View Full Version : Gears & Axles
  1. Howling Noise from 45-25 deceleration! What's wrong?
  2. What will I break first
  3. Any regrets with 4.10's in an a4 daily driver?
  4. I Think I can....
  5. Backing plate part #
  6. dana 60 ???
  7. 3.42s into a 2.73 car
  8. SLP Gears??
  9. Quick tip on getting the posi out
  10. Clunk in reverse
  11. Any Maryland Performance Shops!!!
  12. Stock gears on a C5 automatic
  13. Help Help!!! PINON BOLT PRELOAD
  14. USA purchasing advice wanted..4.3/4.5 Diff Gears
  15. Clunk on downshift
  16. 9 inch axle install? help
  17. rear wheels clunking when move car side to
  18. I pulled the cover off of the 10 bolt today...
  19. What do you torque your lug nuts to? (Moser problem)
  20. Who makes the best gear?
  21. Posi/rebuilt Kit
  22. 10 bolt probs
  23. which comes first, rear end or tranny?
  24. 410's for 100 bucks!!!
  25. Problems with 12 Bolt
  26. 410's, 4.30's, 3.73's
  27. Update on my leaking 9"
  28. Put the 4.10s in today.
  29. Moser 12bolt...gears loose when i got it..?
  30. my 12bolt, will it survive a road trip?????
  31. thinking 4.10's
  32. rear end width firebird... ???
  33. 3:90 for an Fbody?
  34. Changing Rearend.. and Removing Rearend Need tips Fast!
  35. Help Guys Rear End Busted?
  36. Recomended tools for 12-Bolt rebuilding
  37. Dana 60 and exhaust...
  38. Well I gotta change gears now..
  39. 1350 u-joint ???HELP ASAP
  40. Rear sway bar + Strange's Dana-60???
  41. Broke lug, done it before?
  42. 3 channel in 4 channel car??
  43. 3400 2.1 str + 3.73's (A-4) work well?
  44. trans am with 4.10's
  45. diameter and pitch of rear end cover bolts?
  46. What do you guys think about lakewood suspension?
  47. Breaking in gears info
  48. Longevity of 12 bolts?
  49. Gear decisions
  50. 9" center bolts keep coming loose.
  51. Great place to order rear in fl?
  52. Installed gears and car whines
  53. How to install a 12 bolt?
  54. I have 4.10's coming
  55. U-Joint Straps for Moser 12 Bolt 1350
  56. Brake Lines for 9inch?
  57. U-joint replacement
  58. I'm getting 4.10's and
  59. Mileage change from 3.42's to 4.10's?
  60. gear pattern help?
  61. what rearend to run
  62. How much gain from 2.73 to 3.42?
  63. 10 to 12 bolt swap..need anything special?
  64. wheel bearings
  65. gear OIL
  66. Strange 12-Bolt arrived last week, but with the wrong gears....
  67. from 2.73 to 3.73...what do I need??
  68. 3rd gen rear in 4th
  69. Will my 10 Bolt last?
  70. cheapest place to get a T/A girdle?
  71. should i wait...
  72. I know age old? What RPM & MPG can I see with 4.10s.
  73. Don't have marking comp, what can I use?
  74. Which synthetic gear oil ??
  75. best driveshaft
  76. Help... Is this bad ring & pinion wear>
  77. Broke a true trac on an 11sec car???
  78. Roaring???
  79. death comes swiftly
  80. Help: Carrier on 10-bolt 7.5 how-to
  81. TA differential cover help out any?
  82. what gears to get for my DD A4?
  83. What should I do?
  84. What size for Torque Arm bolts for a Moser 12 bolt.
  85. axle asr tcs question
  86. Need Help Asap
  87. new strange 12 bolt, unbearable howling on decel.
  88. Thanks a LOT strange
  89. Anyone have a torsen which broke?
  90. finally found a 9 inch!!
  91. Can't drop engine, nipple won't align, can't get drive shaft pushed in all the way
  92. AT/MT Drive Shaft Lengths?
  93. Moser 12 bolt/BMR TA issue!
  94. Need some advice, please help....97 vette C5
  95. What gear should I use with a GT2-3 cam
  96. four link under stock body
  97. Which Oil
  98. posi aditive for a 9 inch
  99. Where to get just 1 9" center section stud???
  100. Another ABS/TCS Moser 9" problem (not caused by bumps)
  101. Gas Mileage with 3.73's
  102. Another rear end ?
  103. ????What spedo gears????
  104. Which brand gears??
  105. Help me pick my gear
  106. 12 bolt from junkyard?
  107. have 9", need to narrow it....what to do?
  108. 3.90's or 4.10's for m6?
  109. Gearing affect on gas mileage
  110. Kit to rebuild Eaton posi?
  111. gear?
  112. truetrac question
  113. Strange 12 bolt owners in here please
  114. Strange 12 bolt weight.
  115. gear ratio and 1/4 time
  116. new member of the whining dana group.
  117. When will my 10 bolt break?
  118. How to prevent rear end problems?
  119. What fluid for stock 10 bolt?
  120. Is there a big difference between 3:73 and 3:90
  121. axle shafts
  122. Solid Pinion Spacer??
  123. 71 monte 12 bolt
  124. can you turn a stock 9" into a useable body rear with discs and abs?
  125. 4.10's in an auto!
