View Full Version : Gears & Axles
  1. 7.5 max hp
  2. Those who ditched ASR & ABS
  3. How to check fluid level on Strange 12 bolt w/aluminum cover? How much fluid total?
  4. adjusting my tach and spedometer?
  5. New at this .. Need some help
  6. Rear end decision
  7. Lug stud removal?
  8. Need opinions!
  9. is new drive shaft and spicer U-joint need or worth it?
  10. do you lose rwhp when switching for mroe gear
  11. need help stock ratio!!!!
  12. How do I find out my rear end gear ratio?
  13. gear oil?
  14. Anyone know main bearing cap bolt torque specs?
  15. How long with 4.10s?
  16. 3.73 or 4.10
  17. what does it mean to have tall or short gears?
  18. How much should i narrow rear?
  19. can i put a '96 firebird (v6) diff into my '98 trans am?
  20. ???'s about the drain plug on 9"
  21. Moser 9" and removing axles! LS1 to LT1 swap...
  22. 4:10's or 3:73's for M6?
  23. Building the stock 10 bolt
  24. More Questions
  25. I need a new clutch durable enough about 400 ft lbs.
  26. U-bolts for sway bar 12 bolt
  27. Auburn Posi?
  28. has anyone tried modding a 9".....
  29. gear ratio
  30. bolt broke, need help
  31. AUBURN POSI UNITS OR Eaton Posi
  32. aluminum or nodular iron daytona pinion support for 9in
  33. 3.73 or 4.10 gears...
  34. which driveshaft to get??
  35. Stock sized ARP studs?
  36. double check my gear setup figures please
  37. 4:10 gears will it help me?
  38. daily driven auto= 12 or 9? spool???
  39. 9" w/ Detriot Locker question...
  40. A4 - How big of a RPM difference from 3.23's to 3.73's
  41. I found a 12 bolt with 4:10s need help!
  42. V6 97 Camaro Differential are they the same as LS1
  43. Strange 12-bolt w/Pinion Leak
  44. ARP or Strange Studs Stronger?
  45. Just placed my order for my 9in!!!
  46. Do I have the 3 series or 4 series carrier?
  47. downshifted into 2nd at 80mph?!!
  48. Powertrax
  49. 373s
  50. question on the stock rear....
  51. Carrier swap completed!
  52. noise in rearend?
  53. how long till boom
  54. mac rear cover vs t/a rear cover
  55. Q: Gu5
  56. gears
  57. What gear do i choose if i trap 140+?
  58. Grind the paddle or grind the gear?
  59. Strange C/M Driveshaft
  60. ktre 12 bolt same as moser?
  61. m6 with 4.56s
  62. keep abs and traction with 9"?
  63. What rearend are you guys running?
  64. What gear with these mods ???
  65. Stock truck 10 bolt hold up to 500rwhp
  66. ordering 12 bolt, what gears? what brand?
  67. need some help on the drivetrian
  68. driveshaft questions??
  69. New Moser Axles, Please look at pics and tell me if
  70. Need a Formula for calculating ....
  71. Driveshaft to Support 500++ rwhp
  72. stock rear end
  73. Any body running 4.56's in a 10 bolt????
  74. how strong is the strange 9 inch "s" series case
  75. Do you have to shortin the drive shaft for a 9in rear?
  76. how muxh are rear axles?
  77. Anywhere I can buy a dial guage online?
  78. what shoud i do
  79. carrier swap
  80. Fading diff.
  81. Is an A4 driveshaft the same as an M6?
  82. Stock For Stock
  83. eaton posi repair????
  84. 93 V6 Camaro rear end size
  85. Which rear end girdle?
  86. Am I mistaken?
  87. What rpm do you run with 3.73's.
  88. Stock D/S with 12 bolt??
  89. How to take bearings off auburn?
  90. difference between the posi and locker at track and street
  91. Will the ten bolt hold
  92. 9" Complete Rear 4.10 $1200 Ohio
  93. 3.73's, and a Hypertech computer
  94. how much power is lost fro ma 10 bolt to a 9in?
  95. ABS Reluctor Ring install
  96. rear end poping
  97. locker for 12 bolt
  98. Torque Spec.
  99. Think I found the reason for popping sound...
  100. Idea for modding Moser 12 bolt TA mount
  101. Putting in gears
  102. any one running the BMR extreme torque arm on after market rear?
  103. tired of searching...HOW DO I REPLACE THE REAREND?!?!
  104. should i change my drive shaft? and what rear to do?
  105. Breakin in gears question.
  106. Any 12 bolt with 3.55???????????????????????????????????/
  107. Gear whine??
  108. Axle studs?
  109. Auburn differential ?
  110. Gear Fluid?
  111. Rear End Noise--- Poopy. Ideas Anyone?
  112. Just installed 3.73's in my auburn PROBLEM
  113. Where can i buy Factory (GM 3.73 gears)?
  114. HELP..my car is doing one wheel burnouts!
  115. Will the Wolfe sway bar work with a Moser 9"
  116. 3.23 vs. 3.73's A4 High speed stall
  117. how do i figure out my ratio with taller tires?
