View Full Version : Gears & Axles
  1. Ford 8.8" and Ford 9" the same rear?
  2. Are all torque arms the same?
  3. 8.8 in an F-body?
  4. help with clunking
  5. Motiv 373s
  6. Dana 60
  7. reluctor rings...
  8. Ive got a problem and need some brainstorming.
  9. Weird Vibration
  10. Built 10-bolt?
  11. gear install
  12. where to buy
  13. Paddles???
  14. finally broke my 10 bolt twice!
  15. How are 8.8s
  16. Fab 9" question
  17. if 10 bolt breaks will i need to replace just gears or everything?
  18. How much is my 10 bolt worth?
  19. Installing gears in a C5
  20. how fast was i going
  21. Early Christmas For Me too!
  22. 9" Third Member
  23. Power TV Video of Moser M9 Rearend and EPP's Camaro
  24. HELP ASAP!! Moser Shim
  25. how to
  26. what pulls harder????
  27. 4channel to 3channel conversion 12bolt question
  28. moser 9in, need help!!!
  29. Currie Enterprises Problem
  30. Strange 12-bolt weight list inside
  31. Can anyone identify this Differential?
  32. Help Need pics of stock 3 channel and 4 channel rear
  33. Steel driveshaft on a 98 Formula M6???
  34. Gear Ratio vs Computer vs Speedo
  35. Torque arm for 9 inch
  36. How much noise should come from stock rear end?
  37. truetrack worth it?
  38. Where to buy Carbon fiber driveshaft
  39. Moser 9"
  40. Pinion seal leaking down the tq arm.
  41. 12 bolt or 9 inch????
  42. Moser 12 bolt install Q?
  43. Stock 10 bolt leak at wheel
  44. what gears?
  45. when do gears start to hurt
  46. 3.43 Stge II C5 rear w/hardened output!
  47. 3.73 & 4.10 Motive gear sets in stock!
  48. Moser 12-bolt Kaboom
  49. swapping rear ends monday. Anything special I need to know?
  50. Rearend Issue?
  51. in desperate need of help for this vibration
  52. 9", 4channel, Locker....
  53. putting in a spool?
  54. need help!! dont know what to do!!
  55. Spool and posi identification
  56. ABS inop light....
  57. gear swap
  58. How much more efficient is a 12 bolt than a 9 inch?
  59. Can get a 4 channel rear, but mine is 3 series! Gimme Suggestions
  60. 10 bolt w/ 4.10s sticky tire Q's
  61. newbie 9" question
  62. lookin for JASON at TDP for gear install
  63. what gear size?
  64. 31 spline stuff, what is rebuildable?
  65. 9" Question
  66. Billingsley 9-inch locker, abs tcs problems
  67. cheap rear end
  68. rear end qs
  69. putting in a 3-channel
  70. moser 9 install ? torque arm
  71. ? on 12 bolt pricing
  72. Info needed!
  73. How to tell the difference between 2 and 3 series carrier?
  74. installing gears
  75. What kind of rear is this?? Pics inside
  76. After breaking in 1000 miles on my 9".... can I do anything about the whine?
  77. 2001 Trans Am rear end Q's
  78. Locker guys step inside.
  79. what center section and gears
  80. Cheapest place to buy 12 bolt (Strange or Moser) or 9inch rear end.
  81. Gear Size
  82. Gear change How-to...
  83. []My Strange 12 bolt... ...again!!![]
  84. Moser Axle-Which gears for street?
  85. 10 Bolt Question
  86. putting in a 3 channel rear end into my 4 channel vehicle- 12 bolt aftermarket
  87. 342 gears on a 2 series carrier
  88. Question about marking compound
  89. Chevy high performance, 9" poor choice for late mod Fbods...
  90. Need help with 9" Ford... Pics anyone?
  91. Moser 9" for 93-02 Fbody question.
  92. 454ss gears??
  93. 9 inch compatability questions
  94. Looking for specific setup help..9 inch with duals!
  95. What gear do i need
  96. girdle for 10 bolt
  97. is there any way to tell with rear end i have?
  98. backing paltes tcs
  99. 2.73 vrs 3.73
  100. Strange 12 bolt center for ford 9" housing
  101. $2,500. 2 spend rearend or cam and more bolt ons?
  102. Best 10 bolt Diff???
  103. thinking about buying new rear end need help!
  104. My Aluminum Driveshaft...
  105. Tourque Spec for the differential yoke.
  106. Moser 12bolt weight?? ASAP
  107. gear swap now whine and VIBRATION
  108. Can I go with a Spicer 1350 u-joint?
  109. 3.73 good or bad idea !!!!?????!!!
  110. What gear should I look into running with my current setup?
  111. OK the famous 12 Bolt or 9" POLL please help me decide
  112. axles from a 2.73 rear fit in a 3.42 rear?
  113. need info
  114. Aftermarket Diff cover??
  115. 9" center section question?
  116. Quick question-part number for DS on 2001 Z..dealer screwing me!
  117. '61 Tbird
  118. What gear install kit do I need?
  119. Any last minute advice before gear install?
  120. 2 channel Axle, 4 channel diff. Is it possible?
