View Full Version : Gears & Axles
- Broken pump question
- Could someone tell me the weight diff. in driveshafts?
- Stock Rearend
- ??????'s about what u joint with my Drive shaft and rear
- HELP ASAP PLEASE!! removing trans lines E clips
- lou's short stick? .. where can i buy?
- Rear End "Clank"
- TH 200 metric transmission shop
- Tranny won't shift to 3rd at track.........help
- 2000 SS Performance - Disappointing Numbers (Track & Dyno)???
- Uh, Star Stage III Kevlar TOASTED?!@ WTF?!
- whos broken a driveshaft?
- Conveter, gears , or both?????
- Syncro's... Does someone make kevlar syncro's?
- Broke Rear--->Shatttered Tranny!
- My 3.23 to 3.73 gear swap thoughts after lengthy testing
- TP Method for removing Pilot Bushing BEWARE!!!!
- I have decided to make a gear change within a month.
- Popping out of gear.
- New here! Need help
- PT4000 is in!
- Simple manual Q
- Where can I get a good deal on a new or used 12 Bolt?
- TP 4400 and a stock car ?
- E.T. improvement with 3.73s and a 4400?
- 410's
- TC always sets a PCM code?
- HELP: Convince wife I need Corsa.
- Hidden shift mode in the PCM?
- PT4400...
- PT4000 Arrived :-)
- Finally did it!
- Differential Question
- Axle removal w/o draining the oil?
- any issues with shift kits
- How do you get to the bleeder valve on the slave???????
- ET Drags and no traction on the street.
- TRANSMISSION FLUID???????
- are the 10bolts interchangable from 93-02
- fixed the shift to 3rd but now the tranny whines?
- Instructions for Adj master install???????? Anyone
- Two Questions?????
- ABS INOP and the ASR does not come on??
- T/A Rear End Girdle Question
- Keep chewing up rotors....WTF
- Rear Whine Please Help... Very Strange!!!!!!
- How much gear lube in a Moser 9 inch?
- Best was to fill the Trans back up??
- Where to get 7.35 pushrods and head gaskets??
- Do I need 'em
- Trans. Help !
- How much play is needed in driveshaft???HELP
- Carbotech vs. Hawk brake pads
- Who's running a 9" with a posi?
- put battery in back?
- How much higher would my top speed be going from 3.23's to 2.73's?
- 3.23's to 3.73's
- longer wheel studs for 12 bolt?
- I need the number for SPEC
- where is the optimal tranny fluid level on dispstick?
- Paging Camaroholic
- Which Rotors to buy - Power slots or Cross drilled?
- hatch weight?
- Solved the puzzle of my "mystery gears"
- Can't feel the tires spin but leaving black marks??
- Anyone running rod ends on LCAs?
- what will help smooth out the ride
- Too Much Torque!!!!
- Simple question...
- Anyone seen the MAC Torque Arm?
- spring rates?
- Stock Axle Load
- For those with light weight K-members how did you???
- need pics of et streets!
- Squeaky brakes!
- need moser 12 bolt help ASAP!!
- I cannot hook with my new setup with more HP!!!!!Help!!!!!!!!I
- Do I need adjustable LCA if I have relocation brackets?
- relocation brackets?
- 3 channel or 4 channel abs? how to tell?
- more 12 bolt questions???
- poly/rubber LCA's?
- HELP asap... Is ASR (TCS) adjustable?????
- Will I be safe with only 3 tranny crossmember bolts?
- Someone have the distance between shock mounts..Please
- manual tranny conversion
- Help Suspension
- Gear/Tire ratio ???
- Do SFC get in the way of other stuff under the car?
- Someone please help!!
- HELP! 12 bolt backing plates core?
- 4:10 gears versus 3:73 gears in an Auto
- recalibrating speedo's.. options?
- Do I want chromoly or mild steel k-member / a arms?
- Are the 315/35/17 Nitto Drags too wide for a 9.5 inch wheel???
- Rear disc brakes
- 4.30 vs 4.56 gears?
- Please tell me I won't regret this.....SFC's
- ET streets and yank py3600e?? help!
- Back-spacing needed for Center Line rims?
- **********HELP********* i wanna race again!!!
- Eibach Springs + Hal Struts - Good or bad combination?
- What does your 1le car weigh?
- Auburn or Torsen?
- slp line lock is in
- what will allow me to win more street races???
- Roto-Tech Brakes??
- Who has cut stock rear springs to lower their car?
- Who's running heads/cam with a 3:73 or 410 rear end?
- 93-02 fbody LT1/LS1 brake to C5 brake conversion
- Reverse lockout takes 100lbs of force to shift into reverse...WTF???
- Tranny problem update.....and how Pro Dyno in Phoenix rocks!!!
- Anybody buy the JEGS driveshaft Safety Loop???
- Need help picking out brake pads!!!
- Brake kit to buy?
- Eibach vs Cheap springs?
- Putting LS1 springs on an LT1 car, couple of ?'s....
- 2 Times to the track and both time I blew up the 12 bolt
- ?? Cutting front springs / removing rear spring rubber bushing ??