  126. 3.90's for 10bolt??
  127. 4.30 or 4.10 on g5x3, what do u guys think????
  128. 9" rear end issue...
  129. help needed ASAP on rear end swap...RE: Sensors?
  130. 2.73 Top Speed?
  131. Awesome buying experience with BMR!
  132. 12-bolt
  133. 4.10's???
  134. Lsd?
  135. Trying to decide on a rear
  136. Weight Difference???
  137. SLP Rear-Jounce-Bumper Spacers. are these installed on axles?
  138. What does stock posi look like?
  139. Help Me Win In Court!!
  140. 410 Mph
  141. gears
  142. motive 3.73s
  143. 10 Bolt Leaking/Sweating at Diff/Axle joint?
  144. Drive gearing question 4.10 with a 3 speed?
  145. GM 7.5" gears vs. Ford 8.8" gears
  146. new gears, some Q
  147. End Caps For The 1350 Yoke?
  148. Zexel HD or Eaton Posi
  149. 9inch On It's Way
  150. Question
  151. Pinion Woes Revisted
  152. help please
  153. My gear is Making a noise at decelartion?
  154. Gears on a 02 WS6 A4
  155. How much does a typical gear install cost?
  156. Need Help!
  157. topping fluid off on a strange 12 bolt..
  158. Whirrring Noise
  159. Noisy gears after drag racing?
  160. 10 bolt lasts 145 miles
  161. Problems w/ ABS/ASR on Moser 9"
  162. how much fluid in a 9"
  163. Eaton or Auburn
  164. gears in an auto 99?
  165. 4.10 gears
  166. installing 3.91's in a GTO?
  167. BEST GEAR WITH STOCK REAR END dAILY DRIVER?
  168. after PUTTING MY REAR TOGETHER,WEIRD CLUNKING NOISE!
  169. 12 bolt with 33 spline with tru track hold 500rwhp?
  170. trouble
  171. 47000 mile rear end service
  172. What broke in your 12 bolt and whos was it??
  173. Are 4.10s affecting my top end????!
  174. LPW Girdle?
  175. loud bang (clunk)
  176. A strong rear for $1500-1700 possible???
  177. need help with rear end gears
  178. Help: torque arm w/ the 9"
  179. rear end service plug question
  180. motives for 12-bolt?
  181. WTB Motive OEM 4.10s
  182. Anybody else waiting on 4.30's from Strange?
  183. How much for 9 in.????
  184. spool?
  185. What Pinion angle with Adj. Torque Arm?
  186. 4:10'sin third gen f-body with 305
  187. totally off topic (Differential)
  188. What do I need to convert a Strange 12 bolt from posi to spool?
  189. Any one have
  190. Need gear info!
  191. Who all is running a 9in.?
  192. Need To Know What Spline I Have...need Fast Help!!
  193. fastest times with a 7.5?
  194. Girdle Question
  195. What rear to get?
  196. LS1 S-10 7.5" stock rear build up HELP!!!!
  197. lt1 rear ends VS. ls1 Rear ends
  198. going from 2.73 to 3.73 gear...questions??
  199. gov-loc
  200. True-Trac owners, quick question
  201. C-clip problems
  202. Powertrax style lockers and mini spool?...
  203. New Tire will mess up my 10 bolt?
  204. Measurement needed for drive shaft for 6 speed & Moser 12-bolt
  205. Would my 4 channel rear work in my 3 channel car
  206. 10 bolt rear cover?
  207. What gears are on...
  208. 600+ hp thru 3.73's on the stock rear end?
  209. rear end swap
  210. What rpm?
  211. Rear differential
  212. 4.30s 10bolt what brand?
  213. What do I have???
  214. Anyone have 4.10's that DONT whine???
  215. 94 camaro what ratio gear do I have?
  216. 9 inch question(HELP!)
  217. 3.90s for TWO series carrier?
  218. 12 bolt owners inside plus people with knowledge
  219. Motive 3.90s vs Strange 3.73s for an A3 /w 10 bolt
  220. Are all Eaton 7.5" 10 bolt posi units the same?
  221. I can't get these U-joints out..
  222. Racing 12 Bolt FOR SALE!!
  223. 4.10 Gears In An Auto
  224. rear end swap step by step...?
  225. is there a difference between 98and 99 rearend??
  226. HELP!! 9" 3CH. WHERE TO BUY??
  227. Eaton Posi on 10 bolt any one use this?
  228. Rebuilt Ford 9" Trak Loc posi, worth anything?
  229. 9" pinion support
  230. Question
  231. detroit trutrac
  232. Reasonable price for used 10 bolt M6 3.42 internals and compat question, please help.
  233. 4.10 Breakage
  234. Ford 9" pics, what can you tell me?
  235. moser problems
  236. carrier bearings went south w/ pics any ideas why?
  237. how to find a gear ratio
  238. Rear ticking noise?
  239. How do I know if I have Posi Trac
  240. backing plates and...
  241. changing rearends
  242. 3.90's for a stock 10bolt?
  243. Rear end movement.
  244. How do I tell when it's time to change U-joints?
  245. Strange sound coming from the driveline???
  246. Strange 4:10's in a 10 bolt (paddle kit ?)
  247. Rear End Noise!!!!
  248. independent rear suspension
  249. Good gears for an M6
  250. gears
