View Full Version : Gears & Axles
- Driveshaft
- wtf i have a 3 channel???
- Gm 4.10 or Motive 4.10
- Loud metallic bang sound from new 9" w/Detroit Locker.
- Gears for a 4 series carrier?????
- Pinion won't come out!!!!
- Experience with Strange DS.
- Retorqueing pinion nut after gear install
- DS Loop for 3.5" Drive Shaft?
- Posi or Detroit Locker?
- Potential with a 4.10 gear?
- stock drive shaft with turbo setup
- DriveLine Solutions built dana-picked up today
- size + mounting differences 82-92 and 93-02
- help with putting together a 9" PLEASE
- 3.73 or 4.10's?
- GU6 and steel Drive shaft
- my used 4.10s whine
- 4 Channel rear into 3 channel car
- Ratech Solid Spacer for 7.5 10-bolt - how hard to install??
- clunking sound coming from underneath car
- ford 9" axle seal part # help????????/
- 12 bolt spool axle removal?
- building a 9" and have a couple ?s
- Just got my 4.10s in. Kicks ass!!
- Rear end started making noise last night!?!?
- 9" complete third member parts list?
- How much HP does Spools rob?
- changing gears
- 9 inch w/35 spline truetrac
- 12 bolt Vs. 9"
- Quick ?
- Fluids...
- what all do i need to purchase when buying gears
- 600 rwhp, m6, 315/35/R17, What gears???
- abs inop/ low trac lights
- Get gears or get a tune?
- Don't Paint!
- Rebuild 10 bolt? only 360hp max.
- Driver's Axle Doesn't Fit
- what diff do most of you guys run?
- rear end fluid
- Scott @ DLS
- Rear-end whine
- whining noise coming from stock rearend...
- stock driveshaft
- Thanks to Scott@DrivelineSolutions!
- What is a used 9" third member worth?
- driveshaft hitting safety loop...HELP!
- will lower gears affect the ABS system?
- Another ''broken 10bolts'' story...
- Will older 12 bolt (69 Camaro) gears fit a Strange 12 bolt?
- 3 channel swapped with 4 channel possible?
- need good place to buy gears
- Paging Scott @ DLS
- 4.10 or 4.30
- Going from 2.73 to 3.42, Need Help!
- gears, 9 pinion and 37 ring gear. Is this 4.10??
- need help asap
- Stock 10 bolt-Nitrous a no no?
- out come the 3.73's. what next for my turbo setup
- Help me please!!!!!!!!
- 4.11s in a 10 bolt
- traction control into a non trc control?
- ABS and the 9"
- How much to narrow a rear end? and what are the pros?
- lca relocation brackets on a 9 inch
- Yet another TA rear-end cover question
- a few noises in my Moser 9"
- Any body know if motive gears are as strong or well made as richmond?
- 10 Bolt Axle Question
- Stock 10 bolt precautions
- NEED HELP! rear end is leaking after changing the fluid
- Play in rear axles
- Driveshaft weights?
- rear end weight???
- How to get into contact with DLS?
- SPOOL question???
- Bad rear end shudder, need help
- Can you rebuild a Eaton HD in a 12 bolt?
- Vibration starting at 70mph after 12bolt install
- 3 channel/4 channel questions
- Rear end bluge????
- New to the Rear-ends
- 3:90 gear in an A4
- How much power???
- will an A4 carrier from 02 z28 workon my 00 M6 T/A
- Broke 9"
- wheel hop
- Howling in rear differential
- Putting a Ford 9" rear into my camaro
- Will a Girdle help at all on an a4?
- Clunking/Popping when i turn
- Gear Install Question
- My experience with Moser and EPP
- I need a new rear end... Which Kind? Where to buy?
- Pros and Cons going from 2.73 to 3.42?
- Who's got the best price on a 9"
- Fair price for used rear? Short/Sweet Please help!
- Programmed for wrong gears question
- Tru-Trac or Eaton?
- rear-end query
- Yes
- what do i have
- whos running 3.89's
- Got my Fab 9" from Burkhart
- Using a 3 channel diff in a 4 channel rear?
- regearing vette
- Gear choices with a strange 12 bolt spool
- question about 86 rear and 02 rear
- 4.10's or 4.30's?
- Aftermarket driveshafts worth it?
- C5 diff goes boom (PICS)
- Rear end howl on Decel--am I getting screwed by the dealer?
- Toasting my wheel bearings or rear end going sour on me (again)?
- used axles
- Whiny rears....somewhat normal or imminent disaster?
- Click Sound!???
- what size driveshaft do we have?
- Pro gear on the street question
- For those debating on doing 4.10's...
- Need some help.
- Now what?
