View Full Version : Gears & Axles
- moser 12 bolt, powerglide...driveshaft length?
- Noise from rear-end only with throttle
- What is this rear end set up worth.
- what way would be better 4 tha trex??????
- clunk sounds
- Experience with 9 inch from Driveline Solutions.
- U-Joints
- Rear end noise. Opinions needed.
- Are Richmonds the strongest gears?
- 9 Inch question
- ford 9" soilid pinion spacer help
- 8.8 for Fbody
- Just Rear Ends=anyone done business??
- My new M9 came today form EPP :)
- think i broke my 12 bolt....need help
- 9" Tilting Up (Pics Included) Any advice?
- Replaced axles in the 10bolt, now very noticeable resistance
- Acting Funny! Help Please!
- Shortening rear question
- What Backspacing?
- Need Help FAST!
- well I finally did it. Broke my 10 bolt.
- 4:10 in a 98 trans am a4 what you think
- Q on Torque values and washer size
- shopping list for 4-channel 2.73 car
- going rate for a gear swap?
- people running an a4 with 456s
- Okay Okay i know im sorry another rear end noise.
- Rear axle out of a Silverado 2500
- Rear End Unit Question
- Diff question
- Gear Upgrade
- Burkhart Fab 9 packages and sale
- Anyone running 4.30's with their h/c car???
- Quick Rear End Question!
- Friend's 10 bolt broke
- What gears should i go with?
- Midwest Chassis & Performance fab rearends... new pics
- powertrax???anyone using it???
- U Joint End Play
- what rear end do i have
- Gear question
- When I get a 12 bolt?
- Jaw's Gear & Axle - We Do Rearends
- Posi or 1 Wheel Wonder
- Bad pinion angle...DAMAGE????
- 12 bolt question
- Differential ?
- Something is wrong, can't figure it out..
- Just curious.
- 4 channel 12 Bolt
- Cost Of Gear Swap.
- So I sprung my First LEAK need HELP!!!!
- ford 9" setup
- 4 channel questions
- Genuine GM 4.10 gears (GM PART # 26016309) for 10-bolt
- hmmm weird
- What Differentials do you guys use in your 9"???
- TA housing Bearing cap tightening, how tight?
- Richmond Gears
- Rear-end weights - Post what you have
- more 9 in trouble
- Quick LSD question.
- Mac 7.5" Rear End Covers ---> Only 106.00!
- Ford 8.8" and Ford 9" the same rear?
- Are all torque arms the same?
- 8.8 in an F-body?
- help with clunking
- Motiv 373s
- Dana 60
- reluctor rings...
- Ive got a problem and need some brainstorming.
- Weird Vibration
- Built 10-bolt?
- gear install
- where to buy
- Paddles???
- finally broke my 10 bolt twice!
- How are 8.8s
- Fab 9" question
- if 10 bolt breaks will i need to replace just gears or everything?
- How much is my 10 bolt worth?
- Installing gears in a C5
- how fast was i going
- Early Christmas For Me too!
- 9" Third Member
- Power TV Video of Moser M9 Rearend and EPP's Camaro
- HELP ASAP!! Moser Shim
- how to
- what pulls harder????
- 4channel to 3channel conversion 12bolt question
- moser 9in, need help!!!
- Currie Enterprises Problem
- Strange 12-bolt weight list inside
- Can anyone identify this Differential?
- Help Need pics of stock 3 channel and 4 channel rear
- Steel driveshaft on a 98 Formula M6???
- Gear Ratio vs Computer vs Speedo
- Torque arm for 9 inch
- How much noise should come from stock rear end?
- truetrack worth it?
- Where to buy Carbon fiber driveshaft
- Moser 9"
- Pinion seal leaking down the tq arm.
- 12 bolt or 9 inch????
- Moser 12 bolt install Q?
- Stock 10 bolt leak at wheel
- what gears?
- when do gears start to hurt
- 3.43 Stge II C5 rear w/hardened output!
- 3.73 & 4.10 Motive gear sets in stock!
- Moser 12-bolt Kaboom
- swapping rear ends monday. Anything special I need to know?
- Rearend Issue?
- in desperate need of help for this vibration
- 9", 4channel, Locker....
- putting in a spool?
- need help!! dont know what to do!!
- Spool and posi identification
- ABS inop light....
- gear swap
- How much more efficient is a 12 bolt than a 9 inch?
- Can get a 4 channel rear, but mine is 3 series! Gimme Suggestions
- 10 bolt w/ 4.10s sticky tire Q's
- newbie 9" question
- lookin for JASON at TDP for gear install
- what gear size?
- 31 spline stuff, what is rebuildable?
