- ST4000 and 3.73s?
- Another 4:10 question
- How to make poly trans mount act like stock?
- need to pull rear axles out, how hard is that to do ???
- Gears worn out???
- Weird squeaking noise coming from rear end only when I turn?
- Will this TRANSMISSION JACK WORK??
- What are my chances of snapping this...?
- What's the difference between a spool and posi?
- Tranny fluid leaking from some place...experts step inside...
- Hesitation? Broken Tranny Mount?
- 9" drive shaft
- I'm just not ment to get my car done!!!
- What are the chances of breaking a Moser 12-bolt out of the hole on spray?
- GM posi lube...Whats in it?
- Creative gear heads and/or hurst white ball owners wanted
- ACPT shaft-->Worth anything???
- please if you had this problem, help me out!
- mods for rear to hook up
- Vibration & Clunking Noise
- Cam and gear question
- TB400 with GV overdrive
- GEAR SELECTION PLEASE HELP ME
- Worth the switch to go from a 3600vig to a 4400PT??
- 3 gear not shifting right.........
- Anyone rebuilt Hust billet plus shifter?
- Gears????
- SWAPING REAR!!
- 1-2 shift slipping
- Trany wan't shift into 3 on spray
- Tire Height question
- Spec Stage 3 or what other?
- Tryin to learn about TC's
- Do i have the 1st stage sign of a rear going???
- Rearend poppin like corn?
- Neutral safety switch/ help
- A Question for those who have upgraded to 4.10 gears
- Stock Rear End Swap / Need Help, Advise Please...
- Should my tranny be slipping already??!!
- Cheap speedo fix??
- Anyone with an opinion of Shifters?
- Question about torque management...
- Bad Vibrations?
- will someone @#! answer my question?
- Just broke my 3rd tranny.
- rearend noise
- 9" and 12 bolt?
- Lockup characteristics of PYE 4000
- SPEED INC'S TRANS
- I Need a Good Trans and Rear Shop In Chicago
- Well, I went ahead and did it!
- PT4400 is in...DAYUM!
- Efficiency with a TP4400?
- Big TCs + Big TQ = broken tailshaft housing!
- 4L70 Reverse pattern-What shifter?
- New Strange posi unit junk before 300 miles
- Do you think PY3400EXTREME cool for Blown 427?
- Getting a new rear. Want to retain ABS and traction control ...
- Anyone running a locker w/ a 6speed?
- Source for rear end bearing kits?
- Need advice on building a fast daily driver.
- What can I expect from 4.10's?
- reaar axles
- question on our 12bolts
- P0502 DTC after first run...
- I really need these 2 measurements from this Denny's Driveshafts diagram
- SLP linelock problem
- mph to rpm/
- how much diff. from a roll...
- LCA Angle?
- 3.42 vs 3.73
- Rear Axle
- Tranny shift firmness increased w/0 shift kit or hpp3?
- Need some Trans explanations
- Anyone have stock driveshaft dimensions handy?
- Strange noises coming from raer suspension
- Paging the guy with 4L70 tranny trouble
- Has anyone ever broken a Denny's HD Aluminum DS?
- is this tranny combo possible?
- Clunking noise??
- Speedo recalabration using HPP on 1999s
- Stuck in 2nd Gear after 400 swap, won't start
- sometimes 2nd bogs?
- People that run 28" X 10.5 slick need advice please.
- Broke my DS on the DYNO! Anyone have Denny's 'Nitrous ready' driveshaft measurements?
- what year did they stop putting the 7.5 rear in the f-bodys
- Custom driveshaft loop?
- Vig 2800: Best TC for daily driver?
- ATTENTION ALL PHOENIX MEMBERS!!!
- Drive shaft loop questions?
- Bad noise coming from tranny...
- Clicking/banging noise when turning! (MOSER)
- tranny not shifting?
- rear girdle starts leaking after 15k miles
- What A B!tch!!!!
- TC Slippage & MPH/RPM Q?
- tranny deasnīt shift at WOT, need help again!
- Best way to use Adj. PHR
- Went slower with TC???
- recommend driveshaft?
- Stock PCM and Lock Up Feature
- pics please of spohn torque arm
- Help me upgrade my drivetrain...
- RR airbag psi for street?
- after hals tire hits wheel well sometimes settings?
- Who has broken there 10 bolt?
- How Much HP Lost with 12 bolt and Chrome Moly Drive Shaft? How Bout None!
- Pinion angle?
- Upgrade rear swaybar but not the front OK?
- I Need New Gears - Opinions Needed
- 2.73 to 3.73
- BIG PROBLEMS WITH SUSPENSION GEOMETRY--->HELP!!!!
- Pic of launch with YTP4000
- Driveshaft
- Ultimate Rear End Cover???
- I NEED TO GET MY TRANNY BUILT
- What does a shift kit do?
- Part number for 1350 to stock DS?
- Will front/rear springs from a '96 Camaro fit my 2002?
- paid +$100 for moser to add 4chan abs>>>
- Quick lockup switch question
- wheel hop problem....need help
- carbon fiber driveshaft ?
- Tips / Tricks bleeding the master cylinder
- spool what oil?
- Chances of breaking a Moser 12-bolt....
- how much is my speedo off now ? 2.73's to 3.42's?
- best sway bar WITH mounts for moser 12 bolt?
- What's the best launch for a YTP4000?
- Anyone have a wire diagram for a LU switch???
- 12bolt with 1350 yoke + CF driveshaft = spicer 460X ujoint.
- ok to go without rear swaybar?
- Trans is out. Everything appears normal??
- Drive Shaft Question
- just use the gasket?
- Will and LT1 rearend fit in an LS1?
- GM posi additive or not?
- How do I remove my stock U joint
- Trans Problems need help
- HELP moser 12 bolt/eton posi need gm additive?
- ST3200 and 2.73s?
- Will 3rd Gen 9" housing fit in 4th Gen?
- Dyno'd HP loss 3.42 -> 4.10
- What U-Joint with stock driveshaft and Moser 9"
- wow . . . too many parts and no TV in the garage
- 85w140 rear end dope...........Opinions?
- Is the sy 4000 nitrous friendly?
- moser 12 bolt/use which u joint/which oil/how much
- TCI Streetfighter info...
- Knock Sensor and U-Joint??
- Paging Ragtop!
- Your gear of choice?
- Rear End Questions?
- Poll: Richmond vs Superior
- 9 inch vs 12 bolt pros & cons
- convince me to buy...
- tp-4400 vs. #7 pump showdown!
- Paging LS1Lover
- Moser 1310 Yoke people (Nineball?)
- Are Moser 12 Bolts junk?
- Swapped 3500 stall TCI TC for a 3800 stall WOW!
- how to measure pinion angle
- 4.10 rear from S series truck; compatible??
- VSS voltage
- Will I need to reprogram???
- HELP! Burnout Question
- Help with exhaust?????????
- Are 1LE LCA's tubular and are BMR's worth it over the 1LE's?
- 12-Bolt Rearend
- Trans Not Shifting on 1-2 :(
- Anyway to put a non ASR rear in a car with ASR?
- 12 bolt from a junk yard?
- Differences between ST and TP
- Swapping trannys
