View Full Version : Gears & Axles
  1. Dropping a driveshaft off a 1350 U-joint on a Moser Rear-Best tool?
  2. gear swap ?
  3. Thinking about 4.10's (yes I read sticky, and did some searching)
  4. 9" driveshaft ?
  5. Mounting the swaybar to my new 9inch
  6. carrier size
  7. Pinion Question
  8. Made the plunge
  9. s-10 rear swap
  10. Installing Powertrax Locker What size thrust washer do I need?
  11. Where to purchase a rear end? (online?)
  12. Good 7.5" master rebuild kit?
  13. Rear end swap worth it.
  14. question for ya
  15. Do gears affect RWHP?
  16. how to tell if my car has gears?
  17. How long until a bad pattern is broken in
  18. Switching to Strange 12-bolt... anything else needed?
  19. Richmond or motives?
  20. c-clips
  21. what is the best gears for my camaro ?
  22. Which cars had the Auburn, and which cars had a Torsen rear end?
  23. ? for those with 3.73's and a M6
  24. DIY 10 bolt gear swap questions
  25. what rear did the old car have?
  26. loud ticking sound
  27. 9" qeustion
  28. Moser 9" axle bearings??? HELP.
  29. What do you guys think of the GM 4.10s Thunder sells now?
  30. 3.89s on a auto
  31. 1350 u-bolt torque
  32. Your problem can be fixed by 67ss509!
  33. DISCLOSURE:67ss509 is KING of GM setups!!!
  34. S60's in .. have a few Q's
  35. 2.73's to 3.42's
  36. 9" Inner housing seal...?
  37. 9inch HELP!!!!!!!
  38. Gear change effect odometer?
  39. used gears or not?
  40. dana 60
  41. Having a problem with my moser 12 bolt.
  42. 3.42 1\4 mile trap mph vs 4.11 1\4 mile trap mph?
  43. Bad posi ???
  44. Pinion Angle
  45. Just a quick question!
  46. Rear end problems
  47. non traction control
  48. Strange Dana 60 pinion seal replacement...??
  49. How wide is 3rd Gen rear end vs. 4th?
  50. Strange 3.42 gears for 2 series carrier
  51. Help with rear end noise...maybe something else
  52. diff cooler
  53. M6 w/ 3.90 or 4.10's, anyone know...
  54. Gear Question??
  55. Nova Rear End
  56. rear end whine??
  57. O.D. of axle bearings in a 7.5?
  58. Crunch
  59. Slp Paddle Block
  60. DAMN these 4.10's kick ass!!!!
  61. Need help with my new Eaton!!!!
  62. 9inch driveshaft length???
  63. DanaS60: Props to Scott @ DLS!!!
  64. Replacing Leaky rear pinion seal
  65. thunder racing gear pkg
  66. WHo here is running a 12 bolt, m6?
  67. Stock 10 Bolt Question....
  68. Difference in an S10 rear
  69. Overall axle length
  70. Moser 12 Bolt Drivetrain loss
  71. looking for some help.
  72. I need your opinions on what type of rear I should use.
  73. What size are the stock 10 bolt?
  74. lug nuts 4 my 9 inch
  75. paddle kit modification
  76. Possible jack rear up to hear noises?
  77. Quiet Fluid
  78. Spool For 7.5"
  79. I think you guys just talked me outta of this
  80. rear end howling
  81. Damn paddle kit
  82. will this all work together?
  83. Help with 9" problem...
  84. Squealling sounds from rear end
  85. What are the signs ?
  86. 4:30??? Where can I get them?
  87. thunder racing gear package
  88. Who has the best deal on a 9inch
  89. LS1 diff same as LT1 diff...ABS still work?
  90. How do I find what gear a car has?
  91. Rear just a few miles from exploding... Need to make a decision...
  92. 3.50 vs 3.70 vs 3.25 gears
  93. 4.10 worth it?
  94. stock 97 a4 3:73 or 4:10????
  95. TA cover question
  96. Leaky moser 12bolt axel bearings
  97. Moser backing plate bolts
  98. Need Help With Gear And Tranny Choice
  99. Factory limited slip a gear type?
  100. '93 Z28 - Which gears stock?
  101. 9 inch and tranny mount TA...BAD ?
  102. Odds
  103. Had a strange situation at the track tonight. looking for advice/suggestions.
  104. Could I benefit from a gear?
  105. Ford 9" and Spohn TA ?
  106. Really frustrated-9" axle bearing question
  107. labor prices-Moser 9" vs. Strange 12-bolt
  108. rear end question
  109. Who makes custom driveshafts?
  110. Thunder Racing Complete Gear Package for GM 7.5" 10 Bolt
  111. 9" Relocation Brackets
  112. How much before it goes?
  113. Problem putting C-clips back in, HELP
  114. Rear gear?
  115. Can you just use the stock shims if you use Motive gears?
  116. Props to Scott at DLS
  117. Carbonfiber DS
  118. What are the quietest gears on 9 inch Tru Track??
  119. AXLE INSTALL, give me some pointers
  120. Anybody have any experience with this compnay?
  121. bolts w/ MAC girdle...TOO SHORT
  122. Newbie Q's
  123. Moser 9in, my car sits like a 4x4 now!
  124. 10 Bolt Question
  125. Need a 10 bolt expert
  126. Urgent help required please
  127. Cam and 3.73 gears on stock 10 bolt
  128. mobile 1 gear oil....lsd additive already in it?