- I have a MAJOR decision on rear ends.. Please Help!!
- Need help with axle removal
- Best Gear Brand?
- wheelhop!
- Noisy Rear End
- What should I expect from the YTP4000?
- Gearvendors track test coming soon at Capitol Raceway!
- auto to a stick
- Bendix brake pads?
- pic inside: clearance problem with phr on eibach prokit
- Ram's websiteURL?
- got bmr navy blue sfc's, they look f_ckin purple!
- Need help with husband's shifter knob
- Car sounds like it has mud tires on it, any guesses?
- Rear Drag Sway Bar
- What all parts do I need?
- 4.10 or 4.11????????
- Worth it to have the trans fluid flushed?
- noise coming from crossdrilled brakes
- Transmission Mount????
- Upper &/or lower arms??
- About to order another Kirban, differences between..
- TA Girdle Stud Kit
- another 12 bolt ?
- problems getting into reverse??
- does this suspension sound good?
- Question on changing tranny fluid.
- Thoughts on Nitto 555R 2's
- 12 bolt Components, Best deal?
- ABS-Inop light won't go out. Anyone else have this problem?
- Car shudders and makes noise when downshifting from 4 to 3 with conv. locked
- 17x11 and lowering
- 1350 Yoke and stock driveshaft--->HELP!!!
- 2001-SS SWAY BAR SIZE??
- Another Poly Tranny Mount Question
- What brand of SFC do you have on your Vert?
- Moser help.
- Shifter doesn't auto-center nicely?
- 2.73 to 3.42 without HPP III programming???
- 12 Bolt Should be here this week!!!!! 4.30 gears...
- First Suspension Mods
- Which 4.10s to get
- Traction Help
- coil overs
- 3.73 or 4.10
- lou's short stick where can i find one
- Rearend Question
- Paging Nine Ball
- Are the front sway bars on a 1998 WS6 welded?
- Warped rotors on 98' T/A
- SLP/Moser Rear?
- Do upper control arms come with ball joints?
- question about panhard bar
- Moser In!!! Thanx MTI!!!
- need help asap
- Best brake rotors...
- Should I use a shift kit?
- Factory Hurst Vs. Pro-5.0
- TranGo shift kit, Need help
- Difference between tp4400 and 4600
- Can I hook up with a YTP4000?
- How can a rear end be without ABS?
- A few ?'s about the RAM.......
- LCA relocation question...
- Pinion seal replacement,,,,,
- anyone heard of krp rotors??
- Ported MAF ends
- Shifting with TC locked
- Is a driveshaft safety loop really required?
- QUICK Suggestions on Suspension work
- How can I make my 1999 SS handle like a 2002 Vette.....
- Need part number for 12 Bolt/1350 u joint?
- block to trans bolt pattern
- Anyone run royal purple tranny fluid?
- Rearend Whine
- Stock driveshaft length on 9 inch or 12 bolt?
- Springs ?
- Patrick G, Colonel, I'm told you guys have...
- How much trans fluid do I need?
- I bit the bullet
- Help with identifying a part...I'm sure you'll know.
- Noise coming from my rear end....
- can we use synthetic tranny fluid in our 6 speeds? or
- LOWERING 2001 SS??
- Who's running a RAM 980 Disk in thier setup?
- BMW Z3
- Torque Arm Problems??
- Gear Break-In:
- ported MAF's ??
- Best synthetic trans fluid?
- 95 Dakota
- Need Trans. help (odd noise)
- I've been robbed!
- Driveline vibration. HELP! (long)
- Anyone have a link for a lockup switch??
- Good Place
- setting torque arm?
- Pinion angle question?
- Need brake experts in here.
- Tired of going down the street at like 30-45 and punching and slowly getting up..HELP
- NEED Help with JFP Stealth Torque Arm....
- Wilwood brakes arrived.. pics ~ PROBLEM!!!!!!!
- 10 bolt torque specs?
- One wheel spin?
- Is this pilot shaft bearing going to work?
- 12 bolt brake-in
- Suspension Setup Comments? (Long)
- 15" wheels on stock rotors?
- Could this drag radial be made to work on a Camaro
- Stepping up to the next level. (12 bolt and BIG tires)
- LT-1 and LS-1 4-l60E differences?
- Questions about the new Wilwood brakes.
- Confused about 1LE part numbers, 1LE sway bar owners please read
- Adjustable LCA's Question
- Help! ABS InOP light won't go off after Dyno!
- Question about Eibach ProKit
- Squeaking noise
- 12 bolt question...
- Which DS Loop will fit?
- shifter b&m or hurst?
- TH-400 and the Gear Vendor's OD unit...
- NEED HELP with JFP dual adj Pan Hard Bar!!!!!
- how hard is it to warp your rotors?
- Vigilante 2800 TC -> LS1 flexplate mounting holes mismatch
- Tubular Front Suspension Arm Upgrade
- Experiences with a PI3600....Lucky #7??
- Why no Dana or Tera?
- 3rd gear syncro took a crap again I think
- Is this normal? (transmission)
- SFC's on
