View Full Version : Gears & Axles
- 9" with 3 channel ABS.
- Motive 3.90s second thoughts? Come in if you run these gears
- moser 9" ?
- Looking to buy a new driveshaft ? 02 z28 camaro
- Can I add abs to a none abs rear?
- Best Replacement 10 Bolt
- Moving to a 9 inch...
- Gears
- Should I buy this rear?
- 8.8 28 spline axle
- I need a measurement for a s60 case, help!
- MWC swaybar brackets broke! (Not happy soo far!!)
- someone explain gears to me
- 9-Inch Noise Help!!
- 79 10 bolt
- How much will I hate life with a spool?
- Rear Axle Ratio for me
- Which Rear End should I get
- Swaping out 10 bolt for 9" driveshaft ??
- Ford 9" Housing Material
- LT1 10-bolt in my LS1 car?
- Driveshaft length for 10 bolt to th400
- Solid crush slevees/ spacers...
- New car, new gears, what are they?
- need help choosing a rear end gear..
- Differential Questions?! Help pls
- Narrowing moser 12 bolt
- Bad 10 Bolt Resuse Gears?
- backlash help
- High Pitch Whining/clicking when stopping
- Just upgraded to S60
- Rear end
- Driveline vibration, cant figure it out?! Strange, Koni
- GU2 and GU5 RPO codes and (rearend ratio)
- 8.8 build question
- 01 s10 blazer gears
- Rear Differential is Growling
- Can you shorten a Aluminum DS
- problems after replacing differential
- Did i purchase the correct ring & pinion gear?
- has anyone actually welded the spider gears up?
- Reviews on the MWC 9"
- GTO Pattern FUBAR (with pics)
- Reinstalled rear now driveshaft is rubbing
- Pics / Midwest Chassis Double Drop Torque arm Mount / Driveshaft Loop
- what gear should i run? 5spd
- driveshafte with cv joint
- considering changing gearsin my 10 bolt
- Pinion seal and crush sleeve help!!
- 8.8 built write up please?
- 3.73 or 4.10 with S60
- panhard bar
- 9 inch questions
- Reluctor wheel contacting speed sensor, WHY?
- 10 bolt C clip pics for rookies.
- Best budget rear end ??
- opinon and questions on 12bolt from texas speed performance
- Are these gears setup properly?
- tail bearing won't fit.... + the old blue vs orange motive debate
- Moser 12 Bolt Whine and Chatter
- Help
- Midwest Chassis fab9 on the way
- 8.8 Torque Arm Mount
- Post 9 inch install fuel mileage?
- driveshaft length
- Driveshaft options for Strange S60
- 10-Bolt Rebuild Questions...
- Axle limits
- 4.10 10 bolt.
- 10 bolt help
- Need help with factory 10 Bolt Rear End!
- loud gears hurt my car?
- 9" or 12 Bolt on my Project?
- speeometer acting crazy
- Can someone help me, PLEASE! $440 in diagnosis fees, and both shops stumped-rear end
- 9" questions.... changing carriers and gears.
- 10 Bolt Whine Advice
- 8.8 Rear End?
- 3 Channel to 4 Channel 10 bolt.
- New gears very loud!!
- Will this work in my car?
- $1400 to rebuild 10 bolt rear end??
- S60 guys: what shocks are you using?
- NON WHINING GEAR Advise
- replacing studs questions?
- 8.8, trying something different, thoughts??
- ten bolt leaking question
- strange 1/2 inch wheel studs
- Trac-Lok for S60
- Changing U-Joint
- what gears do i have
- how do i know if my ws6 has an aftermarket differential gears
- Can an 8.8 be built to handle 8-900 rw and keep posi?
- cheapest and best place to buy 3.73 gears and install kit
- 8.8 axle bearings?
- Need some help with gears on my 3rd gen Trans am!!!
- what gears to go with...
- 8.8 and ABS
- Best Gears for Texas Mile Course
- Rearend question for the 1,000+ hp cars
- 4.10s in my rear end with 95 thousand miles
- first break-in drive after 9 inch install, whining and a strange smell after i parked
- Pwr level of a 8.8 with a 6speed ?
- 3.23 positive traction/limited slip
- S60 vs. 9' - (Strength)
- Alright, who's got the best price on ready to drop in 12 bolt axles?
- How to make my 9" work?
- MWC FAB9 vent tube thread size..?
- Just swapped out my rear end
- How much can a 10 bolt really hold
- Driveshaft?
- bent my studs on s60
- Moser 9" swap brake line problems help
- To grease or to NOT grease?
- Need Help
- Anyone using synthetic in a Tru Trac 9"?
- eaton tru trac posi question
- Opinions on longevity posi VS open
- How to tell if your rear diff is on its way out
- 9 inch install issues... Sway bar dosnt fit!
- Some good info on Summit Racing Axles
- F-body What kind of gear oil?
- Need Some Input On Moser 12-Bolt Options
- 98 trans am pinion bearing noise??
