View Full Version : Gears & Axles
  1. what gears to go with?
  2. Thanks R&D's for great customer service!!
  3. ford 9" what mods do i have to do to get it in my 96 t/a
  4. 10 bolt posi question...
  5. Moser rear end ?s
  6. limited slip question
  7. RaTech Rear end Rebuild to fix WAWAWA sound?
  8. GM Rear end additive
  9. "Local" ND/MN Rearend Shop?
  10. Why is the torque arm needed?
  11. shop says I need adjus.TA to Stop gear whine
  12. 3.90s? Will it work
  13. 9 in rear transfer?
  14. will a 98camaro rearend fit in my 96t/a
  15. who makes the best carrier
  16. I am looking into getting 2:73...
  17. how many slines does my 96t/a have
  18. Red Line Limited Slip Additive
  19. Where to purchase 12 bolt?
  20. what do i need 2 do to fit a 71camaro 12bolt in my 96t/a
  21. motive performance gears vs motive gears
  22. Noise form Wheel Bearings??
  23. What's it take to install a posi diff in a nonposi 10bolt
  24. Going with 3.73's, What brand for my 10 bolt?
  25. 3.73 or 4.10's?????
  26. Gov Loc Posi?
  27. LT1 ABS and LS1 ABS 3 ch the same?
  28. 10 bolt, 9", dana axles pics
  29. Pieceing together a 9" Help?
  30. 9" Help
  31. Why not "Dana"
  32. "Help" 3 sensor ABS for 9" conversion?
  33. Can I use stock driveshaft with a 9"?
  34. Got a bad noise in rear of car and cant figure out what it is?!
  35. What DS Loop For A TSP Catted Y?
  36. Ring and Pinion-What Brand?
  37. Fastest gear ratio for my setup/plans? 4.10's or 3.73's?
  38. 4-ch ABS diff work with 3-ch ABS housing?
  39. New 9" Coming!
  40. What gears to go to
  41. Need help choosing rear end
  42. 3:73 gas mileage
  43. Best Posi For The Street?
  44. would like to put 4.10's in stock 99 z28...
  45. Please look at this pattern and give advice
  46. M6 gears.?.?.?. drag guys here
  47. how to beef up ur 10bolt
  48. when i get a gear in the car can i fix the speedo myself or ???
  49. Grinding noise when braking
  50. shift points
  51. rear-end swap
  52. possible bent axle shaft?
  53. What is this rear worth
  54. Will 4.10s help me out???
  55. what to sell a built stock rearend for?
  56. Car pulls to the right or left on acceleration
  57. My 10 Bolt Broke. 1st time EVER at the track :(
  58. 10 bolt gears
  59. posi units different from 98-02?
  60. New built rearend broke
  61. Vibration........Not sure what
  62. Ls1 into lt1
  63. "Soft" or "Half" locker??
  64. 12 bolt Leaking Question
  65. Pinion Seal Problems
  66. 97 Formula LT1 rear end ABS 3ch or 4ch?
  67. C-Clip Problems....
  68. Caliper Plates...
  69. no clearance problems here
  70. How many 9" guys have the backbrace?
  71. 3:90 gears=great mod
  72. How wide is the stock rearend in in the 93-02 fbodies
  73. Question about replacing gears
  74. Moser Steps Up To Fix M9 Issue
  75. Main pin & bolt on Auburn posi
  76. axle and diff sliding
  77. help somthing popping!
  78. Stock Drive shaft?
  79. Lifespan of an aftermarket gear set.
  80. ring gear & pinion
  81. hey need help with a quick question
  82. vibration at 110 mph
  83. 9" Help!
  84. do I need sway bar with 9" rearend?
  85. YO wtf series 2 gears arent avail anymore accoding to exotic performance.
  86. just got 4.10's installed cars not pulling right
  87. **IMPORTANT** carrier bearing removal
  88. 3.90 or 4.10 for hardly driven M6 w/cam+spray
  89. Mini spool for stock rear in 2000 A4
  90. A4 3:73's going in tomorrow and...
  91. when i drive my car
  92. New to This, Advise please!
  93. Rear Gears?
  94. Strange noise from rear
  95. Rear end swap advice
  96. stall or not
  97. LT1 rear work in LS1?
  98. What gears for street/highway driven car in 9"?
  99. Pinion seal leaking....
  100. c5 z06 rear end
  101. which brand 9inch
  102. PLEASE HELP!!! 9in problems
  103. stock rearend help
  104. Question about 12 bolt and 4.10 gears?
  105. Moser Rearend studs (Screw in or press in)
  106. help with my drive shaft
  107. locking pin in limited slip rear end
  108. New Rear Questions...
  109. 9'' or 12 bolt?
  110. Moser 9" install complete
  111. Will my 10 bolt last the season?
  112. 3in Studs users
  113. Average Price of a Gear install?
  114. 9-inch was dead quiet for 100 miles, but now whines like crazy after 5000 RPM launch?