  121. 10 Bolt - finally had enough
  122. Moser 9" with or without aluminum case???
  123. question about rear clunk
  124. Rear end or u-joints?
  125. 4:10s and a Girdle
  126. stripped my LR axle bolts
  127. welding axle tubes
  128. 4th gen rearend
  129. Differential cover torque specs
  130. Length of 10 bolt flange to flange?
  131. rem/micronite gear and pinion
  132. Broke my posi today..what next?
  133. U joint torque
  134. gear question
  135. what size tire for 3.89 gear
  136. what gear ratio?
  137. ?????lug sizes??????
  138. What gears to buy after th400 swap?
  139. 9 inch = no ABS?
  140. Help me identify my rear end
  141. Any certified test results for Dana 60 vs 12 bolt vs 9" ?
  142. Power TV video of Moser M9 rear
  143. nodular verus alumn center section
  144. Swapped rearend, problem.
  145. Y I never let anyone work on my cars...(!AUBURN rear~end related!)
  146. 1979 12 Bolt on 1996 Camaro
  147. Moser 9" spool in rain???
  148. Cleargearz CLEAR diff.. cover..
  149. Cleargearz CLEAR diff.. cover..
  150. Auburn Service
  151. Suspension or Rearend???Need Help!!
  152. 35th le SS gear ratio??
  153. >>> My New Strange 12 bolt <<<
  154. Jasper rebuilt diff?
  155. Swap 12 bolt Eaton internals from 3 to 4 series carrier?
  156. gear whine????
  157. New Driveshaft
  158. have a question about my axle
  159. Check this video out, created by Moser Engineering
  160. Help W/ Cobra rear
  161. speedometer and odometer off after gear swap
  162. 12-bolts: Strange vs. Moser
  163. ned part numbers for strange 12 bolt axle seals and bearings
  164. how much for a rearend
  165. Used 9 inch rear end-How much work to get it to fit a 4th gen?
  166. The $1000.00 Ring Gear & Pinion From General Motors
  167. differential shims
  168. im going to be ordering a new rearend soon
  169. Threat Pitch on Axle
  170. moser 9 inch stock torque arm?
  171. Axle twist question
  172. Post Up Your Rears!
  173. Gear Size
  174. Sounds like I toasted Torsen! Going 9", but can I keep the POS alive w/ oe auburn LS?
  175. What did I mess up?
  176. Lets see sum Moser M7 PiCS on a fbod
  177. Pinion setup issues
  178. will 342s fit a V6 carrier?
  179. S60 Torque arm
  180. 3.90 or 4.10 in AUTO?
  181. ? on Lockers and gear lube types
  182. locker question
  183. Which rearend fluid?
  184. locker problems?
  185. Magnet inside rear Diff. cover...
  186. Putting 4 channel rear in 3 channel car
  187. well im about to buy a rear but before i do any suggestions?
  188. What bolt holes to use on BMR TA for 9" Install
  189. Easiest way to install axle bearings
  190. Moser Rear End Lug Studs
  191. found a KTRE 12 bolt 3 channel- want to put in my 4 channel- concerns help
  192. Gear rebuild package, Price Reasonable?
  193. 4.30's for a 12 bolt 3 series carrier?
  194. The 10-bolt Howl
  195. Studs in carrie bearing holders?
  196. narrowed and 325s
  197. the truth about mild vs. chromemoly steel
  198. Question about highway speed
  199. 12 bolt question
  200. Parking Brake 9" modification
  201. opinions on gears with a th350
  202. Should a 4.10 gear make any noise?
  203. 3.73 question
  204. What gears do you guys think 1/4 mile car
  205. Will it fit?
  206. Gear/Stall Question
  207. Urgent: Need to know stock driveshaft length
  208. DLS 9" review
  209. 4.10's or 4.30's ?
  210. 10 bolt Pinion bearing replacement?
  211. 4:10 Setup Ques.
  212. pinion support options?
  213. Gear Help!!!!
  214. List of factory 9" cars/trucks/etc???
  215. 3:73 vs 4:10's
  216. 2002 SS Stock Axel with ABS Gear..best price?
  217. 9" vs. 12 bolt...Interesting Observation.
  218. Need some help here folks
  219. Info needed on DANA 44
  220. someone sell me a new rear
  221. 10 Bolt setup questions
  222. Centering Moser 12 bolt.
  223. gear question
  224. some help plz ...
  225. rear channel setup question
  226. questions on rebuilding 9'' centers
  227. What axle ??
  228. Carbon fiber Driveshaft nightmare
  229. Sway bar for moser 12bolt??
  230. much differance 3.42 - 3.73
  231. Use a rear cover gasket?
  232. Gear shop in OC, CA???
  233. moser 12 bolt fluid spray
  234. auto w/4.10's + taller tires or 3.73s with stock tires??
  235. Moser spring perch issue
  236. building a 9'', got some ???'s
  237. What diff. do I need?
  238. m9 vs 9"
  239. gear shop
  240. torsen making noise...could it be causing vibrations??
  241. Auburn Pro in a series 2
  242. Midwest Chassis & Performance fab 9 inch install pics
  243. Differences between 9" diffs
  244. 12 Bolt Pinion Bearing P/N's?
  245. S60
  246. Moser 12 bolt maintence
  247. Gettin a 3.73 gear. Got some ?'s
  248. Detroit Tru Trac for 7.5 10 bolts?
  249. M6 with 4.30 gears?
  250. Driveshaft...steel or aluminum?
