- Gauging interest
- Free 3.73's or buy 4.11's. 1999 m6 SS
- Fed up with 9" vibrations
- vibration with torque arm relocation
- humming from the rear end
- New 4.10 were quiet, but now noisy
- Busted rear or no?
- MWC 9" with Strange axles Need some advice if this is proper with pics
- will the stock rearend hold or waste money
- Speedo don't work
- Moser 12 bolt growing when backing up or turning right?
- 10 bolt posi unit question
- Moser Rearend -leak near e-brake
- Pinion Yoke -End Cap u bolts
- Need advice on rear
- getting computer calibrated for gears
- Is this differential comaptible?
- Are 4th gen camaro LS1 and Lt1 torsen's interchangeable?
- Driveshaft options
- 9' with 4.30 want 3.89
- Turbo+M6+ gear help go 3.73's or spend $600+ on new carrier?
- Where to buy a 9"
- 9 inch and true duals
- S60 Finally In!!! Thanks go to CRP, Strano, UMI, MWC, WS6Store (Lots of pics)
- Strange S60 and brake brackets???
- Factory 3.42s
- Strange s60 and stock sway bar???
- rear end\torque arm bolt\nut size
- Loud POP coming from rear after I turn ?????
- Diagnose my problem
- brake line mounting
- What RPM in 1/4 with...
- Suggestions for weld location - LPW Ultimate Axle Brace Tube Kit
- 4.10 with a 26" tire vs 4.56 gears on a 28" tire?
- Will i run into any problems?
- quick question
- swaping a 99 10 bolt into a 93
- ABS ring for a 10 bolt
- Need square cross pin and bolt for Torsen
- Another 8.8 Build
- almost back on the road, one last question
- possible bad diff?
- Who has 410's, Or 373's In there A4?
- moser M9 vs mwc 9"
- Rear end whine after gear install
- Be for warned Nine inch users (if you are buying a nine inch read this!)
- How does this look?
- rearend upgrade question
- 9 inch conversion
- ? Re: Moser 12 bolt rear ends and gear changes
- Moser FAB 9 E-brake brackets
- Gasket or Permatex?
- American Axle manufacturing
- Rear end grinding
- Axle housing issues.. Got ????
- Break in motive 3.73 gears?
- whiine new 373
- 8.8 Torqe Arm Mount Help
- Gears
- Moser M9 vent?
- help needed on building a junkyard 9 inch
- what to get?
- please, need some help,1999 TA 3.42, G80/GU6, odd gears (pictures)
- Is a 8.8???
- 3 channel on a 9"
- Central Racing Parts
- 4.10's
- Rear end Whine/Wail under 70 mph
- rear end swap
- spool vs mini spool
- BYE BYE REAR, anyone wanna give their .02?
- Need advice! please help
- Another vibration thread
- Eaton Tru Trac
- Truck Driveshaft
- factory torque arm question
- Best ring & pinion brand ?
- Aluminum drive shaft question
- goin for 3.42's
- Yoke too short, or pinion too long?
- Stalls and gears, opinions wanted.
- Custom CV Axles
- 10 bolt broke this past week need some help
- Vibration and whine with rearend install
- M9 and Eibach Pros rubbing the gas tank?
- 8.8 questions???
- Strange engineering s trac help
- MWC 9 inch wheel bearing help
- 3 or 4 Series
- How far does the slip yolk have to be in the trans?!
- Need help finding a diff rebuild kit
- *Help* 2 or 3 series *pics*
- what gears to run....
- S60 sawpp
- moser axle seals and wheel bearings
- Help rear axle/wheel noise!?
- Psa: 8.8 mustang housings
- What length are 10 bolt axle tubes??
- Auburn Gear Differential Installation
- Question on pinion seal / install kit
- just double checking my list for an 8.8build
- S10 gear help
- S60 install
- 8.8 axle "walking" out
- Rear Diff
- who has bought a Fab 9 from MWC and have there ABS/TCS working?
- Those with 9" and TCS (4 channel) - come in
- Building a stock 10 bolt?!
- 373 Swap and Rebuild
- T-2R - so far, so good
- How much RWHP can the stock LS1 driveshaft take?
- 12 bolt DS with a 9inch rear
- What size tire with 3.23?
- 2 quick questions...
- Best carrier?
- Brake clean for diff ?
- 95 trans am 15x10 streetlites
- What is the shield on top of the differential housing for?
- Slicks on stock diff
- Need help deciding which gear
- 04 c5z T56 what gears 3.73s or 3.90s ?
