View Full Version : Gears & Axles
  1. 3.23's vs 3.73's vs 4.10-11's
  2. 3.73 or 4.11 Gearing
  3. ASR switch to turn ASR on instead of off
  4. Pros and Cons comparison?
  5. Whats the difference between locker and Spool?
  6. Moser 9": To service clutches in posi diff?
  7. 4:10 problems
  8. Quick question about 4.10's
  9. low trac?
  10. 3.23 gears w/ cc306
  11. 3.23'z to 3.73'z hp/et info
  12. gear and driveshaft
  13. am i being ripped?
  14. How much will 12-bolt reduce my times?
  15. Moser axles are twisted!!!!!
  16. Need to replace a wheel bearing...How??
  17. what rear end combo should i consider?
  18. 3.42 vs. 3.73 N2O and convertor
  19. Stock Gear questions??
  20. 3.55 gears for 12 bolt with 4 series?
  21. Installing 3.73's in place of my 4.10's
  22. 3-ch. Moser in 4-ch. car?? Swaybar/driveshaft?'s
  23. What series carrier do i have in my WS6
  24. Is my rear getting tired?
  25. 10 bolt buildup ????...
  26. What gears are in my 10 bolt?
  27. replaced pinion seal and have?
  28. what axles are these!?!?!?!?!
  29. Are there issues with moser gears in a strange rear?
  30. what gears do i have
  31. Install Kit? for 2.73 to 3.42
  32. What 33 spline differential choices
  33. 2 carrier 3.73's any way will fit???
  34. Another Rearend Question
  35. Changed my front pads and theirs a problem.....
  36. Pulling axle
  37. 4th gear whine!
  38. Axle question???
  39. help with setting up my rearend angles ..ASAP
  40. What does a stock WS6 have?
  41. overgearing and undergearing
  42. how much power will it take to break a 10 bolt
  43. TCS + ABS codes thrown after rearend swap
  44. Cryoing a 10 bolt?
  45. Best fitting Tourqe Arm w/ saft loop
  46. Auburn Pro question
  47. Do I need a slide hammer to pull an axel out of a Moser 9"?
  48. Can a driveshaft make this much of a difference?
  49. who makes a good driveshaft, that doesnt take 2-3 weeks to arrive
  50. what did the 9" say to the driveshaft
  51. Vibration over 65mph - Twisted driveshaft?
  52. Dana 60 in a LS1 F-body?
  53. Perfect gears for TH350??
  54. Driveshaft Loop Question
  55. Cheapest way to recalibate speedo
  56. 9" misalignment?
  57. WOT or Take off and grind!
  58. need help please
  59. just put 3.73's in
  60. winding sound
  61. 4.30 gears w/bolt on car ok?
  62. rear end help
  63. What is this?!?!
  64. Removing bearing from old pinion shaft
  65. What do you think I will run
  66. Weird noise coming from rear end
  67. 10 bolt interchange?
  68. 2.73 swap to 3.23
  69. strange install?
  70. 10Bolt broke, need 9" help please
  71. Rearend help
  72. Changing from 3 chanel to 4 chanel
  73. Auto-x on slipping posi
  74. 5.38s too much????
  75. 4.11`s, 27" tire, 228/.588 cam=Too much for a A4??
  76. Guys w/ Strange 12 bolts and Denny`s DS...
  77. 3.73 + 3800 stall... ?
  78. LPE driveshaft power level?
  79. Best streetable rear-end?
  80. When the rear end dies...
  81. Possible to disable rear ABS?
  82. rear wheel stud question
  83. where to get ABS sensor for moser
  84. Installing 3.73's
  85. Why no Moser for 3 channel(ABS Only)?
  86. weird grinding noise??
  87. Moser Lugnut Studs...are they good enough?
  88. loud clunking in rear..
  89. Need Help!What kind of rearend do i have?
  90. extreme chassis 8.8" installed
  91. Broken Axle
  92. Luck with 4.10s?
  93. Breaking in new gears.
  94. Modifying a 12-bolt/8.8" to fit
  95. Moser Rear Cover hitting upper PHR...WTF???
  96. Newbie with a bunch of questions!
  97. Poll:Have you been able to quiet your Moser?
  98. Weird Vibration in the rear?
  99. Is Some Noise Normal From A New 4.10 Gear?
  100. Installing A Moser 9" Rear End
  101. Moser rear fitment
  102. Rattle in rearend
  103. burnt smell
  104. Is 2" a side too much to narrow?
  105. moser rear end burns bearings?????
  106. Rebuild for Eaton posi?
  107. Synthetic Rear End Grease
  108. have a vibration in my drivetrain
  109. Problem When Installing A 4.10 Gear
  110. best 10 bolt posi and gears
  111. Strange no longer offering a spool in there F-body 12 bolts??
  112. 9 Inch Spline Lenth?
  113. Want gears, need shop or help? Few Q's also.
  114. Look what I got Today!!!
  115. How much do factory 10 bolts weigh?
  116. 2.73 In A M6
  117. Install Question
  118. Install Question
  119. Need a narrowed 12bolt or 9"-----Where?
  120. 4.10 for daily driver??
  121. Spool for a 10 bolt
  122. which gear 3.73/3.42?
  123. Need Info On Setting Up 10-bolt Rear
  124. Box of rocks noise after installing moser
  125. stronger gears
  126. Are Stock LT1 flywheels/bellhousings SFI approved?
  127. 3 channel on 8.8
  128. 4.10's
  129. 98 and up F_bod six banger cars have standard rear disc brakes?