  129. Locker???? HELP!!!
  130. 10 bolt rearend leak, easy to fix?
  131. f-body 10 bolt question
  132. Pics of my new Mikronite Gears
  133. Stock T56 DS length
  134. Need Help Fast!
  135. will these work?
  136. I need rearend torque specs!
  137. Anyone making the 8.8 hybrids anymore?
  138. 3.42's any louder stock for stock than 3.23's?
  139. u-joints. Solid or grease fitting!!
  140. 4:10's in an auto?
  141. help me please!!
  142. 9in quick help
  143. Narrowed 9in. is it avalible?
  144. Changing stud (stange 12bolt)
  145. Backlash
  146. MAC differential cover, ARP stud kit...clearance issues
  147. Ratech
  148. We have a problem new gears
  149. loud whining from rear
  150. Rear end carnage
  151. Exciter rings on a 10 bolt
  152. Full read end swap, have a few's
  153. 3channel rear into a 4 channel car
  154. What gears do I have?
  155. Pinion Seal
  156. 10 bolt question
  157. 2:73 spacer?
  158. Reluctor Rings
  159. Rear end prob?
  160. Changing my gear/stall setup questions...
  161. Who sells gears for a 12-bolt?
  162. TA Aluminum Covers for 10 bolts-worth it???
  163. Need help on diagnosing squeaking from RR...
  164. what gears and TC are better?
  165. PLEASE read and let me know quick...
  166. 3.73 gears
  167. Whats the difference: spool, true-trac, detroit locker?
  168. Stock Rearend Trouble
  169. I'm getting metal on metal whining roar...
  170. Is this a bad rear.. question
  171. What are the average rear gears?
  172. 4:10s ?
  173. Just ordered a 9" rear end from Scott at DLS
  174. Axle bearing Install help
  175. S60 Installed tonight
  176. Rear end cover...I guess
  177. Diff Install
  178. Anybody have a link on how-to 9 inch rear installation???
  179. Can u add tcs to a 12bolt
  180. Driveshaft for 9 inch Moser in 94 F body
  181. e brake
  182. broken 10bolt people
  183. help me
  184. Driveshaft/Pinion Yoke
  185. where to measure is RING GEAR DIAMETER
  186. WHAT GEARS???? help me out!!!
  187. Unknown Problem
  188. s60 rear sway bar??
  189. rear end install
  190. rear end??
  191. Something failed.......CARNAGE(ds, ta, exhaust, floorboard)
  192. Torque spec for 9" center to housing studs?
  193. changing rear end fluid
  194. Eaton diffrential oppinions
  195. how much should i pay for gears
  196. rearend help
  197. bought some gears....now i got a ?
  198. quick driveshaft question
  199. how to fix my rear.
  200. What paint for new 9"???
  201. tq specs on TA cover
  202. u joints goin bad??? i dunno???
  203. Which driveshaft is stronger?
  204. Weakness of stock rear end
  205. Knocking noises from what seems like tranny output shaft/ds connection...
  206. rear end gasket
  207. TH400 and 4.56's
  208. amsoil gear oil
  209. Ten bolts are great... Please help
  210. Gear ratio vs. Tire size?
  211. Any Gear Installers Around The San Marcos, Austin Tx Area.
  212. I did something stupid
  213. ATTN: Scott @ DLS
  214. Strange axle bearing ?
  215. Swapping out differentials
  216. Backing Plates
  217. strengthening stock rear?
  218. 4.10 adaptor question
  219. My spedo is off
  220. **how do u remove axles from rear end**
  221. What is the plug on top of the housing?
  222. 3:73's what effect will they have on my trap speed, and 1/4
  223. Identify my problem, please. Sound clip
  224. Bad rear end?
  225. Nine inch center section
  226. 9inch aluminum center strange or moser?
  227. help me figure out my 10 bolt problem
  228. U-joint issue
  229. Good 12 bolt posi/lockers ect?
  230. Disaster at the Track
  231. Vibration at 50mph+ off throttle, pinion angle?
  232. Is my rear end going for good??? Help!!!
  233. How much does a moser 12bolt weigh?
  234. Strange 12-Bolt..New bearings and seals...
  235. Poll: Will my 10 bolt survive?
  236. Is a quiet setup a strong setup?
  237. which would u choose?
  238. will a 30k mile 10 bolt hold up.
  239. Fixed my rear end problem
  240. Pinion Depth
  241. Where can i find...
  242. My New 9"
  243. ford 9 inch Bearing Caps
  244. 12 bolt pics for Scott@DLS
  245. Axles....
  246. Lockers on the street
  247. Wanted 3.42 Gear For C5
  248. rear end messed up again
  249. Never let that wine go unfixed::pics::
  250. AAM gear backlash at .004"