- Lug nut options: S60
- anybody having noise problems with s60 4.30 gears?
- 2 or 3 series carrier?
- e-brake brackets
- Moser 12 bolt trips ABS Inop/Brake lights
- Rubber bumper between axle and chassis
- Quick Performance 9"/MWC T/A Install
- Question on rearend
- Ford 8.8 Rear End with GM Axle Tubes
- 4.56's ?
- new to f-bodies.. been reading but still have some questions.
- Rear End suggestions!!
- Did an LQ9 swap... Now I got a vibration at speed...
- Thanks carl@ crp!!
- drive shaft to short?
- Axle carnage
- 3.73 3.90 4.10 ?? th350 not a dd
- Driveline squeek question?
- Moser 12 wheel studs
- Rear end shopping
- Random Rear axle/bearings question.. Multiple failure
- True-Trac wear.. Failure soon?
- Pinion seal leaking?
- What's a good gear size?
- wake up the beast!
- Rear setup help in Newport news VA
- ABS deleted question
- Rubbing noise from the rearend
- Thanks Eric @ Midwest Chassis
- What gears you running in 1/8th mile...
- MWC Trans Mount Issue........
- ASR removed
- What gears should I use on my automatic Camaro
- DIY Ford 9 inch
- ms4 cam "thinking of switching gear"
- quick question???
- Forcing a differential
- Car will not roll forward?
- Rebuilt rear end whine after break in
- opinion on ford 8.8
- Identify this unit please
- quick spline question, moser 9"?
- New rear end is whining
- DIY differential replacement questions
- Progressive noises
- Loud whine at 72-79mph
- Setting Pinon Angle
- S60 Break in procedure
- just dropped some cash on a S60 from speed inc.
- 12-Bolt from a truck
- Can anyone tell me....
- Whir noise on right turns only after new ring and pinion
- Locker or posi?i gotta buy one NOW!!
- ~ Cannot get center pin in! Did JEGS send me the wrong set AGAIN? ~
- funny new u joint
- From 4 channel to 3 channel
- 2002 SS Rear End Noise (?)
- Et streets and stock 10 bolt
- will 342 rear from a v6 work on my ws6
- beating a dead horse
- 9 inch ???
- Rear end help
- 9" Gear Install
- Bye Bye Driveshaft!!!
- Future New rearend...Moser? Strange?
- How much power will differential brace handle?
- 9" gear install
- Axel...
- Break in procedure for new gears?
- Whining rear that needs replacement.
- what's the point
- 373 393 or 410
- Anyone else experience this?
- Which carrier shim kit?!
- 3 tenth ET drop going from 2:73 to 4:10`s
- 9' rear axle seal
- Exploded 10 Bolt
- 10 bolt shot its wad.... sorta, one wheels faster than the other.
- What will happen to 1/4 mph after gear swap?
- Want to change 3.25 gear to 3.73 or 4.10 (A4)
- Axle swap
- Broken axle stock rear?
- Klunking noises
- Couple of Stock Diff Questions(WS6)
- 4.11 gears?
- Assembling 9" question
- need help picking gears for turbo car
- rack backed into cover, but looks ok
- Rear end setup
- Need a new rear fast, Strange S60??
- 3.42 to 3.73
- Experience w/ Stock 10-bolt (45k at 700 HP)
- What u joint?
- which gears in a 99 maro 3.8 manual???
- Just some help to price off stock rear end
- Driveshaft ???
- 2.73's to 3.73's wow
- New Motive Gears Break In Period??????
- Removing Diff.. screw up lash?
- help 10 bolt ?
- RPM calculations
- Smaller cam stock rear,bigger cam and 4.10's??
- Driveshaft loop hardware???
- wall thickness of MWC sfc
- 3.90 Motive Pro Series Gears???
- Eaton elocker& 411
- more bad luck..
- Need bolt size for rear differential cover 2000 ls1 10 bolt...
- 10bolt Eaton e locker and 411 gears
- Time to spend some money :(
- Just installed royal purple fluid and now my rear is noisy :/
- 2002 ws6 rear end swap questions
- Differential noisy in turns.
- I joined the club
- Quick question about these 3.42's
- Advice for those thinking of doing their own gears
- Yet another new s60 thread...
- New Rear End
- Limited slip additive for trutrac?
- questions on upgrading my rear end
- New rear end or rebuilt rear end?
- 9" time
- strange 12bolt
- Some more questions on an 8.8 swap. I searched first.
- Fluid???
- 4 channel backing plate
- Problem setting up gears in an S60, help!
- where to order strage spool and gears?
- Bent axle!?