  130. 12 Bolt Install ?
  131. Used 3.42 gear price?
  132. ABS light and 9"...
  133. Just got my 8.8 rear end
  134. Z06 Half Shaft Question
  135. ls1 rear end
  136. Axle leaking fluid again
  137. Vibration over 65
  138. What type rear end do I have????
  139. Strange or Moser 12 bolt
  140. Broke my "posi"?
  141. cheapest 12 bolt??
  142. Does Strange make a bolt in 9"
  143. 4.10's in an AUTO.. gains? top speed?
  144. 03 Silverado 10 bolt rear
  145. HELP with custom axles PLEASE
  146. can 12bolt gears be used in a 10 bolt??
  147. 4:10's ?????????
  148. rpms vs mph w/ a4 & 3.73
  149. Do I have a stock 10 bolt rear end???
  150. Ordered my 4.10's
  151. What gains in et when going from 3.42s to 4.10s?
  152. What driveshafts and tq arms are you 9" guys using?
  153. 3.73's or 3.42's....and 10 bolt
  154. Strange Aluminum Support Cover?
  155. wich clutch
  156. best differential
  157. Rebuild kit for stock Auburn?
  158. Moser Shipping?
  159. 9" is in, break in???
  160. Is there anyway to repack the wheel bearings on the Silverados
  161. KTRE 12 bolt with LPE 3.5 DS questions???
  162. do i need another part?
  163. rwhp for an a4 rear
  164. Whining in the rear end
  165. Pinon Bearing
  166. Sings of a failing tranny or rearend?
  167. All those that BROKE spider gear in 12 Bolt Moser
  168. simple questions about rearend JARGON
  169. Rearend install guide
  170. Broke a 12 Bolt Moser
  171. 10 Bolt worth builing?
  172. How can I find out what posi unit my stock rear end has?
  173. narrowed rear, how much shortened before trouble? need advice
  174. Posi???
  175. Just installed a new Strange 12 bolt, need to know how to break it in?
  176. New Gear Break In Question
  177. Looking for an 8.8'' rearend
  178. Correct way to measure and set pinion angle on a 2000 Camaro?
  179. Rear-end work done... Is this correct??
  180. Looking for a new rearend or just gears?
  181. slight car accident, possible rear end damage, please help!
  182. problem with a set of 3.73's
  183. do tehy make lockers for strange/moser 12 bolts?
  184. 3" Chromoly DS question
  185. How much vibration is allowable?
  186. What gear is in my 98 TA
  187. Rearend BS
  188. Define Loud
  189. 2.23's, 2.42's, 3.73's which gear to go with....? Hoping the Colonel give his 2 cent
  190. How do these compare?
  191. Gear whine
  192. Jeep Rear axle problems
  193. Need a new driveshaft any recommendations
  194. Gear Help ASAP!!!
  195. Anyone go higher then 4:10's?
  196. What DS loop with true duals?
  197. steel to alumn driveshaft swap question
  198. Break in period
  199. ASR to non ASR 10 bolt swap?
  200. Rearend Oil?
  201. best fluid for the diff?
  202. ok, 1 more question
  203. What Rear do I have
  204. Question about gains from gears
  205. I think I fixed most of my gear whine
  206. posi removal question
  207. How much RWHP will a stock 10 bolt hold with DR's
  208. pinion nut size?
  209. Need torque specs for t/a stud girdle kit.
  210. Why does it seem impossible to get a rear to withstand reasonable power?
  211. U joint size for stock driveshaft??
  212. stock driveshaft with 9" rear?
  213. Installing strange 4:10 gears.
  214. Does anyone LOVE their Strange 12 bolt
  215. 373 gears seems to have sluggish acceleration when driving
  216. I think I want an 8.8 rear end
  217. POR-15 questions.
  218. axle question
  219. Changed d/s, now vibration
  220. help me pick my parts
  221. How much interest is there in an 8.8 housing modded to fit Fbodies?
  222. how do you change a u joint
  223. has anyone narrowed a rearend 2"
  224. i've got an axle shaft oil seal leaking
  225. Poor quality of Moser products
  226. Step Inside and Help me with My Rear!
  227. Stoopid V6 Car rear end questions
  228. Driveshaft that can handle 550rwh? Moser 9 inch
  229. 2.73 to 3.42 with 3 series swap
  230. can some one exlain this torsen zexal "rocks in a box" noise
  231. Is Mobil 1 grease ok for lubing driveshaft splines?
  232. for 3.73 gear drivers
  233. vibration
  234. pinion seal - differencet sizes?
  235. not shifting
  236. Stock DS Q's
  237. Paddle kit?
  238. Any diff in axle splines on stock 10 bolt axles?
  239. Strange 12bolt in M6... super strength posi hold up... or spool?
  240. part number for 12bolt solid pinion spacer/sleeve
  241. pinion seal differences?
  242. Has anyone welded there axle tubes to the housing on a 10bolt??
  243. where can i find a new 9"
  244. Gears
  245. 12 bolt
  246. stock posi carrier
  247. bolts loose on rear backing plate cause noise on left turns???
  248. when changing shift points what aim i looking for?
  249. How much e.t/mph loss with 9 inch ?
  250. Does anyone know about Gears
