View Full Version : Gears & Axles
  1. ok so i need a stronger rearend but what kind?
  2. What rearend is in the C6
  3. best brand gear for me?
  4. can my stock rear end handle 440rwhp
  5. 12 bolt woes
  6. will my stock rear end be ok?
  7. finally a bolt-in set-up for a 8.8 for us??
  8. strongest u joints?
  9. 12bolt center piece
  10. C6 Gears
  11. this sucks
  12. are all GM gears the same?
  13. Gear Benefit
  14. Time for Gears?
  15. Am I going to get any gain going from 3.90 to 4.56?
  16. Help me pinpoint rear-end trouble!
  17. Just need opinions on a new rear
  18. rear end vibration DRIVING ME NUTS!!!!----HELP!!
  19. m6+408+spray.. what gears
  20. DYNO STOCK 10bolt VS. DANA S60 I have the answer
  21. Sponsors inside please.....
  22. Having a Rear end Issue ( long story)
  23. pull-a-part salvage yard ford 9"
  24. ticking on decel
  25. Moser 10 bolt
  26. gear ratio v tire size
  27. 3.42 to 3.73 HELPPPP
  28. New Gears
  29. 12 bolt install in Texas
  30. what is better? S60, Moser 9", or 12 bolt
  31. Bad Gears
  32. driveshaft possible problem pic included
  33. GM Limited Slip Additive?
  34. High Speed Vibration... I need a checklist!
  35. what else do i need to buy, going spool
  36. Do I need a 12 bolt?
  37. Possible clearance problems with dana 60s using girdle cover on lowered cars
  38. going to a salvage yard for a new rear
  39. Plan on buying a 9'' soon a few questions?
  40. 10 Bolt Rebuild Kit?
  41. rearend shifted!! please help!!!
  42. drive shafts what options are there
  43. 3:23's/RPM's
  44. 4 11's
  45. Moser 9" question
  46. replacing wheel studs in 12 bolt... who has them?
  47. gear spacer question
  48. 10 Bolt - LS1 vs. LT1
  49. VIbration from T56 or 10 bolt
  50. what do you need to piece together a 9 inch?
  51. Replace Pinion Bearing when Replacing Axle Bearings?
  52. what would have to be done to convert a 3 channel 12 bolt ot a 4 channel?
  53. have a question about pulling driveshaft
  54. which gears
  55. U-joints
  56. Moser 9" Housing Width?
  57. 12 bolt or a S60 for my ride?
  58. Burned up a ring and pinion at the track
  59. 10 bolt carrier spacers
  60. Wheel Spacers?
  61. determining what gear....
  62. Pics of guys using Narrowed 9"
  63. Rear end troubles
  64. Ring and Pinion help
  65. Posi unit shot cheap replacement rebuild?
  66. 2002 Camaro SS 10 bolt rear with 6,000 miles! $400.00
  67. Hard to convert to 4-link rear?
  68. Mild clunk in rear
  69. How to reduce spline clrearance?
  70. Dana 60 and tru track..how much can it take really?
  71. rear end problems help!
  72. this combo of gears and stall?
  73. Installing Caliper Mounting Bracket
  74. Big block on torsen style posi
  75. 3rd gen rear end
  76. Best RING & PINION
  77. correct gear tooth pattern ? 3.73's
  78. New LS1Tech Sponsor ! T56 special and gear install special
  79. Something wrong...please help
  80. Will Strange retainer/caliper brackets fit Moser?
  81. help with 9"
  82. making my own drain and fill on a 9"
  83. Gears...
  84. What sensor is on top pf the rear end?
  85. Pinion Support threads??? What bolts?
  86. best gearset for a 10bolt with cam
  87. rearend ppl chime in
  88. Gas mileage with 373 gears with 6 speed trans
  89. What gears do I have???
  90. This is serious! Rear end?????????????
  91. T56 Yoke Question(s), No walk bushing
  92. Need a tune after rearend swap?
  93. gears for my turboed m6??!
  94. help with 4.10's install
  95. What kind of gears for my midwest 9" rear?
  96. 3:73 or 4:10 gear 6 speed street only
  97. Moser 9"
  98. Diff Shops in Los Angeles, CA
  99. M6 & 3.50 Gears
  100. BOOM!!! Ever seen this one from a 10 bolt???
  101. 373s-410s ??
  102. dana 60 or ford 9"?
  103. hitting rev limiter with 3.73's
  104. set pinion angle at -2 now vibration 80mph
  105. stick with stock or go 4.10's???? which is faster
  106. extra things needed for installing a 12 bolt
  107. Removing the pressed on bearings off an axle...
  108. Diff. fluid change questions
  109. How to disable ABS light in a 98?
  110. 4.10's in an auto
  111. Is there an additive or spacifice fluid to add
  112. Strange Enginering
  113. Are Torsen and Auburn posi's interchangeable?
  114. 1LE Driveshaft?
  115. 9 inch and 3 channel ABS
  116. ring dia. of 12 bolt?
  117. Question for M6 guys running Spools?
  118. Rear/Tranny Feels Weird - Look Inside
  119. Rearend....
  120. getting different answers
  121. I think my LSD is taking a crap
  122. Used 9" Center
  123. bullet proof drive shaft?
