View Full Version : Gears & Axles
  1. what is a 10-bolt between a 99 10-bolt and a 95 10-bolt???
  2. Dumb question but need Help ASAP
  3. Need Help ASAP!!!!
  4. 9" Wants to tilt up when car is lifted!
  5. What direction do wheel bearings get pressed on?
  6. grind/whine 2nd time
  7. Prob with rear end... need HELP!!
  8. 3.42 gears - looking to trade Raleigh NC
  9. 373 1/4 mile
  10. From 10 bolt to 8.8
  11. crap...
  12. MS4 is 410 gears the right choice?
  13. Rearend Help
  14. comparable rear widths
  15. 3.15 case for 3.42 gears
  16. Strange Dana 60
  17. Getting sideways!
  18. Clunk when accel and decel! Any ideas?
  19. Did I get the right gears?
  20. What to expect after a gear swap?
  21. causes of gear noise?
  22. How Much For Gears In My 1999 T/a A4
  23. General Motors 12 Bolt Rear End Assy
  24. Why cant we use synth gear oil on our 10 bolts
  25. What type of rear end??
  26. GM 12 Bolt?
  27. define "built 10 bolt"
  28. any v6 cars come with limited slip
  29. help*asap*bad sound when i drive!!!
  30. Fab your own 12 bolt article?
  31. Rear Diff oil change
  32. What oil is best for my rear diif????
  33. any way to get rid of that sound??
  34. Scratches on Driveshaft. Yay or nay
  35. What Brand & Weight Gear Oil for New Rear End?
  36. graphite powder lubercation on gears
  37. What type of center section is this?
  38. Spohn Driveshaft and u-joint
  39. DLS 9inch rear problem?
  40. 9'' prob
  41. What carrier so I have?
  42. New Moser M9 rear with Moser torque arm!
  43. Quick Performance ?
  44. 1 wheel spinning?
  45. Weird Noise???
  46. 4.56's???
  47. Edelbrock adj TA with Moser 9"?
  48. dana 60/ driveshaft problems! please help
  49. pos 10 bolts
  50. Stock aluminum SS driveshafts M6 A4 same?
  51. 4.10s or 4.11s
  52. Need 9in. axle bearings locally
  53. witch torque arm works best with moser 9in.
  54. do bearings come with a new moser 9"?
  55. HELP Thumping noise
  56. 9" is in, went for a ride
  57. 4.10s or 4.56s
  58. help!! axle shaft removal
  59. Whine with my 3.73s..
  60. I put a 4.56 in an A4
  61. Posi identification
  62. 9" Assembly
  63. Want to be sure on buying a 3 channel 96 rear end for my 01 bird
  64. 4th gen carrier in 3rd gen rear end?
  65. difference between 7.5 and 8.5 10 bolt
  66. 373s
  67. e-z locker
  68. ques on 9"
  69. gears or tranny??
  70. How thick is the thick ring gear?
  71. axle shaft replacements?
  72. quick ?
  73. Need some input, stuck on what to do!
  74. rear info
  75. 'Bolt-in' Moser 9" Housing lol
  76. A decision to make
  77. just broke my rear end witch on is the best??
  78. Have a howl on right turns after gear swap.
  79. 10 bolt question
  80. 2.73 to 3.42 with Yank SS4000
  81. 9 inch question
  82. How much HP / tenths do you you lose but swapping to 12 bolt or 9inch ?
  83. what gears for a 500rwhp A3?
  84. Stock Carrier question
  85. Mechanic left a bolt loose on my rear - can I drive about 5 miles with it half-full?
  86. 2 Series Carrier
  87. What auburn differential should I get?
  88. Fastest 10 Bolt Rearend???
  89. Trax's 9-inch assembly question thread
  90. what kind of gains
  91. 4.10's for a Strange 12bolt
  92. Vibration Driving Me Crazy
  93. good price on posi and gears
  94. What kind of noise does a rear end make when it's going bad?
  95. LSD only install
  96. Axle R&R instructions
  97. Moser Wheel Stud ???
  98. anyone make a spool for c5 corvette?
  99. F-Body Gears in stock, Install Special!
  100. Noisy Rear End
  101. How hard is it to do a gear swap?
  102. DS Loop problems!
  103. Rear End Fluid Leak - What do you recommend?
  104. rear end oil change?
  105. posi and gears
  106. rear ends
  107. Pressing on u-joint and axel bearings
  108. Ring gear runout? Teeth seem to have a "wave" in them as I spin the diff...
  109. Found my axle noise
  110. Summit Ring and Pinon Gears???
  111. another 10 bolt noise question
  112. What with 3.73's?
  113. Stock 1998 Trans Am Gear Ratio
  114. Moser 9" - Brand NEW and NOISY!
  115. How do you install a pilot bearing in a 9-inch center section?
  116. clicking noise
  117. Broken 12 bolt?
  118. Warped axle????? Idk
  119. Going from a 3.15 to 3.42 rear end
  120. quick question
  121. TA Cover/Girdle magnet?
  122. Which rear end to use - 92 3.23 or 2000 LS1 3.46
  123. How to change fluid?
  124. Can you keep your ls1 brakes with a 9inch ?
  125. what is a 9' bolt in worth
  126. Anyone Running 3.90s or 4.10s in a 10 bolt M6
  127. need help with 4:10
  128. Rear End is Humming/Whinning??
  129. Gears that haul ass 3.90 or 4.11 ?
  130. 3.90s to 4.10s?