  118. 2005 C6
  119. How do you guys like the Moser driveshafts?
  120. On moderate 1-2 shift, I hear a clunk-cluhnk
  121. How does the LPE Driveshaft compare to the rest?
  122. Parts needed to put in new TC and output shaft?
  123. 3.90's
  124. Stange sound in my 12 bolt???
  125. What Oil should I use when swapping in 3.91 gears?
  126. Does this Package suitable ................?
  127. Will 10 bolt Hold?
  128. Shutter under acceleration
  129. Ok to use regular 1 1/4" socket?
  130. this the correct rear??
  131. Is there 3.55 ratio?
  132. Whos running MWs
  133. 3.73 or 4.11
  134. whats the socket size...
  135. Stock 10 bolt
  136. Once again Strange v.s. Moser????????
  137. Stripped torque arm bolts.
  138. stock 10 bolt carrier question
  139. rear end help 10 bolt
  140. Strange 12-bolt install
  141. C-clip
  142. 4.10=slow??
  143. Help choosing a rear end!
  144. Anybody have a 9" rear with LockRight locker installed, need help
  145. 60 foot ???with 12 bolt.
  146. driveshaft with 12 bolt
  147. Disposable rear end theory?
  148. Carrier size
  149. 3.73 Gear and ET improvements
  150. 12 bolt instaled!!!
  151. Stock DS - aluminum or steel?
  152. 3.73's & SSF 3500 stall
  153. _+_+_+How much it will cost me to install 12 bolts? _+_+_+_+
  154. shortening a regular ford 9"
  155. Drag Racing with a Detroit Locker
  156. weird noise
  157. 10 bolt question
  158. Differental replace or repair?
  159. I need ratios
  160. WTB New 12 Bolt soon, why all the issues?
  161. Axle install question
  162. Randy's Ring and Pinion....As good as Genuine GM?
  163. How do i keep my 10 bolt alive???
  164. Bad gear install
  165. T2R Torsen carrier
  166. to mush gear???
  167. Do Strange rears arrive painted?
  168. I sold my stock 3.42 for 100 dollars is that good?
  169. BEST Ratio for racing
  170. Why not piece together a 9 inch for less money?
  171. only one tire spinning on burnout ?
  172. 9" Moser housing, new brake lines?
  173. rear end????
  174. Strange Rearend
  175. low speed vibration and occasional popping
  176. WHEEL BACKSPACING on drag lites
  177. Rear End Fluid Choice....
  178. Would a stock steel driveshaft work?
  179. Stock 10 bolt (3.42) question
  180. Stock 10 bolt with Moser axles
  181. spider gear?
  182. Weight difference between spool and posi?
  183. Anyone running the Strange PRG230 Drag rear with spool?
  184. Install Gears How Much
  185. DS question?
  186. Third gen rear end question
  187. Rear-end help
  188. Anyone make 3.90's for ten bolt
  189. strange 12 bolt
  190. 9" problems, how is this possible?
  191. 2005 H2 Gears questions??
  192. $ Install gears
  193. 4 channel Strange 12-bolt users
  194. Currie 9"
  195. Why do the LS1 12 Bolts break when the......
  196. selling my 4:10 rear TCS,ABS,brakes & all
  197. Helppppp!!!!!
  198. How much more can my rear-end withstand?
  199. 30 or 33 spline?
  200. Junkyards - Which Rear Ends Will Work?
  201. Quietest Gear?
  202. which gears
  203. 3.23 = 2,100 at 75MPH?
  204. My car has gas
  205. 9" rear end
  206. need some 12 bolt advice
  207. Rear end fluid level 9"
  208. which rear end?
  209. 3.23 or 3.73 gear?
  210. Which wheel can I run if I get a slightly narrowed rearend?
  211. 12 bolt from 68 camaro
  212. Installing Output Shaft on 01 Vette
  213. Stud Length and Lug Length
  214. Brand new surplus 10 bolt rears....
  215. Did anyones 4 channel strange 12 bolt
  216. Should I go with a 9 or 12 Bolt for my TA??
  217. U-joint question
  218. Putting a '98 rear end in my '02..problems?
  219. C5 rearend help ...
  220. 10 Bolt cover bolts???
  221. 9" Soft Locker?
  222. Is a spool really necessary w/o t-brake or clutch dumps?
  223. What is Involved in Converting a 3 Channel to 4 Channel?
  224. Wish u joint girdles with 12bolts?
  225. Need Advice fast!! Will this be ok???
  226. Strange 12 Bolt Installed
  227. What do I have 2.73 or 3.23?
  228. 4.10 gears
  229. what to expect?
  230. What is the difference between the strange
  231. Question about 10 bolt
  232. install guide for 12 bolt???
  233. Poll: Anyone who has broken their 12 bolt/9" rearend.
  234. What gears do I have?
  235. Is my rear end done???
  236. 12 Bolt coming soon, but what gear works best for me?
  237. Going from 3.73 to 4.10?????
  238. Richmond vs. Strange gears
  239. Torsen Troubleshooting Help
  240. Who is selling the 8.8 conversions?
  241. Difference in a 98 and 99 rearend???
  242. 373 or 410 for a4
  243. Blown rear?
  244. How many of you are pushing over 500hp on the stock 10 bolt rear end?
  245. Can someone explain to me the differences 9" vs 12 bolt
  246. Behavior difference between Eaton Posi and Stock G80
  247. i need some help
  248. Broken Driveshaft and Lessons Learned
  249. How to tell
  250. Roaring rearend