- 9" Question
- Billingsley 9-inch locker, abs tcs problems
- cheap rear end
- rear end qs
- putting in a 3-channel
- moser 9 install ? torque arm
- ? on 12 bolt pricing
- Info needed!
- How to tell the difference between 2 and 3 series carrier?
- installing gears
- What kind of rear is this?? Pics inside
- After breaking in 1000 miles on my 9".... can I do anything about the whine?
- 2001 Trans Am rear end Q's
- Locker guys step inside.
- what center section and gears
- Cheapest place to buy 12 bolt (Strange or Moser) or 9inch rear end.
- Gear Size
- Gear change How-to...
- []My Strange 12 bolt... ...again!!![]
- Moser Axle-Which gears for street?
- 10 Bolt Question
- putting in a 3 channel rear end into my 4 channel vehicle- 12 bolt aftermarket
- 342 gears on a 2 series carrier
- Question about marking compound
- Chevy high performance, 9" poor choice for late mod Fbods...
- Need help with 9" Ford... Pics anyone?
- Moser 9" for 93-02 Fbody question.
- 454ss gears??
- 9 inch compatability questions
- Looking for specific setup help..9 inch with duals!
- What gear do i need
- girdle for 10 bolt
- is there any way to tell with rear end i have?
- backing paltes tcs
- 2.73 vrs 3.73
- Strange 12 bolt center for ford 9" housing
- $2,500. 2 spend rearend or cam and more bolt ons?
- Best 10 bolt Diff???
- thinking about buying new rear end need help!
- My Aluminum Driveshaft...
- Tourque Spec for the differential yoke.
- Moser 12bolt weight?? ASAP
- gear swap now whine and VIBRATION
- Can I go with a Spicer 1350 u-joint?
- 3.73 good or bad idea !!!!?????!!!
- What gear should I look into running with my current setup?
- OK the famous 12 Bolt or 9" POLL please help me decide
- axles from a 2.73 rear fit in a 3.42 rear?
- need info
- Aftermarket Diff cover??
- 9" center section question?
- Quick question-part number for DS on 2001 Z..dealer screwing me!
- '61 Tbird
- What gear install kit do I need?
- Any last minute advice before gear install?
- 2 channel Axle, 4 channel diff. Is it possible?
- 10 Bolt - finally had enough
- Moser 9" with or without aluminum case???
- question about rear clunk
- Rear end or u-joints?
- 4:10s and a Girdle
- stripped my LR axle bolts
- welding axle tubes
- 4th gen rearend
- Differential cover torque specs
- Length of 10 bolt flange to flange?
- rem/micronite gear and pinion
- Broke my posi today..what next?
- U joint torque
- gear question
- what size tire for 3.89 gear
- what gear ratio?
- ?????lug sizes??????
- What gears to buy after th400 swap?
- 9 inch = no ABS?
- Help me identify my rear end
- Any certified test results for Dana 60 vs 12 bolt vs 9" ?
- Power TV video of Moser M9 rear
- nodular verus alumn center section
- Swapped rearend, problem.
- Y I never let anyone work on my cars...(!AUBURN rear~end related!)
- 1979 12 Bolt on 1996 Camaro
- Moser 9" spool in rain???
- Cleargearz CLEAR diff.. cover..
- Auburn Service
- Suspension or Rearend???Need Help!!
- 35th le SS gear ratio??
- >>> My New Strange 12 bolt <<<
- Jasper rebuilt diff?
- Swap 12 bolt Eaton internals from 3 to 4 series carrier?
- gear whine????
- New Driveshaft
- have a question about my axle
- Check this video out, created by Moser Engineering
- Help W/ Cobra rear
- speedometer and odometer off after gear swap
- 12-bolts: Strange vs. Moser
- ned part numbers for strange 12 bolt axle seals and bearings
- how much for a rearend
- Used 9 inch rear end-How much work to get it to fit a 4th gen?
- The $1000.00 Ring Gear & Pinion From General Motors
- differential shims
- im going to be ordering a new rearend soon
- Threat Pitch on Axle
- moser 9 inch stock torque arm?
- Axle twist question
- Post Up Your Rears!
- Gear Size
- Sounds like I toasted Torsen! Going 9", but can I keep the POS alive w/ oe auburn LS?
- What did I mess up?
- Lets see sum Moser M7 PiCS on a fbod
- Pinion setup issues
- will 342s fit a V6 carrier?
- S60 Torque arm
- 3.90 or 4.10 in AUTO?
- ? on Lockers and gear lube types
- locker question
- Which rearend fluid?
- locker problems?
- Magnet inside rear Diff. cover...
- Putting 4 channel rear in 3 channel car