  131. which gears to run with eaton posi?
  132. LT1 and LS1 interchangeability and ABS problem
  133. will a 7.5 posi fit our rear axles? (7.625?)
  134. Need help diagnosing rear end problem, please help!
  135. How bad is my rear end?
  136. Gear Whine?
  137. I need some help
  138. Why does it seem that my read end isnt centered?!
  139. new rear
  140. 9 inch axel seal HELP!!
  141. Rear end Fluid??!!??
  142. What gear ratio is this
  143. What the heck's making all that noise
  144. LS1 rearend on an LT1 Fbody?
  145. Rear End Upgrades... Want to know ET Differences
  146. Harsh disengagement of driveline
  147. Bad Posi? Rear End?
  148. 2-series vs 3-series rear end noise
  149. loud noise help??
  150. do i really need a 9"?
  151. Carbon Fiber
  152. help! something broke.
  153. What will break next?
  154. rear end locks up when going in reverse?
  155. So I searched... no results. 3.42 question
  156. question for strange 12bolt users
  157. Replaced pinion seal, now major leaking
  158. Need some help on new rear
  159. lsd oil additive neccessary?
  160. Which LSD/POSI/LOCKER should I buy for my 10 bolt???
  161. We(me and my friend) totally hate the adj sphon TA
  162. U joint question
  163. so my car has steel driveshaft, should i bother?
  164. Initial thoughts on 4.10s/spool install...
  165. how to replace strange 12 bolt axle seals??
  166. Newer T2Rs Less Reliable?
  167. Only difference between 2 and 3 rears?
  168. 3.43 to replace my 2.73's
  169. Rear or intake?
  170. Finally happening
  171. rear end question
  172. How to tell if I have Tru Trac or Eaton Posi????
  173. all z28s have posi?
  174. Third Gear Gone! What To Do?
  175. looking to get 373s and a posi unit
  176. Direction of Torsen Thrust Block 0n 99
  177. 3.42s to 4.10s
  178. What is the yoke type or P/N for drive-shaft?
  179. Where to buy rear brake backplates
  180. Gear whine fixable???
  181. Getting pinion bearing off
  182. Will 96 Camaro 3 channel rearend with ABS bolt up to my 99 z28
  183. Who has the best prices on 12 bolt parts?
  184. Do i need 3.73 gears?
  185. Cheapest website for 3.73 gears
  186. Midwest Chassis fabricated 9 inch
  187. Strange vibration
  188. Stock 10bolt probs......
  189. Looking to upgrade axles and spool, any suggestions
  190. calculating driveshaft length
  191. 2 series 3.42 brand options
  192. Paging Scott (or Bob) - can't access backing plate bolts through 9-inch axle hubs?
  193. Stock 10 bolt specs? Length? Height?
  194. sponsers i need a quote on 9" or best place to get one
  195. Strengthening the stock 10-bolt
  196. Strange vibration
  197. spool questions
  198. What gears do I have?
  199. which pinion is the best
  200. killed me a ten bolt
  201. I dont think i can fix this one...lol
  202. help with motive gear
  203. How much does a 10 bolt weigh?
  204. Anyone buy there gears used? Opinions?
  205. Do I have 3.23 or 3.42 gears?
  206. gear change in 10 bolt
  207. Need a decent replacement 10 bolt.
  208. putting a 4-channel rear in a 3 channel car?
  209. Why is my rear end HOT and puking fluid???
  210. low speed deceleration whine
  211. Detroit TruTrac or Eaton
  212. Replaced Axles, now Gear Whine?
  213. 410 bad for Auto?
  214. Question on rear gear choice ?
  215. carbon fiber/alum/steel driveshaft test
  216. Gettin 342s
  217. Replacing axle bearing...
  218. do i need 3:73s
  219. moser 12 bolt vs. moser 9"
  220. Bolt In -Vs- Weld In LCA Relocation Brackets
  221. 9 inch lsd
  222. need torque converter for my c6 for a big cam
  223. Used Moser 12 Bolt for sale $1,600.00!
  224. what rear ends fit 99 ss?
  225. Gear Oil Weight Poll
  226. D&*%!!!! Boogered up the yoke on the rear...
  227. Anybody with Currie style TA mount come in!
  228. Full spool vs. detroit locker
  229. whats the fastest anyone has gone on 2.73 gears
  230. 3.73 to 3.42s
  231. Full spool vs. detroit locker
  232. Moser 12 bolt question
  233. 96-98 rear ends compatible?
  234. Weird Noise
  235. Ranger rear end into Camaro
  236. moser 9in
  237. What years have 3 ch or 4 ch?
  238. Torsen miles, what's too much?
  239. Used 12 bolt
  240. Question about rear end gears..
  241. driveshaft for 9" setup
  242. drivetrain similarities
  243. Leaking...
  244. Yeah No More Vibration..........with the d/s out
  245. 6th gear burn out your gears?
  246. Best place to buy a 9 inch from?
  247. Should I get 3.73s with stall and nitrous?
  248. New 9inch!
  249. Any one done 3.42 to 3.90?
  250. 9" makes odd noise when I turn?