  124. What rear??
  125. Who sells Spicer U-joints???
  126. used 10 bolt whine
  127. 41-1/2" vs. 40-3/4" driveshaft
  128. can i reuse the reluctor wheel on a 3 channel?
  129. Rear end whining
  130. Grinding noise at low speed
  131. 9" truetrac poping on tight turns
  132. can someone show me a picture of thier moser tq arm mount
  133. help? i need to know what carrier????
  134. Aluminum center section
  135. Wheel bearing part number needed for moser 12 bolt?
  136. 500RWHP and stock rear...
  137. 1344 u joints??????????
  138. 9 inch WOT "snap" sound
  139. 10 bolt woes, part 2
  140. Quick u joint question
  141. how many splines on the axle?
  142. Help!!!!! Size and Carrier
  143. 9 bolt borg-warner rearend fit in a 2000 Z-28
  144. 9 inch parts
  145. axle help needed
  146. New best with my new Moser 9!
  147. what does it mean?
  148. Quick U-joint Question
  149. Help**help
  150. 12-Bolt Tru Trac Update!
  151. road noise
  152. 9 inch question
  153. Stock rear?
  154. 3 channel and 4 channel rear
  155. U joint girdle for 12 bolt?
  156. ? rear end question
  157. Stock 10 bolt spider gears!?
  158. Question on ABS reluctor ring
  159. 9 inch axle machining or sleeves for reluctor rings
  160. so after a professional rear diff fluid change and a clean...
  161. picked up a 9 inch for free need help making it work
  162. rearend cover
  163. A4 with 3.73's
  164. Problems with 12 bolt and driveshaft mating!
  165. Gears for a Moser 12 bolt
  166. Pros Vs Cons When it comes to Narrowing a Rearend?
  167. Think my 10 bolt might be going out???
  168. dose anyone make break brackets for a 9"
  169. 9" Moser does the trick.
  170. what ratio ???
  171. Diff question
  172. Would this do much?
  173. torquing down bolts
  174. Mikronited gears
  175. Truetrac, Locker, or Full Spool
  176. wierd noise
  177. Get a 12-bolt or a 9" crowd..
  178. Stock rear/+500whp/stickier tires...
  179. Bolt size for driveshaft saftey loop?
  180. auburn posi unit in an LS1 car?
  181. Midwest fabb'd 9's, Whats the concencus on weight savings over the 10 bolt?
  182. wtb: 9" rear
  183. Whinning and howling rear
  184. Is My Rear Going Bad
  185. Moser Review
  186. Help choosing gear setup with th400?
  187. Factory gear options
  188. which gears with nitrous?
  189. Stock driveshaft???
  190. Rear choice question
  191. POLL: 12 bolt or 9 inch for street/strip
  192. How to determine if gears are for 2 or 3 series?
  193. Swapping a 2 series for a 3 series
  194. Wondering about my gear oil
  195. Midwest fab 9" installation pics
  196. How much abuse can a 1330 to 1350 conversion joint take?
  197. I think I may have a 'Fix' for the bullet proof 10B
  198. Shortening a 10 bolt?
  199. 2000 rear in a 97?
  200. Torque Arm has a crack in it
  201. speedo still 10 -15mph off after tuning
  202. 9in Magnetic Drain Plug
  203. whine in rear gears look fine
  204. Help Differential ID
  205. slip yoke ?
  206. Non Pro-Gear for large pinion 9"?
  207. Rear end locked up
  208. Any sponsor with 9 inch expertise in here please
  209. Used Gears Whining
  210. Peace of Mind: 9 inch?
  211. 5 passes at track, whine from rear after last pass.
  212. Where can i get a moser 12 bolt?
  213. Where can I get a Moser 3 channel ABS ring for my 12 bolt?
  214. Strange chromoly dshaft color??
  215. drive shaft
  216. upgrade 28 to 31 spine
  217. TR230's and gears???
  218. Need Help with Gears TH400 & 28" Tires
  219. C5 diff WOA's......need insight.
  220. Who has the best deal on a 12 bolt for the 98-02 ls1 camaro?
  221. A few questions about swapping to 12 bolt
  222. 2002 Camaro SS 10 bolt rear with 6,000 miles! $400.00
  223. Axles....How do I know which one??
  224. rear spindle breaking
  225. Is a rear REALLY worth it over 3.42's??
  226. Will a 9 inch made for a LT1 be the same as for a 9 inch for a LS1?
  227. 4.10 question for autos
  228. Is a 96 camaro steel driveshaft stronger than the ls1 aluminum one?
  229. KALTECH saves day!
  230. best brand of gears
  231. moser 12 axle bearings?
  232. ***rear End Noisy*** Please Help
  233. The Thud!
  234. not sure what this means, little help?
  235. Is this seepage normal ?
  236. whats is the stock differential
  237. Gear Experts/Drag Race Only: What Gear Size?
  238. Is this a good 10 bolt setup?
  239. Need to trade my 82-92 width Strange 12 bolt for 93-02 width one!
  240. 2000 ws6 m6 what gears?
  241. Should I narrow it??
  242. Some Advice?
  243. 10 bolt carnage
  244. 373s auto and stalled
  245. what size gear?
  246. Axle bearings
  247. 99 V6 Rearend Gear ratio....???
  248. Anyone snapped an axle in a 10 bolt?
  249. built motor, built T56, built moser 9" stock driveshaft...guess what...
  250. Success on gear howl
