View Full Version : Gears & Axles
  1. Rear diff cover bolts torque specs
  2. Qq
  3. nine inch housing ends
  4. 3.42 or 3.73 for DD
  5. help me price this 1o bolt
  6. new rearend
  7. Will this work for me
  8. 8.8?
  9. 3.42 to 3.90 how do you correct the speedometer?
  10. Will gear swaps....
  11. Why does it look like I have 3.42 gear ratio?
  12. 410 m6 guys, whats your rpm at 75mph?
  13. Shaking at high speeds in the rear end
  14. What rear is in 2011 Camaro
  15. Bad Front Wheel Bearings...
  16. Squeeking noise from rear...crap
  17. Help me Diagnose Rear End noises
  18. can you please verify my pinion angle?
  19. Broke the Auburn
  20. help 10 bolt/4.10s, what install kit do I need?
  21. LT1 Rear in LS1 Car...How?
  22. Spider Gear Replacement?
  23. Bracket placement on housing
  24. Gear Install.... pics
  25. What gear for my car?
  26. strange or moser 12 bolt housing & axle
  27. MWC 9" set up? and PST Driveshaft. Vibration
  28. Rear End Smokeing
  29. what to "paint" my rear with
  30. WTB aftermarket axles......
  31. 3rd gen rear end ??
  32. Bent axle? Out-of-balance or bent wheel? Video inside...
  33. weight diff. moser 12 bolt & stock rear end
  34. Why does my rear-end groan only after a few hundred miles of highway driving?
  35. Just placed an order today with MWC
  36. ? about my Midwest 9" rearend
  37. Whats the formula?
  38. rear end gurus step in
  39. OK what size rear end do we have???
  40. Moser 9" Passanger side axle won't slid in flush???
  41. Dumb question I have.
  42. Which Axles...
  43. Just finished 4:10 swap in '09 Lingenfelter Z06
  44. Rear end question....
  45. A few axle questions, possible 9 inch upgrade
  46. 4.10 or 4.30
  47. Is this a realistic price for this?
  48. need help new gears
  49. Used gears whine
  50. In need of ARP housing stud
  51. Need some help with new Eaton posi
  52. Delivery from MWC and others
  53. Correct bolt size for moser 9" torque arm mount?
  54. built proof 8.8 ford rear
  55. popping sound in rear
  56. Need Help Quick
  57. my new rear feels like its gunna fall out??
  58. 3.73's or 4.10's for MS3 cam A4 car?
  59. rear axle question?
  60. Ford 9" Trac-Loc
  61. GM 4.10's Where to buy?????
  62. 12 bolt posi from a 98 camaro
  63. is there any difference between lt1 6 speed drive shaft and lt1 auto driveshaft?
  64. f up wheel bearing install?
  65. Rear end rattle
  66. would it be worth it to make a 12 bolt fit
  67. C-Clip Issues! woohoo!
  68. Tightening Pinion Nut
  69. 8.8 question?
  70. What is stock backlash? What are other things to check?
  71. Oil
  72. is this an abnormal amount of metal shavings on magnet?
  73. Truck axles??
  74. gears/rear end
  75. Nine Inch install questions
  76. 8.5 swap into a 2000 Z28
  77. my new moser 9 whines when turning low speeds??
  78. eliminating torque arm saves our 10 bolt?
  79. driveshaft a little short.. longer yoke ok?
  80. replacing the gear sets. NEED SOME HELP
  81. Moser 9 inch TA mt. touching 3rd member
  82. Carbon Fiber Driveshaft Durability
  83. Aluminum Driveshaft and Slicks.
  84. Possible to swap 10 bolt from 69 into LS1?
  85. On the verge (within a day or three)
  86. Moser 9" what needs replaced when pulling axels.
  87. What exactly 'breaks' when a rear goes?
  88. 3.23's to 3.42's
  89. 4th gen rear axle width
  90. 10 bolt power limits ??
  91. Installing rear pinion bearing and carrier bearings
  92. 12 bolt carrier questions?
  93. Remove Axels on 12 Bolt
  94. 300 km/h in third gear?
  95. 10 bolt with 3.73 and nitrous on ET radials
  96. Might be buying a 9" few questions
  97. Narrow my 9 inch or buy another housing
  98. How do you center the rear u-joint in the pinion yoke?
  99. HELP driveshaft and S60 seal or length problem
  100. Strongest U.S made 4.10 gears
  101. 8.8 parts collection
  102. Quick rear end swap question for my 97TA
  103. Brutal rear end vibration - stock car
  104. where to buy 4.30 gears for stock 10 bolt
  105. 10 bolt shot??
  106. AlloyUSA
  107. Torsen Thrust Block Install
  108. Help ABS sensor ring
  109. wtb rear diff for a 10 bolt 99-02
  110. 12 bolt gear question
  111. 9 in quiestion
  112. Is a 28" tire faster down the track then a 26" tall tire
  113. cheap 4.10 swap upgrades
  114. Rear end noise
  115. fabricated rear vs. stamped rear
  116. SDPC now offering Eaton/Detroit differentials
  117. possible bad wheel bearing
  118. M6 4.10 Gears Question
  119. Driveshaft Moser 12 bolt
  120. 12 bolt upgrade
  121. Changing the insides of the rear end on 00 Trans-Am
  122. Is 98 rear different fromt 99-02?
  123. 10 bolt on its way out?