- Narrowed or not narrowed 9"
- noise in pumpkin around turns only
- rebuild or ditch rear?
- Need help please asap!!
- s60 question
- 3.42 or 3.73???
- Why do 9" Rears = Less Power?
- gear whine only on decel 4th+
- Bent axle? *video*
- Getting a better rear end?
- Bent Axel?? **Video**
- aftermarket reluctor ring for 98-02 fbody?
- Watts link question
- i got a moser 9" and need a 3.00 gear, but dont know what specs to buy need help FAST
- which is a better drive shaft
- Full Kooks true-Dual exhast+long tube headers fitment for a MWC 9" setup
- Help with AXELS!!!!!
- Clunking from rear
- 12 bolt questions
- Gear?????
- what are good brands of ring and pinions??
- pinion angle vibration at 70+ on load only.....please help
- True duals/ TA reloc mount?
- MWC 9 rear, axle seal leak?
- moser 12 install issues
- 9 Inch LT1 brakes issue
- Moser used in 3rdgen...will these specs work on 4thgen?
- will moser 9 " or 12 bolt 4.10 gears fit factory 10bolt
- Rearend brackets and spring perches from f-body for 9in
- Strange S-60 E-Brake Help
- Can I safely hook?
- 9" question
- 9" pinion sleeve??
- 3.90 Gear question
- how loud should a used set of gears be on a 9"
- Strange 12 Bolt Rear End Cover
- who to buy cusom axles from?
- rear end question
- motive gear alloys..? 9310?
- ?? on gears for my Camaro...
- synthetic or non synthetic for ford trac loc?
- Only when cruising, an "on the gas", "off the gas", "on the gas" clunking from the DL
- A4 to m6 rear end swap help
- bought 8.8 Starting build up
- 160K+ mile old GM Richmond gears
- 9 inch Driveshaft
- Narrowing a S60? 4-5 inch backspace
- 97 Trans Am Posi Rear?
- Testing rearend noise
- Rear-End Slack Diagnose (Video)
- Third gen to fourth gen gear swap
- Need some ideas (without a lift) 9"
- Low Trac after new wheels
- Can the rear end slip ?
- New Differential and Gears; Car won't Move
- My story with Dana S60
- wheel studs are too short
- 12 bolt queation
- Quick question about jegs housebrand parts.
- 9" question
- Can I use a v6 rear end in my z28?
- Having trouble getting the gears to stop whining.
- Vibration at 60+
- Wavetrac require limited slip additive?
- Narrowed explorer?
- 3:42s in A4 from factory?
- Rear end rebuild questions!? **update 10/3**
- Help with rear rebuild
- 9 Inch install underway, how do I do the brake lines?
- Gear Install Kit
- Narrowed 46in ford 9" ?
- Questions about mineral oil in my Moser 12 bolt
- ATTN SPONSORS: LF Quiet rear end for LS7 Camaro with 4L60e
- what gears should i run?
- speedo not reading right... blowing my mind D:
- Seriously... what rear end to use?
- yukon solid pinion spacer assembly (ford 9 inch)
- Specific Pinion Bearing Preload Question
- My S60 is back on the road
- need help with 99 Z28 rear end, posi might be blown out!! help anybody...
- rear end swap question.
- 96 impala ss rearend?
- Possible to have Ford 9" Without Whine?
- 8.8 torque arm bracket
- Axle Spline Count Strength?
- lt1 rear
- Question about 3.73's!
- Differences in axles
- building a 9 inch center, need some help with the yoke selection..
- Need help on posi diff problem
- How long of wheel studs?
- How long before change fluid after a gear swap?
- 9 bolt backed LS1 question
- Track Only Cars
- Stock 10 bolt axle, 3 channel
- 3.50 gears
- 8.8 with TCS/ASR question
- Holy freaking whino
- Which gear oil
- Torsen part from a 9022 3 series. Name and would anyone sell these?
- rear end brands
- Need help with a rear end issue.
- alternative rear end upgrades??
- New Rear End (S60, Ford 9', 12 bolt) ?
- Measurements for a junkyard 9 inch build
- gear choice
- (damage report) bent wheels studs
- Anyone get ABS to work on a 8.8 rear in there f-body?
- 8.8 guys chrck this out
- Driveshaft Woes During S60 Install
- Grand sport rearend information
- 3.90 in a 10 bolt
- Detroit trutrac, any clunks around turns?
- Ford 9" build
- Moser 9'' 31 spline axles how much hp?
- 5.3/th400/9"/1000hp, what brand gear????
- my auburn diff is sounding like a chopper..
- Ticking noise?
- AbS Toner Ring?
- Moser 9 U-joint?
- Reluctor wheel
- Axle & axle bearing ???
- Rear Wheel Wobbling When Driving?
- Were all 98-02's equipped with aluminum driveshafts?
- Drive shaft only 3/4 inch gap?
- Driveline Vibration, Whine from Rear, Clunking noise in front? .... WTH
