View Full Version : Gears & Axles
  1. Please Help, Afraid To Drive!!!
  2. ITS BACK !!!....Well sort of here is the problem
  3. how much will going back to 3.23's hurt me?
  4. True Trak
  5. 12-bolt doesn't fit...need immediate help.
  6. Ok Why am I going slower with 4.10 gears.
  7. Our phone lines and a snow plow...
  8. 7.5 ring gear offset
  9. 10 bolt rebuild - carrier removal?
  10. getting torsen and gears installed what kind of lube ?
  11. anyone have the rpm vs. speed table?
  12. Three Teeth Missing on 4.10s
  13. Using OD with 4.10s?
  14. Gears or Stall Converter
  15. How to tell what ratio gear in rear end?
  16. 3:73's in a a4?
  17. slicks??? what do i need to do
  18. Swapping a 10 bolt in my TA how hard is it?
  19. What Aftermarket Differential covers are available ???
  20. How to remove brake mounting plates from 10-bolt?
  21. HP/TQ lose with gears
  22. Effects on systems of changing gearsets
  23. how much 1/4 mile gain?
  24. A Street-Car M6 only thread about gears
  25. rear end leak from the driveshaft
  26. drove car on spare for 100 miles, now there is a whine
  27. Stock rear end gear ratio
  28. Who has a True Trac in their 10 Bolt?
  29. Help get into 11s.how much gain?Advice?
  30. 4.10s in a TH-400
  31. driveshaft?
  32. please explain for me: locker vs. posi vs. spool
  33. How to recognize a "thick" ring?
  34. 8.8" ford rear end worthwhile for an f body?
  35. 9 inch center section
  36. spooling the 10 bolt?
  37. Anyone fab up their own 9"?
  38. Question on my new 9" Im confused....
  39. Motive gears (2 & 3 cut)
  40. Red Line rear end fluid
  41. Did I break it?
  42. bolt on m6--what gear?
  43. Rear End Help
  44. Moser 9" for 3rd Gen Camaro in 4th Gen ?
  45. UH, I can't spin my car sideways...???
  46. ok i am going to order fluid for my diff change,, where?!
  47. Just put 4.10s in my 99 TA and it really made it wake up!
  48. How do you tell if you have Traction Control (TCS)?
  49. Drive Shaft Loop Install-Bolt size to subframe?
  50. Rear End is Shot
  51. Rear is leaking around Driveshaft?
  52. Sponsors & Advice Needed
  53. cheapest 12 bolt or 9 inch bolt in
  54. Quick: Should I get a new driveshaft?
  55. Will 10-bolt '01 with TCS work on my '98 non-TCS?
  56. Wierd sound when shifting hard at high RPM's.......WTF?
  57. what to look for when the diff cover is off?
  58. What size drill bit for brakes, w/ 5/8" studs???
  59. Alternatives to new rear end?
  60. what kind of oil ??
  61. 9" With True Trac Or Moser 12-Bolt With True Trac?
  62. 3.90 Gears in an A4?
  63. How do I know what series carrier I have?
  64. Question about gears..
  65. 10 vs 12 bolt mounting flanges
  66. RMPs with 4.10's?
  67. What oil do I run in a newly rebuilt rearend?
  68. Schematic showing the IC for RWD car?
  69. gear help
  70. Rear End Oil Change
  71. Rearend Gone, Need Source for 12-bolt from those with 12-bolt (need to order ASAP)
  72. mounting plates on 9" rear end
  73. 3.73 or 4.10?
  74. drive shaft advice please
  75. What gears you M6 guys runnin?
  76. What gears are you A4 guys runnin?
  77. Informative Links to Info On Driveline Vibration
  78. 10 bolt problem
  79. Getting 3.73
  80. Are 4.30 Gears To Much
  81. Pinion Problem Please Help
  82. whats in my rear lol
  83. nitto's on the rear?
  84. Rearend ???
  85. auto rearend
  86. Really; how easy willl my 10 bolt break??
  87. Detroit True Trac in a 12-Bolt?
  88. AAM Gear # 26036813 =2 cut OR 5 cut??
  89. Stock Gears??
  90. ABS or not...how do I tell on a Moser 12-bolt?
  91. A4 gear selection help in race application
  92. where to get ujoints?
  93. broken/bent axle symptoms??
  94. just want some opinions on what i should do
  95. 12 bolts eat horsepower??
  96. Search for 9" rear
  97. ASR off, does not respond to button press
  98. drive line vibration
  99. Ford 9"
  100. Rear end ?
  101. 10 bolt destroyed
  102. moser 9" driver axle too long
  103. Aluminum Driveshaft?
  104. Locker Vs TruTrack at track?
  105. aam gears ?
  106. need to fix somethings in the rear and need help.
  107. Was an Auburn Differential standard or an SLP option?
  108. pulling my 10 bolt
  109. A Few Eaton Questions
  110. Which posi in 12-bolt?
  111. Ford 9' inch
  112. what rear gears to get
  113. Cost to rebuild stock 10 bolt
  114. how strong is the detroit locker?
  115. Rearend Help
  116. Rear end...9"???
  117. what gears in my 98 z28?
  118. making a 10 bolt last?
  119. Gears , TA Girdles and install kits on sale at New Era !!!
  120. Going from 2:73s to 3:42s. Questions....
  121. whos 9" to buy?