  124. 10 bolt w/Good Carrier ok for 400rwhp/
  125. 12 bolt 4 channel swap to stock 3 channel rear
  126. Finished My 8.8 Project
  127. How much shop charge for pinion seal replacement ?
  128. abs/traction control with 9inch and 35 spline
  129. C Clip Eliminators....?
  130. 10 bolt 3/4 channel questions
  131. Rear End Rebuild question
  132. 12 bolt questi5on?
  133. M6-373's to 411's-What was YOUR experience?
  134. pst ds question
  135. I think my rear end is about to go...
  136. 9inch rearend!
  137. Narrowed MWC9 Installed, sitting on new Bogarts *pics*
  138. quick question on rearend
  139. First box from MWC :D
  140. I really hate to ask this question but.......
  141. Correct Gears for a ten bolt?
  142. abs question
  143. turbos and low gears
  144. Backing plates???
  145. Question about gearing and tire size.
  146. 3.73 or 4.10
  147. chromoly driveshafts?
  148. Whats the best rear end gear for Nitrous
  149. narrowed rearend
  150. What parts do I need to swap gears?
  151. Boooyah! S60 with 4.10's.
  152. 8.8 swap vent???
  153. MWC 9" axle/rim question
  154. Weird.
  155. rear end swap question???
  156. 3.73s all else stock
  157. 3rd or 4th gen Rear End?
  158. 3.23s 60 MPH, 2000 RPMs
  159. measureing for driveshaft ?
  160. Lca relocation brackets
  161. Best Place To Get 4.10 Gears For My 2002 Corvette Z06?
  162. 3/4 Channel rear, yes i read the faq ;)
  163. Currie 9in Torque Arm bracket.. Opinions?
  164. should i paint my 9in 3rd member, or leave it
  165. What rear end? 12bolt or 9in? A4
  166. Pretty sure i busted my 10 bolt so i need your opinions
  167. Rear of car leaking?
  168. what color should i paint my moser 9 ??
  169. Driveshaft Question
  170. 416 LS3 + stock rear end = fail
  171. 8.8 diff
  172. after 148,000 miles my rear finally blew...what to do next?
  173. Stock M6 Guys. What's your top speed in 1st?
  174. best price on Strange S60?
  175. does syntheic oil help to quiet rear gears ??
  176. Position of Yoke on Pinion on a 10 bolt?
  177. Auburn oil help for noob
  178. Will gears for 02 silverado fit in 02 camaro?
  179. 4:10 Gear/spool 12 bolt
  180. 3.42 to 3.37 gears ???
  181. a4 4.10 top speed?
  182. Missing lug nut thread! Help!!
  183. Bent Backing Plate On Moser 12-Bolt... Help please...
  184. G8 Pontiac 3.9 gears
  185. Strange 12 bolt, inner axle seal?
  186. Should I be worried about the 10 bolt? (its an a-4)
  187. i want pics of a stamped 9in with backbrace please.
  188. strange 12 bolt noise after some abuse...
  189. This noise is freaking me out!
  190. what posi or locker to go with for a daily driver?
  191. U-joint question.
  192. Help weird pulsating noise from rear
  193. Conversion U joint for Moser 9"??
  194. drive shaft run out
  195. need help picking the right rear end
  196. Driveshaft length: th400-9in
  197. Quick ? about my Detroit Locker
  198. Drive shaft question??
  199. Review of a locker with a M6
  200. Need some real help regarding gears!!!
  201. Screwed by local shop
  202. Tips for getting my UMI torque bar back on the moser 12 bolt?
  203. modifying a 'torsen' paddle-pics
  204. Noob questions about rear end.
  205. New decel whine coming from 10-bolt
  206. auburn or eaton???
  207. auburn or eaton
  208. Midwest chasis 9" or Strange S60
  209. Just got my s60
  210. is the rear diff cover thicker question
  211. Dana s60 rearend fitment ??????
  212. 98-02 rear in 94 camaro?
  213. Draining my Rear tomorrow, What fluid should i fill it back up with?
  214. S60 or 9in.
  215. 9" backbrace option
  216. Intermittent vibration at 80+
  217. how many rpm at 70 mph?
  218. Carbon fiber driveshaft are they worth it?
  219. need some help here...
  220. MWC rear end. Axle seals leaking
  221. im looking for a paddel kit for my rear end can anyone help
  222. Gears
  223. After tonight I need 4.10s!! *video*
  224. a4 3.73 or 4.10.....help
  225. M6 SS 10 bolt w/ 4.10's anyone
  226. Gen 5 ss with 4.10's
  227. rebuilding a 7.5" rear
  228. MWC and monster 3 install w/pics
  229. Ring & pinion question
  230. newbie question on rotating the rearend
  231. 373's or 410's
  232. Need thoughts on rear end noise
  233. Which 9" ends for LT1 brakes??
  234. moser 12 bolt bolts
  235. Does Strange S60 have any type of warranty??
  236. 4:10's in a manual ok for highway use?
  237. help with options for rear end
  238. Where to buy AAM gears
  239. 4 channel wheel speed sensor same frequency as 3channel?
  240. Help me pick a posi/locker...
  241. my 8.8 build
  242. How to make a 8.8 fit. please help
  243. Mwc 9 or moser 9
  244. 3.73s or 4.10s for H/C A4
  245. Is this the right housing end & 9'' Install Questions
  246. Need more opinions - 850 rwhp
  247. Choices of differentials in 12 bolt
  248. Few questions about the M9
  249. Pinion depth adjustment needed after very hard shift?? wtf??
  250. just built my first 9" housing, need help on finishing
