View Full Version : Gears & Axles
- Will my cat back fit over the axle after 9" install?
- Just so you know... 4.86 gears can work in an A4 4L60E :P
- ABS INOP and TCS OFF
- rear noise click when the car gets warm
- MT ET Streets on Prostars...
- Where to buy ford 9"
- gears?
- gears in camaro v6 with auto
- break a stock rearend on street tires?
- TCS Module????
- Can Somebody Tell Me The Difference Between a 9 bolt, 10 bolt, or 12 bolt
- Driveshaft question. Difference????
- goodbye stock driveshaft!
- doh!!! need help asap, pinion stuck
- Rear end noise after 3.73 installed in stock rear
- Speedo Reporgram
- The crappy 10 bolt!?!
- 9 rear end 3 channel
- Can a 3 channel Strange 12 bolt work in a 4 channel car?
- how much limited slip additive for rearend fluid change??
- Stock 3.42's to 3.73 or 4.10's... is it really worth it??
- What to do first H/C or 12 bolt with gear?
- 4.10 gear question
- m6 guys with 10 bolts please.
- g-body rear...
- 9 in rear end price
- Axles arrived, but..........
- Am I hurting my rear?(no jokes lol)
- Replace stock rear cover with chrome & 2 plugs - which one?
- traction control/thick gear question
- how about 10bolt 8.5
- Anybody here using the Strange S-series nodular 9" case?
- Happy with your new 12-bolt or not?
- Pinion washer broke
- Pics of your relocation brackets on your 12 bolt.
- HELP!!! installed 4.10s and now whine
- my rear end is leaking a lot from the front
- Gear whine, but not normal whine..get in here!
- Gear swap???
- what sould i expect to pay.
- 12-bolt on its way...now time for a DS
- 31, 33 or 35 spline axles ?? 4.11 or 4.33 ??
- Is the 9" the only answer
- 9" ABS problem
- size of allen bolts for MAC rear-end cover?
- I just put my new 9" in tonight(pics)
- Is this a great deal?
- Zexel Torsion vs. Eaton
- 10 bolt, 4:10?
- Daily Driver 4.56?
- yayayay.. I broke my rear..
- 12 bolt issue with Autocross use.
- Is this whine normal? Anything i can do about it?
- 4.11's
- 4.11s are done for
- Couple of Questions before I buy My Gears...
- a new chevy, good rear end
- Rear axel swap
- need help on rear end
- Gear ?
- Serious bad whine...need HELP
- rear end strengthing
- clearancing a 9" for ring gear
- Changing rear end fluid?
- I've decided to go with 9", which carrier???
- Upgraded 10 Bolt Axles?
- Stock 10 bolt issue..
- anybody with 4.10's in an auto?
- whining from rear when taking turns
- Axle From V6 10 Bolt Into Ws.6 10 Bolt - No Tcs Though
- Can a stock 10 bolt hold up to ET Streets on an M6?
- NEED HELP...quick 10-bolt question
- A Positraction Rear that doesnt act Posi
- where to find used 9" 28 spline posi? anyone?
- Need torque specs for 12 bolt girdle....
- pion seal and bearing
- driveshaft help!
- Does ANY company make 3.90 gears for stock 10 bolt?
- do i need a 9 inch?
- U-joint going bad or what?
- Which RearEnd??
- best 7.5 posi unit...
- Does this sound like a bad posi??
- u joint help
- axle???
- series 2 vs series 3
- frc99 rear end
- Bearing going out, my guess rear wheel bearing
- Changing from 2.73 to 3.43
- Yukon 4:30 Gear Fit in Ten Bolt
- Just broke my rearend! 12" or 9"? HELP !!!
- 410 Gear
- stock gear options
- Anyone going fast with a 12bolt and 6spd?
- 4 Channel to 3 Channel...
- Will 96 rear fit 99?
- 3.23 vs 3.73
- Cannot keep this 12 bolt alive
- any body with 4:10's and a bottle?
- 3.23 to 3.73
- 273s gears
- Who has the best price on a Moser 12bolt?
- IRS from a C4
- Rear mounted spare tire & differential
- PLEASE HELP!!! Pinion angle/vibration question?
- Can you swap carrier caps?
- 3.42 and 3.73 Gear Questions...
- 273 Rear
- 9" question
- Stock Rear and horrible howl
- works one way, won't the other?
- Moser 12 Bolt w/373's very wise choice
- Posi unit for Ford 9"
- S10 8.5...
- GM Master Install Kit for ring and pinion question
- DRs vs bias-ply stickies...which is harder on rearend?
- Easy way to fill Diff.
- Gears
- Going from 410's to 373's couple ??
- What is the stock pinion angle?