- 2.73 to 3.42 swap help
- gears(daily driver)
- Thanks to Scott@Driveline Solutions
- Relocation Brackets
- just went from 273 to 410s in a4 97 trans am
- rearend HELP !
- Do you like your dana 60?
- 1500-2000 rpm + 30 mph decel rear noise sounds like tire/road noise
- Installed TA Performance rear cover and stud kit
- Pulled rear axles, thnk I found a problem....help!
- E-Brake With A Ford 9 Inch Help
- 07 Silverado
- A4 with gears shorter than 4.11
- what gears, 3.73 or 4.10
- Whats stronger a strange s60 or a moser 9"
- quietest off the tranny adjustable torque arm
- Bad Vibration
- Nine inch install
- moser 9in
- Driveshaft length with Moser 9"
- Reluctor ring tooth count and diameter (4-channel)???
- Broke 10 Bolt Need Help!
- Gear change and Cam Swap Question
- Stock Swaybar and a Moser...problem
- moser 9 inch axle seals part #
- 04-06 GTO w/Solid Axle
- Planning on going to 4.10s. Have ?s
- Spool?
- need some opinions
- Worth the money?
- Drive shaft length, is this correct?
- 4.10's Tomorrow!!!!
- detroit locker
- going from stock to moser 12
- Cutting backing plates?
- Moser 12 bolt fill plug.
- Thinking about doing a stall....
- Need to replace driveshaft...Which one?
- vette Rear end
- Cheapest place to buy AAM 4.11's?
- Bad Junkyard rear end?
- MS4 with 4.10?
- Rear-end options?
- My DD M6 now with 3.73s...
- My 3.73 M6 as a DD...
- Thoughts on my 3.73 M6 as a DD...
- 12 bolt housing question.........
- moser 9" capacity
- Freeway Flyer Gears
- Auburn vs. Truetrac, which is better in a 10 bolt
- Decel noise
- I tryed a search Dana s60 relocation brackets
- Broken Axle?
- Driveshaft ?
- upgrade gears or new rear end
- carrier
- Installed a Moser 9" this weekend...pics
- bad high speed vibration. Speed Related!
- Number of teeth
- Need F-Body 10 bolt dimensional drawing
- Best gear for 1000ft & 1/4???
- Which sponsor carries Timken Bearings?
- Grinding/squeaking noise from rear when turning
- Scary Dana S60 Install
- Slip yoke too long, cut it?
- 4.10's A4 drivers chime in!
- diff carrer sap question
- Differential Cover
- Diffrence between Tru Trak & Detroit Locker
- F-body 10 bolt 2/3 series carrier question
- moser axles in strange 12 bolt?
- Diff oil questions! come quick!
- Best 3.73 ring and pinion install kit- Ratech?
- Broken Rear End I Think...help!!!!!!
- stock 10 bolt
- Moser axles worth it?
- Motive Blue box vs. orange box
- Need some advice guys
- Those with t56 and 4.10...
- this will work right?
- Strang 12 bolt question, may have to pull rear to get fixed.
- do adj. torque arms really ruin rears???
- Piecing together a rear?
- Tru trac, posi, spool
- Changing my rear fluid..... .questions
- Gear oil question
- Best gear ratio A4 this dyno chart. http://www.kennebell.net/superchargers/gm/Corvett
- 9" with no 3rd member, will the axles stay in?
- Ford 9"/True-Trac help
- 10 bolt, 4.10 rear end noise, help
- Moser 9" and stock driveshaft
- Any guesses on which series carrier I have?
- moser 9" fluid question
- Rear End
- Got Quoted $800 for gear swap. sound right?
- Help me decide!!!
- Anyone converted a 3 channel car to 4 channel?
- U-joint straps
- 3.23 to 3.73
- 4.10's in a m6
- questions about a 2002 TA 10BOLT
- 3rd gen rear in a 4th gen questions???
- bout to get a 9 inch
- Dana 60 Clunking on deceleration
- So.. i think my driveshaft just shat on me...
- Help - need answer ASAP! Strange 12-bolt backlash question
- Abs/inop Light?
- Is your aftermarket rear-end as quiet as a brand-new 10-bolt?
- 8.5 10 bolt possible?
- Rear end
- moser 12 bolt problems
- aw crap - stuck in garage, lca question
- Are you happy with strange dana 60?
- Are you happy with your strange 12 bolt??
- Are you happy with your moser 9 inch?
- Don't give me any crap for a 10-bolt question
- Getting my rear soon,need opinions
- Noise coming from rear of my C5
- how to paint the rearend??
- Moser 9 inch aluminum or iron center..pros and cons..
- Ok getting rear end shortly some choices
- Auburn Pro making Clunking Banging noise in sharp turns....help!!
- rear leaking fluid
- Fluid Dripping from Rear End
- 3.08 ratio!
- help with 12 bolt install
- Pinion Preload