  122. what is the benefit of...
  123. is the posi gone???
  124. Question about Moser Quality...
  125. Did they offer 3.42 gears in the 96 SS with an auto?
  126. u-joint needed
  127. 9 inch clearance problems?
  128. 9in is definately the way to go
  129. Rear End FAQ!
  130. Noise in my 9 inch?
  131. So my rear is shot. Leaking Tranny fluid?
  132. Stock Differential Breakage?
  133. What takes more power to turn?
  134. LS1 drive shaft slip yoke problem
  135. Anyone Wanna Trade Their 3.73'S for my 3.42'S
  136. What type of 12 bolt?
  137. what gears?
  138. 10 bolt shat on me today
  139. Help me build a 10 bolt...Don't laugh
  140. anything special when installing a TA girdle?
  141. Currie
  142. How to break shit.. [pics]
  143. Help Me Now...please...Crush Sleeve
  144. u-joint question
  145. GM 4.10 gear with detroit true trac install questions.........
  146. Strange Drive Shaft U-Bolt Part Number
  147. Stock 10 Bolt Power Threshold
  148. Zexel Torsen Pros Inside, Explain Something Please!
  149. slight high pitch wine...........
  150. carbon driveshaft.
  151. 3.90's?
  152. Weird nosie coming from the back....
  153. built for major horsepower
  154. Fitment question
  155. 3.73or4.10
  156. Worth my time?
  157. 9" installed pics
  158. 9 inch pinion support
  159. Gear swap in a 193,xxx mile Z?
  160. Can someone help me, what kind of yoke is this??? (pic inside)
  161. bolts for ta and moser rearend
  162. TA Cover Ring Gear Bolt ????
  163. Strange or Moser
  164. Going to 4.10's
  165. ??? About 9" vs. 12 bolt
  166. lenght of 7.5 rearends
  167. Using a Dial Indicator?
  168. What will 3:73 gain with this set up
  169. 7.5 vs 7.625 in. Diferences
  170. Bad driveshaft?
  171. can you balance a carrier?
  172. shudder on low speed turns
  173. Swapping out rear from 3rd to 4th gen
  174. gears vs gas milage ?
  175. How many splines?
  176. Why is my rear so noisy?
  177. 373's or 410's?
  178. axles
  179. 2:73s to 3:42s
  180. What's needed for a new gear install?
  181. How far will my speedo be off
  182. Leaking oil?
  183. 3.23 For Sale
  184. RIP 10bolt
  185. Gears
  186. rearend making bad clunk
  187. 9" hell
  188. Keep Breaking Wheel Studs...help Please!!!
  189. Dimension of Stock Drive Shaft
  190. What exactly makes a 10 bolt weak?
  191. Are "thick" gears noisy?
  192. Moser/Strange 9 install
  193. HELP...DIFF going to BREAK?...HELP
  194. TCS/ASR Problem. This One Is Unique.. Help If You Can.
  195. Best rear end for 650rwhp?
  196. 98 Truck 3.73's in a 98 T/A
  197. What is involved with putting an 8.8 in a F-body
  198. 12 bolt with Channel ABS (non-traction control) Question?
  199. Best Gears for An Auto Vette
  200. Spohn Driveshaft safety loop and stock torque arm
  201. Best gear ratio
  202. Insurance Buys Me Rear End
  203. Just did my first swap........
  204. Moser 12 Bolt Cost at Exotic Performance Plus
  205. Price on gears and install?
  206. another gear selection q's
  207. Gearing on 2002 Trans Am
  208. Cost for gear setup
  209. Carbon fiber drive shaft question
  210. Question about Axle
  211. 2.73 gears to 3.73
  212. help please with choosing gears
  213. help please with choosing gears
  214. narrowed 12 bolt possibly for sale.
  215. ABS > FORD 9" Q??
  216. Custom gearing for 12 bolts ???
  217. Finally getting a 9"
  218. Is this right?
  219. s-10 posi?
  220. Is this a fare price
  221. 8.8 Ford rear going in Tuesday
  222. Rear End questions
  223. Mark Williams
  224. Spool, Detroit, or Posi
  225. Going from 3.23's to 3.73's gears
  226. exactly what breaks?
  227. best Acceleration
  228. Do i have 4.10 gears?
  229. Who has broken their 4.10's?
  230. Where did you order your TA Performance rear cover?
  231. Pinion Gear and bearing ?
  232. 2.73 to 3.42 needs a different yoke?
  233. My ABS INOP light is on, BUT ABS STILL WORKS!! WTF?
  234. how bad are bearings hurting me?
  235. 3.73 or convertor first?
  236. 3.73 for A4........
  237. Sould I use a Regular or a Rethreading die for thread clean-up on wheel studs?
  238. 12 bolt or 9 inch needed?
  239. My driveshaft wont mount with my 12 bolt!
  240. Build the 10 bolt or swap to a 12?
  241. TA Performance stud kit
  242. Part # for torque arm to rear end bolts?
  243. Rearend Blues
  244. How do you know if your rear end is blown out?
  245. help with picking rear end
  246. Help please
  247. rev limit on 3.73's...
  248. help with rear end?
  249. 4:10s are in!!
  250. How much did you pay for your 12-bolt???