- Need speed equation ASAP! court date
- more rear end problems
- Please HELP..Strange Crunching/popping noise
- howling rear end noise
- What Yoke Do I need
- Pinion help.. anyone around Indiana that can help
- What rear for a daily driver/sometimes road racer? 8.8" or 12-bolt?
- Help whit new Carrier and Gears
- Another 9" question
- In need of a rear end
- Conversion U-joint confusion......
- How much HP with stock 10 bolt?
- Are 10 bolt 3 channel and 4 channel axles the same?
- Who makes a 9" with 4ch abs/tcs f-body drop-in assembly?
- Which Differential Cover??
- Had shop replace pinion seal, now...
- Do Moser's use gaskets?
- why would a bolt be missing from my rear girdle???
- pinion leak???
- Pack rear wheel bearings?
- gear install with pics
- Pinion seal question
- Whats it worth?
- ls1 with steel driveshaft?
- Help... Where can I purchase a 3.5" Aluminum DS for a Moser 9"
- WTB: Diff Oil
- Gear Howl When Decelerating
- Who should I buy 4:10's from
- Rear end noise only on bumps
- Detroit locker
- gear contact pattern pics inside Advise?
- The 10 bolt mystery....
- abs ?
- where to find a diff
- Rearend Noise??? Or U-joint Noise???
- questions about 4 channel
- ??How much fluid for 9"??
- need some opinons
- 10 bolt
- abs ? please help!!!
- help!!!!
- Gear Question
- A4 With 410's
- How strong??
- howling coming from rear end?
- How many bought a 9in housing and added a chunk?
- sounds like rocks bouncing around in the rear?
- new posi, gears, and bearings, is there an install walkthrough anywhere?
- USed 4.10's, new auburn posi, and all new bearings..PLEASE HELP
- 9in question
- burn rubber
- 411 gear break in ?s
- Moser 12 Bolt Question
- Need some input
- any1 blow a 10 bolt w/ no mods?
- tool for loosening fill plug(need help asap)
- need rearend
- quick 3.73 question
- ls1 rear in lt1 car
- Best gear ratio for FI
- The Saga continues
- 2001 SS A-4 3000 stall and 3.73 gears
- when do you replace stock driveshaft?
- Best price on a Moser 12 bolt??
- Which fluid with a Detroit TrueTrac and Moser??
- alternative rear option
- Just install Detroit Locker - have problem ?
- Installing 4.10's
- Gear oil temperature?
- Rear Cover Girdle
- rear end going out?
- Anyone know thread pitch of stock torque arm bolt?
- Maintenance for a Moser??
- Is a small clunk normal for 4.10s?
- Do I need a Stud Kit w my T/A Girdle stock 10 bolt build?
- 2001 Z28/LS1 Diff Assy Question
- How much will the 4:10 gears help my 98 z28
- rear end ID.......
- need help with 10 bolt
- 12 bolt home buildup!
- motive gears mod?
- Who's broken a 12 bolt posi with an A4?
- HELP, how much fluid is this Strange 12 bolt supposed to take?
- New gear question
- Which Gears To Use????
- Need pics of rear-end
- Help plz
- wat gears does a 98 ss bring
- 10 bolt bearings
- Rearend Noise
- A shot in the dark....
- Driver side rear wheel slight wobble, ANY IDEAS?
- Did i bust my rear? Quick help needed
- Guys with 4.10s?
- strange 9" or 12 bolt differences in weight and power to run!?!
- ? for 00SSCAM
- 12-bolt OR 9"? Which is best?
- Stock sway bar hitting after TA girdle install
- 12 bolt question????????
- quietest rear end?
- Has anyone here tried 4:86 gears in an A4???
- Help with 9" purchase
- Can you swap spools?
- New auburn with 4.10's goin in tonight?????
- i need a 12 bolt! anyone have one?
- Anyone know the culprit?
- Changing gears in my Strange 12 bolt, what brand of gears?
- Am I gonna run outta gear?
- Driveshaft balance?
- tailshaft bushing
- lt1 rear into ls1 info
- 4.10 ten bolt rear end w/ Moser T/A Girdle & Royal Purple Gear Oil
- help with MAC differential cover...
- rear question
- What all do I need.
- rearend strength?.
- Anyone using Jeg's gears for 9 inch
- Driveshaft length???
- 380rwhp & upgrade 10 bolt..is it enough?
- ls1 strange rear into lt1?
- vibration problem!
- Diffrential Oil change?
- Stock gears in 02 SS?
- Anyone Have The Slp Aam Rear Diff Cover?
- limited slip additive in Zexel Posi??
- with 4:11 gears you can really get lost...
- What rearend?
- Putting 97TA 3.42 gears into a 97Formula with 2.73???
- identifying Gears?
- Ebrake disconnect