  115. Need Help !! Wierd Thump Noise Coming From The Tranny Area , Help.
  116. correct pinion angle (swapping stock 10 bolt to S60)
  117. Backlash Settings?????
  118. ABS inop light remedied
  119. Looking for help on bulletproofing my rear.!!!
  120. 12 bolt 4series gears to 3series carrier
  121. master install kit
  122. Thinking About Going to 4.10s
  123. Parts to convert from 3 to 4 channel
  124. Isnt there anyone selling a used 12 bolt or 9"
  125. Planning to install 4.10's
  126. Who's building a QUALITY 8.8 rear end for the F-bodies these days??
  127. Weird noise.....
  128. gear sponsor
  129. carrier caps
  130. Rear price questions?
  131. I'm cammed and thinking about 4.10s...
  132. Moser M9
  133. Where to find ACTUAL GM 4:10's???
  134. Rear end rattle.
  135. ticking driveshaft??
  136. help gear pattern?
  137. Should I risk the 10bolt?
  138. Lost speedo after rear install??????
  139. Motive 4.10. where does it say in pinion what shim to start with?
  140. posi tracton?
  141. Odd Rear End Noise
  142. Narrowed Moser 9 inch - Wheel back Space
  143. squeaking/hum during tight low speed turns
  144. Rear end places in STL?
  145. New gear installed making noise HELP!
  146. new driveshaft
  147. 10 bolt..stong enough for 10's??
  148. What gears do i have? I already checked the jam and glove box.
  149. How much driveshaft runout is allowable.
  150. Please look at this pattern and give advice
  151. Mini spool
  152. dunking noise?????
  153. 4th Gen fbody with 3.42 gears?
  154. Is this normal for my rear end?
  155. 4.30's too big?
  156. bmr safety loop wont fit
  157. which gears?
  158. What differential is this?
  159. Is it worth it?
  160. Rear Whine
  161. spool
  162. stall with gears
  163. what spline axles
  164. questions about setting up rear
  165. Need opinion on ratio choice
  166. Need help identifying my 12 bolt please
  167. Breaking in Dana 60
  168. help me choose a new rearend
  169. Gear whine pinion too deep or shallow?
  170. New Rear needed!
  171. Anyone ever run or think about after market suspension?
  172. need rear end rebuilt
  173. 9'' Install help..
  174. Are a4 and m6 driveshafts the same length?
  175. Moser gets an A+
  176. Do Auburns and Torsens Interchange?
  177. Does anybody make a bolt in 8.8" FORD rear for our cars??? Seems like a good idea?!?
  178. s60 powwer loss/ dyno numbers
  179. Is this normal?
  180. Time to Buy a 9"... Need some info/advice...
  181. Is .003 of backlash too tight for 4.10's in a 10 bolt?
  182. Weight difference between driveshafts?
  183. has anyone done a gear swap DIY?
  184. lt1 and ls1axles the same?
  185. Auburn carrier differences
  186. what the break in period
  187. Is something wrong here??
  188. *post pictures up of rearends**
  189. 4:10's or 4:11's? Any differences?
  190. 9 inch powdercoating/painting
  191. help fast...summit racing gears, yes or no
  192. dana s60
  193. driveline viberation(short vid)
  194. rearend ????
  195. Help me pick Rear end
  196. Stuck pinion shaft: Fun with a sledge hammer
  197. Is the girdle cover worth doing on a mostly stock car? Or save for another rear?
  198. what gears best for highway racing?
  199. 3.73 or 4.10? What rpm are you crossing the 1/4 line at? Which is better for our cars
  200. Should i buy a new driveshaft and a safety loop with my new 9 inch?
  201. What serious gears do i need to order for my 95 trans am?
  202. Odd vibration.. ideas?
  203. E Brake issues with nine inch
  204. Down sizing gear ratios
  205. Narrow rear?
  206. Will it hold?
  207. stock 323's to 373's ?
  208. Trac Cont issues with gear change?
  209. series 2 10bolt to series 4 10 bolt can i make this work
  210. Strange 12 bolt question
  211. Thoughts on Auburn Pro Series Carriers?
  212. Torsen Diff 2 or 3 ?
  213. I am looking for info on a 4.30 gear for a 7.5
  214. solid crush sleeve?
  215. Reinstalling stock gears?
  216. Moser 12 Bolt Parts List
  217. Will I lose my custom tune?
  218. Just Got my 12bolt Moser
  219. 9" e-brake install?
  220. wtb gear install kit or just shims
  221. Have rear clunk when turning left only
  222. Quietest 3.73s for a 10 bolt ?
  223. Moser 12 Bolt U-Joint Question
  224. Gear ratio affect on dyno numbers?
  225. Car jerks?
  226. spool tru trac posi??????
  227. People with 3.73's
  228. How much gear oil for 9"
  229. worried about my rear
  230. 3.90 gears
  231. is this the right limited-slip differential for my 10bolt
  232. 373 not worth installing
  233. what gears would be best
  234. Will gears help with "chugging"????
  235. In market for a beefy new rear.
  236. Need help ASAP
  237. driveshaft
  238. 10bolt Torsen about to Grenade! Is there write up on changing gears carrier seal etc?
  239. Stupid quick carrier question (10 bolt)
  240. Do i need a paddle kit?
  241. yukon 3.73s
  242. A4 TA 3.73 or 4.10
  243. Need opinions on 9" options
  244. Anyone have results on hp loss from 10 bolt to 9 inch, etc...
  245. i think the 10 bolt is screwed
  246. 81 K10 blazer 12bolt?????
  247. So i got my s60. help please
  248. Longer driveshaft needed after 10 bolt swap??? PLEASE HELP!!!
  249. gear info needed
  250. cheapest R/E setup
